- lunati .660 ls1 spring package
- Anything between Patriot extremes and PAC 1335 ?
- Are there any 76cc heads available?
- compression q?
- New combo is back together: home port 799, EPS cam, ported Fast 90mm
- LQ4 oil pump question
- PRC EHT vs Lunati Extreme Gold
- ASA Cam Enough Vacuum for Power Brakes?
- valvespring install help
- quick compression guesstimate?
- Best choice of heads for 6.0 build
- cyl. head ????
- To all ls1tech's!!!
- Cam choice for Mast headed LS1
- 5.3hp ??
- 5.3l questions
- id like 12.99
- 5.3 w/ F-body pan... which oil pump o-ring?
- Knock @ 3k rpms
- Pushrod length and valve spring suggestions NEEDED ASAP!!!! PLEASE
- thread cleaner
- Someone help me here
- What cam do i have
- anything missing for cam swap?
- Anyone with Exp with Wegner ported 243 heads
- AFR valves
- Where can i get single Mahley pistons
- Qverlap question
- cam install questions
- Identify these heads
- Low oil pressure?
- Help picking an engine for my Jet Boat...
- Need advice for vavle springs
- 853 to 243 heads help!
- Tsp 233/239
- Ls1 cam and heads
- What's so great about the LS6 oil pump?
- mix and match spring seats/locators and springs
- Timing chain failure on Labor Day, rebuild in progress STAY TUNED
- ported FAST 92, torquer V3, 1 7/8 lts... best CHEAP option for heads?
- thunder racing reverse split cam
- ported 243's & stock cam
- Patriot spring install, major snag
- What vendor sells Ferrea racing products
- 1998 camaro z28 ls1 knocking
- HP Stock LS1 Crank Can Handle?
- dual purpose cam ideas
- wanting to rebuild my high milage ls1
- LQ4 build options
- 2000 z28
- 350 vortec lifters in a ls1?
- posted in wrong post please help
- Another "help with my CR/head suggestion" thread
- lifter tick/piston slap???!!
- valve seal install F*&K up??? (PICS)
- Good write up on valve spring shimming?
- spring shims over or under seat
- Any benefit to installing 3.918" rings in a 3.898" bore?
- truck accessory bracket
- Broke a valvespring
- Checking pushrod length without installing a solid lifter?
- Could the engine still be good as is?
- will this clean up with a valve job? (pics)
- looking for best cam for my SET UP??
- TRak cam & AFR 215s
- 2007 6.0 For my 2000 Trans Am
- compression height
- LQ4/LQ9 Static Compression Ratio Discussion
- 5.3 first swap wiring help
- What am I missing for my cam swap?
- Has anyone seen or heard of a tsp engine failing
- Forged Build Options For My DD Pig
- Need Cam/Stall Advice
- I got the ok...
- Initial Start Up Noise
- Cam for Stock LS1
- Cylinder 6 Misfire, Coil(s) saying Malfunction
- 5.3 bored out reliability?
- Comp Thumpr Cam w/ stock converter
- Piston Reliefs === Does it Require to Re-Balance Complete Rotating Assembly???
- eagle crank leaking?
- What else do I need to make a reliable 100k mile newly cammed LS1?
- Is this the right plug?
- Headers
- #7 bent spark plug electrode?????
- Oil Bypass Housing + Gauge install
- Need some advice/recommendations
- need help... need hp :)
- Is this amount of cam wear normal? *pic resized*
- how are the DSS EXTREME Forged Piston Sets
- best throttle body maf setup?
- Callies Compstar Crank?
- i want to reuse piston rings
- Am I missing a something here?
- Does anybody Make a Bracket to Utilize the 2nd Hole on the Oil Pump to pickup tube
- CAM install at 185K miles?
- Please note your cam specs when asking cam realted questions
- LS1 AIC sensor help
- single roller timing chain
- Honest Dual Valve Spring input
- machine shop help?
- white smoke coming from my tail pipes
- Worth changing to titanium valves ?
- Please help with this build opinions wanted!!!!!
- ls engine codes
- ???s with head gasket and milling
- Any one running an LQ4 and 243/799 heads?
- 370 W/CheatR Cam questions
- Extreme racing products timing set? Anyone use it?
- TSP-228R 5.3L 2.5 or AI 243's and custom cam?
- Pushrod Q:
- Yes, another "what cam is best.." post
- Driving to get Tune
- Valve tip clearance vary .045???
- Carnage. Time for something new
- ls1 rebuild
- Futral f15 and patriot heads
- Can I drive my car to the shop before doing valve springs?
- Misfire after engine re-install, need advice
- ms3 cam
- crack heads ?
- Running Lean?
- possible cam tell me what you think
- Budget Heads...
- heads
- 243 head questions
- Valvespring change on TFS heads
- Completed my cam swap today!
- ? gain from GTO cam/springs into 4.8l
- What does high oil temp tell you?
- ASA Cam or LS Hot Cam for 5.3L LS Motor
- Remove & Reinstall Valves
- reluctor wheel question
- Is this a GM graphite head gasket??
- Compression Ratio
- Head/Cam/Lifter swap - pushrod length question
- Hole in block. Ideas on what to do?
- I need opinion/suggestions on the future of my car
- how will this cam work on a 5.3?
- Opinions on My Engine Combo
- disable p0492
- Rocker Arm Install
- blew the ls1! need help
- AFR vs AI
- lq4 forged piston rock?Video
- Best cam for 2500 stall 3:23 dd
- Cam suggestions
- Urgent: Oil ring support
- New engine.perfect dyno number.No more oil pressure after 600miles
- New knock sensors
- ls1 280z no power under load
- Critique this combo?
- knock sensor removel...
- Popping threw exhaust and slight tap?
- Opinions on my build
- Springs for EPS 226/230
- help with cam
- Torquing stock rocker arms...
- LS6 Sleeve question
- 04 GTO Ran fine one day and now it's running like it has a big cam
- Which springs for ASA cam?
- G5x3 112lsa
- Need experienced opinions for stock LS1 HP gains PLEASE?!
- Got me an 02 6.0 and a 4L80E
- aluminum 5.3 vs iron 6.0. Want to trap 124mph..
- Help with vibration
- Which heads for a Torquer V3. Cam?
- Something different
- Can't figure this one out..
- oil gurus'
- Adjustable Roller Rockers, Noise through the exhaust...
- LM7 with LS1 parts...
- 408 or 402
- Rebuilding LS1, couple ?s
- Broken # 7 RA now #5
- turbo 5.3 build
- ran on 7 cylinders. How bad?
- Piston Ring/Rod Assembly ?
- compression with milled 243's ???
- Ls6 and ls2 valve weight???
- Want to buy one intake valve from a vendor
- Head gasket options
- Baby cam, LS1 w/manifolds reprise
- Absolute Speed heads intake runner CC??
- Will I have PTV clearance issues???
- G5x4 Cam and PRC 5.3 Heads
- Which Intake for my setup
- Lm7 cathedral port heads vs. Ls1 rectangular manifold
- What is needed with Trex Cam
- Trex guys, what heads you running? Did you fly cut?
- Find specs on a cam
- Help. Chewed up valve tips. pictures
- oct 29th fbody gbody sssb nitrous showdown!
- Gen iii 383build
- Winter blues!! Name that sound game with video.
- Ms3 guys come in.
- LS1 Misfire
- Z06 cam?
- oil pump O-Ring
- Need Cam for LS2 403ci
- cam degree kit
- How will a new cam effect my performance?
- Please help me! Im going crazy lol! 2001 ls1 weird tick noise from engine w video!!!
- What will work?
- heads and cam
- Build up choices for my LS1
- 408ci CR/and hp/tq # est.?
- questions about swapping heads from 04 denali to my 98 Camaro Z28.
- The truth on milled 317s....?
- Ls1/ls6 main and rod bearings?
- Pushrod to Head Hole Clearance
- Stock ported heads with aftermarket cam?
- Heads to match TSP 228R?
- What gains to expect from LS6 head swap only?
- Compression Ratio for an ls1 with 58cc heads??
- 2 rockers hitting covers
- 370ci LSx--LS3 Heads & Intake-- Need some advice!
- need ls1 motor or rebuild mine
- what heads should i go with?
- Possible big torque build?
- Timing Chain Damper, who's runnen them?
- pushrod length questions
- ported 5.3l heads 224r. What esle will i need?
- JP Timing chain install Question???
- 241 head build questions
- How to avoid the double hump in torque often seen in dyno output?
- Cam's done, Need shorter Belt to fit UD pulley...
- Cam install questions and concerns
- Worth Porting 806 Heads?
- Damaged cam?
- Swapping heads with ARP head studs
- Which head gasket?
- LQ9 best heads for it
- Anyone use a 0 overlap cam on purpose?
- Bye bye ls1
- Will an LT1 A/C box fit an LS1 car?
- Head porting chicagoland area?
- LSx newbie.. Looking to build a LQ4/L92 setup.
- 3 keyway adjustable crank gear ??? hmmm...
- 04 LS1 Clutch Slave Cylinder Assy
- 04 LS1 Air Cond Pump
- LQ4 6.0 Cranks Help
- Should I swap my 218 cam for a bigger one?
- Help me figure out a motor build
- TFS/TEA 215 Flow Numbers **with results**
- Okay, I'm finally going to do it... Heads/Cam
- Buying a 100k mile 01 SS tonight, need basic help with maintenance and my first mods
- Does this cam bearing look right?
- help with rockers
- crank and rods
