View Full Version : Generation III Internal Engine
  1. Cam question
  2. lt1 set up
  3. At what point do lifters need to be upgraded
  4. Help with cam choice
  5. PP ls6 stg2 Tsp 231/237 install
  6. a Duramax diesel sounding Z-28
  7. dropped valve seat
  8. Rebuild + Break In
  9. Eagle Cranks and Pilot Bearing??
  10. Hardened Pushrods Worth $100?
  11. Am I setting myself up for failure?
  12. everyone running FMS 30# injectors in thier big cube/stroke motors?
  13. What's the Choices For Taller Valve Covers??
  14. Pics from Australia
  15. Where to get heliCoil kits online? Size & lenght of Rocker bolt?
  16. Guesstimates on how much I'm gonna have to notch my pistons?
  17. Heads are off, what's best method for cleaning carbon off tops of pistons?
  18. Anyone have an ARE 228/228 575/575 cam?
  19. OK, crossthreaded rocker stud....
  20. Hmmm....Patriot Performance
  21. what valve seals are these (pics inside)?
  22. Anyone do a ls6 engine swap
  23. 3 failed lifters
  24. WTF!!! Car fouled out spark plugs right after H/C install
  25. Clean stage when swapping heads ??
  26. Cam talk...specifically the TR224-114...
  27. TRex sound clip finally here!!
  28. Clearance Issue with 395cid Stroker?
  29. looking for abig cam for my 383ci?
  30. Help! Problem with intial startup on new motor?
  31. Looking for 224/233 "cam only" results
  32. Theroy discussion, how does compression make power?
  33. cam Q
  34. What stock springs have orange stripes??
  35. ??Anyone have the part # for the stock crank pulley/dampner??
  36. Cam equivalent in a 370 cu in motor
  37. Help with Valve Springs
  38. Vacuum to low with 224 cam?
  39. Help With Oil Consumption
  40. Cam Install
  41. What is the biggest cam I can go with for a daily driver?
  42. Results from compresssion check. What do the # mean?
  43. Opinions on ARE 346 "street eliminator"
  44. Will these heads support a 408?
  45. G5X-3 question?
  46. Low lift, greater duration cam for a 427
  47. HELP complete my shopping list
  48. What should I do?
  49. LG Motorsports: First Look - SPEED World Challenge Corvette #28
  50. Choosing a Cam
  51. HELP,,with rocker arm bolt?,,missed the thred up in the head???????????????????
  52. f4
  53. Anyone ever dynoed a stroker with stock heads?
  54. Doing H/C with New LT's and want to get Rid Of EGR & AIR Tubes
  55. Best Priced ADJ RR's
  56. How many miles on springs with G5-x2
  57. should i replace oil pump during cam install
  58. quick question about the stealth II cam
  59. Guage sending unit ... why doesn't the manufacturer support us?
  60. SLP Double Roller Timing Chain & Oil Pump
  61. need help
  62. Big heads : Small cam - Discussion thread
  63. Crankshaft/Cam dot-to-dot?
  64. Cam install question
  65. P0133 and P0153 codes Can anyone help???
  66. Does anyone know where this is supposed to connect to
  67. will i need more fuel?
  68. ARP head studs vs. head bolts
  69. Hate to beat a dead horse but?
  70. The new CHP
  71. 5.3L Heads & Pump gas...
  72. 226/226 vs 228/230
  73. What numbers do you think it will make
  74. Just got my new block, possible problem. I want your opinions
  75. how much can it take
  76. Comp Cam Dyno Graph.. too lean?
  77. Rev Kit?
  78. Cam position sensor, still having problems....
  79. solid 383
  80. Ok guys who has the best cam in your opinion?
  81. Changing #7 valve springs HELP
  82. why people love to hate the hotcam
  83. small cam without headers?
  84. Want power
  85. Opinions on a cam
  86. Modifying Oil Pickup and Windage tray with main studs
  87. ls6 block
  88. Head Gasket?
  89. Running lean
  90. Cam install shopping list.. Is this everything I need?
  91. Darton blocks
  92. ls1 to ls6 pvc conversion
  93. MAC's Corsa TR220/114
  94. People with G5X-2 and G5X-3 with Aftermarket Heads Come Inside
  95. about the Z1 cam
  96. It Fired Right Up!!
  97. Has anyone ever broke a rocker arm bolt??
  98. Has anyone broke a Rollmaster timing chain?
  99. Lunati Cams
  100. 228º / .588" / 112º cam questions
  101. Ordered new FMS cam
  102. Question about rod and main bearings....
  103. Breather for driver's side valve cover
  104. Pp 5.3 Vs Are Stage Ii
  105. CNC LS-6 heads
  106. Checking PTV??
  107. 230+ cam and stock injectors....come in
  108. LS1 head casting number ????
  109. What is your Rev Limiter set at?
  110. what would this dyno
  111. Wanna see your LPE GT2-3 Dyno #'s
  112. Removing gas from gas tank?
  113. retainer locks?? Re-use or buy new?????
  114. T/A HP Upgrades
  115. running straight pipe w/ TR220/114
  116. who runs dampeners?
  117. Noise after Cam Install
  118. Cam Only Comparisons- How will dominate?
  119. Dual Valve springs?
  120. Anyone interested in this??
  121. Has anyone o-ringed
  122. REV dual springs and valve seals???
  123. Results from Head/Cam install
  124. help with heads/cam install
  125. stock valves
  126. c5 oilpan
  127. Is this valve spring compressor good?
  128. YT rocker vs comp rockers??
  129. Strongest beehive springs
  130. Is there a diff. in 98-02 heads?
  131. What do you all think about the new additions to the SS?
  132. Has anyone had cam failures????
  133. different GM head bolts?
  134. Cam install problem: Crank pulley removal - M6x120mm bolts don't exist!
  135. Do any LS1s use valve lash caps?
  136. Knock?
  137. Camshafts for stock heads + valvesprings
  138. TSP 228 vs F10
  139. Remove paint from LS6 springs before install?
  140. Anyone have the PN# for oil pump o-ring?
  141. New #241 heads milled .035 = ?C/R
  142. Compressed thickness of Fel Pro #9284PT?
  143. are driver's side injectors louder?
  144. Doing Cam and Heads,LT Headers worth the Money?
  145. Patriot Dual Springs or Crane? For Tsp 231/237 Cam
  146. compression check
  147. LS6 springs with stock cam?
  148. LS2 blocks
  149. switching from Lunati 395 to a 434
  150. Headgasket or cooling systems problem?
  151. head&cam video
  152. replacing lifters
  153. Deck Clearance - Head gasket question ?
  154. Need help with possible new engine (LS6 swap)
  155. I thought it was piston slap
  156. Oil pressure Question
  157. Question about large cam, s2 heads, and revving while cold.
  158. Cam... 230/232 .573 .575 111LSA
  159. People Running the TR230.. 1 Question 4 Ya?
  160. Where's the newer Trex sound clip?
  161. GM Lawsuit on "Pistonslap"
  162. 921 springs - can you use stock lifters etc
  163. Choosing a Cam Criteria
  164. solid roller?
  165. re-sleeved vs c5r?
  166. comp 228/228 .571 .571 112lsa going in, what to expect?
  167. Forged internals?
  168. Check out this PCV idea!!!
  169. Lowering compression ratio
  170. Would you recommend a non-adj valvetrain for this setup?
  171. tr 230 cam inputs please...........
  172. HELP!! How do I fix this??
  173. What kind/size valve seals do i need?
  174. Head studs and rocker arm bolt questions.
  175. just ordered 231/237 and stg. 2 ls6-style race heads
  176. Dyno numbers on 232/234 cam?
  177. Help! Found bearing on oil plug
  178. Cam Selection...
  179. where can I find the torque specs for all the bolts
  180. Price to install H/C package?
  181. car bogging at idol!?
  182. Comp 918 springs or comp dual springs?
  183. TR224 cam and Rev 1116 springs?
  184. How do I find what size pushrod I will need and if I need adjustible rockers?
  185. How many people check/adjust there valve spring preload
  186. Heard a Ticking Noise on startup??
  187. Spun bearing...looking for new shortblock...Valvegod?
  188. New GM heavy duty chain, are new gears nessecary?
  189. cooling problems...
  190. How much Milling needet to get a 6.0 head to 61cc??
  191. Question about head casting numbers...
  192. TRex Vs. G5X-3
  193. are 1 and 5 main bearing different than 2 and 4?
  194. Help Me Help My Buddy
  195. Yello Terra RockerArms
  196. MTI Motors Question
  197. Cylinder Heads
  198. timing chains and asp pully
  199. New Spring Compressor
  200. How hard is it to replace valve stem seals?
  201. Thinking about a 228 cam... opinions?
  202. ARP Stud Torque Procedure.
  203. Rocker recommendations/opinions
  204. 6 liter iron block
  205. Any aftermarket LS1 oil pans?
  206. FYI Callies 4" stroker kit requires clearancing
  207. Cam Guys-Look at this pic
  208. When honing a block.....
  209. Can you guys help?
  210. Cam spec sheet ....?
  211. Need some advise!!
  212. what "ls1 grinds" are there out there?
  213. TSP/PP Race Style Heads & Cam Installed
  214. Breaking in springs
  215. any news on the super 7 locks yet?
  216. pulling the engine how hard?
  217. GTP heads and cam question.
  218. What gasket should I use for LS6 heads on a 97 C5?
  219. What should I do
  220. Can i re-use main cap bolts?
  221. Engine dies while driving home; engine starts briefly, then dies
  222. vacuum leak, difference between ls1 and ls6 intake map sensor?
  223. Who does the best work for a sleeved block
  224. Which way should I go?
  225. New Forged 383, which oil 1st, Syn. or Dino?
  226. New Forged 383, which oil 1st Syn. or Dino?
  227. can 918 springs be used w/g5x1 cam?
  228. Cam position sensor, how to change??
  229. Wrong oil used....need advice
  230. Whats the downside to having a high idle?
  231. Why do LS6 heads perform better?
  232. What is LS1 Edit?:
  233. #7 Cylinder Very Oily - Need Input on Troubleshooting
  234. HELP! Go with T-rex or tr224 and pp stage 2
  235. Heads/Cam on a daily driver...?
  236. Synthetic Oil?
  237. Milled 6.0's with ls6 cam.
  238. ????????????????????????
  239. Im about to get a cam, what else should I get?
  240. Yella Terras and valve float....
  241. What are the options available as far as adjustable rockers?
  242. rev limiter
  243. tsp 231/237 cam ? and comp 978 springs ??
  244. Eagle crankshafts?
  245. Will a remote filter mount with oil filter work as a catch can ????
  246. Which cam for a 3500 stall?
  247. tsp 231/237 PP 5.3 Stage 2 heads with Pacesetter longtubes - Dyno
  248. Changed Cams.. Impressions
  249. TEA or PATRIOT ???
  250. grandam cup cam almost..........
