View Full Version : Generation III Internal Engine
  1. Where to get a good single chain, and timing sprockets?
  2. what are the ft/lbs of torque on the stock head bolts???
  3. a lifter fell while swapping cam please help!!!
  4. How to set lifter preload?
  5. Serious issue with Eagle stroker crank
  6. TR230 with Milled 5.3L heads...
  7. TSP 231/237 With Manley Springs (Single)
  8. I'm totally lost!!!
  9. LS1 Head casting #GO29????
  10. Head bolt tourqe?
  11. Need Help!! Problems with my TEA heads, my TR 230/224 cam and intake valve clearances
  12. No Oil Pressure?
  13. Difference in spring logevity.....918s vs. 921s
  14. Be honest how reliable is it.........
  15. what size cam to get?
  16. Sneek peek at my LS1 (now LS6) for the '63 Grand Sport
  17. 5.7L Heads on a Iron Block?
  18. Thinking of going bigger than my B1
  19. best spring for .620/.624 lift?
  20. Cam question
  21. Ups Man Was Just Here!
  22. Those who built/had motors built...
  23. How deep is a 2cc valve relief, anyone know?
  24. TPIS cams and heads
  25. 4" crank clearance
  26. Any new "middle of the road" cams from Thunder?
  27. C5R head specs
  28. What are the "NEEDED" upgrades for a 408?
  29. What cam for a 408 strocker?
  30. Valve spring pressure?
  31. The formula for figuring valve events. ..would that be helpful
  32. 18 rwhp too much to ask.....
  33. What if Dot-Dot was off by a tooth?
  34. Head Stud Instal Problem
  35. Ceramic Coatings and Turbos
  36. TSP 231/237 users with milled heads....
  37. Curious-Would LS6 springs be sufficient for 224/224, .563, 112 cam?
  38. California CAM
  39. What diameter dual spring ?
  40. Dynoed my car and had some trouble can anyone help??
  41. Rod knock???
  42. Heads help
  43. Heads Cam Setup
  44. Bent Pushrod
  45. Which Springs
  46. Question about REV duals
  47. Time for a new cam! Opinions?
  48. Anyone help me out
  49. What happened here?
  50. 918s or the new LS6 springs?
  51. Retainers
  52. How will my car run without tuning after a cam?
  53. Lunati and Hypertech working together?
  54. biggest cam with 5.7 heads milled .030?
  55. What length pushrods with GMPP LS6 heads?
  56. Using too much gas...help
  57. LS6 valve springs
  58. gasoline in my oil?
  59. Lifter noise?
  60. FMS F13 is in!!
  61. whats the biggest cam used with 987s
  62. Need Dyno Graph on FM11
  63. SLP H/C package
  64. burning oil at high RPM
  65. Will comp 941's hold up???
  66. This is a poll on Yella Terra rockers
  67. Anybody done heads before cam?
  68. everything for cam?
  69. AFR heads...
  70. What Heads for TR220
  71. 224 and lsx
  72. Need some idea/tips
  73. Trying to understanding CC 987/978/921 springs and max lift
  74. Whos still running stock pushrods.
  75. Is the LS6 cam better than the LS1
  76. OK now i'm serious about HEADS!!!
  77. where do i find the id stamped on TEA heads
  78. Stock head casting?
  79. 6.0 buildup
  80. 436 CI broken SB
  81. Loudmouth's plug/rich problem; little assistance please :)
  82. Yellow residue on bottom of oil cap. HELP
  83. ORinging 6L Block...
  84. few pics of head swap
  85. Lifters/removal
  86. Coating internal engine parts......
  87. Cam suggestions please
  88. Compressed head gasket thickness.....
  89. Every single plug fouled?
  90. What springs and push rods are right for me with my new cam?
  91. need your thoughts
  92. Need Help With A 6.0 Liter Block
  93. ARP head stud torque specs
  94. Compression help
  95. Who would do the best headwork for my 5.3...?
  96. need some help
  97. Is this right?
  98. Stock 5.3 heads
  99. Will 918's work for me?
  100. How to pre-oil (pressurize) a new motor?
  101. Give me some ideas on cam specs
  102. Why use synthetic oil
  103. TSP cam
  104. Information regarding the Thunder Racing T-ReX camshaft
  105. Valve covers
  106. Low dyno #'s on new head/cam setup....suggestions?
  107. Anyone ever run this Lunati cam?
  108. Any reason not to run the felpro gaskets?
  109. New Thunder TRx v.2 Cam Specs inside!!
  110. depressing spring depressor
  111. cam with advance ground in????
  112. Mti Z1 Vs F11
  113. Will 978s and YTs collapse stock lifters?
  114. CAM SPECS for TURBO CAR?
  115. For Your Entertainment, Heads Galore
  116. Explain difference between X-ER and cam motion lobes?
  117. Best timing chain and lifters for 410ci and lots of spray?
  118. Need assistance on purchasing new heads!!!
  119. What head gaskets?
  120. reuseable head gasket?
  121. How much power are strokers making
  122. Anyone with BAD piston slap/oil consumption....
  123. Couple motors being finished with eagle cranks
  124. 921's or Crane duals for futral fm4?
  125. Thank You Summit Racing
  126. Guess my Horsepower
  127. TEA vs the rest
  128. LS6 PCV is doing the Job!
  129. pushrod length questions
  130. adviice: timing set/oil pump with cam change?
  131. How big is too big for a Cam
  132. Patriot Performance flow numbers
  133. max compression
  134. Timingchain slack?
  135. Forged bottom end
  136. How do you guys like the Futral F12 cam?
  137. Flowing heads question
  138. lifter replacement
  139. Another dumb question
  140. Does a cam swap require valvetrain parts?
  141. Stupid question...
  142. GM makes 2 different versions of Hot Cam?
  143. So much promise with latest cam numbers
  144. 5.3L Stage II heads in Texas - any problems from heat and bumped up compression?
  145. Need some input. LS6 cam & 1.85 rockers
  146. Absolute 2.75 LS6 heads
  147. Anyone send their block to Darton for sleeving?
  148. cam recommendation
  149. Terry@Patriot Performane uses Fel-Pro Viton seals now?
  150. What kind of power should this make?
  151. this cam in MTI 383
  152. water seepage
  153. Stock Rod length size?
  154. Most hp gain and retain driveability
  155. Kickin around this cam for a 408ci motor.
  156. Houston 231/237 cam owners
  157. tsp 231/237 questions
  158. How strong is a stock LS1 Bottom end?
  159. Need help!
  160. 5.3 motor buildup
  161. Boring over
  162. C5R block
  163. 400 rwhp?
  164. Ported and blueprinted oil pump necessary?
  165. CC918 spring - what is the "blue stripe" issue?
  166. Crane 832 dual valvesprings and LPE GT2-3?
  167. Which cam for Absolute Stg2 5.3's
  168. What heads to lower compression?
  169. is this normal??
  170. What is a pushrod valve gear
  171. Bldg. a motor...
  172. ARP head stud question
  173. TEA LS1 Stage 2 flow sheet
  174. Sea Foam question
  175. Did anyone here measure the P/V clearance changes from a TR230 to any G5X cam?
  176. Is there a way to convert P/V clearnace (from claying) into valve drop clearance?
  177. Does a cam change the volume of an exhaust note?
  178. narrowing down cam
  179. most dependable sleeved block
  180. TR224 112 lca vs. 114 lca = what issues?
  181. best cam
  182. What to purchase next?
  183. someone reccomend a head for a 408 n2o motor
  184. How will this effect drivability
  185. roller rckrs and pushrods
  186. Comp Cams Shaft Mounted Rockers
  187. Jezel timing set
  188. Those with 5.3 heads...
  189. LS1 Head Comparison Website
  190. spark plugs for h/c
  191. Cryogenics?
  192. cheapest way to make 231/237 cam work
  193. 26921 Comp Cams Dual Springs ... Need some specs
  194. Can you put a LS1 crank in a 6.0 liter block?
  195. what is the best cam for 383ci
  196. Knock under load?
  197. is there a test u can to on the pp ls6...
  198. Using hardened valve seats with beehive springs?
  199. next month the 224-228 / 563-569 on 112
  200. POLL on PP LS6 head!
  201. Just ordered a cam
  202. hows the lope on a MTI C2 on the 112 LSA
  203. Would this custom grind work?
  204. anybody w/ PP5.3 heads & 224/224 cam
  205. How does this compression ratio look?
  206. Swapping cams..how much gain..B1 to TSP 231/237
  207. LSA and duration
  208. Complete CAM Install the First Time
  209. 6.0 .030 Pistons
  210. flow Data fast vs ls6
  211. Cam Install
  212. Head chioces AFR or LPE
  213. Thunder Racings new "TRx V1" cam questions...
  214. Horsepower down, need help with dyno graphs
  215. more power...g5x3 on 114 or g5x2 on 112???
  216. what CR do the 59 CC PP ls6 heads make?
  217. TEXAS Cam Owners!!!!!
  218. Mileage on LS1 Motors?
  219. what springs to use ? (part 2)
  220. Is this all you will need?
  221. WOT hesitation...?
  222. Stock cam specs?
  223. G5X3 114 and stock heads piston to valve clearance measureing
  224. Whats all needed for a reliable stroker?
  225. Need cam advice for my setup
  226. Not your typical cam question
  227. What makes popular cams good power makers?
  228. Will a truck intake support a 383?
  229. is this necessary for a H/C install....
  230. high rpm
  231. stock auto going for cam
  232. F1 cam? Help a newbie
  233. Spec out my cam
  234. What are valve seats?
  235. Are these numbers realistic?
  236. 5.3L head question
  237. Com OEM lifter preload...
  238. AP Engineering Stage 1 Ported LS1 Heads/ Pics and Dyno Graphs
  239. GM CNC'd LS6 heads and no GM cam?
  240. If Comp Cams offered......
  241. 6.0 Torque Plate Hone
  242. anyone with comp R lifter noise
  243. Please Help..Need some answers Come in also if have ls6 cam or ligen gt2-3 cam!!
  244. Smaller idler pulley?
  245. best cam only/nitrous cam
  246. Internal Engine Prob or no?
  247. MTI T1 Cam
  248. Stroker???
  249. comp cam 212 218--560 lift on a 115 lobe
  250. any1 pas emissions in mass with a TSP 231 237
