View Full Version : Generation III Internal Engine
  1. How much can I hone my Iron block (408) if it already has a 4.030 bore?
  2. How is my car going to run?
  3. to advance or retard the cam
  4. LS2... some basic specs from Feb MT
  5. John Lingenfelter dies
  6. If you've had a Comp Cams 216/220 come inside
  7. 231/237 cam settings from racers....
  8. AFR heads?
  9. stage 3 heads. which are the best
  10. Comp cam lifters
  11. Would you spray a 382 w/Eagle crank & rotating assembly?
  12. guess on performance?
  13. Milling TEA 1.5s with X1
  14. Are headers a must with a cam??
  15. Cam decision time
  16. Rev Kit
  17. Valve Spring Question
  18. TSP 231/237 owners come in please.
  19. Predator tune first or re-cam, then tune?
  20. Crank Reluctor Wheel
  21. Lets talk valve size and power gains.
  22. bought a LS6 cam
  23. More Iron 6.0L ?s
  24. Engine problem
  25. How much for a CNC Patriot or Absolute Speed heads if you already have 5.3 heads??
  26. LS6Valley cover or Catch Can
  27. Heads and Cam question?
  28. need some input after heads cam in stall please
  29. G5X2 or G5X3 ?????
  30. Stronger cam: MTI S2 or TR 224 114?
  31. 6.0L rods
  32. 3/8 inch Push Rods - Pro's & Con's
  33. TR224 Grind Numbers...
  34. MAX Valve Size on a STOCK BORE LS1????
  35. what is the max cam lift can be used when heads are milled 30-thou?
  36. Does this sound right?? Hp seems low to me.
  37. Piston damage from valves? When is piston too bad?
  38. do any of you guy's ears ever play tricks on you as far as your car goes???
  39. What's the casting number for an 02 LS6 block?
  40. Cam and Head specs for GMMG Phase 2 BlackBird?
  41. cam question
  42. Head gaskets backwards?
  43. what is the compression of this engine?
  44. Car making low numbers
  45. I need TR224 cam only dyno #.
  46. 987 coil bind?
  47. Oh bad, had a customer tell me he has stock pistons in a 3.905" bore, how bad?
  48. Santa (RPM) installed H/C..446rwhp w/cats
  49. TSP's Camshaft swap gasket kit?
  50. is anyone using the tsp 228/228 588/588 112 cam?
  51. Cam Lift at Top Dead Center.
  52. G5X3-114LSA - Cam only dyno - 427/401
  53. oil pressure question
  54. Why isn't my setup making the power expected?
  55. 160 degree thermostat question.......
  56. Please, I need info on JPR lifter tool
  57. Think I found the problem
  58. i have a 98 z28 what heads and cam package should i get
  59. What Is #853 Casting From
  60. Essentials rebuild LS1 kit???
  61. Tea or Patriot?
  62. Installed motor, on startup, horrible rod knock type noise, lifters possibly??
  63. Help with heads
  64. Anyone Running G5x2 With 3.42 Gear?
  65. Powder coat or paint new block???
  66. Can you 'over head' your car?
  67. Complete the following sentence:
  68. Should I rebuild? How much $?
  69. 226/234 570/575 111
  70. Which Sage II Heads for the origional G5 cam?
  71. Cam/Rockers inquiry
  72. Jesel Belt Drive
  73. test trial heads...
  74. How much liters of oil you need for larger c.i. ??
  75. cheapo-synthetic
  76. Would 110-112 LSA work well?
  77. Anyone Tryed the Grand-Am Cup Cam????
  78. ASA sound clip needed!!
  79. T&D 1.7 rockers. Pushrod Clearance dramas
  80. Will P/V clearance be an issue with this setup??
  81. What do you think this cam will put down??
  82. Nee some help
  83. Cam for nitous?
  84. Fair price for machine work & labor to build a stroker motor?
  85. How much does a LS1 Long block weigh?
  86. decisions decisions decisions heads or cam now
  87. Need help with blueprinting specs
  88. Compression Test Results???
  89. TSP 231/237 with milled heads?
  90. MTI will be closed for the Holidays!!!!
  91. Uneven cooling using LS6 coolant line plugs?
  92. What would cause tach to drop to 0 and loose oil pressure?
  93. Cleaning Heads
  94. What can I expect on a Dynojet?
  95. Blower cam specs. what ya think?
  96. So my horsepower seems to be missing....
  97. Small cc sizes
  98. biggest cam on stock heads?
  99. is anyone usuing the SLP cam #51013 228/228-571/571 112?
  100. I have a question about oil consumption!
  101. Which cam will lope more....
  102. How to increase lift without cam change?
  103. help: problem after track run
  104. 230/230 114lsa too much for A4??
  105. Cam selection need suggestions for LS6 91 RS
  106. Perimeter bolts Patriot Heads
  107. AFR 225cc flow numbers out yet??
  108. oil pump install?
  109. g5X-3 with stock heads
  110. Just installed the T1 cam...Is this normal?
  111. Fairly loud piston slap,cold engine under load??
  112. Fastest Ramp & Highest Spring Pressure for Stock Lifters?
  113. would the G5X-3 be good for a cam only car,numbers anyone?
  114. What patriot heads with this cam
  115. Question about shifting and rpms...
  116. Deck height on a 5.3?
  117. Problems after TSP 231/237 cam
  118. help find lost hp??
  119. Cam for z06? Want AGRESSIVE
  120. Oil Analysis
  121. Cometic Head Gaskets?
  122. What valve spring is this?
  123. new lifters or not??
  124. Do I have to have 160 degree thermostat w/ my setup?
  125. Bushing lifter bores?
  126. Oil Pan Question?
  127. 383 or NOS??
  128. thickness of piston coatings?
  129. Lifter Problems with 346
  130. Any news on the AFR heads?
  131. tell me the goods and bad's w this set up
  132. dual springs pros/cons. tell me which ones yall perfer
  133. C5R heads?
  134. overheated
  135. ATT: mti r1 cam users.
  136. Thinking about stroking it? Lunati kits inside!
  137. GT2-3 users please post your times & Dyno numbers/graphs
  138. What is the max compression I can run with 8 psi
  139. installed cam, am I running rich?
  140. Wrist pin will not fit into Eagle rod? Help!
  141. Question for the guys with ARP main studs
  142. Need help from internals experts, what amount of blowby is normal at idle?
  143. thinest head gasket?
  144. w/ Darton install...how many 0.001" lost deck?
  145. which 02 sensors for leaded gas?
  146. Help on timing chain !!
  147. Patriot Heads.
  148. No Oil Pressure Help!!!
  149. Which LSA???
  150. Differences in 98 ls1 vs 00 ls1
  151. can someone explain the difference in dry and wet sumps?
  152. Cam "Wish list" - Need your input
  153. Coolant for a newly Darton MID Sleeved block
  154. 220 v. 224: which cam will pass smog easier?
  155. crank sizes and bores question
  156. Piston-valve problem with TR230 cam
  157. Help me choose a cam!!
  158. help.. how 2 get rollers out?
  159. No one has G5X2 or X3 cam only dynoes?
  160. Tapping sound on cold start???
  161. Changing the B1 cam to the C2 or TR230:what would i gain?
  162. My goal is 400 rwhp w/o heads
  163. Whats the talk of not being able to use SBC 6.125" rods on a ls1 ??
  164. Just got a 4" Eagle crank...
  165. Iron Block folks in here.
  166. Daily driver A4 cam?
  167. Has anyone seen this timing chain before
  168. Installation of a cam
  169. compare motors
  170. Surely after almost two years its not true!
  171. Rumpity Rumpity, 230/236 108lsa 108icl cam on the way
  172. X1 vs TR230 for best et
  173. Degreeing Cam??????? Please help!
  174. Cam experts come inside!
  175. 6.0 block .060 over??
  176. LS1 valve spring install height
  177. wrist pin Q's, diamond pistons
  178. need cam install in texas, where to go?
  179. Expectations of LS6 intake
  180. double roller timing chain....stock pulley
  181. WTF is this noise (soundclip included)
  182. LS6 cam/srings A4 shift points?
  183. What is reasonable/practical to expect from a 409 stroker?
  184. Offset Grinding a stock Crank? Cost?
  185. ls6 cam
  186. Bore vs. Stroke with a LS1 ???
  187. Can my 5.7 ltr .030 milled heads be used on 383 stroker?
  188. 382 cubic inch motor
  189. Taking apart my motor, have questions
  190. Think I have enough cam...
  191. HP from heads only?
  192. CR increase gains?
  193. Fly Cutting stock pistons
  194. Can LS1 heads be used on a 42x c.i. motor?
  195. Which cam is better for my needs TR224 or the Comp XER 224 581"
  196. 402 vs 408
  197. More updates on our Stage 3X on a stock 346 short block, 491 RWHP and 431 RWTQ.
  198. Thoughts on a new combo
  199. Which Patriot Heads For My Cam
  200. Question About Cam Lift
  201. Who does custom camshafts?
  202. Why not 2.055" Int. Valves???
  203. Why LS1 solid rollers do not pick up 40 to 50rwhp like Stangs?
  204. Strokers & Rod length
  205. Who's Flycut Pistons?
  206. A few cam questions
  207. C5R Valve Covers and Jesel JKR Rockers
  208. Newbie here/cam expectations
  209. LS1 5.3L vs 5.7L bore difference?
  210. Telling driver side from passenge side coil packs
  211. Does anyone have a cam they consider NON STREETABLE?
  212. head gaskets?
  213. Anyone running a 393 ci all bore?
  214. No oil to the top of the Engine?
  215. Stock head bolt size (LS1)?
  216. ARP/Head bolt TQ question
  217. '035' die cast or 317'' sand cast heads ? Which process makes fora better head ???
  218. Mounting block to engine stand, what bolts?
  219. 380CI iron motor completed. pics inside.
  220. whats the strongest streetable cam on the market for ls1?
  221. When do you need shorter pushrods?
  222. Stock install heights of the 02 ZO6 heads
  223. Cam Swap Questions.......
  224. What are the specs on a stock '00 SS cam?
  225. Is my 6.0L Iron Block damaged?
  226. thinking about a cam
  227. TR224 with 1.85 rockers?
  228. REV 1116 specs
  229. LS6 HEads vs. LS1 Heads
  230. Has anyone ever slipped a stock sleeve?
  231. which heads to go with?
  232. Switching from 1.7 stock rockers to 1.85. How much does this change the lift of cam?
  233. Aftermarket vs Stock lifters, Benefits?
  234. XER Lobe chart...
  235. Be very careful about blem/ overstock blocks/ parts.
  236. Just finished heads/cam install
  237. TR224 112 cam with dual springs?
  238. Why aren't super-strokers making a lot more power than the all bore motors?
  239. Cam
  240. Can a 99 block go to 3.905
  241. I need Absolute Speed's address...
  242. Poll on Big Bores 382-388 & leaking issues
  243. Need 400hp Cam Only...what Cam?
  244. Biggest cam with stock converter?
  245. How about a Sticky for Cam selection & experiences?
  246. What rocker setup to use with solid
  247. To Degree in a cam wouldnt we need and adjustable cam sprocket?
  248. best aftermarket head
  249. long ratio rod?
  250. 6.0L is almost built.
