View Full Version : Generation III Internal Engine
  1. those with cams and m6
  2. 429hp from LT1
  3. do this sound like a spun bearing?
  4. good price on machine work?
  5. Cam LSA and advance questions..... [Large cams]
  6. Importain Question???
  7. Head/Cam cars????
  8. What are the torque specs on stock rocker arm
  9. Need Help with Cam choice
  10. Pack your oil pump w/grease - WTF?
  11. Hotcam Dyno
  12. Where do I put rev limit on 224/228 581 112 cam?
  13. 6.0 heads?
  14. how to quiet down valve train?
  15. Great, probably bent pushrods, need help
  16. How can I use solid lifters with the stock lifter tray?
  17. weight of stock connecting rod bolts
  18. SES w/ bent push rod or valve
  19. Where did Yella Terra come from???
  20. Pushrod Length with .020 milled heads and a B1cam??
  21. DRE/Comp Rockers....
  22. flashing SES ...
  23. Stock pushrods.
  24. Post Head Install Problems (STILL DOING IT, NOT o2 SENSOR)
  25. JMX and his install notes OWN YOU ALL
  26. Rockers on Stock Engine?
  27. which stage 2 ls6 heads are...
  28. 95K Miles: Piston Rings bad or do I need thicker oil?
  29. What is the difference in perofrmance between these two TSP
  30. how much HP does the Borla plat cost you? Answer inside
  31. Piston selection
  32. JOE SCHUBECK LIFTERS "WHO'S USING THEM" NEED HELP!!!!
  33. Running Leaded gas
  34. How to test for good oil pump ?
  35. whats the difference between ls1 and ls6 heads?
  36. 485hp slp package
  37. Where can i find this
  38. patriot stage 3 heads
  39. question on 6.0L retrofit
  40. What does LSA directly affect? (112 -vs- 114)
  41. RWHP SEEMS WEAK FOR MODS
  42. White smoke after WOT
  43. Anybody got a pic of a 772 comp Ti retainer?
  44. Anyone know anything of the Hammer XRE Cam?
  45. Will a TR230 Run and Idle w/o a Tune?
  46. cam
  47. Best Patriot Head for G5X2 cam
  48. Car Boggin?help
  49. Ok, valvetrain setup questions.....
  50. 417 RWHP and 394 TQ after UD pulley install
  51. Is anybody using a 4.250 stroke?
  52. Oil Pressure Problem Fixed!!!
  53. new 396
  54. SPRING INSTALL HELP ASAP!!!!!!!
  55. g5X2 intake/exhaust duration and lift????
  56. TEA 6.0 head dyno's 502 rwhp
  57. double roller install Q.....
  58. TEA head port stalling test #1, buy an LSX intake!
  59. Federal Mogel VS Clevitte 77 bearings
  60. Prices on some Z06 parts (cam, lifters, springs)
  61. Jesel non-adjustable rockers tq specs?
  62. How do these cam specs look for stock heads?
  63. Buying a '00 SS w/ Lingenfelter 350 pacakage...Input?
  64. BAD Idle. Need HELP!!
  65. 806 casting heads
  66. Dynojet 248c, heavier rotating parts how much does it change
  67. how many wires going to oil pressure sending unit sensor
  68. Tell me how this cam would operate....
  69. How Hard is an LS1/LS6 to build?
  70. Patriot Stage 2 LS6/LQ9 Heads Now Available!!!
  71. Batman #1 - oil question
  72. how to test for good spark plug wires?
  73. Function of LSA; Duration; Lift
  74. OIL PAN LEAKS!!!!!
  75. Corvette oil pan on F-body LS1?
  76. How much does a LS1 Block weigh?
  77. Where can I get the tools to flycut my pistons, ASAP?????
  78. Dyno question.....
  79. Back Fire Diagnosis Anyone?
  80. biggest cam with TEA heads (5.3 or LS6) - post your cams
  81. Periodic stall - 150 miles after c1 install
  82. What brake fluid do you guys use for our cars?
  83. What brake fluid do you guys use for our cars?
  84. any open header tr224/112 sound clips?
  85. Cylinder numbers please.
  86. doing cam swap NOW...few Q's...
  87. another cam quetion for A4 car
  88. Damaged heads, are they repairable? Pics inside.
  89. How important is Lift on Camshafts? Experts
  90. Things to do before cam/heads
  91. Question about changing cams...X1 to G5x2 clone/almost
  92. How exactly are some people getting 420+rwhp/410+rwtq...
  93. Broken valve spring &$#@%^&%*$# !!!!!
  94. quick waterpump removal question
  95. 400 RWHP
  96. How can you get more than 260cfm through a LS6 intake?
  97. Oil Pressure Questions ... Info Needed
  98. Questions on Heads & Cam Install
  99. PCV mod. oil in the intake.......why?
  100. any 110lsa sound clips
  101. MTI Introduces New Stage IIE Cylinder Head!
  102. Need Help with Cam
  103. Mathmatical Way to figure PTV clearance??(valve relief size)
  104. tr220 question
  105. Absolute Speed 6.0l heads, trap 128.9mph
  106. Should i get a 02 or 03 Z06 cam?
  107. Has anyone sleeved a 6.0L iron block?
  108. cam suggestion for new heads
  109. new tr 224 sound clips
  110. How far past 0 lash to preload lifters with adj. rockers??
  111. HELP! Thinking about switching from a XE to a XE-r cam
  112. These Huge Cams..... Why do I feel small now?
  113. TR 224//114 Passes Cali Smog!
  114. What happened to GMMGs website?
  115. Opinions on Patriots new LS6/LQ9 heads
  116. Piston speed rule of thumb??
  117. ISKY Flycutting Tool for LS1
  118. GM head bolts, vs. ARP bolts, VS ARP studs
  119. piston ? for 408 stroker...
  120. Common question...head casting numbers and details
  121. what should i get done to the heads
  122. How to setup and LS6 PCV Valley
  123. Emmissions friendly cam for a 427?
  124. Ok quick comparision here on two different camshafts
  125. Crank - 4.0 vs 4.125
  126. tunning after ls6 intake install?
  127. Oil Leaks
  128. Good shop in South Florida to assemble a short block?
  129. Cam install Q
  130. Rough Idle, Lack of Power, etc
  131. Rod Bearing?
  132. LS6 cam ?
  133. how high to spin 918s+stock vt?
  134. Need P/N for LS1 Clevite77 main & rod bearings
  135. pushrods...stock vs hardened
  136. With all these H/C cars
  137. Would an 02 LS1 with a H&C package be able to an 02 Z06?
  138. Will a granatelli MAF for an LS1 fit a 2002 Silverado 5.3??
  139. Milled heads and intake alignment
  140. what happened MTI?
  141. ls6 vs weiand intakes
  142. Torque specs on head bolts
  143. How do you check PtV clearance
  144. Titanium valves
  145. looking for a good cam
  146. 1.75 rockers
  147. 6.0 head and future S/C Q
  148. o-ring part number please
  149. Cam Ideas for a all out LS1 346 bracket racing Hot Rod
  150. Crankshaft?
  151. Bore gauge accuracy - .0005 - enough for engine assembly?
  152. What is the norm for head flow through a LS6 intake?
  153. rattles from the manifold???
  154. dry vs wet ... ??
  155. My 1999 Z28 hit the 100,000 mile mark today.....
  156. Largest Hydraulic XE-R grind
  157. Update on broken springs:
  158. News on AFR heads
  159. Holden V8 = LS1 correct?
  160. how much flycut to fit G5X-2 cam?
  161. Shrouding or Unshrouding?
  162. NEW HEADS??
  163. How much to mill stock heads
  164. Carfax Help Please!
  165. What mill on 5.3 heads would you reccomend for G5X2 cam?
  166. Need opinions ... tap, tap, tap ...
  167. LS-1 Hot cam
  168. Patriot Performance...
  169. why is one LSA better than another
  170. what length rod?
  171. LS6 cam with stock A4 converter and stock tuning?
  172. Operating temp after head and cam
  173. rods
  174. question about strokers versus all bore
  175. Setting up 977 springs....
  176. final say on this.....
  177. New LS1 performance mods
  178. Signs of a cracked head??
  179. P/N for .050 keepers...
  180. 01-02 LS6 head differences?
  181. Great article on "beehive" aka 918 springs
  182. I got AS heads and track results
  183. paging Pro Stock John...................>
  184. How important is the low-end?
  185. LS6?
  186. Idle Speeds for 112LSA Cams on M6 Cars
  187. timing cover part number
  188. LS1 hot cam tunning
  189. question about 6.0 and 5.3 truck blocks for stokers
  190. LS6 heads on LS1 Block
  191. I need big time help here! (what sounds like it's broke?)
  192. Need opinions on a couple brands of connecting rods...
  193. any info on the G5x3...i've got my x1 sold and i'm lookin ..
  194. Please Post a Clip of a C1 Hammer cam Idle 222/222 112 Autos
  195. Any power to be found in advancing or retarding stock cam?
  196. Patriot LS6 head updates ??
  197. TEA Stg 1.5 heads go 9.87 @ 138.9
  198. Any Ideas on what this might be?
  199. Best heads for G5X2 cam?
  200. anybody have a dyno graph of a G5X2???
  201. Locks/Keepers....WTF?!?!?!?!?
  202. G5X2
  203. 1.8 Rockers and High Ramp Rates??
  204. Should I replace oil pump during cam swap?
  205. Valve train tapping
  206. Best way to check valvetrain........???
  207. Calling all 430+ rwhp cars, what E.T. MPH and weight?
  208. How do I measure the ACTUAL oil pressure?
  209. Thread size for the Oil Pressure Sensor
  210. Oil leak on the 6.0L
  211. Why does the oil pressure drop?
  212. Has ANYONE broken a "blue stripe" 918?
  213. Matching heads and cam??
  214. CombinationMotorsports springs $200- good springs
  215. Oil pressure slowly dropping....worried!!!
  216. cam installation
  217. cheap 382
  218. Problem with yella terra install - 911 Help!
  219. 430 RWHP w/228/224 cam. Should I go bigger?
  220. cams..and what can go wrong?
  221. Cost of a 382???
  222. Oil pressure problem
  223. Valvetrain geometry...DRE/T&D/Jessel
  224. Uh Oh!... I think I hurt something!
  225. Comp Cams adjustable shaft mounted rockers...
  226. What are benefits to going w/aftermarket lifters please??
  227. Head porters , tuners , I'm looking for a yea or nay on this
  228. Sourcing a 382 ci stroker kit
  229. cam install question...
  230. solid roller version of the G5X-2 or 3?
  231. How much RWHP on cam only, stock ls1 head/intake??
  232. LS6 PCV Upgrade
  233. Solvent to clean head gasket off block
  234. Do the Jesel SS rockers fit under the valve covers...??
  235. At what spring pressure does a stock lifter fail?
  236. Cam To Big????
  237. My X1 #'s??? good/bad??? thoughts???
  238. Help w/ HP/TQ figures
  239. What is a good oil to use when first doing H/C?
  240. Double-roller Timing chain vs. Single-roller
  241. Custom cast aluminium intake plenum.
  242. what is the stock redline
  243. symptoms of intake leak?
  244. 8.1 liter
  245. Any sound clips of a C2 (or TR224) on a 114?
  246. What are comp 978's rated to for lift?
  247. Flycutt question.
  248. Show room stock racing cam? Work in daily driver?
  249. mti s2 heads and mti c2 cam
  250. Stroker Motor 382.....422 numbers?
