View Full Version : Generation III Internal Engine
  1. GTP Stage 2 Heads
  2. Oil change question
  3. Anyone running an MTI Z1 cam in a 382 Stroker?
  4. Texas Speed Cam & Patriot Heads Results! ! ! !
  5. Minus EGR -- UH, wtf??
  6. Head/Cam install DONE!
  7. Hot Rod Mag - 450CI - bLS6
  8. Where can i buy a 6.0 block?
  9. ***** F1 Valve Spring Question *******
  10. how much does a bare 5.3L iron weight?
  11. Is this B.S. or what? concerning a stroker motor
  12. PROBLEMS WITH A LEAK ON THE STEERING PUMP!!! H E L P !!!!!!!
  13. Iridium plugs....
  14. Bad misfire on two cylinders
  15. need opinions on this product !
  16. Metal Shavings in The Oil Bolt??
  17. what is the lockup speed on a stock tuned tq converter?
  18. How many miles?
  19. LS6 Intake Gains please...
  20. Bolt in/Weld in rollcage install, how much on average?
  21. Help, Not getting any Idle Air Counts
  22. Short Belt Question-Pro's vs Con's
  23. torque specs for heads
  24. Can anyone tell me where to get info on repairing a grand am
  25. Is anyone running a Lunati Cam?
  26. Oil Consumption **Pic**
  27. ls6 block or not ??
  28. Reusing old parts in rebuild
  29. MTI Stealth Cam
  30. cam install gone wrong
  31. Stock Lifters how good are they?
  32. Opinions/Experience w/More Performance re: LS1 Shortblocks?
  33. Decisions, Decisions...Intake or Exhaust.
  34. Can anyone offer advice/help or explanation on cam problems?
  35. cam shaft choice help?????
  36. Anyone out there tried the 4.120" dalton sleeves yet?
  37. Removing Crank Sprocket???
  38. ASA hotcam vs. regular hotcam
  39. forged stock bore/stroke LS6?
  40. What Pushrod length?
  41. 228'/230 .571"/.573" 112.....concerned :(
  42. Rocker arm bolt specs
  43. Anyone with the TR 236/230 yet? Any numbers?
  44. member paige!!!
  45. Cam info needed (zo6 cam)
  46. I'm new, I have a question. can i get this?
  47. Ls6 heads vs. Ls1 heads
  48. help code with cam install
  49. Stock internals
  50. Need help with spring choice
  51. Who has a G5X2 with a A-4
  52. Need lots of advise
  53. 1,3,5 carbon fouled plugs
  54. Anybody seen these? Comp Cams Rockers
  55. Torque Specs for Jessel non-adj rockers?
  56. Running problem on warn starts any ideas!
  57. MTI Stealth Cam vs. z06 Cam
  58. 409 Stroker motor will NOT idle! HELP!
  59. Milled Heads = More Valve Lift ?
  60. Max lift for LS6 springs?
  61. Offset Stroker - any disadvantages?
  62. Idle counts 145 in Vette do they have a Idle Air Motor?
  63. Adjustable Timing Sets. How to determining proper position?
  64. ABSOLUTE SPEED
  65. LS6 Cam Dyno Results
  66. SS is back from ESP how did I do?
  67. Compression Test: What is a normal reading for LS1?
  68. Bench racer combo
  69. Replacing Clutch Slave Cylinder
  70. Bore? Stroke? both?
  71. What are typical gains w/ '02 LS6 cam?
  72. Texas Speed's New Project Car!!
  73. Before & after results 216/220, tell me what you think.
  74. Good deal????
  75. Wear on Cam after 6k miles?
  76. Cam, and rocker?
  77. Test for oil pressure??
  78. Need instructions oil Vette Oil Pump install.
  79. First fire, horrible noises!! Any ideas?
  80. Need help with iron block buildup
  81. quick question.. drivers side front piston #1?
  82. Help!! Car is breaking up at 5600 rpms?
  83. Problem Solved! BROKEN REV...
  84. Engine Builders Inside...I have some issues
  85. Does top end cleaner go into the MAF?
  86. Reverse Split cam vs Standard cam?
  87. How to get cam out of block?
  88. 228/228 .588 lift 112 dyno numbers
  89. Will they notice?
  90. Reverse split on a bigger motor?
  91. 1.8 rockers and GM cams
  92. Head Gaskets....
  93. i need help!! my car is running horrible!!
  94. RIGHT COMBINATION?
  95. 11:1 compression
  96. what springs to run??
  97. which cam for my M6? C-1,C-2, or TR Reverse split??
  98. Please help me chose between these few cams for my A4.Thanks
  99. 232/236 cam in a ZO6...advice
  100. looking for DYNO# MMT H/C m2
  101. cam and head suggestions
  102. howto install valves ?
  103. 5.3L head questions
  104. TR230 a good cam to use with stock heads/bolt-on's?
  105. any hp help would be appreciated???????????????????
  106. You guys think I would have a problem with this setup????
  107. Cam for stock engine?
  108. Removing coolant from block? Head swap
  109. How to use search feature within
  110. What kind of power could / would this motor produce?
  111. When will a better intake actually be AVAILABLE?
  112. HELP FEEDBACK NEEDED!!!!
  113. Lets Talk Heads and Cam Package with an A4
  114. Specs for stock LS6 cam?
  115. thanks a.r.e.
  116. Wanting a little more power (cam)
  117. Thoughts and/or opinions on my cam set-up!
  118. How much power from this setup??? Anyone runnin this???
  119. Stroker turbo motor questions
  120. H/C done just right..
  121. SES light code P0108
  122. ARE; Out of business?????????
  123. Would I need a new tune?
  124. 224/228 .581/.581 114LSA any running stock heads or info
  125. cam?
  126. Main Bolts
  127. misfire on number 4 applies here to
  128. Total Engine Airflow S2 5.3s flowed on an independant bench!
  129. What are the specs on the M2 camshaft from MMT?
  130. Cylinder Compression?
  131. 6.0
  132. BEST oil pump!
  133. Head gasket blown?
  134. BEST oil pump!!
  135. Rollmasters the same? TSP vs. SD
  136. What would be the difference between these two cams?
  137. Anyone know P/N#'s for the Katech C5R Heads and Cam?
  138. sleeper cam W/ headers no cats and stock muffler
  139. hotcam or thunder racing old man cam
  140. How many bolt turns to reach .010-.020 lifter preload???
  141. What is the ICL of the C2 Cam and Effect of ICL in General?
  142. rod bolts on a 99?
  143. Lingenfelter GT-2 cam
  144. 400 RWHP With Stock Heads?
  145. New guy......upgrading '98 A4
  146. ASP pulley + rollmaster timeing set???
  147. 98-99 Stock Heads, Cam Only cars..Come In!
  148. How much different are the 98-99 ls1 heads than 2000+?
  149. Why are my 7.400'' Pushrods longer than my ls1 Pushrods?
  150. Need help....
  151. 8# ATI reliable on LS1 Engine?
  152. LQ9 Deck Height
  153. Will this engine combo work alright?
  154. SMOG PROBLEMS WITH HEADS OR NO
  155. Is this right ???
  156. TEA headed cars..... post your dyno #s inside
  157. main caps and bearings
  158. Can't seem to find info regarding...
  159. Time for a new cam (milled heads)
  160. Question about 5.3 heads?
  161. need help dyno #low
  162. One last knock question
  163. MMS 224/224 .570/.570?
  164. Looking for cam info..what should I try!?
  165. DYNO RESULTS:G5X2&5.3 STAGE II HEADS
  166. futral cams
  167. building bottom end to handle big shot......>
  168. What gains will I see from the following mods?
  169. double roller timing chain install help
  170. tr236?
  171. Numbers from cam swap
  172. Crane cam "Truck Power" cam kit for 5.3L, questions!!
  173. Max. valve size
  174. Patriot heads using bad valves?????
  175. Need a nitrous cam ... what do recommend?
  176. Factory Hardware ... Strong Enough?
  177. Cam suggestions please - stock heads.
  178. Removing magnets after cam install?
  179. Whats the MOST NA power seen to date with LS6 heads?Big cube
  180. Help with cam choice on 2001 A4? Thanks
  181. getting MTI S2 H/ C2cam
  182. Sound of 114 LSA Rev vs 112 LSA Rev?
  183. g5x2 or tr230 on a 114lsa
  184. looking for mti stg2 dyno results
  185. NEED help before morning with Diamond's rings!!
  186. guys, i need help for sites for old camaro
  187. Do I need a new pulley?????
  188. Mac vs. SLP
  189. Valve Spring Colors
  190. Is this normal?
  191. TSP 231/237 .598/ .595 cam?
  192. going from a big valve back to small valves
  193. bone stock a4 - 99 ws6 ..best head/cam combo?
  194. Need help quick. ??? on removing pully.
  195. Starting heads/cam install tonight!!!
  196. SLP 1.85 Rockers have Studs?
  197. hitting rev limiter..any damage?
  198. old post...987s and valve float...update
  199. NEW 6.0 LITER PISTONS FOR THE SHELF
  200. Help Me Troubleshoot...
  201. ARE s2 or MTI s2 heads ,?cam?
  202. 407.9 rwhp 400.0 rwtq w/stock heads and hotcam
  203. G5X2 Cam?
  204. Need Your Opinion On This Setup PLZ
  205. ? about solid roller
  206. Got my car back from dealership for piston slap.
  207. Single vs split pattern N20 cams - any comparos
  208. Looking for a bare set of (6.0L Truck Heads)
  209. Looking for dyno info regarding Yella Terra rockers
  210. From Admin - My thoughts regarding the bad batch of 918's...
  211. Sludge buildup in engine. What to do?
  212. cam and n2o
  213. Difference Between Corvette and Camaro blocks
  214. larger seats and valves 346cid...
  215. 405.5 RWHP 385.1 RWTQ Should I be expecting more?
  216. Need a quick answer fast please! (oil pump)
  217. OIL EVERYWHERE
  218. Looking for info on upgrading/improving oil system
  219. oil presure problem!!!!! Please help
  220. what do u need to polish the heads
  221. C2 Cam Input?
  222. Oil fluctuation?
  223. Please post Cam sound clips at idle with stock displacement
  224. Stock Short Block with H/C and Nitrous ... Reliable?
  225. New Cam Only Dyno #s...
  226. can i run a 1.8 rocker arm w/ a tr224cam
  227. Big Cube Blues: Which size do I get?
  228. Hot cam/ a4 combo?
  229. Got dyno #'s for mild AAP cam.
  230. Differences between these two cams??
  231. need to know if anyone can tell me approximate idle
  232. Stock Cam Advertised Duration?
  233. Any reason that one of my Head bolt holes would be...
  234. Rocker question
  235. Removing oil pan, motor in car, PA K member?
  236. which rods/ what length???
  237. TSB out on LS1 Lifters and Rockers....
  238. Rocker Arm Adjustment???
  239. DYNO SHEETS FROM ANYONE RUNNING AN C-2 cam.
  240. Heads
  241. Port matching....LS6 intake to 5.3/ LS1 or 6 heads...
  242. dyno numbers
  243. Calling BLK02WS6 - knock destroyed new LS6 engine?
  244. Engine Block Powdercoating
  245. got some options, need opinions
  246. Determining Compression Ratio
  247. Who makes a good 427?
  248. Typical gains from Stage II heads?
  249. How to advance cam timing on a Rollmaster?
  250. Oil Change?
