- 427ci Iron Block...
- 230/230 .591/.591 Ok on Stock Heads?
- LS6 Cam Dyno #s
- hp gain???
- opinions?
- comp 212/218-.558/.563-115 vs 216/220
- How do you guys feel about this cam?
- Cam choices again
- Are my RPMs going to high for making max power?
- ARP head bolts vs GM head bolts??
- How much hp does a STOCK piston handle?
- Trying to remove paint from LS6 springs...
- Anyone ever have P/V clearance issues with ..
- Is this labor too high?
- TEA 1.5 5.3 HEADS
- Hotcam with stock pushrods?
- Comp Cam need opinion
- Purchased LS6 Cam, What else do I need?
- QUESTION
- SHORT BELT
- 4th Gen LS1 F-Body Technical Aides
- cam opinions/options inside!
- Got my new forged 346 in
- 224/224 Cam what lift, above or below 270
- So I found the problem with my car...
- Stock Lifter part number
- where to buy bearings?
- Getting stock heads milled?????
- Pushrod Length questions?
- What would you do in my place?
- Will this work please help me
- 5.3 or 5.7?
- Engine pics and some info...
- Weird antifreeze problem
- hole in intake port on head
- Warning about online ordering from thunder racing.
- TEA performance question
- H20 pump part number please
- Relacing Oil Pan Gasket Questions....
- # for Valve Spring Seals
- Camshaft . . . which one?
- Ported ls1 or stock ls6 heads?
- What 230 cam will get me up the track the quickest
- Need some cam help.....
- Oil Change Light Question!
- Patman oil question
- Where can I buy ?
- Manifold Fit
- ASA cam kicks A$$
- people with 5.3 heads....hp and et's????
- Cleaning the Pistons?
- TSB work, do we pay out of warrenty???
- Hammer Cam VS. T1/B1 Cam
- Dyno numbers with the Cartek X-package
- New Cam and oil pump problems
- Has anybody broken a REV dual valvespring?
- TEA stg. II heads, MTI cam, & pushrods f/s, cheap!
- Checking P/V clearance
- Valve Spring Pressure Tester on car??
- port velocity between LS1 heads and LT1 heads?
- What does TEA stand for?
- Question about the MTI C2 Cam!!
- ok dammit, now what....
- A4 H/C Dyno Results - TEA 1.5 5.3L/Hammer Cam
- Should coolant look like this???
- Head bolt help
- LS1 gen III engine mods
- Eratic oil pressure after H/C install
- Think I messed up my car, need opinions
- Building a Magnacharged ls1 combo from scratch? *DELETED*
- VALVE TAPPETS VS. LIFTERS???
- Does anyone have the Raging MotorSports heads Yet?
- Lifters, due they need to soak in oil........
- Dyno#'s don't look good!
- wasnt a burnt valve.........
- Broke ARP head stud on Smokinhawk's car -- Ideas?
- Futral Motorsports all-bore dyno results!!!
- Input on Nu-Tek Motorsports
- how big can you go
- which heads give the best results
- TEA Stage 2 valve sizes?
- where to buy C5R block?
- Moore Performance valve spring tool!Anyone use it?
- OOOPS lifters
- valve seats
- 3.82 offset stroker
- ported oil pump and a possible low pressure???
- Problems catching idle after cam install
- ? flow = HP
- Major Problem: Piston doesnt clear Reluctor Wheel?
- LS6 cam ideal for high stall A4's?
- Good for 9s?
- Head Porting Questions
- cam install questions
- Simple Question?
- Holla if you have 1.85 - 1.95 installed heighth
- Help me pick out a pretty big cam!!
- Patriot Peformance heads...its competition time :)
- pushrod size for TR 224 cam..
- ARP main studs...
- Need help choosing cam for 422
- Rollmaster Timing Chain
- timing chain help PLEASE.
- [VIDEO] LUNATI 382 Stroker ..First E.T/MPH..
- what are good flow numbers?
- Coolant tube ?'s for LS6 intake install...
- PLEASE HELP
- TDC method for valvespring change
- oil pump install question
- Stage 1.5 Absolute Heads (Pics)
- Head Gasket Problem? Need Help
- Question about my new Comp "R" lifters (HELP)
- General ?: More rich or more lean after cam?
- What to expect from TH400 H/C
- Best bang for the buck motor give your ideas
- Who has the best single spring?
- 6.0 liter question
- GM piston rings
- Anyone have TEA dyno numbers for A4?
- Is my oil pressure low?
- Rod Length for 5.7 and 6.0
- completed my first head/cam swap
- Anyone use the SDPC sring and Ti retainer kit?
- 99+ Valve cover bolt part number?
- Stropespeedshop?
- arp studs
- Pushrod question?
- ARP head studs...install w/engine still in car....
- cranial rectal inversion
- ebay built motor just missed out
- Yella terra's with Double springs?
- Setting up 918 with stock heads
- Patman - another quick oil question
- Pushrod debate with the LS6 cam
- Can 1.8 Cranes work with dual springs
- PUSHRODS
- Factory rod,How good?
- Used the JPR cam tool and ..ummm
- LS1 heads coming off/LS6 heads going on the 382
- 15w40, good or bad option?
- 918's with stock cam...OK?
- I know you have THE answer...so come inside please
- How tight are rockers supposed to be?
- how much green to build 10sec. motor?
- Bearings in oil pan?!?!
- Anyone try yella terra's on .600 or higher lifts?
- 5.3 Head Gasket
- Difference in vette and camaro ls1
- 5.7 heads on 6.0 block
- Head questions and suggestions?
- New cam is in the 383
- Help! What length pushrods to use with a 02 LS6?
- Sound clips of TSP 228?
- Oil on MAF and in bellows
- Installing Hardened Seats for Dual Rev Springs???
- Yella Terra rockers, how do you guys like them?
- Will a thicker oil solve my burning oil problem?
- 6.0 block sonic test results
- Planning a budget rebuild ... need inputs
- Lifter Installation... simple question..
- 382 aluminum stroker vs. 396? iron stroker
- Removing fuel rail for H/C swap??
- Wanting to do Aadifferent cam...
- Going with new combo...need advice please!
- BIG head problem
- New motor/cam/ls1 Edit?
- Is AFR making an aftermarket LS1 head for us???
- Pics of my blown up bottom end
- Bought The COMP "R" lifters today now heres the?'s
- Absolute Spd Stg 2 Flow #s / Head Pics
- [VIDEO]My 382 Lunati Stroker DYNO..OMG..It's HOT!!
- Cam or Torque Conv. what if i go cam 1st
- Track/dyno #'s for H/C ZO6's?
- Z06 cam swap
- 6.0L Stroker, Offset grind 6.0L or LS1 Crank??
- LS1 Build-Up... Need some Info
- 383 Stroker Cost?
- Highest valve lift w/stock bottom end
- ASA in an A4, and Predator tuning it, anyone??
- Interesting look at engine break in technique...
- Cleaned my pistons, look at the difference
- HUGE power loss between 52-5700 rpms on the dyno!
- Head and cam..need opinions. and info
- Cam change for the Hotrod Power Tour.....
- Long distance cam?
- Long block and short block difference?
- I need advice on some mods
- Hey guys...what do you think about these #'s??
- Oil Pressure, and Fuel Pressure?
- Cam Install, Service Engine Lights! HELP!
- How to Build Oil Pressure
- Lunati 395 stroker kit:Thoughts and opinions
- Is a 224/224 .583 114LSA good with my set-up???
- How many Cu. In. on a 6.0 block bored .030" over?
- Injector part number Q.
- factory rod pin diameter?
- velocity ported LS6 heads vs. S2 5.3
- What's a good replacement spring for stock heads?
- got a summer project, tell me what yall think
- GTP heads and G5X-2 cam or keep my TR224?
- G5X-2 Valve spring question
- piston to valve clearance check??????
- P/V clearance losses w/ Yella Terra rockers?
- Oil pressure dropping above 5000rpms in 1st gear
- Possible fix for oil pump O ring sealing problems>
- Replacement cam for use with heads milled .030
- Shes So fine my 409!!!
- Who can offset grind a crankshaft?
- G5X-2 cam/Absolute Speed 5.3L S2 heads dyno
- G5-X2 dyno numbers in automatic Z28
- ? about 230/230 110 LSA cam
- Absolute Speed Stage 2 Heads!
- Currently running the gm hotcam, what heads should
- 2002 Escalade engine into Camaro swap HP/TQ ???
- Air bubbles in the radiator (long)
- Bought a set of Yella Terra rockers today.........
- Anyone have a link to TSB's site??
- A.R.E h/c Z06 completed
- aftermarket rods question
- How Much For Turn-Key Cam Install?
- 419 stroker problems
- HELP W/ HEADS AND CAM!!!
- Any diff in LS-1 and LS-6 shortblock Assy.??
- coolant leak after cam/lifter/pushrod/springs chan
- TEA 5.3 1.5 HEADS/CAM
- LS1 Hot Cam A4 Reprogramming
- Rebuilding engine to like new state
- LS6 Heads
- Cartek Stage 2 Heads and TR 224 Cam
- What cam should i get?
- LS6 Cam guys, please give me your valuable opinion
- any problems with bent pushrods in ls1's or trucks
- Should I change out my lifters
- Who's got a strong running 382 stroker?
- need help with heads
- all bore & nitrous.....
- lunati rotating kit
- LS6 block where to buy....
- Just got my sonic results...need advice???
- Backfiring at WOT over 4500 rpms
- heads/cam nitrous ?'s
- dropped a bolt in oil pan...
- 422 Shortblocks for under $2000 with forged parts?
- Help me pick a cam fro my 02 Z06-please!
- RMS C5 cam stock heads results!
- Short block assembly.....
- ASA cam times
- Help! Still got low oil pressure
- another cam question (Z06)
- Differences between TR and Comp pushrods?
