View Full Version : Generation III Internal Engine
  1. LS1 Hot Cam A4 Reprogramming
  2. Rebuilding engine to like new state
  3. LS6 Heads
  4. Cartek Stage 2 Heads and TR 224 Cam
  5. What cam should i get?
  6. LS6 Cam guys, please give me your valuable opinion
  7. any problems with bent pushrods in ls1's or trucks
  8. Should I change out my lifters
  9. Who's got a strong running 382 stroker?
  10. need help with heads
  11. all bore & nitrous.....
  12. lunati rotating kit
  13. LS6 block where to buy....
  14. Just got my sonic results...need advice???
  15. Backfiring at WOT over 4500 rpms
  16. heads/cam nitrous ?'s
  17. dropped a bolt in oil pan...
  18. 422 Shortblocks for under $2000 with forged parts?
  19. Help me pick a cam fro my 02 Z06-please!
  20. RMS C5 cam stock heads results!
  21. Short block assembly.....
  22. ASA cam times
  23. Help! Still got low oil pressure
  24. another cam question (Z06)
  25. Differences between TR and Comp pushrods?
  26. GM head gasket differences: 01-prior and 02-newer
  27. 383 stroker.... initial impressions
  28. Would an LS6 oil pan fit in an f-body
  29. Felpro head gasket VS Cometic - help
  30. Is this cam swap worth it?
  31. need some knowledge in here
  32. Flow #'s on ported LS1 heads? HEAD HELP????
  33. BBC valve springs on a LS1 ?
  34. Degree of advance for big cams?
  35. Stock crank on 383?
  36. How much does it cost to offset grind crank??
  37. Opinions on TR 224 and Yella Terra 1.8 ratios
  38. New shortblock question...
  39. Any opinions as to when to change valve springs?
  40. ASA Cam Question.
  41. Any updates on JPR's new cam tooL?
  42. How many cam only cars over 400? post up
  43. Comp 224/224 .581 Cam Dyno Results!!
  44. Whats the max cfm our heads can be ported to?
  45. LS6 heads vs 5.3L truck heads
  46. Cloyes timing gear- which mark?
  47. Block Clearances
  48. ARE Z/28 589 RWHP N/A
  49. Which spring do u guys recomend, Manley or CC918's
  50. The best cam for 382ci ALL-BORE
  51. New to the board...cam question fo L98
  52. LS6 blocks in 2001 & 2002s?
  53. rev 1116 spring question
  54. My ASA cam is in.
  55. Did I mess something up?
  56. Trashed a lobe on my cam..anyone else ?
  57. Gut the cats???
  58. Rod Length?
  59. power loss on holley, why?
  60. what would I see with this mods
  61. G5X2 Installed and running!
  62. Cam Question
  63. Good list??
  64. Cam timing hell, please help
  65. Got the car dynoed with the new cam...
  66. oil leak help needed
  67. GM SER-912 spring compressor tool
  68. A stupid question about the PCV system...
  69. Burning alot of oil since cam install
  70. LS6 oil pump>>
  71. Engine almost complete....
  72. LQ9 heads, how much?
  73. HotCam users inside
  74. X1 vs C2 cam
  75. Valve Spring tool for dual springs
  76. Cam sound and spec question
  77. Best cam for the job
  78. Hotcam & 1.8 rockers
  79. tune with cam question.
  80. What do you think the G5X2 will do in my LS6 ?
  81. Very confused about "2" things
  82. ARP head bolts
  83. FUEL with Heads and Cam >>
  84. what size cam?
  85. Anyone Have Their Pulley Off Their Car Right Now?
  86. CHS Stage 2 5.7L Flow Numbers
  87. Valve seal install
  88. Losing Coolant after Heads and Cam install
  89. Double Row timing chain And Pulley
  90. Cam Recommendations
  91. building engine...comb. chamber vs piston dish Q's
  92. ls1 vs tpi
  93. Can I use yella terras?
  94. New Engine Break-in Procedure
  95. Hotcam question
  96. ? Computer with heads??>>>
  97. S1 Cam too big? G5X-2 just right?
  98. What about this set up?>>
  99. Oil Pickup Tube Installed - See How I Did It!
  100. Will My 3.42 gear be ok for Tr224?
  101. ATTENTION - All registered members inside please.
  102. Installing ARP head studs, need help please
  103. At What RPM are you shifting H/C & Cam only Cars?
  104. Un-milled 5.3 truck head = what compression ratio?
  105. Extra Quart of oil OK?
  106. Are the stock pistons forged?
  107. How to install cam?
  108. Some help please
  109. 100,000 + Miles on the Old LS1
  110. '96 Vortech 5.7 w/ LT4 HotCam
  111. Stupid valve question
  112. Ticking after rebuilding engine
  113. REV or Comp Dual valve springs??
  114. Comp "R" lifter question..
  115. Anyone running a 5.3 oil pan with PA K-member?
  116. Self Porting your oil pump
  117. Double REV springs Vs. .560 lift cam?
  118. ASP and double chain, spacing problem?!?!
  119. 1.8 Rocker on Intake only???
  120. Info and advice appreciated on the LPE GT2-3 cam
  121. [Video] 388 big bore at idle
  122. Reading TR6 Plugs..
  123. Oil pressure sending unit... special tool needed?
  124. What is the compressed hight of GM head Gasket?
  125. Passed Emissions with 224/228 112 LSA Cam !!!!
  126. Will an MTI cam work in a truck?
  127. 5.3 heads or ls6 heads ?????
  128. White smoke out back, where to start....
  129. ? about ARP Main Studs and the oil deflector!
  130. How to remove timing gear from crank snout?
  131. How to check for bent valves???
  132. bare ls6 heads *DELETED*
  133. Harmonic Balancer Bolt?
  134. anyone retard an ASA cam
  135. Cam's List... help
  136. HELP I lost my oil 5 QUARTS
  137. Time to upgrade some parts, but what?
  138. Have to Exchange heads, HELP
  139. 224/224 110lsa 106icl cam dyno results, VERY HAPPY
  140. Lost in cam world!!!
  141. HELP Ls6 pass. side head leaking! sensor?
  142. Please Help Me: Oil Pickup Tube and SDPC Chain
  143. JPR 387 Darton Sleeved Motor on Order!
  144. ASA racing cam question???
  145. Knock, Rattle or WHAT???
  146. Major oil leak...Need input?
  147. Cam questions
  148. TSP 396 on Nitrous: 729.9 RWHP and 834.9 RWTQ!
  149. Low comp 422?
  150. Do I have too much preload? Not making good power
  151. *CAM ONLY* #'s
  152. [VIDEO] My 382 Stroker ..some ear candy for 'ya
  153. Who has high milage on their Isky 295D springs?
  154. new member
  155. 11:1 would be fine for 93 gas right? TEA 5.3's
  156. Update on P/V clearance with my H/C combo
  157. MTI B1 cam >>
  158. GAINS WITH TR224 OVER CURRENT SETUP?
  159. what is the best cam 4 me?
  160. possible new set up ??'s
  161. CAM ?
  162. Newer cam grinds (on 114LSA) to replace TR224
  163. Can 2.02/1.60 valves be put in 5.3 heads?
  164. Bigger cam = Better ET's in my car?
  165. Tapping sound at idle, now at cruising speed
  166. Anyone use Crower valvetrain parts?
  167. stock injectors with head/cam setup?
  168. 4.8 heads compression ratio
  169. Hammer Cam
  170. Timing chain and/or Ported Oil pump necessary?
  171. difference between ls1 and ls6 heads
  172. The 2001 ls6 cam
  173. Milling
  174. ARP head studs, need help please
  175. Purpose of LS6 valley cover??
  176. Bolting in a LS6 >>?
  177. G5X2 cam question
  178. Ready to re-install my lifters any special tricks?
  179. 4.8 Vortech heads
  180. ASA Cam
  181. *-Stock head specs-*
  182. Safest compression with 91 octane
  183. Dyno Results - TEAS2 Heads and Yella Terra Rockers
  184. Ed Potter and Cartek
  185. Crank Bolt for UD PUlley
  186. '02 & Up Z-06 Cam Technical Discussion--Cam gurus
  187. How to assemble a short block...
  188. Quick - need advice on how to clean intake ports
  189. To late for h/c mods?
  190. Valve Spring Change Question
  191. Z06 cam question
  192. Oil pump O-rings - part # please?
  193. Cam Q's
  194. Absolute StgII Ls1 + TR224? Got numbers? (prf A4)
  195. How much to mill for 11:1?
  196. 580 lift w/stock heads,manifolds? What et's
  197. Cam question, REF: Roller rockers
  198. How many guys run 11:1 CR with their heads?
  199. Engine Removal Guidance Needed
  200. Cam and Headers With Stock Tuning
  201. TR224 RWHP Average with stock heads
  202. Login problems? Step inside --->
  203. Yella Terra Rockers don't bolt in direct 97- 98
  204. Higher RPM?
  205. Cam specs for 02 LS6 motor, opinions?
  206. More Performance Valvespring tool?
  207. Knock Sensor TSB?
  208. Couple of newb questions
  209. 98 valve covers wont fit 5.3 heads right?
  210. 98 motor
  211. Sources/cost for Oil Pressure sending unit
  212. Oil Pickup Tube and Double Roller Timing Chain
  213. Compression Question - 5.3L Heads...
  214. Maximum valve lift for stock 2002 LS6 Valve Spring
  215. Picked up 52rwhp with MTI C2 cam!
  216. G5 cam and which heads?
  217. 02 WS-6 Dyno #'s within!
  218. f1 cam
  219. Can the 2001 LS6 cam compete with 2002 LS6 cam...
  220. Useless information to anyone who cares....
  221. Recieved My cam today from COMPCAMS, have question
  222. Question about the original G5 cam
  223. Whats the stock 241 casting CC numbers?
  224. HeadBolt ? please help
  225. Springs for X1 cam?
  226. engine builders needed
  227. Picked up some YellaTerra Rocker Arms today!
  228. low oil pressure, possible causes??!?!?!
  229. 1998 Block
  230. Motor Installation Question?
  231. Want a Powerful but Safe Cam
  232. Weird, chirping noise..pls look at description...
  233. Compression
  234. Where to get oil pump O-Ring?
  235. Best CAM only or head/cam combo?
  236. New LS1Tech software (identified BUGS)
  237. Polish, not porting, stock heads?
  238. LS6 CAM DYNO
  239. Lunati Engine Kits
  240. Need opinions on doing sponsors a favor
  241. Do I need different pistons with my heads??
  242. Where to set the gap with Diamond rings @
  243. LS6 Block? How Do You Identify One?
  244. Install Head Gaskets Dry?
  245. 226/234.554/.575 112LSA - Works w/ stock heads?
  246. Need some suggestions.......
  247. Today is the day! Old motor is coming out and....
  248. New LS1 owner has a plan
  249. 6.0 heads
  250. Joe Prince, your help is needed
