- LS6 Block? How Do You Identify One?
- Install Head Gaskets Dry?
- 226/234.554/.575 112LSA - Works w/ stock heads?
- Need some suggestions.......
- Today is the day! Old motor is coming out and....
- New LS1 owner has a plan
- 6.0 heads
- Joe Prince, your help is needed
- Turbo Camshaft& Max cubic inches out of a 346?
- bigger valves
- TR224 112 dyno numbers
- what to get, (experience needed
- differences between manifolds
- Changing out the Total Seal Rings seemed to fix it
- GM CNC Ported LS6 Heads Flow Number Wanted
- Milled Heads and Spray
- will this combo work?
- lifter / p-rod query...
- Need Part # for updated LS1 PCV valve
- I was wrong about my TR224
- piston slap when warm?
- 11s on stock heads?
- Hi..im new here.
- big cam stock valve guides
- Finished Heads/cam, car starts but leaking oil
- Help Choosing Pistons
- Anyone have that list of XE-R cam specs?
- TR Cam Users Come help!
- LG Motorsports
- base circle
- noise vavle train after racing!
- oil pump pickup tube oring??
- Which CAM to buy?
- HP Guess?
- What cam to use?
- TEA STAGE II LS6 HEADS
- solid motor mounts
- Bottom end, who has broken what and how?
- head ?
- Ultimate "bolt on" combo?
- Hotcam install in a '02 Z tomorrow, question re...
- When torquing heads with ARP studs.......
- Is my car timed right?
- Stroker guys, what rods are you using?
- Cam suggestions for a 382 Stroker.
- Question about the same Figures but different vend
- How many miles might I get out of my LS1?
- LS6 block in F-body
- damages to check for after a blown head gasket?
- Info on getting heads Milled
- Can't get on ls1howto.com...
- Porting my own heads, tell me if this is good idea
- NEED HELP PLEASE!!!
- Most aggressive cam for my 436
- Shimming oil pump to .100
- quick B1 cam question
- Which part # for Crane solid lifters?
- Tell me all about the MMS230/230
- rocker noise
- guys with 5.3 heads and 987 springs...
- ALL ABOUT CAMS
- Need SDPC double timing chain help!!!!
- TEST Forum 1
- TEA 5.3L S1.5 owners
- Pulling an engine question
- Maximum safe oil capacity in Corvette?
- new dyno #'s......
- Please Any Advise is better than none
- AAP 388 baseline dyno results 487 rwhp/457rwtq
- Offset key??
- HELP! Cam question related to P/V clearance issue.
- Building for Boost ?'s
- Boring the stock block, is it possible?
- bad port work?
- How Can You Tell If a Lifter Dropped During the Cam Install?
- Valve Stem Seals other than GM?
- What gaskets/bolts are needed for head swap
- can this really be done??
- Is this to big?
- Is there a freeze plug that is behind the timing cover that causes lost oil pressure?
- HELP! need input on building motor
- Site is going offline 4/25 at 11:30 for software upgrade
- GMPP LS6 Heads? Are these any good?
- New internal engine tool !!!
- Will ported heads with a stock cam pass emissions?(CA)
- Anyone running the chs heads?
- Does anyone know how much a stock crankshaft weighs???
- What percentage of new head purchasers - 5.7 or 5.3 no matter the vendor??
- For ls1(5.7) heads milled .030 - what compression?
- Cam swap- new lifters required??
- LS6 Vs. LS1 retainers interchangable ?
- Opinions on my H/C setup?
- HELP! 14 out of 16 springs swapped, LOST retainer!
- dyno numbers with LG G5X-2 cam
- Post cam install power loss...
- How much clearance should the piston have in the cylinder?
- Cam Lift... How much is too much?
- TR 224, how can you tell?
- Snapped a knock sensor clip....
- stock springs on a 02 Z28
- 5.3 heads for a daily driver.
- Well, had to chose which head gasket to use........
- Milling heads (5.7 or 5.3), and ability to run on 91?
- Newbie who needs some advice desperately.
- I need to change burnt valve....help
- What is the weight of Empty LS1 block ?
- PCV Vent hose on Drivers valve cover
- valvespring change w/o compressor?
- plz clear this cam issue up....
- valve upgrade
- NEED HELP FAST! fan temps and air/ fuel
- 45,000 should i check or replace anything
- How to questions for using ARP head-studs
- piston question?
- 6.100 vs. 6.125 Rods-Pros/Cons
- what cam do you guys think i should go with?
- 5.3 or 6.0 heads
- 5.3L heads ?
- Cam,springs & header install time
- JPR 388ci all-bore initial dyno results
- Soo, the shop thinks my engine blew a head gasket... *DELETED*
- ASA Soundclip
- Thunder 224 cam only numbers
- cam dyno graph of a 2002 LS6 cam?
- Valves???
- How far can my heads be milled with a C2 cam?
- advancing cam timing...
- suggestions for either stock or big bore build up
- motor went
- Who is running Yella Terra rockers?
- 5.7 TEA HEADS
- Indented piston, what next??
- What CR does a .025" mill off a 5.7 head give you
- Some f-cars may have an ls6 block
- I know this isn't internal engine but...
- CC 224/224 116-118 lsa possible w/ TEA 1.5 heads and stock pistons?
- super high RPM hydrolic cam
- Best heads and cam for 02 z28
- LS1 Knowledge
- Alignment pins in manifold - milled heads
- 11.1 compression to 10.5?
- Cam?????
- I need a cam that will work with my Nitrous
- Oil Pump ?
- HELP ASAP PLEASE
- New cam help....ICL
- M2 and stock heads dyno #'s
- What Is The Difference Between '99 and '02 Valve Seals??
- gasket set question....
- How hard is it to change valve springs on F-body?
- why are my lifters collapsing?
- how to post sound clip of ASA cam
- 01-02 F-body owners read this
- How Much HP can MY stock motor Handle?
- ATTN:11BRAVO
- Pen magnets not pulling out of pushrod hole?!?!
- F4 cam with 918's
- HELP. Installing hotcam's LS6 springs and shims don't fit?
- If you have changed out your knock sensors, inside please
- 6.0L heads part number?
- Couple of question in ONE TREAD.
- Plug Gap and Pinging?
- New Cam Bearing ??
- Porting an LT1 head vs. LS1 head...
- offset ground crank owners....
- Is there such a thing as a bad bore/stroke combination?
- Just ordered TEA Heads
- what cam to use????
- low oil pressure
- Spun a rod bearing and bent the crank :(
- a tapping sound coming from....
- 5.3 what does it take to make them worth while??
- How does Intake and Exhaust flow on heads effect...
- CR on a 382 Stroker.
- Tell me how to replace knock sensors.
- What gaskets should I replace?
- need web site with oil info
- shims with springs
- Valve noise with TR 224
- 1998 camaro ls1 stock cam specs?
- hey, what do you guys think about this? Opinions, please
- Can 98 blocks be resleeved as reliably as 99+ blocks?
- OK to dab keepers in grease during install?
- Low Oil Pressure after cam install
- Burnt piston ----- pic inside !!!!!!!!!!
- ASA Cam and LS6 Springs
- G5X-2 Cam - PTV
- Lets see your Absolute Speed Flow Numbers
- 1.8/1.85:1 Roller Rockers...Yea or Nay?
- home built vs. sponsor built engine ?
- anyone tried mti"s S1 cam grind in a lunati 383 stroker ?
- Biggest Cam on 346cid?
- What pushrods to use?
- just installed new cam WOW!
- Stock Bottom End Reliable?
- what else with a H/C package
- New h/c Dyno #'s
- should i get slicks and skinnies or a cam first?
- Head bolt broken and stuck
- What will this sound like (CAM)
- Part 2 on H/C install
- LS1 vs. LT1
- lifter differences?
- Cam only results 2001 A4 Vette with G5X-2
- using 6.0 heads on a 346 block?
- Rocker arm upgrade worth it??
- Prolly a stupid ? here but ...
- Clean new cam before oiling and installing?
- 224/224 .581/.581 112 LSA, 918 Springs _ Springs Service&Maint.
- Help me pick a cam
- Schubeck lifter users, come in please!!!!
- Has anyone done a back to back omparison between the 224/581 and the F1/X1 type cams?
- New motor break in....
- PCV fitting on center bolt valve covers
- Is it ok to use the 3M Rolock Cookies to clean the deck (block)
- What's the best cam
- Big bore, short stroke, long rod LS1
- ls1 timing chain noise
- MTI X1 Cam Impressions...
- need help with passenger side valve cover
- engine balanced... got specs
- Who has before/after dynos or track mphs with juts cam change?
- Need some help picking a bigger cam...
- Need help: Low oil pressure
- Driveability with the new LG 2x cam..
- I've got the broken rod blues...
- bolt holes behind oil pump?
- Boring a 5.3 to 3.905
- needle cam bearings???
- Would LG's G5x2 cam work well in an A4?
- What are the specs on the G5x2 cam?
- Attn:C5 owners-cam install ?
- Just received my stage II heads today...:)
- are dynaflo rods on ebay worth buying?
- Help!! Reading that MTI H/C thread, now I have a question?
- Need some predictions on a Cam
- uniform valvetrain?
- Ported runner size?
- heads and 6.0 block question
- TEA or Absolute Speed heads? Which ones
- G5X-2 Dyno Results
- Will the idle on an X1 be a lot harder than the TR224 112lsa?
- Big Cam LS6 question
- '02 LS1 Cam specs
- what engine bearings to use?
- Where to get 6.0 block
- Cam only A4's who now have heads: few ?'s
- Rod Bolts
- 388 "Big Bore" is in!!! Thank you AAP!!!
- LS6 and LS1 heads intake ports short side radius and floor diffeences
