- 228R Shift Point?
- Proform 67605 valve spring tool
- BBK intake MAP instal?
- Another Ticking Noise thread, Please help :)
- Reverse split. Exhaust question.
- Who ports TFS 220 heads?
- who's car is this
- just beginning
- LS1 to LS2 swap...
- Vented oil breather, compression question(s)
- valve springs too stiff?
- Educated on cams just curious other memebers input
- LS engine building. Engine builder told me I couldnt do it.
- LS6 HPDE/road race engine build
- MS3 and 42lb injectors & stock heads
- ls1 in 68 camaro
- 98 z28 with a blown motor!
- Head/cam/stall.... Help
- Finding tdc without air
- who installs cams??
- fast or victor
- 317's on Ls1 block.. How Far Can They Be Milled?
- help on cam and heads
- Wanted Fast Intake! LS1
- tu1 cam question
- Help identify this valve lock and retainer
- Which LS1 header gaskets to use?
- Budget 408 Build
- Slp stage 2 heads?
- Camshaft: '99 LS1 vs. '01 LS1
- Head Recommendations
- New to the LSx from LTx need help with my LQ4
- Heads/cam build.
- How to calculate IVC @ABDC?
- Crank Pulley Install Tool, Who sells it?
- Anyone run LS6 Z06 heads up with LS1 6 spd both stock?
- unsafe oil pressure
- I have a rotating assembly, but can't find a shop to machine/assemble it
- is this a bad cam mfor my setup?
- 800 hp lq9 supercharged
- Ticking noise
- Why LS7 lifters?
- timing chain broke?
- "Requirements" for 215cc heads?
- Running way too hot (yes I've searched)
- cooling
- Possible forging the motor...
- L92 head gasket reuseable?
- What pushrod length?
- Oil pressure issue on new car
- Quick stock cam question
- Valve issues
- PRCs/AI 243s/Dart Pros??
- Question about changing pushrods…
- 5.3 heads
- 243 haters...
- 6.0 heads on LS1?
- Help
- ok so I would like some opinions.
- head question
- I Need some advice...
- need help asap!!!!
- How to tell Engine code by the block on a 5.3??
- quick ? about teardown
- Any problems with a 98 ls1 vette block?
- matching 85mm typhoon to 862 heads
- Critique my Head/Cam Build
- switching 853 heads to 806 heads
- Thinking about switching cams.
- questional rod bearing
- very dumb question...
- lunati 60516 cam ? Good Cam ?
- Dyno Chasis Tuners
- How bad should an LS1 with a cam shake?
- How bad should an Ls1 with a cam shake when it's idling?
- What to or what not to reuse?
- Texas speed help????
- first ls swap cam suggestions
- Gas question?
- need a kit for rings, bearings, gaskets.
- Isky cams
- Dart Pros vs Ported 243s..Cam choices?
- Broken Torx T-40 Cam Retainer Plate
- Stem Seals
- 500Hp goal to the wheels Need Help!!!
- rocker arms
- identify this block please.
- Who has had problems with SLP LS6 Ported Oil Pump?
- lq4 teardown - how far do I go?
- Will this block still work?
- Cam swap, what am I forgetting?
- Piston Advice
- New Build Questions
- 00 WS6 Overheated, what damage to look for?
- tightening ARP rod bolts... torque vs. stretch
- Oil pressure not rising with RPM
- 408 wont start
- Melling oil pump question
- Lifter Failed
- 98 camaro z28 trying to swap 99 ls1
- P0151 killing me !!!
- Anyone run A.I 243's with a A.I cam?
- What do you think of this?
- good budget freindly forged pistons?
- Broken ring land result,whats your opinion(lot of pics)
- How does valve angle effect performance
- Low oil pressure after nitrous backfire
- Considering a Lunati cam in LS6 (60516)
- help!! bad vibration!
- Time for a small stroker
- Chirp from exhaust
- Identify this bolt from photo?
- Inspect the bottom end?
- All cam gurus and ppl familiar with the carcraft LQ4/L92 build come in!!!
- Questions about VRX5 and SI5 cams
- how I honed my block, w/ pics
- Ls3 maf
- stage 2 ported 241 heads
- LS6 connecting rod part number
- LS1 cam options with these heads. I think I got bad info....
- ls1 - gen3 block confusion.
- should i deck the heads or not?
- Oil light came on, now no oil pressure
- Can this be a blocked CAT?
- Which bolts should I replace?
- Cam install gone wrong
- ls1 bottom end ?s
- zero lash....dummy question
- ls1 cam tool won't go in
- Looking for a parts list with part #s for Cam install on Stock LS1 plz !!
- Aluminum 6.0 Blocks
- What valve spring is this?
- lq9 or not?
- 5.3L Cam Specs?
- Oil Pump Install Question
- ls1 ls6
- How do I install my con rod cap?
- Need reccomendations for a super smooth DD WDNK (wife does not know) Cam !
- water jackets clogged?
- Afr heads
- what is the differance LQ4- LQ9
- rocker arm torque specs? pushrod length?
- new to ls motors need suggestions
- Serious Coolant Leak
- Engine Block Digitizing at TSP!
- TSP Torquer V3 Cam only application
- How to get a 6.0 to 500 rwhp NA without a stroker.....
- Trex guys, what did you down grade too?
- Help!!! Asap
- Car randomly falls on it's face while under load!
- Anyone interested in a Corsa Cat back?
- Cammed Z28 sounds terrible
- ok heres where im at with this whole H/C/I thing
- Starting an Lq4 build
- Windowed ls6 block= total loss?
- Help Identify Parts & Pieces LS1 Compressor
- Compression Test or Leak Down Test
- Darth Vader....Your LSx Stroker is ready!!
- best tool for replaceing springs in vehicle?
- Ram air hood and throttle body
- ok guys... really need advice!
- Cam swap questions, need a little advice
- Kooks headers on TSP website
- 5.3 build (In a bit of a pickle, dick)
- LS3 heads Will they work
- Ls1 cam
- lets play: whats in my cooling jacket
- GMHTP Lunati cam
- parts numbers check please..
- rotating assembly with billet rods rated at 850whp?!?
- ls1 aftermarket cam question
- Spun rod bearing - no oil?
- ls wiring help
- Can i reach 450 rwhp on pump gas with my set up ???
- Valve Clearence???
- 11 Second Potential Recipe for DD
- camming a truck
- Question on valve stem seals and valve stem seats
- Does anyone have info on this forged stroker kit?
- Loud noise from driver's side... Vid included
- LS1 to LQ4...what all is needed?
- 2001 T/A LS6 Build.
- 408 build
- Local Cam Installer
- im missing the low end grunt
- HELP!! Temp sensor going crazy!!
- 2000 trans am 6.0 f1 build
- Water injection N/A?
- ptv clearance issue? rod bearing? engine knock/tap
- How much to shave off heads?
- 799/243 heads
- Heads
- victor jr setup
- Comp r lifters
- LS2 vs LS1 Lifter Trays
- how to tell the difference btw ls7 vs caddy lifters
- ls1/ls6 builders in Pittsburgh
- Valve Spring Retainer Question...LS1
- 98 ls1 to 04 6.0
- g5x3 with tfs 215cc?
- Who's running the Vengeance Racing head/cam package?
- Drivability Issues on 5.3L CANT FIGURE IT OUT!!!
- 5.3 to 5.7
- stock injectors ok for now with this combo?
- Mixing oil question
- Overheating Concern
- Is this LS6 motor good for street and pump gas?
- Stuck LS7 lifter...
- low oil pressure high rpm under load
- 5.3/6.0 block dimensions the same?
- Sparkplugs! Im pissed!!!!!
- 460 rwhp ?
- Going with Geoff at EPS!
- 5.3 heads vs ls2 heads
- 331" De-Stroked LSx.. 8500 rpm??
- bottom end build question?
- Anyone running FM-16 cam yet?
- 90mm tb on a Ls6 intake
- lq4 build almost done...rod question?
- Cam opinions for stock head/full bolt on LS1...224/224?
- when to tune your ls1???
- Forza 3
- Thinking my bird has a broken wing :(
- 706 heads
- What DCR?
- Cylinder Head Help
- torquer v3 questions
- Pulled some spark plugs what do they say?
- what year LQ4? and should I swap the cam for my setup?
- Cleaning MLS head gaskets
- SD guys. What size piping are you using to replace MAF?
- Is this a good cam for a TVS 1900?
- Are Injectors necessary for EPS cam only 222/222 115 +3???
- Ms4 cam and heads setup questions
- tick...tick...tick...
- pushrods?
- how do i know if i have an LS1 or an LS6
- LQ4 Build questions
- which injectors should i go with my lq9
- questions aboout my arp bolts
- Could installing cam only increase crank case pressure?
- Newbie to bottom end builds!
- Looking into a rebuild but I want to know if i i am doing anything majorly wrong
- Oliver SBC rods??
- what injectors
- Update for my car after spark plug wires.
- Anybody know the part# for new valve seals for 806 castings?
- oil around intake ports
- Does anybody use eoic method for adjusting valves on ls engine?
- main bolts?
