- heads,cam,and bolt ons= how much hp??
- **CAUTION** PEN MAGNETS **CAUTION**
- Eastside Performance cars?
- 6.0 HEADS WORTH IT?
- Help, found spring in oil?
- TSP 396 Off-Set Stroker Dyno Results! ! !
- Question: Can the rotating assembly be balanced....
- Turbo 400 behind LS1
- 383 stroker or allbore?
- Biggest cam with .055 milled heads?
- Some simple cam questions...
- Someone please tell me what u think
- warning to those flycutting with the isky tool
- 02 Silverado
- B1 installed, questions
- SLP timing chain/oil pump clearance?
- Who knows of a cheap valve spring pressure tester?
- Well guys burnt some plugs on Nitro and guess what.....
- I NEED A LS6!!!
- pace performance ls6 conversion package
- Can't find pen magnets, HELP!!!
- Are these heads too much?
- do I need to hone the block?
- Removing crank timing sprocket?!?!
- hot cam
- Does an LS6 cam require different pushrods with stock heads?
- long tube header problem
- If you had to speculate....
- BLOWN LS1?
- ARE Cast intake, pics:
- ARE 393 All bore is complete!!
- Started car with 227/227 cam tonight!
- tapping / ticking after broken spring
- How much rwhp will I gain with TR224 cam only?
- Valve spring life
- Getting rid of the EGR SES light without LS1 Edit
- Anybody done a leak down test on their engine?
- Valve Springs / Cam Install
- 360rwhp possible with TEA Stage 1.5 5.3L Heads/Hammer Cam?
- Going to mod my WS6 heres my list
- Converterting 422 to solid roller; what size cam?
- I drive 60miles a day...would it be bad to get a cam?
- Going to replace rings and go solid roller; what else do I need?
- Cars with aftermarket cams
- 5.3 Heads
- TR 224 on 346....what on 383???
- Finally Dynoed the new set up
- MAF drop after head swap????
- Parts needed for cam swap
- ls6 cam swap
- Does anyone know the stock piston weight..
- cam of choice for auto-trans
- Oil Catch Can???????
- GM 2002 ring and coated piston set?
- Another cam question
- ls6 cam,emission legal?
- IRON BLOCK BUILD UP
- return fuel line for Z28's
- ported LS1/LS6/6.0L heads between GTP and race-prep, who is better?
- Split/ Reverse- split or "standard".... have some questions
- Any way to prime motor and get oil pressure on fresh motor before starting it?
- Heads freshened up and flowed today...BIG THANKS TO JPR!!!
- Excessive Crank Case Pressure - Need some Help
- redline water wetter
- Help! Piece of Lokar Oil dipstick broke off in block, how to get it out??
- Adv. duration??
- Heads/Cam break in period... (what oil to use Dino or Synth? and weight)
- 6.0 Crankshaft Help Please
- TR230 cam sheet?
- I use Redline 10w40, any reason to switch?
- Radiator backflush question....
- MTI B1 cam?
- Rebuild / Engine Swap ??'s
- Spark Plug Reccomendation
- What cam is right for me
- how do i clean motor out after cracking heads?
- what are these heads worth?
- I can't seem to find what I need to keep cylinder compressed
- Analyze my spark plugs and tell me what is going on....
- cam swap
- LS1 block ... 2 bolt main or 6 bolt main?????
- TR224 OR C2?
- LS6 Cam WOT Impressions
- does anyone have a 227 w/ a 113lsa??
- Need help, SS won't stay running
- Lobe seperation 112+ 2
- It's a done deal now.....
- Will this net me what I want?
- New Cam for AAP 388 all bore - 243/250 .610/.612 114 lsa
- Cartek X package?
- Heads/Cam experts, spend my money!
- what piston rings are you guys using?
- TR224 - 112 or 114 LSA?
- Any difference between 2001 and 2002 LS6 springs?
- Can I mix 5W-30 with 10W-30 ?
- oil pressure problem
- Is it okay to REMOVE head bolts with air tools?
- Has anyone heard about the new intake manifolds from Vararam and Cartek? +50HP ???
- ARE 440 CUBE SOLID ROLLER
- All things being equal is there a difference in idle from .56x lift to 58x lift?
- will 2.02/1.575's fit in stock LS1 valve seat's?
- Please tell me how to identify ls6 heads from ls1 heads. (by looking at a set)
- *** Question: Need help!!!!
- How do I get the crank gear off?
- Wierd PCM issue, looking for info
- LS6 Cam Initial Impressions
- pushrod length
- eric here is the link i told u about
- Comp 947 springs...
- 6.0 block
- Help- Finally took apart blown LS1/noticed Piston is very tight on wrist pin......?
- Support bits for a GrandAM Cam
- Took my Car for a long ride with TR 224/112 cam...
- T1 Question.
- valve seals
- any problems running LS6 springs, stock cam?
- Help me chose please. H/C setup
- How long have your 918's Lasted
- Low Coolant Sensor
- How much can you bore an ls1?
- Age old debate: Hotcam v others...
- what size spring shims with hotcam kit?
- Some New Comp Cam Grinds
- completly stock except cam?
- Looking for TR230 cam or similiar
- What are some of the largest cams in, and highest HP 422s you have seen/ heard about?
- Rear main seal
- has anyone ever heard of street arsenal
- How long does it take to get a custom ground cam from Compcams?
- Start cam install in the morning, damn I'm nervous
- Anyone using the Rev dual valvesprings for stock valve pockets?
- new cam info....
- 500 RWHP - LS6 or LS1
- Need Help ASAP!!!! Antifreeze leaking from back of block??!!??!?
- New LS1/LS6 Book
- Anyone know where I can find...
- WTF is this vibration
- need advice on a good cam
- polishing out CNC gouges/cuts?
- LS1 style heads on old motor
- G5x2 cam----> any valve train noise?
- Please evaluate suggested cam....
- Update with my car
- Absolute Heads and Cam installed
- Rocker Arm Questions
- Want to change my CAM again, NEED YOU HELP.
- LS-6 heads on a 5.3L (combustion chamber sizes)
- TR 230, do anything with plugs?
- Do titanium retainers "wear out"?
- 408 combo/hp/heads
- 425/411tq stock heads/G5X-2 cam
- Top End Off, need help diagnosing issue
- P/V clearance opinions
- Block is being done. Expirenced engine builders w/in
- Where did you buy your Hot Cam from?
- Car's coming out of storage...
- Identify LS6
- Valvetrain noise after pushrods replaced
- Update on my situation... still problems
- Legal Cams in California
- pre-load on hyd. lifters
- Replace valvesprings before roadtrip?
- 226/575/114 IN AN A4 WITH 3.23S?
- for you guys with H/C need advise
- What do you think about this cam???
- ASA CAM
- LS6 Block, anyone have a part number
- Anyone have a HOTCAM sound clip?
- Are these 2003 CNC ported LS6 heads worth this deal?
- Thinking of moving to a bigger cam....
- New short block break in?
- How hard to install double springs on stock heads?
- Goin' for a cam!! (and other goodies) .. Is this too much?
- Ported LS6 Heads and TR224 dyno #'s
- Are LS6 heads really like a stage I or II LS1 head?
- 228/228 .588/.588 112 Cams Power Range and Shift Point?
- Cam Q for 500rwhp motor
- exchange heads in car?
- Picked up the car from Speed Inc today...
- Any Dyno Predictions?
- Cam Question!
- Check out what I bought instead of....
- New Dyno #'s.... heads, C1, cutout
- pushrod lenght,, whats the deal
- Lingenfelter GT1 cam....
- THUNDER CAM IS IN!! THANK YOU JOE PRINCE AND TOM!!!!!!!!
- Andy's Auto Performance 388 (pictures)
- My Camaros S2 Heads and experimental "cam only" dyno report.
- oil and buildup on spark plugs
- stroker ?
- 6.0 L Combos?
- Knocking
- Who says a big cam cant pass emissions!! (Thanks ARE!!)
- cam is in!!!.....
- Question on LS 6 block in F-Body
- G5X-2 Results for an A4
- Post real gains from heads/cam swaps!
- What Parts are needed 4 Head install?
- Best cam for blown 382?
- Build up on valves, disassembled top end...also new cam?
- Looking for Help
- Hotcam powerband questions
- Need some HELP please...Car idleing weird
- !!!!! PATMAN!!!!!!! Kendall Oil!!!!
- Jackson Auto Machine.com
- high mile motors???
- What is the most power possible out of a 346 Hyd. cammed engine?
- Installing cam in 2000 Z-28
- MAX HP STOCK BOTTOM END
- Max valve lift possible without machining in LS1
- Spring Heat Cycle Question
- MTI 475HP HEADS AND CAM PACKAGE
- Does a cam need to be broken in?
- Anyone deal with Norris Motorsports in Orlando?
- Dyno results from my first cam install.. TR220
- comp cams rocker arms on HP Tv
- Which ram air kit for my 3.8 camaro?
- LS1 head porting suggestions
- TR224 installed, Questions!!
- Spring installed height HELP?
- GTP S2 & TR224 dyno results
- What Cam for my A4
- starting a buildup
- Lets talk head flow
- Futral Motorsports Cam ?
- Crane Cams/Lifters
- About the Knock Sensors
- How do you tell bad springs?
- springs..
- Thumbs up to MTI!
- Paging all members who live in Pearland or surrounding areas
- 99 TA...getting 5.3L heads..what gaskets?
- TR220 or TR224 @114?
- Anyone running High Boost #'s on an LS1?
- TR 230 untuned
- 6.0 Truck heads... how much better than stock LS-1's?
- Oil additives-yay or nay
- HOT cam sound clips
- Engine noise, compression test and HELP!
- speedtek F1 cam
- LS1 to LS6 PCV system conversion howto inside
- Hot Cam user inside please
- Installing 918 Springs, Installed height is wrong, where to get .015 shims?
- Cold knock
- Oil Pumps for Big bore engines
- Dirty cam - heads up
- LT1 Head Swap instructions needed!
