- valve train noise
- G5 cam???.....
- what are the best springs, hands down?
- For those who think they have blowby > Easy no-tools Check >
- 222/224 566/568 lift 112LSA
- My Camaro's S1 TR224 cam dyno numbers
- I now know what it sounds like when pistons hit valves.
- I need some quick cam help....
- 5.3, 5.7, and 6.0 Head Casting Numbers
- Gains?
- CR on 5.3 heads
- Head Porting Tutorial
- Time to change my C1 cam??
- double chain
- New cam and lifters installed, now it sounds like a diesel!!!!!!!
- ARP crank bolt for the LS1:
- H/C installed Flow and Dyno inside!
- What Heads & Cam best for my 422 shortblock ??
- MTI vs. TR for spring durability?
- Down to the wire:
- Help me read my campro print out.
- GrandAM cam and support bits
- After cam install. What's the "proper way to recharge AC system?
- dual spring dampeners neccesary?
- Early shifting problem, possibly cam related? Please Help.
- Intake manifold idea....
- LS6 cam/springs question
- grand am cam
- AC Not working. May need new compressor.
- Would a C1 cam be OK for Blower use?
- ARP Head studs.What lube for threads
- 5.3 heads??
- Advertised duration vs. duration at .006?
- FELTON316-Oil pressure
- Why is the PCV valve grounded?
- Anyone know the Comp Cam 228 XE-R?
- Should I trade my TR224 114 cam for a TR224 112 LSA? Anyone else want to trade?
- LG G5X2 GAINS?
- Poor idle with TR220 > Anyone use Thunder's mail order tuning?
- I NEED HELP!!!
- 5.3L Heads
- High Idle and Oil Consumption Issues
- HPPIII???
- Contimplating bigger cam??? like advice
- INSTALLED G5X-2 ....OMG!!!
- how many have done the 02 Zo-6 cam
- Need suggestions on what head/cam package to go with.
- C5R Block
- 222/226 .566/.569 112 ??
- Help me pick a cam!!
- Total engine airflow users dyno results...
- hemi heads on LS1?
- Aftermarket Heads for LS1
- Help with ticking noise.
- What do you guys think about this cam?
- pcv ?'s
- need some serious help...
- Heads/Cam Combo
- head flow and cam duration disscusion
- 5.3L or 5.7L stgII heads....which would be better?
- Bore or Stroked which works better with nitrous?
- Titanium retainers Vs. weight of double springs
- Decisions ...I need some help
- Comp Cams LS1/LS6 Shaft Rocker System ??
- what to expect?
- Absolute Heads & Cam here tomorrow!
- Are new valve cover gaskets necessary?
- Cam ?'s
- 5.3 Cam????
- what size drill bit to use on my TB to make a 5.3 idle
- ? about heads/cam
- does anyone have problems w/ their engine w/ a 224 cam?
- HELP bought used cam and cant find correct part #, hotcams owners come in
- What do you guys think of AP-Engineering 383 Shortblock?
- Loss of HP
- Stripped oil pan bolt? quick fix?
- 6.0L heads with 5.7L gaskets
- What do I need to put 5.3L heads on my 98?
- 224/228 .581 .588 inputs?
- Roller Rocker upgrade question
- piston dia. measure
- Which CaM??????
- 6.0 Liter truck heads
- sorry, another cam question.
- ls6 Intake swap -- oily mess (pics)
- hydraulic vs roller setups?
- jesel street/strip roller rockers
- Dyno tuning results and major props in here...
- Bushed Lifter Bores
- A4 Cam Question.... Help
- 6.0 head gasket PN for the GM MLS gaskets?
- THINK I HAVE A PROBLEM W/THE MOTOR???????
- cam in and now the valve train is loud as hell
- max 99' block bore
- Got my dyno numbers
- Anyone try coating their valvesprings?
- Question about Comp Cam 224/224 .581/.581 112 LSA?
- What cam to buy??
- G5X2 with stock manifolds
- What are the advantages of...
- G5X1 or G5X2 in an a4 car
- What is cost of getting a block bore'd?
- Do you know A.R.E. stage 2 flow #"s ... ??
- I need help with a timing gear(s?) quick
- ARP head stud users inside...
- Can anybody tell me what compression this setup would give me
- help with cam swap
- What would you do?
- Is it possible to Over-Cam an LS-1??
- Dyno Guesses w/C1 Cam?
- Trading Duration For Lift ?
- Head Swap Question
- Parts needed
- porting oil pump?
- Cam and lifter surfaces disintegrated
- G5X2 stuff + Quench height?
- Paging LoNSlo or anyone who knows him...
- Max flow numbers ?
- What Cam should i get?
- 5.3 casting number?
- cam suggestions??
- fitting grand am cam into aussie ls1
- Do I have a blown head hasket?
- Aftermarket or stock pushrods?
- MTI T1 Users Please Come Inside!
- head flow
- Cam only going with ported heads ?'s
- If you've broken a rod bolt ever, come on in....
- Difference betweeen these 2 cams
- need help ASAP
- is it time for bigger injectors?
- what sort of power to expect expect from MTI B1 cam?
- Build Me an Engine!!
- I can't believe it lg 's stick is bigger than mine
- stupid question: What causes a dyno graph to have a spike?
- Mike Norris building my 382 Stroker...what to expect?
- FI cam gains without FI?
- What will be my rwhp be with a comp cam 224/224 .581/.581 112 LSA?
- Need help Finding tools for Heads and Cam swap.
- Started new motor. heard loud noise
- LS6 cam question
- cam only progress
- Glenn's G5X-2 Heads/Cam Dyno
- Total cost of a H/C setup?
- not sure if this goes here...
- Best shop for engine work in WI
- G5X1 stock heads - NEW numbers
- LS6 Head Porting & RWHP help...
- 1.8 Roller Rocker Questions
- Rapid Motorsports Stage 2 Heads and Cam
- Will switching to the ASA Hotcam give me 20 more ponies over my current set-up?
- Need help with valvetrain choice!
- Cam and header install. How Long?
- Anyone use MMS stage II heads
- Who has the best heads hands down?
- Now that the secret is out.......
- What is the stock cam spec's for a 98 Z28?
- Will these springs fit the LS1 head?
- best cam slection
- What can I expect from this cam ...
- How do you break in a cam on a LS1?
- What stock cam spec's for a 01 SS?
- Trying to pick next mod help me out
- Found my oil leak...
- 1.8 Rockers installed (Dyno results)
- C5R heads questions
- Which heads to go with?
- A new LQ4 block
- TR reverse split
- S1 Heads, who can make the most power and quickest car with the following:
- .650+ solid rollers.... low oil pressure
- G5X-2 cam being installed
- need to know ASAP couple oil questions.
- Thanks, MTI (Jayson)!
- need advice on cam w/ 5.3 truck heads!!
- How to change valve springs leaving the heads on?
- Explain to me the process of "filling an engine with hard block".
- Help me pick a Cam for my forged block build....
- Valve spring recommendation needed
- G5X2
- Question on GTP Stage 2 heads and 218/224 cam
- Attention: making a public apology to Agostino Racing Engines
- Everyone inside please
- MILD Cam help, tuning, HP, KR, Xtrooper, etc.
- I'm the newest member of the Boom Bitch Club. HELP!
- TR 230/224 vs TR 227/224 cam questions
- Yella Terra Rockers, worth any HP?
- Comp Cam - 918 spring breakage....
- Ordered cam today 224/222 .568 .566 112 +4
- can i hit my goal w/ this cam
- LS1 block casting #?
- cam selection - passing smell test NY
- heads - stage 1 vs stage 2
- 02 LS6 cam
- Someone explain to me the theory behind Reverse Split cams?
- New member Question? Stock ls1 Motor Rebuild
- Stock vs Titanium Retainer Weight Info..
- New to the realm and need some advice
- Schubeck Lifters-anyone using them?
- what kind of cam!
- Question about stock heads
- Pulling heads, then leaving them off for a month
- Raging Motorsports News! Must read!
- cam
- Lunati 382 kit, who has the best price?
- ReSleeved Block Question
- To people curious about part specifications - cams, cranks, blocks, etc.
- I want the tr 230 cam ,but have ?
- Question......
- hEAD INSTALL ......
- gaskets for cam swap
- Question about C2 hammer Cam
- boring 5.3 block
- Is My Alternator Going Out?
- Oil Temps???
- How to tell a Z06 block from regular ls1 block?
- Car in for Cam and Macs what est.HP
- how do you pronouce cam specifications
- Solid Roller guru's inside please
- Cam and Head ?
- LGM G5x-2 Cam Only Dyno Graph within
- How much to have heads machines to fit 987s?
- Titanium retainer question
- Got the car dynoed today :(
- what is the best sounding (loping) and best hp cam?
- What's harder, cam swap or header install?
- ASA Cam?
- In middle of race car gave up...please read...
- Any A4s making 400rwhp ( 346CID NA ) ?
- shift points?
- Cam install
- new timing chain with new cam?
- What do you think of this cam...
- A word about Norris Motorsports,
- Checking on Thunder's 346ci Solid Roller...
- East Side Packages tested and ready for sale
- rocker arm deflection
- Junk Yard Dog 346ci motor completed!!
- Need suggestions on what cam to replace T1
- Who makes the best Stroker motors
- 160 t- stat
- Stock rocker arms and lifters question
- Jesel Adjustable rockers question -- I see MTI sells them
- Cylinder Head Porting...
- dyno tune Monday night at Cartek
- Heads/Cam Install Price
