- T-1 to a C-1
- LS1 cam swap on engine with 65000 miles? bearing safe?
- Changing Pistons
- pcv ?'s
- Any FLP Header Gains Changing Y and Collector?
- any drawbacks to retaining stock lifters..?
- XER 224/228 .581/.588 112+2
- what exactly is lope? any sound clips?
- Little worried about cam choice TR 224
- What kind of power from this cam??
- Quick i could buy a cam cheap but need to know if it is good
- New style cam in old style block
- Help Please
- Should I be concerned with my oil pressure?
- Oil gauge question, stock to mechanical
- Do Cartek heads perform?
- opinions on the .581/581 .224/.224 112lsa cam
- cam/heads dyno #'s with cutout open and closed?
- Automatic Vs. 6-speed
- How much can I mill stock heads with an X1 cam?
- (Pics inside) need an expert opinion on what I thought to be a spun bearing
- Question for ALL aftermarket cam guys > slight "rattling" at 2000 rpm
- Cracked Sleeves in cylinder, now what?
- Benifits of honing
- Milled Heads How Much Compression
- inch-pound and Foot pounds
- Best timing chain?
- Will 918 springs hold this cam?
- whats the max rev limit to set a stock ls1 at?
- TR 224 / 227
- 230/591/111 - 7.40 or 7.35 PR?
- Stock LS1/ LS6 deck height ?
- Anyone familiar with HESCO in Birmingham, AL?
- G5X-2 cam with stock LS1 heads...dyno results within!!!
- Crank pulley removal tip
- what to do about heads....?? have the HotCam
- Does my engine build plans sound good for 400+rwhp?
- Quick cam Q....please
- Valve Spring question
- Head options, need input.
- Dyno results with SLP 1.85 rockers
- What Cam Shaft should i get?
- How many hours labor for cam swap on 5.3 truck?
- how much will a cam help et
- 275RWHP @ 4000 rpms, then shut down...
- B1 cam (only) users...is my TORQUE low?
- 422 dyno results within
- Cam Difference
- Cam question
- MMS 388 Dyno Results
- LS1 to LS6 Z06 Swap
- Failed emissions What now?
- Thinking about a cam which one?? your opinoins please!!!!!!!
- F**K! Broke an oil pan bolt
- 02 Z0-6 cam -- SLP 1.85 rockers??
- broken valve cover bolt...
- ARP High Performance vs. Pro Series Rod Bolts
- I just got a cam, springs, and retainers for $250
- Possible colapsed lifter.....
- Analyze these flow numbers...
- A/C disconnect during cam install?
- Opinions needed - comparison between 10-bolt, 12-bolt, and 9" on the dyno
- When after 99 did the valve covers change?
- APE S2 dyno #'s
- What is the most reliable sleeve setup now?
- What RWHP for a f-body to hit 140 trap speed
- Used Cam
- LS6 stock springs OK with new TR cam?
- cam opinion please
- I need your opinion's
- How do I take my motor out?
- Comp vs Crane Lifters
- C5R Twin Turbo info
- Best Cam For Stock Exhaust Manifolds and Cats
- Service Engine Soon
- Very impressed with LGM
- CAR IS LEAKING OIL....HELP PLEASE...
- Cam/spring ?
- Where should I set my rev limiter at?
- What cam to get? I have aTR224 want bigger
- cam intake ceterline ?
- installation instructions h/c
- What gains to expect from MTI T1 Cam?
- Retainer weight, Titanium vs. Steel for 918 springs?
- GM documentation on new engine sizes (6.4L), and also including new v12....
- BEST AFTERMARKET OIL PUMP ???
- Why am i not making THAT much hp??
- Need sound clips on a 224/224 .581/.581 112.
- What heads should I get to go with my TR224 cam? Or
- CORRECT PUSH ROD LENGTH
- Biggest cam I can fit Possible?
- Which heads? 5.3 or 5.7
- Power loss...please help!!
- Started for the first time with new cam.
- Anybody have the absolute speed S2 LS1 heads?
- Big Block Questions
- Motor in car ARP Rod bolt swap......
- What kind of compression?
- Too much cam?
- JPR scores again!!!!
- How to tap a spark plug hole?
- Do places take 1 Head for 1/2 Core charge?
- Cam??? Big Lope.....Stock Heads....
- Best cam for a stroker,,,
- ARE 436 and stuff, 30-day UPDATE ..............
- Eastside Performance Cam (Dyno & Video)
- no headers
- newby questions
- Is there a locking type rocker arm bolt setup avail.?
- PCV Delete???
- will ZO6 springs work with the stock LS1 retainers??
- Cams to pass emmissions
- PLEASE....X1 SOUNDCLIPS!!!1
- 97 LS-1 Corvette heads question
- Thunder Racing 224/224 .561/.561 112 LSA or 224/224 .563/.563 114 LSA
- AFR Hydra Rev kit
- Cam experts, please come inside (long)...
- Pre-Lube the engine, after storage?
- Is A Titanium Retainer A Titanium Retainer?
- Pushrod Length With 02 LS6 Cam?
- Hammer Cam & M6 ? ? ?
- All those with PCV mod within
- BEST CAM FOR CNC LS6 HEADS?
- Cartek Stage IIx and LGM G5X1 soundclips... Compare for yourself.
- MTI C1 Sound Clips Wanted
- please help me
- 425 RWHP with a total duration of 440, possible?
- Lowest price for Pistons!!
- I just bought a set of valve cover spacers without hardware?
- SLP 1.85 Rocker Package?
- 422 solid roller ...!!
- intake ??
- Open headers bad for exhaust valves? QTP with QTECS?
- CAM IN AN 01 Z-28 ?????????????
- Help!!! Know nothing about cams!
- X1 or TR230/224
- Will a hotcam work without tuning
- XE-R 224/228/112 idle issues
- TEA s2 + F1 cam = OMFG!!!
- Expectations from different combos
- LS1- oil pressure?
- Solid -vs- hydraulic cam Qs....
- Helicoil in oil pan drain normal?
- Who should I send heads to for installing double springs?
- oil pressure ?
- Engine Break-In / Synthetic or Dino Oil?
- GTP Stage 2's with LS6 Cam. Big Enough?
- Called Comp Cams They Said to just torque rockers to 22'lbs.
- L vs. cc?
- How do you set rocker arms.
- Doing cam swap .. opinions?
- Alternate Heads for an LS1
- Is it worth swapping these cams??
- Help me pick the right cam...
- Do I really need titanium retainers?
- How much did you spend on your BUILD short block?
- Cam install question?
- ls6 cam..... is it really making as much hp as i've heard
- Lube crank and cam cover seals or not?
- Cal smog ?'s
- Maximum safe bore size for ......
- Dyno results !
- Need tips on installs
- 382 all bore with solid cam vs 422 stroker with hydraulic cam
- Cams?
- MTI Stage II ls6 heads C2 dyno numbers
- Cams 4 sell
- The search for the right cam...
- ls1 valve lenghts?
- Did anyone use a 232/236 (MTI R1) cam in there 382?
- Valvetrain experts I really need some help!!
- Possible bad lifter part II, with video clip
- Gm hot cam anyone have any thoughts?
- Well I ordered my new motor today..
- HEADS/ CAM
- colonel and his monster?
- 216 / 220 .525 / .532 114 LSA?
- Ok, need a smaller cam, suggestions please.....
- GM HEADGASKETS
- Comp .563/222/112 cam
- F1 and X1 users inside please
- stock valve seats????
- Crane lifter help needed..Please look inside
- If you know about TR220 cams.. please come in!
- Chapter 1/ LS1Tech Project/ Supercharged Formula
- Ok to drive without EGR?
- 232-236 XE-R 112 LS in a 393 all bore?
- Stock rods width?
- Anyone know the exact specs on Piglet cam??
- Best Combo
- What kind of internals do I need for a nitrious or S/C set-up?
- Is this possible need some help??
- Car shaking! (???)
- I just did a leak down test on my car is this normal?
- Engine builders..... Question on rear oil galley plug
- GM part number on LS6 springs??
- Where to buy cam swap gaskets?
- 6.0 cam???
- Is $800.00 a good price for LS6 heads
- Car running like CHIT
- So what the valvespring brand of the day. Broke a K-motion today
- Sound clip of a mild cam w/ stock manifolds?
- How can we beat up Al Corda and steal his cam?
- Why don't big cubes make big numbers?
- keep getting misfire codes help
- what do i need for cam install
- C1 cam lovers educate me
- Need Opinions Before I Spend Some Serious Cash
- Disaster at the drag strip... possible bent pushrods.....
- LS1 vs. LS6 heads and cam to match
- LS6 Valley cover
- how do you break in a new motor?
- LS1 vs. LS6 Heads?
- When installing the oil pump spacers that come with the Rollmaster double...
- Pacaloy or 26918 springs,which are BEST!!
- got 2 questions for yas
- Those with X1 cam or TR230/224 in Here Please..
- Are Amsoil oil filters any good?
- Head flow #'s inside now what size cam
- Crankcase Vacuum????
- How can I figure out total area under the curve of a cam lobe?
- Anyone have a cam card from F1, TR230 or X1 cam?
- Need direction and insight. Post cam install valvetrain noise
- 5.3.HEADS WITH 224/224 581/581 112 CAM
- cam shaft
- Will standard SBC rods work in a LS1 (6.1 length)????
- heads with Hotcam??
- sealing WS6 ram air hood
- Help How to unplug the knock sensors.....
- MY CAR IS FRAGGED -PART 2 (long with big pics)
- Honey .....really ....really, I am done.....
- Quick opinion: Running an 02 Gasket(.060) vs. pre-02 gasket(.054)
- best cam on stock heads 4 street use !!!
- stroker
- Please Help
- Head bolt problem.. got a quick question
- biggest cam (stock heads) that can pass dyno emissions (PA)? CA guys?
- LS6 heads over LS1's
- Patman: Redline : NJ Winter + 74k miles, + 6300 RPMs= what weight?
- What's the best vavlespring to use on a...
- Part #'s for a 2002 lower ram-air box
- Change oil light came on, but not low on oil really...whats the deal?
- Help me ID my cam.
- Milled 6.0 C/R and Pushrod length
- 112 or 114 LSA?
- tr224/224 .563/.563 112lsa
- Joel...Info about Redline
- Main Bearings replace?
- head and cam question?
