View Full Version : Generation III Internal Engine
  1. TR230 or X1 in an Auto..?
  2. titanium retainers - educate me please
  3. Miles per gallon
  4. 6.0 rods
  5. TR 227/224 Users in here please.
  6. Dyno numbers for FLP stage 2 h/c set up
  7. Biggest cam with stock heads?
  8. Anybody have a Junk crank or a trigger ring I can have cheap!!
  9. G5X1 dyno results - stock heads
  10. F1 Cam Dyno Results?
  11. Absolute 5.3L Stage 2's on order!!
  12. a cams lift
  13. Water pump
  14. What size socket for knock sensors?
  15. 427 build up, need suggestions on resleeved block
  16. difference between 224 and 222
  17. Will I need to drill the throttle body with tuning and cam?
  18. Not all 6.0 cranks are the same...
  19. Walls are too thin to go .060 on a 6.0 block
  20. Is this oil pressure ok?
  21. Need some help on buying these heads
  22. Valves in 5.3 heads
  23. Crane Valve springs...
  24. B1 or MMS 218 idle better in an A4?
  25. X1 cam specs are way off!!!!
  26. Please help me decide between 2 cams
  27. Installing Head Studs While Heads Are On The Car
  28. FYI : Head stud shortage
  29. Cam install on an A4 question
  30. yes,another ?
  31. yes,another ?
  32. TR 230/224 with 3.42
  33. TR 230/224 with 3.42
  34. I NEED cam bearing help.. like NOW!!!!
  35. Cam selection
  36. Max bore for a 5.3
  37. valve spring change????
  38. Hello, what do you think of my system?
  39. Installing Forged pistons in stock shortblock, Do i need to have it honed/bored??
  40. 218/224 comp cam?
  41. Can someone list every part needed for building a 427?
  42. Will 918 springs work with this cam
  43. Hot Cam #'s? ? ?
  44. power band of F1 and X1
  45. Help me understand heads differences - 5.3/5.7/6.0?
  46. temp, Oil press, gauge adaptors
  47. Twin turbo C5R headed stroker
  48. Opinions needed, Bigger Cam or Gas?
  49. Need an Oil Pump and Timing Chain for just Cam?
  50. My new 383 short block......
  51. Total Seal TS1 Rings
  52. Rocker Arms
  53. ~Will this setup make alot of power?
  54. Degreeing a cam without cyl. heads off?
  55. Lunati or Callies
  56. LS6 Valley Cover Coolant Cross-over P/N
  57. Why shouldn't I go with a brand new GM head gasket?
  58. WHAT HEADS FOR ME?
  59. Correct part number for stock LS1 lifters?
  60. MTI B1 OR C1 CAM
  61. another cam question
  62. Stock head flow numbers
  63. 6.0L Heads milled .038, shorter pushrods?
  64. 6.0L Heads milled .038, shorter pushrods?
  65. Does anyone make a cam like this?
  66. Which Rods, are stock rockers ok with B1?
  67. CAM Combo - Basic Questions (Fuel, NOS, tuning, etc...)
  68. What things can I do to get the best...
  69. ASA cam questions?
  70. tr 230/224 cam any comments appreciated.
  71. MTI 427 dyno results... UPDATED
  72. Gaskets Cometic vs. Felpro?
  73. Which sleeves in YOUR motor??
  74. Helping a friend out
  75. Low oil pressure problems..... Need some help guys!
  76. Crower camshaft opinions wanted
  77. Thermal Coatings? Woth it or not?
  78. Eagle Rods + L19 ARP's = Need to ???
  79. Need advice on an 01 LS6 engine Valley Cover
  80. anyone running around 11.5 compression
  81. What is the maximum bore for darton sleeve's
  82. Smoking out the breather valve....
  83. JPR STAGE II 224 CAM !!! DYNO!
  84. G5X1 info
  85. 6.0 liter heads
  86. ASA Heads.. Who Has Them?
  87. TR230/224 sound
  88. When are the 6.0 aluminum blocks scheduled for release???
  89. Cam ?
  90. How can you tell if you have a bad lifter? Inside please.
  91. Need new valvesprings for b1 cam turbo car
  92. Pick a new cam.
  93. Should I buy an adjustable timing chain...
  94. Is a single spring set up ok for this cam?
  95. Cam recomendations
  96. new timing chain needed??
  97. why does my valvetrain get noisy after WOT?
  98. 1.8 rockers with this cam
  99. heads?
  100. CompCam XE-R 230/232 .585/.585 112 +4custom...?
  101. MTI heads/Cam guys inside.. Please convince me!
  102. MTI heads/Cam guys inside please.. Please convince me!
  103. What rod and main bearings y'all using?
  104. What wrong with the search
  105. MTI T1 Cam
  106. tea 5.3 truck heads stage 1.5??
  107. Help with cam choice. Lift, LSA and degree?
  108. Does anyone have a link to cam only install instructions?
  109. 346 Forged internals
  110. *-*-*-* 112 OR 114 *-*-*-*
  111. still no info on assembling ls6 heads
  112. Working stock heads?
  113. 220/220 would be more streetable than 224 right?
  114. Need an "LS1Tech.com Diagnosis" - please take a look (long)
  115. 6.0 block
  116. stock lifter ok with high lift cam????
  117. who runs a cam and stock manifolds
  118. Gm Hot Cam, again
  119. Stroker Crank
  120. HELP ASAP!!
  121. What gains with stock LS6 heads?
  122. Is my cam too big for an auto??? help needed inside.
  123. what springs with the GM ASA cam...
  124. Blower cam w/o the blower
  125. Who makes undercut valves like Manley?
  126. Opinions on Hammer Cam wanted
  127. Sttroker combinations
  128. Sttroker combinations
  129. need head
  130. 1:15:03 @ 7pm... First phase of archiving is complete!
  131. 17x11s on dyno runs????
  132. piston slap ?
  133. Dyno Numbers For Comp 224/.581 112 LSA
  134. Dyno Numbers For Comp 224/.581 112 LSA
  135. What do you think about this cam?
  136. tachs up quick but...
  137. Which oils to use??????
  138. What effect does the cam have on emmissions?
  139. At My Wits End! (???) HELP!
  140. spray and tr230/224
  141. Valvetrain noise after H/C???
  142. ATTN: JPJBC
  143. TR220, MMS 218, or B1 cam for A4
  144. Is there a cam out there that offers good gas milage?
  145. Does anyone know where I can buy a 02 zo6 cam?
  146. Old Man Cam - dyno results
  147. What's the best timing chain?
  148. head install question
  149. head problems?
  150. What do you think of N/A Ford Engine development?
  151. Motor is ready to go in!!!!
  152. TR 227 224 114LSA??
  153. LS1 Hot Cam Feedback Still trying to pick a cam LOTS OF Questions
  154. Are 918s ok for X1??
  155. Anyone have a stock-head "T-1" Dyno Sheet Handy??
  156. How quickly can Comp grind a cam?
  157. Milling LS6 Heads
  158. How much can LS6 heads be cut?
  159. Cam with stock manifolds a good idea?
  160. Cam with stock manifolds a good idea?
  161. Whats the best cam for.......
  162. Should i have advanced / retarded my cam??
  163. absolute 5.3 stg2 tr 227 dyno results
  164. After heads/intake isntall on 99 Firehawk, car has a miss at idle/low speed
  165. Too much compression - stroker setup
  166. oil on spark plug?
  167. oil on spark plug?
  168. Best how-to guide for cam swap on 01-02 LS1???
  169. curious - what could be the reason oil would be getting into the intake?
  170. ASA 110 LSA Cam. Anyone have info?
  171. any site with pics / how to for assembling heads
  172. Felpro Head gaskets
  173. Finished head swap.......
  174. Best valve spring tool?
  175. do LS6 's have a installed height for springs?
  176. what valve stem seals to get
  177. when installing arp head studs does the chamfer ono the washer face up or down
  178. Almost done with heads install, but I forgot to put something in, is it important?
  179. 2000 or 2001 and 1998 engine differences?
  180. hammer c2 question
  181. New Quaker State Synthetic Oil
  182. LS1 Tech Sponsors
  183. wtf is up with my car
  184. LS-6 valve seals with LS-1 heads
  185. Ran the car tonight with new heads and cam....
  186. degreeing cam: is it necessary?
  187. Any reason NOT to get the X1 cam?
  188. Did I pick the right cam.
  189. Anyone have DARTON sleeves installed in a block yet?
  190. degreeing a cam,is it a must do?
  191. FYI we are creating an archive for this section
  192. MAINS
  193. TR 224 vs. smaller Comp stick with 1.8's what do you think?
  194. Minimum oil level for drag racing?
  195. Need help trouble shooting a car wont stay on problem
  196. Aftermarket Timing Chain users come in >>>>>>
  197. "Yella Terra" Stealth Street Rockers
  198. Help with shopping list if I get TR224 .563 112?
  199. Piston to wall clearance on a 383 stroker??
  200. Best Valve-Springs on the market.....
  201. Biggest Exhaust valve on stock seat
  202. Pewter00TA's dyno report
  203. slp h/c
  204. ABSOLUTE SPEED ROCKS
  205. Anyone have some pics of a Rollmaster install?
  206. Need help with next mod, please come in!
  207. Paging Brian Tooley
  208. Brent, Mark, Bill, Robert and Les win the first five places in the Breathless shoot o
  209. What parts are needed?
  210. Any updates on the Eastside Performance Cams yet?
  211. Blown motors?
  212. Got a nice set of LS6 heads today...
  213. How can I determine if this cam needs to be advanced or not?
  214. Head and cam swap?
  215. CAM SWAP HELP
  216. Calculating compression...
  217. h/c ? based on 2000ss's ?
  218. Quick Diamond Piston Q (FI)
  219. valve length
  220. Water Pump R&R instructions
  221. Stroke and S/C???
  222. Cams
  223. Head Gaskets?
  224. All 987 Comp dual spring users, need help FAST!
  225. Internals & Balancing
  226. Over heating problem-slow loss of coolant?
  227. Lunati Stroker Kit Dyno Numbers
  228. Anybody dynoed in cold weather? How does it effect it?
  229. cam help
  230. Stroked iron block
  231. need some head pictures
  232. It piston slap from oil through the PVC valve?
  233. 5.3L TEA S2 question......
  234. How to change pushrods?
  235. What Houston Machine Shops?
  236. Iron Block Solid rolla 408 .... trap speeds?
  237. Question for people running the Thunder Cam and Stage 2 LS1 heads:
  238. 6.0l with cam bearings
  239. Help me choose from the following cams
  240. Those w/5.3L heads & TR224 cam , P/V question
  241. lumpy cam for a stock 98 ls1?
  242. Simple spark-plugs question
  243. Will I need longer push rods with this cam?
  244. Paging Cammin' Beast
  245. Flowtested Lingenfelter CNC heads, MMS Stage II's, sell or are these good #'s??
  246. Loud clicking noise and smoke at high RPMs
  247. combustion chamber size to achieve 12:1 compression w/ truck heads.
  248. FI vs Head/ Cam/ Nitrous
  249. Some say that a rebuild will not fix the problem?
  250. Suggestions for heads and cam??
