- OIL PRESSURE
- gota problem - need some guidance please!
- Not another LSA discussion, My take on the situation. Tell me what you think.
- Question about the main bolts that go through the outside of block...
- Pushrods: Thunder's VS. Comp Cams...
- LS1, what is the pushrod length?
- play pick a camshaft (i really appreciate any help)
- 99 SS knocking and won't stop after warm-up
- LS6 Heads
- Cam Advise
- Head/cam package help...
- "Project Wife's Car" get a CAM!!! results;
- changing pushrods? Got a couple ?'s...
- CAM opinion- 2000 SS
- Power difference from 346ci to 6.0L????
- Need help about overheating problem!!
- Anyone running a 382 all bore?
- ENGINE INSTALL
- help appreciated what is a good cam for a 98 z
- What's the biggest lift on a cam you can go w/ stock pistons?
- 6.0 bored .030 or .060-stock rods & Crank
- 6.0 Qs
- Any one ever had their car worked on by LPE?
- Wanting to mod my car
- would u please discuss this cam with me
- Stock rods vs aftermarket rods
- 02 LS6 cam + 1.8 rockers okay?
- What is involved in a cam install?
- head stud clearence
- Installing head studs with shortblock in F-car??
- ASA hotcam and piston to valve clearance?
- Budget calls for a ARE 393 all bore, help me select a cam:
- Help me pick a cam!
- LS1 - 5.3L parts compatability
- ls6 port measurements
- cam install question?
- Lifting a Head: what is it???????
- LS1 hotcam in A4
- 5.3 liter heads and cometic gaskets
- Pagin 770 Boy, Cam Question
- H/C or Turbo?
- Jesel rocker torque?
- crankshaft question
- Stock cam
- Help pick a suitable cam for my hybrid swap!!
- TR 224-112 OWNERS
- Thoughts on forged pistons and knock sensors...
- Where are the splash guards
- got cam, want bigger
- what are the specs on the ASA camshaft
- asa cam-cnc stage 2 heads what do u think
- Can our stock camshaft be reground?
- F1 CAM INFO
- Torque specs on Lunati rod bolts?
- Any LS1 dry sumpers out there??????
- 10w30 or 10w40 for High rpm's?
- CAM QUESTION
- Oil pump went out
- WTF is this condensation??
- TEA= Total Engine Airflow
- Car choking?
- Car keeps dying?????
- hot cam sound clips any one
- cam question
- Is the HOT CAM a good choice for me?
- absolute speed heads.
- Pistons - Please Help !??
- Different Dyno's - Same car - Same set up - Biggest difference in RWHP you've seen?
- Does windage tray need to be shimmed with stroker crank?
- Please Help!!! Need GM Part # for vspring retainer key asap!!!!
- Anyone gained low end torque from cam change
- Help, want a stock sounding idle cam? Z06?
- ARP main and rod bolts
- engine building question
- LS1 Part Numbers
- Weird Problem with ARP studs
- Any install/tech info Websites ???
- Put LS6 cam in, Lost 15hp?
- Connecting Rods and FI
- Coolant/Oil Sludge on the underside of the Oil Fill cap....HELP!
- GM LS6 CNC ported heads
- NEED HELP CHOOSING A CAM
- dealers on crack?
- 6.0L Buildup ???
- What dyno numbers do you predict for my MTI ironblock 427?
- stroke bore question?
- Oil.......
- dumb question..but of major importance
- Cam questions about degrees +/- advanced/retarded
- non LS1.... Tips for restarting an engine thats been sitting
- Storing my car. need help please
- A couple of Engine Building Questions
- A Couple of Engine building Questions.
- Gettin my heads ported and polished
- PCV system removal?
- head and cam with out pulling motor?
- Lunati camshaft
- ARE
- What should I be running after cam install?
- opinions on 228 224 588 581 on a 111.
- Hotcam with stock headers worth it?
- Holy FREAKING POPCORN BATMAN!!!
- Attaining Sound of 302 Camaro
- casting numbers
- C5R Block
- How much compression you running with your big cubed motor?
- Inside of the Intake is shiney....could it be?
- Using Patrick G's 44-46 ABDC theory.....
- Anyone running a ARE 442 big bore?
- TEA heads?
- What numbers if a 6speed?
- What is the largest dish you can order pistons....
- BEnt Pushrods??
- benefit of milling heads??
- Any difference in N/A performance between TR-55 and TR-6 plugs?
- radiused inlet flowing heads....
- Alright, I am convinced. Time to get an adjustable timing chain.
- good head question please respond
- 425 hp with 01 LS6 cam
- Synthetic Oil Life Study
- another compcam 212/218 question
- do u need a spacer or tall valve covers for Jesel ShftMntd Rockers ?
- new Stage II setup: is 360 rwhp in the ballpark?
- Best cam for stock heads
- Whats a good throttle body cleaner that won't damage plastic intake?
- H.P. Limit on stock crank and rods???
- optimal oil temp? Ifound condensation under my oil cap..
- 02 Z06 Valve size?
- GM stock rings pistons.....gap
- Main and rod bearing clearances??
- Hello Everyone
- The best rings ??
- What kinda cam does it take to get 550 HP out if a 422-436 CI?
- Speed-Pro/Sealed Power rings
- Solid Roller ?'s
- ls6 heads
- what is the best way to install new lifters
- TR224 112 & GTP S3 heads dyno
- Would I have to get the block machined to install this Lunati stroker kit?
- Double Rollmaster vs. Single Rollmaster
- my clutch....i think?
- Will 2002 LS6 springs fit on LS1 heads?
- Comp XE or XE-R cam
- Anyone with more than .600 lift and stock rockers
- HASTINGS ring piston ????
- factory head gasket??edit please helpmore!
- ***Tell me if I'm Forgetting Something***
- motor suggestions....
- Assemled stock LS6 heads right off an 02 Z06? Worth it?
- Any other budget cam besides the HotCam?
- best head and cam package
- TR 227/224
- LS1 Hot Cam kit or 2002 Z06 cam and springs
- Lifter question
- LARGEST cam without missfire codes (stock tuning)
- switched from 918s to REV-1116 springs
- TR 224, and 1.8 RR
- OK the life long question "what cam" (long)
- Engine gurus - need a recommendation on valve spring compressor - -
- LS1 POWER!!
- Whats with GM bashing websites?
- Iron blocks.
- Screw The PCV ??
- Hot cam specs. Help newbie cam guy decipher
- cam doesn't fit after new cam bearings installed
- I'm back. Car suggestions?
- diff between the ls1 and the ls6
- Pushrod length question.
- Aftermarket Oil pan?
- HP loss with heavier oil?
- New writeup: Heads/cam/pulley install
- Damege in my crank shaft , port it or put a new one ??
- Price Of 918 Springs And Titanium Retainers
- Need H/C Advice
- TR 227/224 cam in a 2002 Z06- results
- 918 failure time frame?
- Aeration of oil due to overfilling?
- valve spring ?
- what does a broken valve spring sound like
- Need help identifying my LS1
- More Performance valvespring tool ROCKS!
- Oil or assembly lube on new cam??
- Bmw recommending 10w60 for engines of M3's?
- Comp 918's with 2.02 valves
- People who had both TR224 and TR230-Jason...
- valve train experts
- HOTCAM???
- f2 cam pistion to valve clearance
- TR224 112 cam users inside please
- HELP!!!! What is this? Found while changing oil
- what cam??
- Ring end gap with 4.080" bore??
- where to buy an aftermarket oil pump??????
- Heads flow question
- Reason for stagerring lift #`s on cams??
- Are LS6 springs more durable than Comp 26918's?
- I need some help here....
- Absolute Speed Stage 1x Flow #'s
- part number?
- broke off my temp sensor in the head
- need serious cam experts
- Bar none..what is the best timing chain and gear combo?
- What's up with my ride???
- 3,300 miles New chain???
- All bore resleved block, stock crank, what would the CI be?
- Rough Idle and Hunting for Idle...
- part #s for 918's and ti retainers
- Could this be an ASA or Hot Cam???
- FAstest ET with cam and heads and convertor
- Are their aftermarket pistons for 346 c.i. ??
- How much more power from stock 00 Z/28 with a decent heads/cam kit?
- Does "Stock" 02 LS6 Heads?
- Did Search..Some good questions for you cam only guys.
- Exhaust flow#s onTEA and Absolute ST2 heads
- Gear Drives??
- Help....TR224!!!!
- Raising the idle manually?!!
- how much compression gain?
- closed seat pressure?
- what springs would meet this .......
- Retainers?
- Thinking of Heads & Cam - Come inside
- XE lobes + 1.8 rockers , yes or no ?
- Differences in stage 1/2 heads, power and drivability?
- Cam advance adjustments?
- Just ordered my TR 220 cam!!
- Flow #'s- Absolute Speed Stage 2 Heads
- Whats the formula to find the compression ratio
- MTI stage 2 heads come with 11:1 compression stock????
- How do you check the preload on the valve springs?
- 6.0 pistons
- My new cam is in!!
- Cam , install it straight up , or advanced ?
- 6.0
- What pitch are the threads on the head bolts ?
- Absolute Speed Heads
- Head bolts reused?
- Is My OIL PUMP About To DIE????????? long--Please Help!
- LS6 Cam and Springs, What retainers can I use?
- I think I foudn my missfiring problem....
- Has anyone had a 222/220 .591/.571 113 + 3 cam installed?
- Lifter preload on my new setup...
- Heads and Cam Package
- Do I need different length pushrods?
- Article on the differences between an LS6 and an LS1
- Lightweight Valves
- Which cube setup?
- Heads/cam results from latest sponsor, AAP!
