View Full Version : Generation III Internal Engine
  1. Does anyone have info on this forged stroker kit?
  2. Loud noise from driver's side... Vid included
  3. LS1 to LQ4...what all is needed?
  4. 2001 T/A LS6 Build.
  5. 408 build
  6. Local Cam Installer
  7. im missing the low end grunt
  8. HELP!! Temp sensor going crazy!!
  9. 2000 trans am 6.0 f1 build
  10. Water injection N/A?
  11. ptv clearance issue? rod bearing? engine knock/tap
  12. How much to shave off heads?
  13. 799/243 heads
  14. Heads
  15. victor jr setup
  16. Comp r lifters
  17. LS2 vs LS1 Lifter Trays
  18. how to tell the difference btw ls7 vs caddy lifters
  19. ls1/ls6 builders in Pittsburgh
  20. Valve Spring Retainer Question...LS1
  21. 98 ls1 to 04 6.0
  22. g5x3 with tfs 215cc?
  23. Who's running the Vengeance Racing head/cam package?
  24. Drivability Issues on 5.3L CANT FIGURE IT OUT!!!
  25. 5.3 to 5.7
  26. stock injectors ok for now with this combo?
  27. Mixing oil question
  28. Overheating Concern
  29. Is this LS6 motor good for street and pump gas?
  30. Stuck LS7 lifter...
  31. low oil pressure high rpm under load
  32. 5.3/6.0 block dimensions the same?
  33. Sparkplugs! Im pissed!!!!!
  34. 460 rwhp ?
  35. Going with Geoff at EPS!
  36. 5.3 heads vs ls2 heads
  37. 331" De-Stroked LSx.. 8500 rpm??
  38. bottom end build question?
  39. Anyone running FM-16 cam yet?
  40. 90mm tb on a Ls6 intake
  41. lq4 build almost done...rod question?
  42. Cam opinions for stock head/full bolt on LS1...224/224?
  43. when to tune your ls1???
  44. Forza 3
  45. Thinking my bird has a broken wing :(
  46. 706 heads
  47. What DCR?
  48. Cylinder Head Help
  49. torquer v3 questions
  50. Pulled some spark plugs what do they say?
  51. what year LQ4? and should I swap the cam for my setup?
  52. Cleaning MLS head gaskets
  53. SD guys. What size piping are you using to replace MAF?
  54. Is this a good cam for a TVS 1900?
  55. Are Injectors necessary for EPS cam only 222/222 115 +3???
  56. Ms4 cam and heads setup questions
  57. tick...tick...tick...
  58. pushrods?
  59. how do i know if i have an LS1 or an LS6
  60. LQ4 Build questions
  61. which injectors should i go with my lq9
  62. questions aboout my arp bolts
  63. Could installing cam only increase crank case pressure?
  64. Newbie to bottom end builds!
  65. Looking into a rebuild but I want to know if i i am doing anything majorly wrong
  66. Oliver SBC rods??
  67. what injectors
  68. Update for my car after spark plug wires.
  69. Anybody know the part# for new valve seals for 806 castings?
  70. oil around intake ports
  71. Does anybody use eoic method for adjusting valves on ls engine?
  72. main bolts?
  73. LS1 coolant flow - liquid cooled turbo?
  74. highest compression on pump gas
  75. Cam bolts came loose
  76. tsp 228R cam
  77. 6.0 questions
  78. Spark plugs
  79. Head instl questions
  80. LQ9 build
  81. Stock block 4.125 stroke power limit?
  82. ptv clearance on ls1 flat top
  83. Need intake advice
  84. What plug wires to run?
  85. BBK tb now misfire
  86. future engine build ???'s
  87. ZO6 ls6 cam or Patriot Billet 225/229
  88. MS3 vs. MS4
  89. 243 heads and yellow valve springs
  90. opinions please
  91. Anybody still running titanium valves in LS1?
  92. looking for best head cam combo for 00 ls1 formula A4
  93. Stupid question
  94. EPS 234/246 112LSA Idle Vid
  95. ls1 cylinder wall ridge?
  96. when to replace...???
  97. Looking to Refresh and Upgrade My LS1, Questions......
  98. will ls3 pistons work in my lq9
  99. who has bored out a ls1 to put ls2 pistons in it
  100. Iron LS1
  101. Tune and Injector question
  102. Lifter only swap..worth it?
  103. Best rotating assembly?
  104. Does anybody else have any surging with the Torquer V2?
  105. Low Lift Flow
  106. torquer v2 installed... greenish fluid leaking... and other problems as well
  107. ls1 cam tool question
  108. LS6 heads and cam question
  109. SLP lid?
  110. LS6 Intake
  111. Unidentified magnetic objects on drain plug and low and fluctuating oil pressure
  112. Help figuring out my head/cam combo
  113. LQ4 build help
  114. lq4 head gasket question?
  115. Question about Lunati Gold Dual Spring Set Viton Seals
  116. 6.0 Casting Heads?
  117. Crazy loud tapping noise
  118. should have more horsepower?
  119. Best headers for the money???
  120. Planning a 383 turbo motor
  121. Am I gonna get 50rwhp outta this combo?
  122. ticking on start up
  123. Good shop in chicago area?????
  124. 383 Build Assistance
  125. Bank two, 2,4,6,8 misfire
  126. Adjusting valves for solid roller
  127. 3500 to spend. what should i get?
  128. 224r or 228r? Single pac springs or prc doubles?
  129. G5x3 For everyday driver?
  130. help 6.0 swap
  131. New combo questions
  132. Circle D 4C+3.73's+full weight= help?
  133. need some head advice please
  134. cam/headers problem
  135. type of head gasket do i need
  136. chocolate milk in rad..
  137. 2000 SS M6, doesn't seem that impressive.
  138. 408 guys, need info!
  139. Stock Crank Guys: How many have chamfered cranks?
  140. AFR210s, Results???
  141. EPS 234/246 with L92 heads
  142. Eagle vs Callies Compstar
  143. Honing a must with new pistons?
  144. LS6 intake uses o-ring gaskets?
  145. buillding a drift ls1 motor
  146. Getting Fresh Patriot Springs
  147. Thermostat
  148. Intake manifold gasket
  149. Pushrod length HELP
  150. Are all 4.8's created equal
  151. comp cams trunion upgrade kit bang head
  152. Broke Bolt off in Coolant pipe hole ,HELP!
  153. Pushrods
  154. LS3 vs Dart Pro1 Ls1 Heads?
  155. cam ?
  156. ls2 tb on ls3 intake?
  157. just bought a 2000 SS project car...help me with a motor decision!
  158. 706 Heads on LQ9?
  159. 233/239 cam with stock 241 heads
  160. Drivers side ground wasn't connected?
  161. freeze/welch plug in 4.8 cranks?
  162. Heads and cam for LS1
  163. Questions on LM7/LS1 build
  164. Real World Differences? TSP 233/239 vs MS4
  165. Zip tie mod?
  166. Ran into a prob with the o2 sensor....
  167. PRC Dual's vs Lunati Gold Duals
  168. Head identification
  169. H/C question
  170. What in the hell is that noise? Intermittent Tick
  171. knock sensor relocation
  172. Rebuilding 210K Mile LQ4 - Have a couple questions
  173. misfire/hesitation
  174. Thinking about f13 cam install
  175. Cam swap in 150k mi engine?
  176. TSP 233/239 too advance or not
  177. Springs for 228r that don't have to be checked every 10-20k
  178. Wierd Startup problem (Tuning?)
  179. cooling fan power wire
  180. Heads and Cam for stock converter
  181. LQ4/9 - 4.125 Stroke 4.060 Bore - Opinions
  182. Lq4 - 370 Questions
  183. What next
  184. 5.3/6.0 swap questions
  185. Double-Roller Timing Chain Options....
  186. 408ci vs 421ci..??????
  187. Sulfer vs Valve Alloy
  188. Help!!!
  189. stock injectors?
  190. Engine code (slow response 02 sensor??
  191. predator cams?
  192. lq4 in 95 stang
  193. Broken exhaust bolts
  194. ls heads
  195. What oil for .026-.028" ring gap
  196. puking coolant by tranny
  197. Anyone with cam install tools for borrow/rent?
  198. Whats a stellar bolt on combo
  199. Talk me out of an MS3 on 112 LSA
  200. arp ls1 head bolts
  201. Does this pushrod look bent?
  202. Ticking sound
  203. oil pressure help please, new block
  204. Valvespring replacement time??
  205. Piston and ring suggestions please
  206. 40 mpg Trans am LS1/LS6?
  207. Wat are compstar rods and weisco piston rated to? cause i just broke one of them...
  208. compression test???wats wrong
  209. 88 iroc-z lq9 turbo
  210. Any differance between early model 243 heads and later model heads???
  211. 98 ls1 car no spark
  212. Heads/Cam Affordability, Power, Fuel Economy
  213. valvetrain noise?
  214. Valve train crash need some help!
  215. Backfire help
  216. ls6 243 heads 310$ on ebay? is this a hoax?
  217. Trans Am wanting to die.. HELP
  218. ETs way off...need help
  219. wot hesitation
  220. good read on block machining
  221. Head numbers?
  222. Bought a set of 241's-best modding for them?
  223. Need place to get viton seals and 505 seats
  224. ARP thread chaser question
  225. 4.8 starts then dies
  226. Unknown engine problem?
  227. Piston #7
  228. NEW! KATECH High capacity LS oil pump
  229. callies lsc 5140 crankshaft
  230. Major Oil leak before cam swap,,, need help
  231. LM7 cam questions
  232. Cam won't come out! help!
  233. High rpm crankcase pressure = oil pan leak
  234. LS2 chain too loose?
  235. Compression ratio and boost
  236. How much lift is to much in a turbo 5.3
  237. Another "which cam?" thread
  238. MS4 Cam
  239. copper valve guides
  240. 6.0 Rebuild with H/C questions
  241. AI Valve job tell me your thoughts....
  242. tqr3
  243. 1 7/8 headers
  244. 243 heads
  245. Injector size for 224R on LM7
  246. Parts pics for my upcoming build.
  247. 6.0 with a t56?
  248. installed torquer v2 and longtubes...video clip inside.
  249. Metal shavings on back of cam
  250. running hot after cam & headers
