View Full Version : Generation III Internal Engine
  1. TR224 112 cam users inside please
  2. HELP!!!! What is this? Found while changing oil
  3. what cam??
  4. Ring end gap with 4.080" bore??
  5. where to buy an aftermarket oil pump??????
  6. Heads flow question
  7. Reason for stagerring lift #`s on cams??
  8. Are LS6 springs more durable than Comp 26918's?
  9. I need some help here....
  10. Absolute Speed Stage 1x Flow #'s
  11. part number?
  12. broke off my temp sensor in the head
  13. need serious cam experts
  14. Bar none..what is the best timing chain and gear combo?
  15. What's up with my ride???
  16. 3,300 miles New chain???
  17. All bore resleved block, stock crank, what would the CI be?
  18. Rough Idle and Hunting for Idle...
  19. part #s for 918's and ti retainers
  20. Could this be an ASA or Hot Cam???
  21. FAstest ET with cam and heads and convertor
  22. Are their aftermarket pistons for 346 c.i. ??
  23. How much more power from stock 00 Z/28 with a decent heads/cam kit?
  24. Does "Stock" 02 LS6 Heads?
  25. Did Search..Some good questions for you cam only guys.
  26. Exhaust flow#s onTEA and Absolute ST2 heads
  27. Gear Drives??
  28. Help....TR224!!!!
  29. Raising the idle manually?!!
  30. how much compression gain?
  31. closed seat pressure?
  32. what springs would meet this .......
  33. Retainers?
  34. Thinking of Heads & Cam - Come inside
  35. XE lobes + 1.8 rockers , yes or no ?
  36. Differences in stage 1/2 heads, power and drivability?
  37. Cam advance adjustments?
  38. Just ordered my TR 220 cam!!
  39. Flow #'s- Absolute Speed Stage 2 Heads
  40. Whats the formula to find the compression ratio
  41. MTI stage 2 heads come with 11:1 compression stock????
  42. How do you check the preload on the valve springs?
  43. 6.0 pistons
  44. My new cam is in!!
  45. Cam , install it straight up , or advanced ?
  46. 6.0
  47. What pitch are the threads on the head bolts ?
  48. Absolute Speed Heads
  49. Head bolts reused?
  50. Is My OIL PUMP About To DIE????????? long--Please Help!
  51. LS6 Cam and Springs, What retainers can I use?
  52. I think I foudn my missfiring problem....
  53. Has anyone had a 222/220 .591/.571 113 + 3 cam installed?
  54. Lifter preload on my new setup...
  55. Heads and Cam Package
  56. Do I need different length pushrods?
  57. Article on the differences between an LS6 and an LS1
  58. Lightweight Valves
  59. Which cube setup?
  60. Heads/cam results from latest sponsor, AAP!
  61. Paging.....Joe Prince
  62. Thinking of getting a Custom Grind cam, tell me what you think of these specs:
  63. Wanted 6.0L heads
  64. Head Questions...
  65. Lost the motor in 99 Vette, Broken REV valve spring
  66. Valve Springs for Boost
  67. Can ARP rod bolts be reused?
  68. Convince me why to get LS6 heads over 5.3
  69. Newbie cam install... where can I find just a hose from a leakdown kit??
  70. Whatsa good starting point on the MafT after headers and big cam?
  71. Adjustable vernier type cam timing set.
  72. MAX HP Cam on stock Heads?
  73. ? about hotcam
  74. 422 guru's inside please
  75. advancing a cam
  76. roller rockers?????
  77. valve question
  78. New here...Can I do heads with stock headers?
  79. How about a 6.0 LS1 Escalade motor with a T1 cam and LS6 heads?
  80. torque spec on eagle rods
  81. Should I have gotten the titanium retainers????
  82. reliable cam for daily driver
  83. looking for a shop
  84. Who has best price and delivery on a 4" crank?
  85. Need some part #'s
  86. Anybody port thier own heads with decent results?
  87. JPR All Bore is up and running!!!!!
  88. Need Help Asap, Cam experts inside ASAP.
  89. Anyone using the Comp 218 / 224 .527 / .534 114 LSA ?
  90. what springs to use with my 236/240 , 601/609 ,114 LSA cam??
  91. Tranny problem or tuning problem?
  92. TR230 owners or tight LSA cam owners...
  93. engine missfiring from new cam...
  94. How to make a little cam act big
  95. Spec difference between 02 LS1 and LS6 cams?
  96. Install head bolts dry?
  97. Need H/C help.
  98. good modifications
  99. 232/236 114 110 XE-R Track Results
  100. GTP HEADS
  101. High compression + bad battery + underdrive pullies = missfire?
  102. Does my ported oil pump suck?
  103. Does my ported oil pump suck?
  104. PLEASE HELP!!!
  105. help me, C1 or C2 cam?
  106. Cam spec question......
  107. ENGINE REBUILDER
  108. heads, cam, & n2o
  109. 01 LS6 Vs 02LS6
  110. oil pressure
  111. Will the 1.85:1 rocker arms make the car lope?
  112. Whats the biggest cam without doing heads?
  113. 383 done
  114. Questions about hotcam
  115. O-Ringing a block for nitrous???(non-LS1)
  116. camshaft loping
  117. Will 2.02intake & 1.57 exhaust fit in stock 6.0L head
  118. Milling heads, pros vs. cons
  119. Go big or Stay smogable???????? help me decide
  120. 02 LS6 heads,specs don't look right?
  121. getting knock retard now!
  122. What valve springs to go with.
  123. Car has lost significant power for no reason...Please help!
  124. Snapped rear long oil pan bolt...
  125. Oil Analysis: Royal Purple 10w30 for 6,000 miles
  126. Stock head porting??
  127. Dyno #s, what you think? C1 cam
  128. My SS breathes again!! but not with out some bugs!
  129. Bottom End Noise Help
  130. TR224 Spring question.
  131. SS is running again!!!!!!!!
  132. Any issues with nitrous on the 427 block?
  133. Thunder and MTI Cams vs HOTCAM
  134. LS1/LS6 Timing Chain Damper > 98 blocks drilled for it?
  135. Tested P to V clearance on 5.3 heads & 224 XE-R cam - It's TIGHT in there!
  136. TEA stage 2 heads and hammer cam finaly done
  137. Flow Technics Heads
  138. oil cooler?
  139. Going to dyno tomorrow.
  140. TEA 5.3 flow #'s
  141. Are all year LS1 torque specs the same?
  142. best cam for TEA 5.3 and A4
  143. Single or Dual valve spring?
  144. Head gaskets ????
  145. 242/242 .610/.610 114 lsa; scratching my head.......
  146. Anybody actually tried a 110lsa cam, compared to 112?
  147. Just ordered my new motor
  148. New Cam Idea.
  149. What would you change with this setup.
  150. Are there any good performance cams with low lift?
  151. What is "machined" for dual spring setups on the cylinder heads?
  152. Oil Around My Block and Heads
  153. Pushrod length question
  154. Piston Rings
  155. will 2.05 fit 5.3 stock valve seats
  156. I WAS RIPPED OFF BY PHIL WATSON (matchstick)....
  157. What seat pressure?
  158. Stock LS6 heads install question
  159. REGROUND STOCK CRANKSHAFT TO MAKE 382???
  160. Folks using Isky 295-D's
  161. ? on dual spring install
  162. Dyno numbers on MTI StageII's, TR230 cam, and spray....
  163. What rev limiter on 422?
  164. Check out this NEW valve spring removal tool >
  165. engine missfire and running flat after new cam....
  166. Does TR230/224 cam create too much cylinder pressure for big nitrous shots of 150+?
  167. Does anyone know where I can buy stress plates for honing?
  168. Overlap
  169. What ya think about this cam with stock heads.
  170. Solid Roller and Oil Pressure
  171. Bit The Bullet, Tell me what ya think of my coming bumpstick
  172. Compiled stock and ported LS6 head information
  173. Please help me decide which cam will to go with
  174. How the #$%* do you get the springs off the head with the SLP compressor?
  175. Dyno numbers before heads and cam - What do you think?
  176. GM MLS 6.0L head gasket part#
  177. Recipe for 7.0 liter motor
  178. Connecting Rods
  179. Any heads/cam guys using Warranty Gold aftermarket extended warranty?
  180. 6.0L Heads
  181. What do you guys think of the comp cam 226/232 112?
  182. Anyone have the TR 227/224 Reverse Split???????
  183. which head is a better 5.3?
  184. pick my cam
  185. Who has the best price for LS6 Heads?
  186. G5 vs. X1 vs. TR230
  187. I need some suggestions please..
  188. Stage 1 made into Stage 2 ?
  189. Installed 218/224 .562/.567 114LSA
  190. What's the break-in, if any, for a H/C??
  191. Lighter Alum ATI Super Damper affect on engine?
  192. How do you read a Cam Pro Report
  193. Titanium or Stock Retainers?
  194. Who has best deal for hotcam
  195. Help me match the baddest azz cam to be used with my stage II MTI LS6 Heads.
  196. valve cover breather?
  197. Lifter install direction??
  198. Katech head and cam package?
  199. taking engine out
  200. question on head studs
  201. Cam Spec Help.
  202. lunati 382 stroker....
  203. Does LG's G5 cam have any advance ground in?
  204. NHRA Stock engine build
  205. LPE stage 2 LS6 flow #'s and prices
  206. LS1 intake holding me back?
  207. jpr382ci all bore
  208. Forged Block -break-in
  209. need torque specs
  210. Best engine parts?? block/pistons/rods etc
  211. need 5.3 heads casting #.a.s.a.p tia.
  212. What rpm do you guys shift with TR 230/224
  213. What rpm do you guys shift with TR 230/224
  214. Cylinder Head help please......Need to know exhaust port length.
  215. Cam install
  216. Anyone running Speed Demon heads?
  217. Tr224/112 vs Tr224/114
  218. I need some general knowledge on H/C/I
  219. Has anyone lost a rear main in an LS1?
  220. ARE `S NEW LS6 HEAD
  221. B&BP shortblock vs. stock shortblock
  222. Burning 1/2 Quart of Oil in 100 miles....Opinions on this please....
  223. oil brand and type
  224. Cam for me
  225. Stone stock LS1 pinging...interesting paragraph in owners manual...please comment...
  226. Starts and Dies
  227. What custom grind comp cam for 422
  228. Are LS1 valves same size as SBC?
  229. Calling all stock headed 380+ rwhp cars....
  230. Cam Q&A!!!!!!!!!!!
  231. 427 MMS C5R Blocked Reliability Update
  232. Collapsed cylinder
  233. What would be the best heads to go with??
  234. Interesting read: SLP heads/cam + dyno
  235. What weight/visc motor oil do you use in your heads/cam or stroker cars?
  236. "Hot" cam is in!
  237. What's the best sleeper cam that can yield +430rwhp with S2 heads and Edit?
  238. 382-388 All bore motor guru's please offer advice
  239. Katech ported oil pump vs ARE ported oil pump
  240. Piston to valve clearance?
  241. What custom grind would be good?
  242. What cam for my car???
  243. TR 230 in a 02 Z06
  244. What cam and heads combo is proven for 10s on stock bottom end LS1s?
  245. Best Head gasket?
  246. LS1 Hot Cam! Worth it??? Specs inside!!
  247. LS1 Hot Cam! Worth it??? Specs inside!!
  248. Assembling engine? Crank hard to turn?
  249. What mods next?
  250. scat crank-shafts
