View Full Version : Generation III Internal Engine
  1. Help needed on oilpan...
  2. Anyone running the ARE 346 forged longblock?
  3. If anyone has a Cam card please post the specs....
  4. how will GTP stage 3's work on my combo?
  5. Help...What size pushrods should I get?
  6. 216 216 cam
  7. 216 216 cam
  8. Anyone Tap their 99+ Block for GM Timing Chain Damper yet??
  9. Where can I buy, beg , borrow, or steal stress plates to do a stress hone?
  10. Lifters?
  11. can someone explain the specs on a cam to me please.
  12. G5 Cam users: spring setup question
  13. Iron block LS1 - spdc 6 liter = $550
  14. 6.0 & nitrous. How much would your bore over for a 300 shot?
  15. What is the best HP and Torque cam for a H & C 346 LS1?
  16. Cam Specs for 2001 ZO6
  17. Name some of the causes of hard starting you have seen within...
  18. Any 1 running Valvegod's LS6 shortblock
  19. 01 Factory cam specs?
  20. iron block
  21. My cam choice....opinions?
  22. Rocker preload
  23. Oil pressure question
  24. MMS tuning/Hotcam results...
  25. two things
  26. Stroker cranks?
  27. 6.0liter swap
  28. Valvespring Broke ..
  29. car smells bad when i get on it inside only???
  30. rev limiter problem upon installation of TR224 cam?
  31. Broken head bolt...
  32. hot cam vs tr224
  33. X1 or F1? Differences?
  34. Oil pressure question
  35. Paging Joe Valenti
  36. Rollmaster timing chain setup?
  37. Need cam specs for a stroker!!!
  38. Opinions on ARP rod bolts.....
  39. Questions about 6.0l
  40. ls1 stock valve size?
  41. 941s or 918s ???
  42. Car is seriously screwed and Im about to start tearing out hair
  43. Fel Pro Head Gaskets for ls1--compressed thickness???
  44. Cam Motion has ne one delt w/ them??
  45. Royal Purple #41 racing oil analysis results
  46. ls1 crank options ????
  47. 2.08 or 2.05 intake valves???
  48. rocker question?
  49. Milled heads question...
  50. Anyone use Isky Springs???
  51. Aftermarket Oil Pump and Timing Chain
  52. TR220 has 4 degrees advance built in > Retard it 2 degrees?
  53. oil pressure super low
  54. C5R heads
  55. Why does the LS1 rev so high with a small cam?
  56. AF ratio, can someone explain
  57. Valvetrain Noise or Piston Slap
  58. Pretend you're a newbie... what do the numbers mean?
  59. Whats the difference between Comps 978&987-16 dual spring?
  60. Experts inside, curious as to how car feels stronger with more fuel in tank
  61. Help me pick a cam...
  62. Do 382 and 422 strokers use same rods? What rods to use?
  63. Adjustable timing chain???
  64. the feel of a head and cam package???
  65. 4.00 or 4.125 stroke
  66. Wiseco forged pistons?
  67. engine year choice for swap
  68. good cam to run on stock programing?
  69. 382 all bore question....
  70. What are the specs of a 3/4 race cam?
  71. ls1 engine quiz......
  72. Good TORQUER cam for a 382/383 stroker?
  73. clearancing iron block for 4.00" stroke
  74. 500 RWHP goal
  75. 4.8L heads/how much h.p
  76. Looking for the link about cams, emmissions, and user feedback
  77. Valvetrain noise and KR?
  78. Titanium Retainers vs. Stock ...
  79. C1 cam w/ stock heads -- dyno results
  80. Ok.... so explain head studs...
  81. This GTP/TR combo
  82. Very Rich Condition
  83. LS1 PISTONS.......LOOK INSIDE
  84. Food for thought on some bigger Stroker Combos 480 inch LS1
  85. TURBO MOTOR, aluminum or cast iron block?
  86. Sold T1 Cam...now need input on this gnarly cam
  87. Help.Piston to valve question with 230/230 cam
  88. What do u think of this setup?
  89. which heads are better for me?
  90. Rod length/stroke ratio....educate me please:
  91. Set-up, does it make any sense?
  92. Thunder 230 or M.T.I. X1 cam info needed
  93. Porting heads - Intake airflow ??? w/ pics
  94. all parts for my winter project what should i expect
  95. ? after dyno run today
  96. pushrods in 01' ls1, are they the same as 03' ls6?
  97. head/cam, stock manifold guys, questions...
  98. PISTON SLAP!!!!!!!!!!!!!!!!!
  99. 408 vs. 422
  100. Flow # Dyno #on MTI S2 heads and X1 cam
  101. Found out the problem with my oil pressure problem
  102. New cam coming soon! :)
  103. X1 cam, Stage II heads milled.060 with an .043 thick headgasket???
  104. Blown head gasket?
  105. Head Studs....Hex vs. 12-Point
  106. White powdery residue around head and block, did I lift the head?
  107. Engine bore questions...
  108. Roller bearing Cam, has anyone done this
  109. ** Polished Combustion Chambers **
  110. Will there be any clearance issues on the block with a 382 stroker it?
  111. What do you think it will take to get 500RWHP out of a 346?
  112. 5.7 VS. 5.3L heads
  113. GTP VS. TEA S2 Heads
  114. 6.0L block, doesn't have iron liners? right?
  115. MisFire Code?
  116. Looking for 37# injectors! Who's got em?
  117. MTI Stage 2 heads/C1 hammer cam Dyno and track results
  118. Retainer Question
  119. LS6 or stage 3 heads for 422
  120. Overheated my ls1, how to check for damage
  121. 6.0L LS1, bigger bore, stroke, or both?
  122. What mods are good?
  123. tr-224 cam
  124. TSB on Excessive Oil Consumption need advise
  125. Looking for some cam advice
  126. Resolving knock with...
  127. Thinking of degreeing my cam in...
  128. bent push rod, need new cam - what's best to do
  129. cam is on it's way- what else?
  130. How high can you rev stock springs?
  131. Fuel cell
  132. Valve train setup with F1 cam...
  133. 4 valves or 2 valves?
  134. CNC LS6 or Stage II LS1 Heads?
  135. Rollmaster Installation
  136. built 6.0. opinons plz.
  137. Engine Damage - How Bad Is It? Need Input
  138. WTF is wrong with my car??
  139. UPDATE........Valves hitting pistons = Trashed motor
  140. Camaro SS
  141. 382 Stroker questions...
  142. ? about lifter/valve spring preload + some other ?'s
  143. Need HELP !!!something is making my front O2's crap out ?
  144. H Beam vs. I Beam Rods for the ls1?
  145. To acheive a 408 on a 6.0L...
  146. got to dyno finally
  147. Cam question
  148. Timing cover gasket removal
  149. Sounds like audible pinging, but no KR?
  150. TR 224 Cam
  151. 6.0 or LS1/LS6 Motor???
  152. machining of the C5-R block for wet sump - what needs to be done?
  153. question about Speed inc.
  154. Where can I get a LS1/LS6 block...
  155. How do you degree a cam with the heads on?
  156. HELP!! Anti-Freeze EVERYWHERE!!!
  157. oil pan
  158. C2 camshaft owners inside please
  159. Tore the motor back down......H-o-l-y shit
  160. tnt wet on head and cam car....
  161. whats a good shift point for a 224/224 114 cam in a A4?
  162. Serious questions& concerns on my TEA heads
  163. What about the 8.1L?
  164. Who has the highest mileage on a 382 stroker? A longevity question.
  165. stock flow numbers?
  166. new cam valve train is noise?
  167. new cam valve train is noise?
  168. Absolute Speed Stage II +TR cam 11.27/119.7 first time out
  169. Help w/engine choices 382 stroker/bore or 422
  170. Has anyone heard anything about Evans cooling?
  171. Just pulled the rockers and plugs......Crank still won't budge
  172. NEED HELP!! Car Is Slow
  173. need 10 under crankshaft bearings?
  174. ANyone use and run goo numbers with normal split pattern (more exh. dur.) cam?
  175. Need Help ASAP. Front Knock Sensor Question
  176. What if a shop told you your rebuilt STOCK motor..
  177. What if a shop told you your rebuilt STOCK motor should not be taken to 5800RPM
  178. What cam are you using in your stroker???
  179. need cam advise ASAP!
  180. NEED SOME HELP HERE!! Fuel related
  181. What would happen if a grain of sand was in engine?
  182. SLP cam...
  183. ** 496rwHP NA through mufflers from my ARE436ci after X-pipe addition --->
  184. For you Joel, new dyno #'s (471.6rwhp, 505rwtq)
  185. Maximum Displacement for C5R block?
  186. How Much Hp from ls6 intake and 2001 ls6 cam or hot cam?
  187. How much hp & tq can a stock ls1 bottom end handle
  188. Is it possible for me to achieve 400 rwhp with the following?
  189. Rollmaster/ASP please help!!
  190. 370hp
  191. Rod Bolts
  192. Hydrolocked engine...head gasket??
  193. Double row timing chain and cam at same time
  194. C-1 cam from MTI
  195. Katech pump idle pressure?
  196. Why not CNC S2 heads over GTP S2 heads?
  197. Paging Thunderracing/Geoff
  198. Whats the benefti of high compression?
  199. Push rod length qustion
  200. What rod bolts to buy?
  201. 6.100 VS. 6.125 rods?
  202. Next logical step up in cam???
  203. QUICK.... How good are the Eagle H beam rods???
  204. Stage 2 Heads/Cam base dyno numbers 436 rwhp/394 rwtq
  205. 6.0L heads for temporary use
  206. JPR heads/tr224 cam dyno#'s
  207. Listen to this knock on a buddy's Z28 please
  208. Need a machine shop in Dallas, TX area
  209. ARP 12pt head bolt torque specs..
  210. To build my engine a little bit.
  211. Timing Chain and Lifters???
  212. Press fit connecting rod pins
  213. How do these flow numbers look?
  214. 96 TA Oil pressure issue
  215. T1 dyno - what do you think?
  216. Compression using 5.3 unmilled heads?
  217. Noisy lifter solution?
  218. Stroker vs. Bore: Why the big cost difference?
  219. GTP
  220. get oil pan off with motor in the car?
  221. engine builders inside please.....
  222. TR 230/224 Users! ...inside please!
  223. Different cams same motor?
  224. HRT 427 cubes, WOW!! Tech info & web link inside...Also new c/f C5R intake manifold..
  225. Holden 427...
  226. What is the bennefit of a 2.02 valve in a stock seat?
  227. which cam with stock heads?
  228. Does stroker crank use same rods/pistons etc?
  229. Would Stage III heads be good on a ...
  230. Stroker cam ????
  231. 2.055 intake and 1.55 exhaust valves, too big for stock cubes?
  232. hole in tb?
  233. Cam base circle difference...
  234. Heads and Cam ?
  235. What is the optimal spring pressure for TR224? Thanks.
  236. Where to get head and header studs?
  237. Which would be better...
  238. 6.0L Turbo Pistons/Rods
  239. Small amounts of metal on oil drain plug
  240. Rev1116 double springs?
  241. Anyone running a 4.125 inch stroke
  242. Has anyone had clearance issue when using .563 intake and .568 exhaust for a cam
  243. dipstick tube stuck...uh oh???
  244. What is the best all around cam for....
  245. TR vs. Comp Cams...
  246. New heads are on the way....flow sheet and specs:
  247. So, why all the new interest in ported 5.3 Truck Heads?
  248. >600" lift and springs
  249. 400 rwhp w/ no headers or heads.......is it possible
  250. To achieve 11:1:1 compression.....
