View Full Version : Generation III Internal Engine
  1. 6.0L heads question
  2. Solid Roller Specs! I need them...
  3. MAFT setting after installing TR224/112
  4. NEED HELP WITH 02 ZO6 CAM SHIFT POINTS
  5. UPS just dropped off my new cam!
  6. TR 230/224 cam and drivability?
  7. HEADS ARE IN!!! :)
  8. B1 owners inside
  9. GTP anyone???
  10. TR 224/224 .561/.561 112 vs. Comp Cams 224/224 .563/.563 112
  11. 98-99 m6 cars,STOCK dyno#s????
  12. photos gm 2002 cnc ported ls6 heads
  13. What kind of power should I expect?
  14. Let's talk a bit about internal engine measurments....
  15. At what point does your car lose its "stock" status???
  16. a PCV idea
  17. What to take off to pull motor out
  18. Need some cam suggestions
  19. Ca emission legal set-up help needed
  20. My ARE flow sheet for 5.3 heads
  21. FYI
  22. LS1/LS6 springs/retainers/keepers info??
  23. Pulling the engine out question.
  24. Should I have a higher or lower exhaust duration on cam with stock heads/no headers?
  25. How good are the stock rods with ARP bolts?
  26. What cam for 01Z28 M6 w/stock heads, full catback, no headers, DYNO #'s?
  27. Janzter's heads?
  28. G5 cam dyno results
  29. How are my Flow #s?
  30. You guys with 382 strokers... what do you rev to?
  31. Any benefit of the TR 224/224 with stock exhaust?
  32. High-Perf springs don't last???
  33. 413 stock 98 head dyno sheet
  34. What does stock heads flow at, I might port them.....
  35. Scratch on retainer
  36. Pistons, dome, flat top etc.
  37. MTI Stage2 LS6 heads and X1 cam Dyno #'s **link to graph is now up**
  38. Teach me all i need to know about pushrods!!
  39. Head/cam suggestions for a 382 Stroker
  40. Question for those who pulled the motot out from the top..
  41. Great googly moogly.....cam specs for 230/224 TR
  42. Head surface Q's....
  43. Opinions on my 409 plans? I want the ultimate sleeper.
  44. Results on engine swap are in!!
  45. All the bolt-ons minus the ASP pulley = 367rwhp!
  46. The Plan: 414"; Solid roller; Iron Block; need help.
  47. 915 springs?
  48. cam or heads and cam?
  49. Rev1116 double springs?
  50. Cam Swap Question
  51. duration and LSA
  52. rule for added duration for displacement???
  53. new cam.verter...REALLY BAD gas mileage????
  54. P/V clearance issues.
  55. Rocker Arm failure
  56. Installing a Cam - Read Before Drilling the TB
  57. Is this a good cam for forced induction?
  58. F1 Cam In!
  59. Cam Question
  60. how to tell if i have a bad/broken valve spring???
  61. Remember folks, the LS-6 block doesnt mean LS-6 pistons, LS6 PCV, or LS6 heads.
  62. o ring to seal it??? Does this need to be replaced
  63. whast is the stroke on 6.0
  64. When to change to Synthetics????
  65. Stupid oil question
  66. formula for cubic inches
  67. comp 918 lift question
  68. going to install cam this weekend!!
  69. Anyone seen the Katech article on 941 vs 918 springs?
  70. Do these end gaps sound right?
  71. Idle: TR 224 vs. T1
  72. G5 Cam and Emissions???
  73. MTI 422 ORDERED!
  74. Engine rebuild questions...
  75. Did thermostat stick, or what?
  76. 382 update: New cam is in!!
  77. How many miles are 918 springs good for?
  78. speed control
  79. Dragula Update: Something must not be right
  80. 500 rwhp streeet driven
  81. Thanks NINEBALL
  82. New dyno numbers for TR224/114
  83. Thunder 224/224 vs. 230/224
  84. XE-R cam vs. Thunder cam
  85. Cam swap parts?
  86. going with a new motor next season
  87. Anyone Fast Running Over 4" Stroke?
  88. Anyone running or know someone running High Flow ported LS1 heads?
  89. Valve Spring Height and Seat Pressures
  90. Valve Train Geometry
  91. Whats the maximum difference....
  92. PLEASE HELP ME
  93. MTI 422 + Nitrous = 807 rwhp
  94. i know it is internal
  95. I NEED MORE POWER! Cam suggestions
  96. What makes a head good? Why are some heads really expensive and others cheap?
  97. offset ground crank question
  98. How to I check my bottom end? (any tests I can do from home?)
  99. Z06 cam
  100. Son of a motherbitch!!!! Dropped pickup tube bolt in oil pan.....
  101. 6.0 heads vs LS6 heads for 422/427 Iron Block Engines???
  102. Anyone running a cam from Katech?
  103. iron LQ4 427 (4.060 by 4.125)... Why not?
  104. Dynograph of my ARE436 – 485rwHP/495rwTQ through full exhaust
  105. Second guessing my 112 LSA decision
  106. Installed new JPR Stage II Setup!!
  107. 382/383
  108. TR 224/227 114 LSA Cam
  109. External balancing
  110. Needing info on a 6 litre block....
  111. Parts for cam install
  112. MTI cam question??
  113. gm lifter preload
  114. oil drain plug washer????
  115. Head Install question
  116. Re-Sleeved Block Secrets Revealed!
  117. break in
  118. What Happened to the 918 thread
  119. how much is MTI 422 with stage 3 heads?
  120. Used camshaft.
  121. Bigger valve Heads or new Cam?
  122. TR224 Cam Upgrade in Progress ( pics too)
  123. reverse split and emisions
  124. Bronze valve guides/liners??
  125. Who had a warrantee "Re-Ring" job and blew thier motor?
  126. Camshaft LSA explained and tested
  127. Heads and cam package
  128. JPR heads and thunder cam
  129. Mr. Moly Engine Oil Modifier (first impressions...)
  130. My latest oil analysis, Valvoline Maxlife
  131. How big is too big with reverse split cams???
  132. Running lean in high rpms...Possible pinging?
  133. is z06 cam worth the install????
  134. Ordered a timing chain from Katech and......
  135. Katech Oil pump failure
  136. TR 224/Shaner S2 dyno numbers
  137. Installing Heads and Cam next weekend, do I have everything???
  138. Those with G5 cam...
  139. Cam spec ?
  140. Any Problems Using Thicker Than Stock Head Gaskets?
  141. LS6 block in 01/02 F-Bods?
  142. cam installed, but i think i need headers?????
  143. lots of smoke comin outta the back of the car....
  144. not again, no oil pressure!
  145. anyone have gm cnc ported ls6 heads
  146. How to remove oil pan?
  147. valve spring broke on MMS heads. now question.
  148. Stage 1 heads and cam A4 dyno results!
  149. do you have to re-torque heads studs?
  150. Big motor guys: If you had to do it all over again... iron 408, AL 422, 427, 434?
  151. Question
  152. 382 Stroker VS. 382 All bore?????
  153. Nineball - Status of your 434ci?
  154. Turbo motor?
  155. PRO MAGNUM LIFTERS or Genuine GM Replacement Lifters?
  156. MTI Stage 1 or 2?
  157. Should I do a test on GTP heads?
  158. my 422 install...
  159. LS1 vs. LS6 ported heads
  160. 4.25 stroke too much? please help :)
  161. Low Oil Pressure, Possible Causes??
  162. Opinions 228/228, 557 lift 110 LSA
  163. JPR stage 2 heads/thunder cam
  164. Cam install, I have a timing chain question.
  165. Cam Choice, Please Help
  166. The facts about LSA on cams
  167. anyone know where i can get these bolts?
  168. MTI Cam question
  169. How stealthy is a TR227/224? Video inside
  170. 230/230 type cam...
  171. How to break-in new LS1
  172. Dragula update 9/26/02
  173. 422 or not to 422, that is the question
  174. Car wont start.....need help
  175. Best set of heads for...
  176. What timing chain, where, and how much???
  177. 01+ LS1 question
  178. Need GM part # for LS1 head Valve seals......
  179. How bad is gas mileage on...
  180. speed control
  181. My car is back, dyno #'s with in....MTI heads/X1
  182. titanium retainers
  183. timing chain oil pump :?
  184. Heads Cam Suggestion for my setup
  185. LSA question
  186. 114 lsa or 112?
  187. *** IMPUT NEED FOR PISTONS ***
  188. Internal Engine experts, Help!
  189. flowtech cutout
  190. Cam upgrade - needed supplies?
  191. Help with valve spring choice
  192. 4.56 Gearing
  193. GTP S2 & PIG cam dyno results on A4
  194. 112 or 114
  195. How many have idle problems after new cam?
  196. Is my thinking flawed here???????
  197. Cam Help Needed Please!
  198. Anyone with a built blower motor shortblock??
  199. changing chain?
  200. What is the combustion chamber cc on the 5.3L truck motor?
  201. Heads are ordered, what cam do you think?
  202. What's the best & affordable Heads & Cam package out there?
  203. maximum bore for a 6.0?
  204. Need Insurance info on Hydro-locked Engine
  205. anyone know weight difference in 6.0 and ls1 blocks
  206. Spoke to Brian @ TEA
  207. Still surging after cam a little
  208. S1 Cam users, what springs are you using?
  209. First Impression of ARE's 232 Cam
  210. C5R Valve Cover Owners (Step Inside)
  211. Does anyone have an X1 cam in ther ls1
  212. What does it take to go REAL fast?
  213. Bored Iron or Aluminum Block?
  214. JPR Stage II heads :)
  215. Best reasons to get forged components?
  216. Differences Between Same Displacements
  217. Jumpy oil pressure after new engine install, and its got a turbo.
  218. dyno #s for C1 cam and stock heads
  219. Please read!
  220. 413/393 on stock LS1 heads
  221. easiest way to get motor out....
  222. ARE H/C 402 RWHP, 381RWTQ, Unlocked
  223. Average cost for Cam install
  224. What modification is required when using Rollmaster and ATI Balancer?
  225. roller dyno emissions Q's for you all
  226. SeaFoam great product
  227. H/C setup???
  228. Does anyone have X1 cam on 383 stroker
  229. Preparation for MTI S2 heads/cam
  230. How to bleed the engine coolant??
  231. Numbers match???
  232. Ridiculous Oil Consumption
  233. What's the best way to administer SeaFoam?
  234. 98 versus 99 heads
  235. 5.3L motor specs?
  236. Anyone know what valve seals GTP uses (not the ones assembled by Thunder Racing)
  237. GIANT cams...
  238. Does anyone have a dyno graph of the TR224 vs the TR220 on a similar car?
  239. new timing chain and oil pump? H/C questions
  240. magazine article showed how to resleave block...
  241. Seeking cam info........
  242. G2 heads
  243. What`s the skinny on the ASA Hot cam???
  244. What all is needed to do a 382 stroker
  245. Cam for road racing
  246. Which engine combo ???
  247. 405rwhp unlocked converter with G5 cam but new 1/4 mile
  248. pics of ported oil pump?
  249. Dyno: GTP Stage2/TR227 vs ARE stage2/MTI-B1
  250. Valve Length Help
