View Full Version : Generation III Internal Engine
  1. cam w/nitrous
  2. Oil pressure question?
  3. Thunder 230 hauls ASS
  4. Why does a large cam make a car lope
  5. tr224/224 112lsa
  6. Give me cam suggestions for 422. Something different..
  7. highest 5.3 head compression?
  8. Annoying tapping sound needs to go away
  9. Questions for putting an LS6 into a FBody as well as a cam
  10. Combustion chamber on a 5.3L ??
  11. Bore on a 5.3 motor?
  12. GTP 4.8L heads are on!
  13. Cam break-in?
  14. 4.8 bore size
  15. We have a great sponser
  16. tr 224 installed!
  17. 5.3L HEADS ON A 99Z?
  18. Is 383 worth it?
  19. How to remove and install freeze plugs
  20. How much for standard engine rebuild? heads and cam? and Stroker to 383?
  21. LS1 Block's max hp/torque rating..?
  22. Which head gaskets & bolts to use?
  23. 2000 LS1 Injectors??? HELP!
  24. What is this cam??
  25. has anyone tried RGR heads before
  26. Big Bore Blocks?
  27. Cam in finally..now a few ???
  28. 382 Stroker Kit ?
  29. to get a cutom grind or not....that is the question????
  30. Head Studs Torque Specs?
  31. Cam suggestions
  32. heads and intake
  33. "Hard Anodizing" Cylinder Heads?
  34. crank questions???
  35. Why do people use 5.3 heads instead of 5.7's
  36. What size rod for a 375cid LQ4?
  37. Base circles of these cams?
  38. GM dealer does not change head bolts
  39. 112 lsa cam in a A4
  40. Can you guys help analyze my dynosheet from the TEA stg. 2 heads and TR 230/224 cam??
  41. Dealer wants to replace rings
  42. Anyone know the base circle of a b1?
  43. Anyone here run 6.0L heads milled back to stock compression?
  44. What size valves do 5.3 liter heads come with??
  45. What kind of gains can I expect from this?
  46. ARE STAGE 1 HEADS
  47. Whats the best fuel pressure?
  48. claying for p/v clearance
  49. Humor me: 10° valve locks for Comp 750 retainers
  50. Some real truth regarding Crank HP versus RWHP
  51. 6.0 vs LS6 heads
  52. Cam is in dot to dot, is #1 cyl about to power stroke or intake stroke?
  53. Crap,when I installed my b1 about 4000 miles ago didn't put loctite on cam bolts..
  54. TR220 or TR224 on a 114 center
  55. Re-torqueing head gaskets
  56. How much compression can you run with stock timing...
  57. Anyone ever done a LT1 to LS1 swap?
  58. Reading through the comp cams install guide......
  59. 918's vs Isky springs?
  60. 918's Vs isky's?
  61. What would cause this to happen???
  62. Knock Sensor Question need answer ASAP!!!
  63. Question regarding Lobe sep/Intake centerline?
  64. How do you determine the correct length pushrod?
  65. Ok, decision time, need input, please....(Valve size question)
  66. replacement motors
  67. Help No oil pressure!
  68. Any differences between 1998 and 2002 short blocks
  69. 383 Stroker Question
  70. How do I know if I was sent the correct timing chain?
  71. Where to buy Redline oil?
  72. where to get good forged pistons for cheap?
  73. What gives when springs bind and pushrods doesn't bend? CC 941's
  74. Calculating compression on 5.3
  75. Cheapest Heads?
  76. MTI stage 2 LS6 heads and X1 install complete!
  77. Head flow number question. Post your info here.
  78. RP users come in please!
  79. LS1 HP BUILDUP PLEEZ HELP
  80. $150 for plug wires?!!??!
  81. Anybody running Internet Racers Supply heads?
  82. Difference between 5.3 and 5.7 engines...
  83. What would be the max horsepower out of a 346ci Solid Roller?
  84. pistons
  85. Why no gear drives for LS1's?
  86. 918 Springs......comments please!
  87. excessive smoke on decel
  88. ported heads and matched intake
  89. Should I upgrade head gasket and bolts with my setup
  90. Roller rockers for LS1 - without higher lift
  91. Head&Cam pack. install center
  92. Best Heads for Comp Cams Extreme
  93. H/C installed, no gain.
  94. Is this cam too much for stock heads?
  95. Any benefit to a 113 LSA over instead of 114 LSA for a medium sized cam?
  96. weblink for Katech oil pump and Jwiss chain
  97. Will I need to flycut pistons?
  98. LS1 head casting #853
  99. SERIOUS CAMSHAFT QUESTIONS!!!!
  100. Valvetrain noise with TR224?
  101. Aluminium heads on Iron block, is it ok?
  102. TEA HEADS
  103. Can I mill stock heads 40 with a T1 cam?
  104. Used MTI Stage 2 heads.....
  105. Building an LS6 motor, questions about HP/TQ......
  106. Another TR224 Horror Story
  107. Comments on New GM Hvy Duty Timing Chain & Damper??
  108. TR 224 cam install
  109. does everyone else have a little smokish mixture from exhaust when its cold out?
  110. Oil pan gasket
  111. How long does the oil pump take to catch prime?
  112. Short Block experts- Come on in
  113. The b1 and c1 cam from MTI
  114. Paging SPANKY LS1
  115. Will these Ti retainers work with Comp 918s???
  116. 88958608, 88958607???????
  117. Question about 2.02 &1.60 valves, and new seats....
  118. A.R.E Stage II heads with 2.08/1.60 valves...need some ?'s answered....
  119. Rings are fried-opinions please.
  120. nitrous cam
  121. 1999 Shop Manuals
  122. My Thunderracing cam package arrived today.
  123. Does the MTI C2 camshaft have to be degreed????
  124. What should i do to get HP?!?!?
  125. nitrous cam
  126. Re-ring engine possible in car?
  127. Anyone running or know about the lunati 73043 dual springs?
  128. Spark plugs running lean, is this real?
  129. bought hotcam how do I know it is for real?
  130. Carbon Removal
  131. Solid roller ??'s Good for juice? spring size? etc..
  132. 9/6/02 Project Dragula Update
  133. What is the thickness on stock GM head gaskets?
  134. Valve/Valve seat question for the experts
  135. destroyed thunder cam
  136. Help me to got the right cam ..
  137. Question about the Isky's 295-D's
  138. Anyone know why this happend???
  139. Timing Chain and Oil Pump
  140. 00 Vette and F-body LS1 differences
  141. CAM install went BAD!! OMG im stressin
  142. 224/224-114 TR cam?
  143. Dirty Valve
  144. PSJ and some of you other LS1 gooroo's I need some help BAD !!!!!!!!!!!!!!!!!!!!!!!!!
  145. Worst case with a broken valve spring?
  146. Hotcam owners....
  147. Long & Short Blocks, whats the difference?
  148. My new motor has no oil pressure
  149. Forged Bottom End
  150. oil pressure??
  151. another head question
  152. Used ported LS1 heads Vs. New LS6 heads
  153. H/C install quote
  154. Head porters: What flow #'s should I look for to match w/ my cam?
  155. Oil consumption after H/C install
  156. Please help! Motor making noise
  157. 5.3L head questions
  158. Who here has UPGRADED LIFTERS?
  159. would I need a 12-bolt?
  160. JPR - where in Hainesport, NJ?
  161. Oil pressure Guage
  162. Synthetic Oils...Royal Purple v Mobil 1 v Redline
  163. Are these SHORTER PUSHRODS OK???
  164. Best place to buy stock pushrods?
  165. Who's had work done at Strope's Speed Shop?
  166. Any way to clean injectors?
  167. ls6 heads
  168. New Project
  169. Paging Vince
  170. What are XE-R lobes?
  171. This is why you shouldn't remover your knock retard... Pics inside:
  172. TR 224 cam only results
  173. Comp Cam 220 / 224 - anyone using this cam?
  174. MTI Stage 2 Heads+ X1 Cam?
  175. Cold start b1 problems..??????????
  176. A little reassurance please? (918's)
  177. MOD ideas
  178. cam and nitrous?
  179. C.I. ?
  180. Bore/Stroke Ratio for FI?
  181. Help please New Motor =No Oil Pressure
  182. This sound like a broken valve spring?
  183. need some tech help
  184. need some tech help
  185. need advice with the dealer repair.
  186. here are dealer cost on gm hot cam kits
  187. What CR could we get away with via reverse-cooling?
  188. Anyone do their own cam install?
  189. What damage can bent pushrods do?
  190. Stage 3 heads
  191. Top end cleaners?
  192. Help with 5.3L heads quick!!
  193. SOMEBODY has to make a better intake manifold!
  194. Which pushrods to get?
  195. whats a good head?
  196. T&D Machine Shaft Mount Rockers
  197. Head stud torque suggestions
  198. Looked but can't find!
  199. anyone dealt with more performance?
  200. What does a motor need to run some serious rpms???
  201. Crankshaft question for a bud.
  202. Please Help!
  203. head help
  204. A warning to all about EMT racing aka Shandy Price
  205. GTP stage 2 heads and B1 cam dyno #'s within
  206. Lifter or Pushrod
  207. ls6 cnc ported heads?
  208. Compression check
  209. CompCams 26915 broken springs
  210. Engine ruined. Where to buy longblock?
  211. Valve spring lb ratings?
  212. 5.3 heads for sale
  213. Debate: Hardened pushrods vs. stock pushrods
  214. Got a 226/.570. What gains should I expect?
  215. Them there liners get surface rust QUICK
  216. california emissions?
  217. Aftermarket springs/pushrods on a stock cam?
  218. Aftermarket springs/pushrods on a stock cam?
  219. Paging Patman, Oil question...
  220. Going to try an aggressive cam and try to pass emissions
  221. 98 heads,same as '01 heads except for valve covers?
  222. SLP timing chain + ASP pulley?
  223. Whats the odds of this happening again?
  224. Project Dragula is fixed... No more backfiring
  225. SLP timing chain question
  226. NEED HELP "MISFIRE PROBLEMS"
  227. What peaks higher- 112 or 114 lsa?
  228. Who sells sleeves for the Ls1 engine?
  229. another CR question
  230. GRB... 427 C5R ZL1 Project Camaro
  231. new at this
  232. california strokers and smog check?
  233. coolant question
  234. Need expert advice, PCV removal, and how crankcase pressure causes oil usage
  235. broke oil ores. sensor/part # for aftermarket unit?
  236. NEED ls1 engine builder within 5 hours of pittsburgh PA
  237. ss camaro ls1 setup
  238. 7 cylinders 185 psi 1 cylinder 250. Whats up?
  239. What happens with a broken valvespring?
  240. Water in engine
  241. What is the JPR EGR delete "thing"
  242. (Yet another) cam advice post
  243. Break-in questions
  244. Will this setup work
  245. Does anyone have the GM part # for the LS6 Block?
  246. How much should I expect to pay for a cam swap?
  247. Should I change lifters with head swap
  248. CID Formula
  249. Attn: people who have milled heads
  250. 2001 Z06 cam questions?
