- Better cam for spray???
- 2001 LM7 fuel rail connectors
- summit racing?????
- Double check my pushrod measurement?
- LQ4 engine with LS2 Top End
- Head Selection
- Spun rod bearing and $2500, what to do?
- Increased valve diameter..
- ls6 cam question
- My engine is back...
- 1.8/1.82/1.85 rockers - good, bad or ugly?
- Will stock valve stem locks work with Patriot Gold retainers?
- Oil Pressure or lack there of. (Dry Sump)
- About to give up on this car
- Procharger - STS - Or N/A
- heads and intake for ms4 cam car
- Pushrod length?
- Anti seize-aluminum heads
- How much Power should this Torquer v.3 Combo make at the wheels?
- Cam installed finally
- Need help h/c set up
- biges T/body with Weiand Intake
- manual fan switch help ??
- 408ci roots blower build
- coolant crossover lines question
- '01 Z28 bogging down during mid-throttle
- Cracked Block
- ls1 to ls6 conversion ?
- Head bolt torque #9 bolt
- I know, another CAM advice thread
- Rings For Diamond Piston 4.030??
- Callies H, H-I, and I Rod Strength?
- Fellas with the TSP torquer 2 cam chime in.....
- Best brand cam??
- need help checking ptv with clay
- Wiped cam lobe and damaged lifter
- Help! Camshaft bolts breaking!
- Ls2 timing chain in a Ls1?
- PSI valve springs??
- Oil pickup tube girdle: gauging intereste before I have them made
- Injector Horror Story (Internal engine related)
- Ls1 heads cam tune question
- LM7 will not start.
- Another stock rod bolt question.
- Anyone running world warkhawks new 15 deg.head with their cam.
- 2000 ls1 high mileage rebuild
- cam numbers???
- ring ?'s
- resizing cracked-cap LS rods ?
- Slight over look now I need help
- Can I remove water neck from pump?
- Piston ideas for a LQ4 build.
- Budget N/A LQ4 build for hillclimb/sprint/circuit car- What would you do?
- bent push rod...whats a good chromemoly push rod ?
- Can a LQ4 Block be Dry Sleeved out to 4.125 Bore?!?
- I bought a ton of new parts..........
- lq9 and what cam
- head gasket
- Connecting rods
- tr-55 plug gap ?
- 99. 5.3 stock build. ls6cam??
- 500+hp?
- Need Opinions
- Pushrod lenghth ?
- ls1 engine noise = bent push rod .... now what ??
- Outer main bolt hole stripped (thrust bearing)
- LS6 block 2004 revision
- 02-04 LS6 Cam
- Vindiactor and 243's question
- JT's C5Z Exhaust and Cam Build
- Mast 275 cath ports
- Cam bearing question, please help.
- 98 Z28 fresh heads & cam - Would like some opinions.
- Trunion upgrade jig?
- cam bearing...should it be replaced?
- LS1 Build
- What stall for a 231/239 cam?
- 408 opinions on the build please
- PAC dual valve springs
- ticking from passenger side
- Quick ? starter bolt size
- Cam Advice
- nitrous on an eps 230/234?
- installing front and rear covers
- Stock Rocker Tech!
- CNC LS1 heads or LS6's
- LS-1 383 build opinions?
- LQ4 (LS2) 4.125" stroke 427ci kits- Where from?
- Piston ring powder
- Best valve springs for 228r cam from tsp?
- Bearing Vendor
- Biggest cam !!
- stock ls1 rod resizing
- Good and bad about the 6.0
- Cheater cam w/ everything else stock
- Stock lifters with cam swap?
- LS1 383cid | PRC 227 | EPS Cam | TEA Vic Jr..Build Thread !! (UPDATED WITH DYNO)
- Cam ???
- Gurus, need suggestions on pushrod length
- head cam set up
- new cam thats nitrous friendly?
- Base Circle Measurement Data: TR224 vs. LS6
- help!!!
- where to buy valve seats and seals for bronze valve guides.
- Look at this plug, isnt this too rich?
- Would 873 Cast iron heads work with a 5.3 block/crank and 5.7 LS1 rods and pistons?
- Hissing sound near intake/injectors
- ls6?
- WHat is a good Head/Cam package?
- Un-freakin believable. I will be da@#ed!!!
- fuel mileage?????
- front crank seal
- Do I have valve float or no? Dyno graph inside, need opinions
- rebuilt 383 stroker LS1 knocking noise help!
- Is a stock o-ring a good replacement for a melling 10296 oil pump.
- New problems crop up...
- Rocker arm choice
- What's the largest cam i can run on an ls1 with stock heads?
- LQ9 With LS3 top end, back fires after warm up!
- 5.3 heads
- Cam question
- building a 6.0, thinking about 5.3 heads...valve clearance question?
- Rebuilt motor zero oil pressure help!
- LS6 Cam question
- Replaced Cam, Now misfiring
- Need help with oil pump I just got....
- Need help, . . been out of the game for awhile
- GM ls7 lifters failed
- need to know bolt size or part number
- choice of 2 cams, which one?
- Newb Question, I have searched A LOT
- ls6 cam?
- antifreeze in oil and loud knocking
- Stroker piston used on a normal stroke
- Need a lil help car running bad now
- anyone spin a ls2 chain above 7k?
- Fuel sending unit?
- 160 Thermostat reflash???
- stay with dish pistons?
- What camshaft is the best to make around 390-410 rwhp?
- Comp Cams Valve Spring Compressor
- oil pump rebuilding
- spring size ?
- Almost done with cam/spring swap butttt...
- noob thread just a quick ?
- Coolant flow - heater valve set up
- third gear grind!!!
- spring guide for my cam????
- Help cant decide on what to put in car
- Springs for Turbo Car
- not torquing rocker arms to spec
- Another newb question - writing on my crank???
- Need some help with my 5.3 build.
- Best heads for me ???
- Cam Reccomendation: 98 LS1, 3800 Stall, 4.10 Rear, Full Exhaust
- :( car wont start after head and cam
- iron block 408.. is there any way to visually identify internals?
- Cam for ss3600 stall?
- 6.0L For Street Performance
- difference between lifters? ls6 to ls7 gm
- Cam walk
- In the midlle of intalling my torquer 2 cam....
- cam swap question
- Need to know what cam to install
- My car wont start! Help please
- Yes, another noisy valvetrain
- What you think about my new setup
- ls1 with h/c/i numbers 434hp/402tq!!
- Stock piston/rod differences
- What Would DCR Be For 220/220 110+4 Cam on XER Lobes in 4.8L or LS1?
- head gasket leak question
- ls1 Zex Nitrous Oxide System With Extras
- which EPS cam for spray?
- Cam swap question
- cam/heads/stall questions
- Lq4 machining ?
- Do I need rod bolts?
- How to check for proper pushrod length???
- Yella Terra's rubbing on 243 heads...
- Cnc ported 799 heads
- Can I run an MS3
- Building a stroked ls1 for fuel mileage?
- Compression check pointers........
- 243 Head on the new 4.8L is the same as the ls6 head
- Oil leak question
- Cylinder Pressure LS1 - LS6
- LS7 Valve Springs on 241's
- Cam and push rod question
- LS1 TB question
- Should I change them
- Collapsed Lifter, maybe a rod?
- Coolant temp sensor popped out of radiator
- Pushrod length- seem right?
- suggestions?
- Top Hat Seals
- stock, modified oil pump vs. aftermarket?
- My high compression 364/LS3 heads build
- help me identify this camshaft please
- What is this? 56k stayaway
- LS6 Cam w/ LS1 heads??
- Trex and 59cc 5.3 heads, What pushrods?
- ? about my Cam.
- Newly Purchased 99 LS1 Z28 M6
- Polluter/trickflow combo or something else??
- going from 5.7 to 6.0 please help
- Patriot Gold dual valvesprings good? Anybody have them and measure installed height?
- 91 mini tubbed foxbody lq9 carb
- Will a 04 c5 zo6 cam fit in a 08 5.3 truck block
- Need Adive on New set up!!
- Crack sprocket question!
- anybody know where i can get these piston kit with rings
- abrasives & cleaning pistons/deck
- will 243 heads help with a stock cam
- Very bent pushrod 99 LS1
- Horsepower per dollar
- Corvette cam install question
- Rotating assembly & bottom end questions
- upsize
- What should I do?
- My "budget" 408 build thread
- engine cutting out...PLEASE HELP!
- Re-assembly has begun. What do you think it will put down?
- Got my first LS1, should I mod it?
- Help! In the middle of H/C Swap
- ls1 bottom end, 243 heads, using 5.3 truck intake. which magic stick
- Warning about Lindy flycutters.....
- Out of 15 LSX cars I think a motor is gone. Video inside
- Is a lq4 from a 04 Yukon worth 1k? Anybody get a 6.0L just swap in a go or rebuild?
- so ive got this 6.0 block at home...
- Low rpm stutter
- Cam for procharger
- shelf cam for 1.85 rockers
- ls1 is ticking like a typewriter
- What cam can geta car in the 11's w/a stock stall?
- Z06 Breaking Valve Springs
- Help! Removed nitrous plate kit, now it wont return to idle after tapping the gas!!
- pushrods discolored?
- Oil pressure
- Valve Guide Material question
- TR cheaTR v3 cam
- ASA cam with slp 1.85 rockers?
- Find the combustion chamber for head
- Anybody have the specs on lm7 and lq4/9 heads?
- ls1 is giving me hell!
- Ordering a cam soon
- O-ring
- I can't title a thread properly because I'm drunk
- Cam???? Tqrv2114
- Anyone know what is the fastest time with a torquer v.2 cam?
- smoke coming out of dipstick?
