View Full Version : Generation III Internal Engine
  1. Anyone want to give some input on my build
  2. Need a dual spring retainer.
  3. cutout effecting sound question
  4. Oil pressure ?
  5. torquer v.2 retard or advance
  6. Best factory head for the money?
  7. Motor build how-to?
  8. Camshaft Question?
  9. Manley ti retainers
  10. HELP....just picked up my car from the tuner
  11. Tr230/236
  12. Mods
  13. Will this work with stock heads?
  14. Aftermarket oil pan options
  15. Oil pump problem
  16. Broke another Comp 918 spring
  17. My TSP torquer 2 cam package gets here today...
  18. h/c n20 questions
  19. swap valve cover gaskets when doing a cam install?
  20. To Fly Cut or Not to Fly Cut???
  21. Lq4? Ls2? Ls6?
  22. rod bolts resize or not ?
  23. stock 243s
  24. Do I need to change valve springs?
  25. lbs injector?...
  26. wats a good injector brand and size to go wit (I donts spel so gud)
  27. Custom grind cam?
  28. what should a front 02 sensor read on mv ?
  29. Cam for me?
  30. General Cam Swap Questions
  31. picked up some 243 heads for free wheres a good place in texas to port em?
  32. heads 806
  33. Good pushrod estimate Comp XER 273HR
  34. SLP Oil Pump
  35. My motor build (New some advie)
  36. compression ratio for pump gas
  37. quick springs question
  38. Piston Compression Height vs Piston Deck Clearance
  39. How to measure flycutting depth?
  40. performed a compression check
  41. LS1 block lifespan?
  42. 416 won't pull past 5800
  43. Milling heads with MS3?
  44. cam>>>
  45. 6.0 swap need help!
  46. ls1 heads
  47. speed inc. tu1 cam ?
  48. Built LS1 for FI (advice)
  49. Valve Spring Install From HELL!!!!
  50. WTF thermostat
  51. Need help in reviving my engine back
  52. 88958607 LS6 timing chain damper in stock
  53. Car started randomly overheating... FML
  54. Help with 6.0 part #'s
  55. HELP me diagnose sounds
  56. TSP Tsunami Cam idle woes
  57. Dynamic Compression
  58. Running dual exhaust w/cut out and muffler
  59. need opinion on what cam to use
  60. ls2 block vs ls6 block
  61. Has anyone ran this cam???
  62. Aftermarket Lifters
  63. Lq4/9 6.0 block question
  64. Those running melling high pressure/volume oil pump please come in!
  65. yellow ls6 valve springs
  66. ls2 heads on a 5.3
  67. Piston diameter lq4
  68. Stripped Intake Thread
  69. 400+ whp cam/head/intake suggestions
  70. Help lq9+ms4+milled 243
  71. car wont start unless jacked up????
  72. Help me pick a Cam PLEase
  73. I have some questions about mods!
  74. Thanks TEXAS SPEED!
  75. Compression and Pump Gas
  76. turbo 5.3 piston rod help
  77. 243 porting gains
  78. Helicoil compression??
  79. Catless to cats, tuning options
  80. Bent valve?
  81. lightweight motor?
  82. Et/mph gain with 228r with bolt-on 3400 stall car?
  83. Piston rings
  84. Which Heads with F13 Cam?
  85. DIY 241 heads w/small EPS only
  86. Cam and Head question
  87. Question of the experimenters gto ls1
  88. The biggest cam with PCV that you can stuff in a ls1 for NA
  89. Cracked ringland?
  90. 5.3 turbo cam question
  91. L92s on a stock LQ9
  92. Aussie LS1 owner seeking advice post cam install.
  93. Best Racing clutch
  94. Spark plugs and gap for 404ci 11.4:1 cp
  95. 6.0 swap trouble. Please help
  96. LS2 crank in LS1 block
  97. L92 heads milling vs bigger cam
  98. Motor help
  99. Stock rocker trunion upgrade
  100. what is the thickest MLS head gasket for the LS1?
  101. how far does crank pulley sit on crank
  102. yella terra's are droppping steal seats what the cause???
  103. Tr 230 in and running
  104. Help identify these plugs please???
  105. ms3 and 36lb injectors
  106. Decision time: 228/230 or 226/226
  107. new heads/ valve spring broke.
  108. reluctor wheel damage help
  109. Help cam & heads installed now knockin bad
  110. Oil useage question? Maybe a fix?
  111. total degrees & rev limiter setting
  112. break in after rebuild
  113. 383 ls1
  114. LS6 cam in a 5.3 - what pushrods??
  115. Updat to the $500 z28 (opened up the pass. Valve cover)
  116. Torquer v.2 or 228r?
  117. Info on 243 heads
  118. Anyone running an EPS cam like or similiar to this one?
  119. which spring for t3?
  120. Newbie Here! Want to swap an LS1 into My '67 Chevelle! Need some assistance....e!
  121. Cam manifold and headers issue
  122. Torque specs/procedures/wiring diagrams
  123. Rod/main bolts?
  124. Castrol oil thread
  125. transmission probblems
  126. What tools are you guys using for lifters and valve springs during cam install?
  127. Pushrod length checking questions
  128. Torquing rockers to 30ft/lbs?
  129. moderator help
  130. Pushrod ID?
  131. Is it blown?? (vid inside)
  132. EPS cam for boost
  133. Yep, it's another "lots of valvetrain ticking" thread...
  134. here's my problems
  135. Temp too low
  136. .060 on iron block LQ4/9?
  137. piston slap?
  138. UPDATED :) Temp won't come down no matter what
  139. G5X3 that need some lifters(ive read and search)
  140. Newbie ? 98 vette with z06 heads z06 intake Comp Cam and corsa titanium exhaust
  141. engine 6.0 and 5.7
  142. 02 ls1 engine trouble
  143. Help for next mods
  144. Are the LS1 and LS6 pistons identical?
  145. Help
  146. Crank End Play
  147. GMPP LS Stage 2 CAM in LS6/Z06
  148. Who has gaskets the cheapest?
  149. Blown Motor. What are my replacement options?
  150. Whats next???
  151. Good cam choice w/ Milled/ported 317's
  152. best rocker arms for the money?
  153. F*** U.P.S.!! What can brown do to you?
  154. Engine Wont crank: First try since rebuild "Help"
  155. putting cam in a stock 2002 ls1 questions
  156. **UPDATED**PRC 215's-EPS Cam-Super Victor setup on a 346
  157. Broke a main stud...
  158. Introduction and LS1 question..new member
  159. PRC 2.5 5.3s vs PRC 2.5 ls6 heads
  160. This thing is BAD!!!
  161. Spark plug replacement
  162. Stripped threads in block!
  163. need advice
  164. Any of you ever Heli Coiled a rocker bolt hole?
  165. 7.4 pushrods with tr230?
  166. Overheating???
  167. LS1 Truck 6.0 conversion
  168. Picked up an eBay LS1 timing chain dampener (PICS)
  169. coils
  170. 408 stroker motor build help
  171. G5X1 witch milled 706's?
  172. Not Bad never seen that dark of a brown in a camaro!
  173. torque spec questions...
  174. best bang for the buck pistons/rods
  175. Which oil pump/chain combo?
  176. where do you buy the asa cam kit? best price?
  177. spring install help!
  178. My original cam choice gone, Need a new one
  179. ASR problems HELP!!!!!!!!
  180. Why would my TSP Tsunami cam need shorter then stock pushrods?
  181. ls6 valley cover why
  182. 243 heads for $500
  183. Piston slap
  184. Cam or N2o ???
  185. Any Idea?
  186. What valve springs are these?
  187. Car feels slow
  188. Remove Heads for cam/spring change
  189. Fuel injectors/ Rails
  190. LM7 and not LQ9/LQ4?
  191. Stock 5.3 short block, chicago
  192. a few non ls nitromethane facts
  193. AFR225's with Raptr cam set up, PLZ help
  194. a few lq4 questions
  195. 98 head swap questions..
  196. PRC Stage 1 LS6 Heads
  197. Dual Valve Springs and Cam Break in Question
  198. Engine Shops Around Florida Panhandle?
  199. best heads for street cam intake build
  200. Battery Tie down bolt size?
  201. Throwing Codes!
  202. Water in Oil
  203. Another pushrod length question
  204. Torque Loss
  205. Cam????
  206. 6.0 Just back from the machine shop... video...
  207. Yellow LS6 springs on a 02+Z06 cam
  208. High oil temp's in LQ9
  209. Double roller timing chain clearance question
  210. Do I have the wrong ARP head bolts?
  211. Which O-Ring Green or Black ??? Help !
  212. cylinder head question
  213. LS4 Crank Question....
  214. thanks TSP!
  215. Tuning Question
  216. help me build this 427 set-up
  217. Advice for LQ9 build?
  218. lq4 & f14hl cam?
  219. Should I do a Stock Rebuild or Not? 99 Z28 LS1
  220. Ticking in the engine again...
  221. rod bolts
  222. Red gm coolant anybody try it???
  223. thinner head gaskets?
  224. has anyone ran/using a J&J ported LS6 oil pump?
  225. PO300-multiple random misfire
  226. good cam for trans am daily driver
  227. Rod bearings replacement help
  228. installing katech rod bolts help!
  229. Regrind cams?
  230. Beehives or Dual valve springs ???
  231. cam suggestion
  232. LS2 Heads on LS1
  233. Help Please! engine overheating, coolant over flowing out of overflow tank
  234. Need Opinions On Stupid Big Comp Cam
  235. Help with verifying SCR and DCR
  236. Possible lifter/rocker/oiling issue with video
  237. ls6 heads on ls1
  238. Viton valve seals part number? (dual springs)
  239. Pushrod ?
  240. 5.3 engine knock or normal (with video)
  241. EGR help
  242. My H/C/I swap
  243. Odd squeal from backside of motor
  244. Question about Lapping Valves.
  245. Can I restore rusty headgaskets(new)?
  246. What gaskets/bolts do I need?
  247. Does this hone look good enough?
  248. engine stall=hot outside= pissed!!
  249. shim 918s with .563 lift
  250. Safe to use "used" components for cam swap?
