View Full Version : Generation III Internal Engine
  1. Engine Build questions
  2. TB questions.
  3. 5.3 heads with offset rocker arms
  4. Compression Check
  5. mileage V.S. H/C swap
  6. 403 to 416.
  7. pilot bearing help!!
  8. Ebay Aluminum Rockers
  9. Need spring recommendations for this cam
  10. Block diagram
  11. Nick Williams
  12. Pushrod help
  13. guys i need help picking catback out of 3!
  14. What heads???
  15. stock Bore sleeve
  16. Custom eps cam and 243 heads
  17. 5.3 cam
  18. ls9 head gaskets, stock 241 heads, pushrod length?
  19. Sound clip from EPS 226/230 cam
  20. Budget baby cam LS-1 383
  21. TEA Stage 2.5 LS6 heads any good?
  22. What cam?
  23. oil soaked plugs
  24. .030 Cometic/LS6 heads and MS3 is Ok??
  25. Is it possible to have 2.165"/1.6" (intake/exshust) valves on 5.3 heads?
  26. Concerned about oil psi
  27. What supercharger kit? Or how to increase NA power?
  28. Anyone did extrude hone to their heads???
  29. Low oil level sensor resistance?
  30. am I doing something wrong? cam swap help..
  31. If your running caddy racing lifters please come in!
  32. ls6 slp ported heads
  33. How much?
  34. Gen II LS1???
  35. stock crank and eagle rods? which bearings for high HP?
  36. Ls1 h/c help
  37. belt ronding
  38. looking for a Cam Intaller or Converter install
  39. Found some pushrods I bought but I don't know what brand they are
  40. Oil Pump
  41. Bottom end durability
  42. Stock bottom end limits?
  43. in need of info
  44. valve spring question
  45. tell me your hp wit a a4,ms3 cam,and stall
  46. LS7 Lifters?
  47. Help putin on som rear welds
  48. Fly cutting
  49. What caused a bearing to look like this??
  50. lookin into some ls6 heads
  51. lq4 /ls3 heads cam selection
  52. LS1 and T56 for $4k?
  53. anyone know correct ls7(stock) cam specs
  54. need help picking intake between FAST
  55. caddy lifters, anything i should do b4 installing?
  56. Cam Suggestions
  57. My car ate a pushrod...
  58. Ls6 Questions
  59. bumping up compression on a ls1
  60. Low oil light on my ls1 swap help
  61. Got a touqer v3 bt blew my bottom end what should i do?
  62. 150k ls1
  63. LQ4 Blazer Rod knock/rebuild
  64. PRC 5.3 heads, 224R cam help needed!
  65. Lifter and spring failure.. Which came first? UPDATE
  66. What pushrods to go with
  67. Valve spring identification
  68. Got my new engine in - 00 ws6 a4 dyno
  69. no heater
  70. New Crank Bolt Necessary?
  71. TSP 228R After Tune!
  72. need input on where to go next for a 2004 corvette
  73. Lifter Question:
  74. Throttle body...?
  75. 7.30 Pushrods sound right?
  76. GMMG 2002 Camaro Earnhardt Edition
  77. bout to go ms3 cam need stall help
  78. what is the correct pushrod length for a MS3 cam?
  79. 6.0 Swap Question
  80. what heads to go with
  81. Guys with 434ci please chime in
  82. Cold start
  83. Camshaft Theory: Lobe Design
  84. 5.3 aluminum block strength and value
  85. idle video anyone?
  86. 403 STROKER what heads????
  87. Dial indicater bracket?
  88. to port or not to port?
  89. Mls head gaskets reusable?
  90. Would True duals help me that much?
  91. etp ported heads vs ported 241 heads
  92. H/C Shopping list. Help me before I order please!
  93. Price range on cam setup/install
  94. Compstar LSC vs. Stock LS2 rods ??
  95. new Trans Am H/C advice
  96. Installing arp head studs with motor in car
  97. stroker pistons with stock stroke What rod length is it possible?
  98. 98 block questions
  99. How to degree a TSP220
  100. should i add rockers to my setup???
  101. 317 heads insted of my 862
  102. spring locator for a ls6 head
  103. anybody ever used a ptc stall
  104. To bolt or not to bolt!
  105. Help! I think my cars about to blow
  106. Lunati or LS7
  107. ETMC does it again.
  108. What to do with heads? Ive searched
  109. dip stick ?? newb kinda question.
  110. cam for ls1
  111. head and cam trick flow
  112. questions before going with TSP 228R + PRC 2.5 5.3 heads and other stuff
  113. arp singles?
  114. dose some one have a turbo kit they want to let go of
  115. Help figure compression
  116. Pushrod Length
  117. stroker motor which one
  118. Port and Polishing heads.
  119. Very queer engine situation, need opinions
  120. PAC 1518's w/ LSL cam lobes, OK?
  121. question about boring a motor
  122. 6.0 throttle body question
  123. seafoam question
  124. Warm-Up Time Seems Too Long
  125. In need of help with some LQ4 questions
  126. Problems running both 243 and 799 heads?
  127. Camshaft Degree help
  128. Fast 90mm Question
  129. Need Cam Suggestions?
  130. 6.0 differences
  131. Lifter Damage
  132. Idea on gains with these mods?
  133. ticking noise after cam
  134. H/C/I, should I rebuild the shortblock?
  135. Keep my H/C/I Forged 346 or go with 408cid ?
  136. Texas Speed 228R Idle Video
  137. Help me pic heads!
  138. 5.3L L33 with mods
  139. How do you order EPS cam from Summit?
  140. MS4 cam, AFR 205 and solid rollers ?
  141. 2000 5.3 rebuild
  142. need head torques
  143. PR lenght
  144. Final Questions... Please take a minute.
  145. got trickflow heads what a deal!!!
  146. Is this a good idea?
  147. Pushrod length Help!
  148. where will this 383 build put me?
  149. ARP Headbolt Question
  150. #7 Piston Failure on Aluminum 5.3
  151. TSP Torquer V2 with LSL lobes...?
  152. options for v.3 cam
  153. Driving with no tune?
  154. 883 casting heads
  155. first time engine build ?'s
  156. preload
  157. Budget cam build for CTS-V LS6
  158. Pushrod Measuring Method ?s...
  159. do i need different pushrod length for cam change? what lenth is stock 6.0?
  160. slp headers help!!
  161. Help ! I took off the rod caps (Both Bolts) Now what?
  162. Head gasket thinkness and push rod length?
  163. gettin fast 90/90 in a couple days
  164. I took off the rod caps (Both Bolts)
  165. Need quik price check on 243 Heads
  166. Engine section
  167. Bucking in low RPMs...
  168. What cam for my LH6 Carb
  169. Troubleshooting Misfire
  170. Help with weird engine noise *vid inside*
  171. Mast Motorsports gear drive?
  172. help with compression ratio
  173. torquer 3 and ms3 guys please read
  174. Retainers, springs, and locks on PAC springs
  175. TSP LS6 2.5 or Patriot LS6 Stg2
  176. LS2 vs LS6 intakes
  177. stock thermostat - kragen - correct?
  178. LSX Valvetrain lubrication question
  179. Piston to Valve Clearence Question
  180. Cam is in and the motor runs!!
  181. DOHC heads on LSx from a Nissan Titan...read
  182. i need 2 gm part numbers
  183. ls3 springs on a 5.3
  184. 2003 LQ4 with 140k miles - Use it?
  185. need help!!!!
  186. Rod side clearance
  187. Heads and Cam
  188. Need Help On Cam For STS Turbo!!!!!
  189. 01 ls1 engine rebuild, suggestions?
  190. AFR 205 or TFS 215 on 408
  191. How streetable is a 408 stroker???
  192. all Futral F13 owners help me out!!
  193. heads heads heads!
  194. Question about installing stock crank pulley?
  195. Head/Engine specs
  196. Yellow Sludge - Throttle Body - Cause!?!?
  197. Torquer v3 vs. EPS
  198. Anyone have access to GM part numbers
  199. Im sure this has been asked 1000 times.
  200. Best Street Cam
  201. Gasket and compression ?
  202. Anyone heard from WCCH latley?
  203. Rattle in bottom
  204. One step forward, two steps back :( (pictures inside)
  205. Torquer 2 and stock springs?
  206. Shouldn't I balance the rotating assembly? lq4
  207. LQ4 piston to valve clearance
  208. Cam opinions for 3400 stall?
  209. Who's got the best deal on complete cam kits?
  210. 317 heads
  211. some advice needed before engine build is underway
  212. what is the weakest points of a ls1? help please
  213. need cylinder head advice
  214. should I install this cam advanced? eps 226/230 116+1
  215. Is my engine shot?
  216. LS1 rebuild
  217. Can I have my stock crank turned?
  218. Opinions please on this Head/Cam combo
  219. running issues. p0327 / p0102
  220. T&d #20041
  221. DO NOT try this at home . . . AKA my BUILD thread :)
  222. cam i please have some cam help
  223. How do you check bearing clearance the right way?
  224. help narrow down cam selection
  225. Arp2000 rods bolt, can it be reuse ?
  226. How much power are you putting through ls2 connecting rods?
  227. Heads/Cam Swap - Steam Tube Question
  228. How do my 130k mile cyclinders look?
  229. What is the compression ration w/ these pistons??
  230. Finally, heads and cam...need some help!
  231. Can I do a ROCKERS ONLY upgrade?
  232. Compression Estimates
  233. Another pushrod length question...
  234. tsp 233/239 0r comp 228/230
  235. 25k mile Crane dual valve springs?
  236. heads for 408 stroker
  237. How long is it safe to keep heads off & cylinders exposed?
  238. Oil pressure little low after engine swap
  239. another rod bolt question
  240. Is this a good deal?
  241. remanufactured engine
  242. Which cam puts out the best gains!!!
  243. Vacuum Line on back of LS6 intake? Need Help!
  244. Blown head gasket.. Does this look ok
  245. what compression?
  246. pacesetter Lt's and the questionable y-pipe
  247. Car Detonating & now wont start, But does turnover & try to start
  248. Looking for more
  249. Oil Pan questions
  250. need help and opinions...
