View Full Version : Generation III Internal Engine
  1. wont idle without a vacuum leak
  2. question
  3. LS2 lifter preload
  4. Aftermarket oil pan, new dipstick?
  5. Lq9, which rod & main bearings?
  6. compression question
  7. How much did you spend to Cam your LS1?
  8. Cam grind question
  9. Harland Sharp rockers?
  10. Does the installed height need to be set when changing to GMPP springs?
  11. Oil pressure drop
  12. Choices. Need opinions.
  13. PRC 220cc 5.3L Stage 2.5 vs PRC LS6 Stage 2.5 Heads
  14. Anyone run cheap Ebay connecting rods?
  15. Paperwork with texas-speed shortblocks? do they send any
  16. best cam for prc 2.5 5.3 heads
  17. Trickflow 215's
  18. wiseco pistons/eagle rods..bearing tangs face out?
  19. question about ported heads??
  20. Sudden overheating
  21. Noob oil pump/ oil capacity question
  22. Need some advice
  23. questions about some 243 heads
  24. 243 head question
  25. Which stall with a MS3
  26. Head recommendations
  27. to change my cam or leave it alone?
  28. Anyone know TFS 215 flow numbers at .650" ?
  29. L33 numbers with just a Cam?
  30. Surging at cold start and loud backfire at cold start up.
  31. how to tell if my crank is warped
  32. can i bore a 98 ls1 out .10
  33. Pushrods question
  34. Rotella T 15w-40: OIL Q's
  35. Big Cam/ Valvetrain noise
  36. 224r cam on a 110 lsa anyone ever ran this or thought about it?
  37. Shaved heads and stock pushrods?
  38. general opinion about engine, head, cam combo
  39. What do yall think of this wear pattern?
  40. Crank no start.
  41. Is it a good trade
  42. Porting a Super Victor... need advice
  43. Sealed Power pistons
  44. Alright another 6.0 build
  45. L92/Lq9/other?
  46. Help, use my current LS1 shorblock or LS2
  47. Anyone running Compstar CSC6125DS2AAAA rods?
  48. Thoughts on a Cracked Oil Pan
  49. Another P2V question
  50. Need an advice for LSR 54-459-11 Comp Cam
  51. Explaination for these low dyno numbers??
  52. 370 build what pistons? details inside
  53. Compiled engine component and accessory weights? LS1/LS6
  54. 88958607 Timing chain dampener being remade!! I will give you $25.00 for your old one
  55. Are my LS3 manifolds good for anything on my LS1?
  56. Teflon Coating internals
  57. Good Cam?
  58. Another "why do my chambers look like this" thread
  59. LQ4 with L92 heads with Livernois stage 2 cam
  60. Noob EPS Cammed LS1 buildup help
  61. How to drop engine from bottom with k-member
  62. #8 Piston Hitting Relucter wheel?
  63. oil pressure problem...
  64. new power
  65. what kind of internals and where to find them
  66. oil pressure question....help please
  67. expansion tank q's
  68. stock internals
  69. Still running stock timing chain?
  70. PTV check question
  71. Should I change crank bearings on this LQ9 ?
  72. timing chain dampener... Y doesnt it fit the ls1/ls6?
  73. My heads and Trex cam. I have some questions.
  74. Possibly broke engine
  75. is a 228r cam right for me? or no cam at all?
  76. Question for texas speed
  77. Broken Exhaust manifold studs L33 head
  78. Head pounding please help
  79. Oil in the water
  80. Does this setup work?
  81. Rebuilding a stock 6.0 to hold XXXwhp
  82. Help me choose a cam and I need advice on these heads.
  83. What would cause this combustion pattern?
  84. timing chain ?
  85. valve lock question
  86. 4.8 oil pan and rear oil seal carrier torque specs
  87. What does it take to make 400whp with a 5.3?
  88. ls1 HELP
  89. stock 99 ls1 comp #'s??? What should they be???
  90. need info HPE mega death cam
  91. Water Pump Pulley Question
  92. L33 Power AND MPG??
  93. Possible blown head gasket????
  94. windage tray??
  95. Who's running milled 317's???
  96. Head swap parts list
  97. Gains from TR230
  98. roller rocker bolt snapped!!
  99. New Camshaft Bolts
  100. Doing headers, which O2 sensors do i put back on
  101. Anyone doing OK on a hone/re-ring while reusing stock pistons?
  102. valve cover spacers?
  103. Cam Timing Marks?
  104. how much can i mill??
  105. Engine apart. Won't use for 18 months. Rebuild now? or wait?
  106. Gains from stock 243's on my combo??
  107. NEED HELP!! what rods are these??
  108. Help! What is this Ball Bearing from?
  109. Ls1 finally out the top..
  110. Finally got the motor apart :/
  111. I bought A LQ9 today ! What HEADS should I look into?
  112. ms3 cam head choice?????????
  113. New Texas Speed 228 is In!
  114. 243 heads from 4.8 engine?
  115. Heads Sticky?? Is there one?
  116. PRC 215 vs TEA stage 2 heads .
  117. Should my pan have this hole in it?
  118. used or new rocker arms
  119. Aftermarket cast head (AFR, TFS, etc.) that has iron/powdered metal valve guides?
  120. any luck with vrx5 cam by vegeance racing
  121. Master Budget Build H/C/I
  122. Cam without headers...thoughts??
  123. lookin for cam ideas
  124. Cam Ideas?
  125. Me so on fire!
  126. My New Prc heads are In. Dyno Numbers Inside Finally!!!
  127. 5.3 lifters
  128. DS coils have no power. Help
  129. What if I buy a Gen IV LQ9? Will I need a new ECU?
  130. Which arp rod bolts u suggest???
  131. Will a LS2 cam fit in a 5.3L motor?
  132. KATECH ROD BOTS-will people who has swaped to them without honing shine in..please
  133. 454 vs 408
  134. *** HPE Flip-Drive Now $789 + FREE SHIPPING!!! For 2011***
  135. Harmonic Damper ARP Bolt?
  136. Rocker Arm
  137. Should I call on any of these 6.0L 's ?
  138. Procomp stuff?
  139. Water In Oil Cap, And Milky PCV System From Valve Cover, Any Ideas? Pic Inside
  140. Putting the Valvetrain back together.
  141. WTF is this shit and why?
  142. Finally building a 408, need a game plan.
  143. 383 Is it worth doing
  144. ran into problems..need help asap
  145. Intake for 235/240 .595", 110lsa
  146. Need help, please take a look - cracked block/motor mount, still good???
  147. what head stud kit?
  148. Is this a good setup? and what pushrods?
  149. need help with gas milage
  150. AFR valve spring pressure?
  151. do u need to retorque heads
  152. Pinned Main Caps
  153. easiest way to put in main seals??
  154. Help w/ mystery cam specs 236/236 114+2
  155. any independant charts of patriot stage II ls6 heads?
  156. upgraded stock rockers with over .600 lift???
  157. cloyes hex a just..... single or double chain
  158. LS7 lifter #
  159. 5.3 bored to 5.7 LS1?
  160. Looking to get ms3 cam??
  161. A little finding the C/R on my 6.0
  162. ls7 lifters question
  163. What tools do you like for building a LS Engine ?
  164. What method do you use when pullin a LS Engine ?
  165. Need H/C help
  166. Should my fuel mileage be this bad????
  167. 228R and LS7 Lifters...
  168. SES Light on.. Codes.. 171, 174, 0300 Plz help..
  169. LQ9 hp estimates
  170. Bringing a 5.3 back from hybernation
  171. heads
  172. need really good push rods
  173. Random Question
  174. lifter and rocker selection
  175. Ported 317 heads
  176. ok need your help, ls6 or lq4
  177. need a cam dose some one have this
  178. Turbo LS1...when to spec custom cam or buy off shelf?
  179. Valve Spring Maintenance
  180. turbo, procharger, supercharger?
  181. rocker selection
  182. Question about porting work on heads
  183. prc 227 question
  184. crank pulley install?
  185. What you think (videos)
  186. Thinking it's time for a new cam.
  187. has anyone passed ca smog with ls6 cam WITHOUT ANY TUNE?
  188. opinions on scorpion roller rockers
  189. Advice on 243's and injectors
  190. Help me out
  191. LS1 block max overbore?
  192. patriot dual gold springs install help.
  193. Cam choice for stock lq4, stock intake
  194. Cam bearing installation... Help please
  195. What Are These ARP Main Studs For?? (PIC)
  196. trunion upgrade proplem
  197. Need help determining compression ratio...
  198. Ordered some new heads from Texas Speed what rockers?
  199. 5.3 Swap into a project car.
  200. Tapping head for temp sensor
  201. Anyone ported 243?
  202. 400rwhp - Smog legal?
  203. A couple of LQ4 questions
  204. What do you think caused this...
  205. Gasket Material in pistons a bad thing?
  206. Where to get 7.30" Pushrods
  207. Best way to clean piston ring area of assembled short block?
  208. Aftermarket Gauges - sending unit locations?
  209. How to prep a cam for storage
  210. Procomp Aluminum Cylinder Heads
  211. some build questions
  212. Harmonic Balancer Problems
  213. LS1 LS2 expert analysis needed!!!!!! plz help
  214. issues with this combo?
  215. Opinions wanted !
  216. lq4 swap no spark
  217. Joined the Dropped Valve Club AGAIN!!! How? UPDATE
  218. Lake Pipes?
  219. Another lq4 build, advice please
  220. PRC 227's and MS4
  221. need some help,which bolt goes where?
  222. flycut how big of lift can i go
  223. 317s on a 5.3?
  224. Honing an LS1 .010
  225. Which heads with a g5x3 cam????
  226. nitrous cam help on stock C.I. LS1
  227. 12pt arp studs or not
  228. Where to get a pillar pod and gauge kit
  229. Need some opinions, rering/bearing or?
  230. LS1 with 245000 miles
  231. Finally Got Off My A$$ and Took Out Mt Motor!
  232. What will swap over and bolt right up if I swap a LQ4 short block into my 01 Z-28 ?
  233. 02 LQ4 or 05' LQ4 which should I buy ?
  234. Futral F14 Cam Hydrolic or Solid Lifters
  235. engine noise / oil pressure issues?
  236. Engine removal disaster
  237. Which oil pump should I use?
  238. Squeak from car when I rev it up?
  239. oil pressure issue
  240. Oil guage
  241. Procharger cam help..come inside if you can help!
  242. head swap problem HELP!
  243. Oil Pump Failure?
  244. Looking for help or advise
  245. LS1 Rocker arm selection ??
  246. Phase 1 / 2/ 2x2???
  247. Please help with unusual oil leak
  248. Ls7 lifters work in ls1???
  249. Stage 2.5 5.3 heads on a 5.3?
  250. Compression test numbers for 10.5:1 compression?
