- PRC 220cc 5.3L Stage 2.5 vs PRC LS6 Stage 2.5 Heads
- Anyone run cheap Ebay connecting rods?
- Paperwork with texas-speed shortblocks? do they send any
- best cam for prc 2.5 5.3 heads
- Trickflow 215's
- wiseco pistons/eagle rods..bearing tangs face out?
- question about ported heads??
- Sudden overheating
- Noob oil pump/ oil capacity question
- Need some advice
- questions about some 243 heads
- 243 head question
- Which stall with a MS3
- Head recommendations
- to change my cam or leave it alone?
- Anyone know TFS 215 flow numbers at .650" ?
- L33 numbers with just a Cam?
- Surging at cold start and loud backfire at cold start up.
- how to tell if my crank is warped
- can i bore a 98 ls1 out .10
- Pushrods question
- Rotella T 15w-40: OIL Q's
- Big Cam/ Valvetrain noise
- 224r cam on a 110 lsa anyone ever ran this or thought about it?
- Shaved heads and stock pushrods?
- general opinion about engine, head, cam combo
- What do yall think of this wear pattern?
- Crank no start.
- Is it a good trade
- Porting a Super Victor... need advice
- Sealed Power pistons
- Alright another 6.0 build
- L92/Lq9/other?
- Help, use my current LS1 shorblock or LS2
- Anyone running Compstar CSC6125DS2AAAA rods?
- Thoughts on a Cracked Oil Pan
- Another P2V question
- Need an advice for LSR 54-459-11 Comp Cam
- Explaination for these low dyno numbers??
- 370 build what pistons? details inside
- Compiled engine component and accessory weights? LS1/LS6
- 88958607 Timing chain dampener being remade!! I will give you $25.00 for your old one
- Are my LS3 manifolds good for anything on my LS1?
- Teflon Coating internals
- Good Cam?
- Another "why do my chambers look like this" thread
- LQ4 with L92 heads with Livernois stage 2 cam
- Noob EPS Cammed LS1 buildup help
- How to drop engine from bottom with k-member
- #8 Piston Hitting Relucter wheel?
- oil pressure problem...
- new power
- what kind of internals and where to find them
- oil pressure question....help please
- expansion tank q's
- stock internals
- Still running stock timing chain?
- PTV check question
- Should I change crank bearings on this LQ9 ?
- timing chain dampener... Y doesnt it fit the ls1/ls6?
- My heads and Trex cam. I have some questions.
- Possibly broke engine
- is a 228r cam right for me? or no cam at all?
- Question for texas speed
- Broken Exhaust manifold studs L33 head
- Head pounding please help
- Oil in the water
- Does this setup work?
- Rebuilding a stock 6.0 to hold XXXwhp
- Help me choose a cam and I need advice on these heads.
- What would cause this combustion pattern?
- timing chain ?
- valve lock question
- 4.8 oil pan and rear oil seal carrier torque specs
- What does it take to make 400whp with a 5.3?
- ls1 HELP
- stock 99 ls1 comp #'s??? What should they be???
- need info HPE mega death cam
- Water Pump Pulley Question
- L33 Power AND MPG??
- Possible blown head gasket????
- windage tray??
- Who's running milled 317's???
- Head swap parts list
- Gains from TR230
- roller rocker bolt snapped!!
- New Camshaft Bolts
- Doing headers, which O2 sensors do i put back on
- Anyone doing OK on a hone/re-ring while reusing stock pistons?
- valve cover spacers?
- Cam Timing Marks?
- how much can i mill??
- Engine apart. Won't use for 18 months. Rebuild now? or wait?
- Gains from stock 243's on my combo??
- NEED HELP!! what rods are these??
- Help! What is this Ball Bearing from?
- Ls1 finally out the top..
- Finally got the motor apart :/
- I bought A LQ9 today ! What HEADS should I look into?
- ms3 cam head choice?????????
- New Texas Speed 228 is In!
- 243 heads from 4.8 engine?
- Heads Sticky?? Is there one?
- PRC 215 vs TEA stage 2 heads .
- Should my pan have this hole in it?
- used or new rocker arms
- Aftermarket cast head (AFR, TFS, etc.) that has iron/powdered metal valve guides?
- any luck with vrx5 cam by vegeance racing
- Master Budget Build H/C/I
- Cam without headers...thoughts??
- lookin for cam ideas
- Cam Ideas?
- Me so on fire!
- My New Prc heads are In. Dyno Numbers Inside Finally!!!
- 5.3 lifters
- DS coils have no power. Help
- What if I buy a Gen IV LQ9? Will I need a new ECU?
- Which arp rod bolts u suggest???
- Will a LS2 cam fit in a 5.3L motor?
- KATECH ROD BOTS-will people who has swaped to them without honing shine in..please
- 454 vs 408
- *** HPE Flip-Drive Now $789 + FREE SHIPPING!!! For 2011***
- Harmonic Damper ARP Bolt?
- Rocker Arm
- Should I call on any of these 6.0L 's ?
- Procomp stuff?
- Water In Oil Cap, And Milky PCV System From Valve Cover, Any Ideas? Pic Inside
- Putting the Valvetrain back together.
- WTF is this shit and why?
- Finally building a 408, need a game plan.
- 383 Is it worth doing
- ran into problems..need help asap
- Intake for 235/240 .595", 110lsa
- Need help, please take a look - cracked block/motor mount, still good???
- what head stud kit?
- Is this a good setup? and what pushrods?
- need help with gas milage
- AFR valve spring pressure?
- do u need to retorque heads
- Pinned Main Caps
- easiest way to put in main seals??
- Help w/ mystery cam specs 236/236 114+2
- any independant charts of patriot stage II ls6 heads?
- upgraded stock rockers with over .600 lift???
- cloyes hex a just..... single or double chain
- LS7 lifter #
- 5.3 bored to 5.7 LS1?
- Looking to get ms3 cam??
- A little finding the C/R on my 6.0
- ls7 lifters question
- What tools do you like for building a LS Engine ?
- What method do you use when pullin a LS Engine ?
- Need H/C help
- Should my fuel mileage be this bad????
- 228R and LS7 Lifters...
- SES Light on.. Codes.. 171, 174, 0300 Plz help..
- LQ9 hp estimates
- Bringing a 5.3 back from hybernation
- heads
- need really good push rods
- Random Question
- lifter and rocker selection
- Ported 317 heads
- ok need your help, ls6 or lq4
- need a cam dose some one have this
- Turbo LS1...when to spec custom cam or buy off shelf?
- Valve Spring Maintenance
- turbo, procharger, supercharger?
- rocker selection
- Question about porting work on heads
- prc 227 question
- crank pulley install?
- What you think (videos)
- Thinking it's time for a new cam.
- has anyone passed ca smog with ls6 cam WITHOUT ANY TUNE?
- opinions on scorpion roller rockers
- Advice on 243's and injectors
- Help me out
- LS1 block max overbore?
- patriot dual gold springs install help.
- Cam choice for stock lq4, stock intake
- Cam bearing installation... Help please
- What Are These ARP Main Studs For?? (PIC)
- trunion upgrade proplem
- Need help determining compression ratio...
- Ordered some new heads from Texas Speed what rockers?
- 5.3 Swap into a project car.
- Tapping head for temp sensor
- Anyone ported 243?
- 400rwhp - Smog legal?
- A couple of LQ4 questions
- What do you think caused this...
- Gasket Material in pistons a bad thing?
- Where to get 7.30" Pushrods
- Best way to clean piston ring area of assembled short block?
- Aftermarket Gauges - sending unit locations?
- How to prep a cam for storage
- Procomp Aluminum Cylinder Heads
- some build questions
- Harmonic Balancer Problems
- LS1 LS2 expert analysis needed!!!!!! plz help
- issues with this combo?
- Opinions wanted !
- lq4 swap no spark
- Joined the Dropped Valve Club AGAIN!!! How? UPDATE
- Lake Pipes?
- Another lq4 build, advice please
- PRC 227's and MS4
- need some help,which bolt goes where?
- flycut how big of lift can i go
- 317s on a 5.3?
- Honing an LS1 .010
- Which heads with a g5x3 cam????
- nitrous cam help on stock C.I. LS1
- 12pt arp studs or not
- Where to get a pillar pod and gauge kit
- Need some opinions, rering/bearing or?
- LS1 with 245000 miles
- Finally Got Off My A$$ and Took Out Mt Motor!
- What will swap over and bolt right up if I swap a LQ4 short block into my 01 Z-28 ?
- 02 LQ4 or 05' LQ4 which should I buy ?
- Futral F14 Cam Hydrolic or Solid Lifters
- engine noise / oil pressure issues?
- Engine removal disaster
- Which oil pump should I use?
- Squeak from car when I rev it up?
- oil pressure issue
- Oil guage
- Procharger cam help..come inside if you can help!
- head swap problem HELP!
- Oil Pump Failure?
- Looking for help or advise
- LS1 Rocker arm selection ??
- Phase 1 / 2/ 2x2???
- Please help with unusual oil leak
- Ls7 lifters work in ls1???
- Stage 2.5 5.3 heads on a 5.3?
- Compression test numbers for 10.5:1 compression?
- Time for new Valve Springs....
- question about an MS4
- head cam rocker combo questions
- Oil temp how hot is too hot?
- Possible LS1 build cam question
- Head/Block damage serious?
- 5.3L heads cleaned up flow chart
- Can someone measure something on their engine for me?
- LS timing chain damper opinion
- 99 Camaro SS Current Mods -- Opinions?
- Dual Valve Springs Keeps Ripping Valve Stem Seal Off?
- copy cams on ebay
