View Full Version : Generation III Internal Engine
  1. Vig 3200 or Yank ss 3200? What would the gains be?
  2. Scat I-Beam or H-Beam rods?
  3. Connecting Rods for rebuild
  4. AC variable displacement compressor
  5. What pistons are these? Came in my ls1 longblock I bought
  6. Post machining inspection, cylinder bore measurements. Opinions needed
  7. Is my ladies Z28 toast?
  8. Anyone used these roller rockers?
  9. 2001 Camaro SS Fuel Return
  10. requesting input into roller rockers -vs- stock w/ trunion upgrade
  11. looking to do some motor work need help
  12. Crank & bearing issues w/ new build
  13. valveterrain noise? chain choice?
  14. Valve Spring Recommendation
  15. What does low vacuum affect?
  16. valve length question
  17. Pushrod length help
  18. 6.0 bottom end strength
  19. Anyone tried a 387, bore 4.125x3.622? Any draw backs?
  20. 1.75 or 1.8 rockers
  21. 4.8L Pistons in a 5.3L
  22. Engine Mods
  23. Need new head gaskets
  24. 6.0 fully dressed
  25. is there a difference in installing rockers with the new trunion
  26. Comp Cam Springs for sale.
  27. sd tune or not sd tune.. pros and cons of both
  28. 3.905 cylinder, might need a hone job...
  29. What is Break In Oil?
  30. Need some valve train advice
  31. Mystery O-ring! Help!
  32. Need a little input on right combination.....
  33. lq4 block
  34. Truck accessories vs F body accessories
  35. Head Stud Trouble
  36. asa cam with more lift
  37. Best Cam for around 350 at the wheels
  38. cam for 36lb injectors
  39. Headers and injectors
  40. Pushrods
  41. Head gaskets and Calculating compression
  42. Which head for a LQ4? CNC Ls3 or AI 243
  43. Pro form Valve Spring Tester
  44. parts list help please
  45. Weight of a LQ short block
  46. Flashing SES, rough idle
  47. rod bolt help
  48. LQ9 on C5 help please
  49. Bigger cubes, 5.3 do-able??
  50. Valve question
  51. what oil do you guys use?
  52. help with LQ4/9 408 build
  53. 99 Ls1 Camaro Build + Tune Question
  54. Melling Oil Pumps / COMP Trunion Upgrade / Powerbond Pulleys / ARP Hardware- On Sale!
  55. Vacuum issue with this cam?
  56. 03 5.7 vortec parts to 07 5.3
  57. Small ARP head stud part #?
  58. High Compression 6.0 Build ?'s
  59. 6.0L bottom end and machining
  60. debris in engine!!! come inside fellas....
  61. help identify a cam please
  62. What would cause this??
  63. NGK TR6's and 75 shot
  64. 5.3 cam
  65. lq4 piston?
  66. Newbie to LS1 Help Cam/Springs/Roller Rockers
  67. another head question
  68. Cam and Cylinder Head Install Gasket Kits- Available Now!
  69. Cam and milling
  70. Pushrod Questions
  71. Heads for 460+ WHP
  72. How much can I mill ?
  73. pushrod help
  74. LS1 long in the tooth?
  75. Ls1 oil pan bolt hole stripped questions
  76. LQ4/G6X3 compatibility
  77. Nitrous 408 build specs
  78. what heads do i need?
  79. 6.0 heads cam info needed
  80. What the hell causes this?!? (Pistons dimples)
  81. Ms4???
  82. Mileage Woes
  83. Food Stamps WTF!!!!
  84. Tr224 cam upgrade
  85. Ignition switch issue?
  86. Need help ASAP please!!!
  87. Cam option
  88. Advanced Engine guys, Help me understand cam ramp rates/ratios; pros and cons
  89. Help with the heads and cam swap!
  90. getting new lifter while upgrading cams?
  91. Ls6 valve springs
  92. prc 215 vs prc 2.5 5.3
  93. Finally set on heads!
  94. Cam bearing clearances
  95. SES light and no tach after cam/heads - help much appreciated!
  96. How much power with this crank
  97. Which cam for stock LS1/T56 in G Body
  98. Mill'n 243
  99. trunion upgrade question
  100. ID This Cam!
  101. Scorpion Roller Rockers
  102. want to do heads/cam setup suggestions?
  103. 98 ws6 rebuild help
  104. LQ4 rod direction
  105. tuning please help
  106. Looking to upgrade from the G5x2 Cam
  107. ls builder in kc
  108. What Rear gear to choose for New cam
  109. Looking for a Balancer pin kit
  110. Checking ptv clearance question
  111. What springs to replace worn out patriots with? Cam specs inside.
  112. Knocking when cold and poor fuel economy
  113. Milling 5.3 heads to 59cc?
  114. should i turbo this motor?
  115. Head cam intake, 383, or 402
  116. is it worth it. fast90 to a new 92
  117. Need advice, keep my current cam or swap?
  118. Ford Modular Coils
  119. Cam vs More bolt ons
  120. Beginning upgrades to my 150K LS1/T56 Camaro SS
  121. Help understanding camshafts
  122. duration?
  123. 2004 LM7 cam options
  124. Where to start.
  125. 98 trans am ls1 loud knock
  126. spark plugs, tappered or washer?
  127. need help with scr/dcr numbers please
  128. SBE V 2.0 98blueSScamaro
  129. Most reliable rocker arm for trick flow heads
  130. Using oem l92 valves to fly cut for 2.00 1.55s?
  131. By pass stock transmission cooler or not?
  132. 383 heads and intake questions
  133. 5.3 heads port limits....? 225cc...?
  134. Heads question
  135. Thoughts on this cam, 231/235
  136. Can I exchange crankshafts without pulling the heads in a 5.3?
  137. Ported and blueprinted LS6 oil pump
  138. How much dynamic compression is to much....
  139. Boring an LM7 to LS1 specs
  140. Need help trying to choose a cam
  141. Is this a good turbo cam??
  142. Head porting questions....
  143. Break-in time for heads and cam
  144. 5.3 vortec vapor
  145. Volant Air Intake question
  146. identifying my engine
  147. valvetrain noise
  148. cut out options
  149. Northern auto parts.
  150. Best Cam for My 370 Build
  151. ls6 motor/head question
  152. Want to change the cat-back on 99 Z28
  153. Cam/MAF/Throttle body Suggestions please
  154. 383 questions..
  155. How much to mill 243's with MS3?
  156. studs or torque to yield?
  157. Brand new engine losing oil pressure
  158. LS2 sensors on a LQ4
  159. Main bearing groove style???
  160. cam with AI 226 heads??
  161. My 347ci build
  162. A4 vs m6 dash/interior harness.
  163. 408 stroker build. Hows this look?
  164. 550 rwhp possible?
  165. A totally different oil consumption question.
  166. TEA CNC Trick flow 225's Nitrous Exhaust Ports???
  167. howards cam?
  168. valve reliefs in pistons
  169. stock 317 rocker arms
  170. Is This a good deal?
  171. Exhaust help
  172. Stroke kit help and opinions
  173. LQ9 build question - need suggestions
  174. AI LS6 heads vs TEA STAGE 2 LS6 heads vs TFS 215s
  175. burning oil or not
  176. GM replacment crankshaft
  177. prc 2.5 stage 5.3 heads on an lq4
  178. Ordering a motor at lunch
  179. lq9 oil pump functionality?
  180. good cam?
  181. Sounds like a bird in my engine bay
  182. 5.3 aluminum block
  183. Help New 408 Wont Start
  184. My lq4 build, rocker questions
  185. Fair price to pay on replacement of oil pan gasket and end seals?
  186. fuel pump
  187. the infamous tick tick tick
  188. need help with pushrods
  189. PRC Valve springs
  190. Oil Pressure Sensor
  191. Removing Front Oil Galley Plug
  192. Please give me a Recommendation of which Oil Pump to go with.....
  193. ms4 specs help
  194. Need advice on engine power surge
  195. what do u think about this cam 230/236 .612/.590 114LSA
  196. Stock Cam ID
  197. Head gasket bore question?
  198. Are factory installed engines tied to the VIN by a serial number?
  199. Pushrod checking tool length concern
  200. SBE LS1 Heads/cam budget build!
  201. Small part of dipstick tube fell into oil pan
  202. LS3 Intake In A LS1 Car: Need Help Please
  203. 243 valve?
  204. Iron LS2 build w 243's and stock LS6 intake and 243?
  205. Finally pulling the trigger on parts!
  206. Lunati LS11 Forged 383 piston questions. And some 383 questions.
  207. Is .075 too much for Morels?
  208. 317 heads
  209. 2004 gto ls1/auto 70k advice on head/cam/intake for best bang for my buck
  210. FAST 78 install help
  211. cam bearing help/opinions
  212. Advanced Induction unresponsive?
  213. 6.0 for drift?
  214. Cam gurus help!
  215. STILL HAVING ISSUES, no low end power
  216. lq4 piston for bored out 6.0l
  217. Took my first whack at taking engine dimensions.
  218. Who builds T56 transmissions?
  219. What cam do I have?
  220. AI 226cc vs 232cc Heads
  221. Heads off to WCCH tommorow!
  222. Engine diagnostic coach needed
  223. Making the Most Out of a DD
  224. How to decide what compression is best?
  225. Going beyond the obvious: Iron vs. Aluminum, strength?
  226. Supercharge LS6?
  227. New heads (thompsons)
  228. Valve Spring Identification Help!
  229. build advice
  230. are these codes Normal after headers/ ory? 5 codes
  231. Timing Chain
  232. Low oil pressure after clutch install???
  233. Who is OEM bearing supplier?
  234. 02 ls camaro wont crank...
  235. Cam bearing and lifter ?s
  236. 4.8 + L92. Is it possible?
  237. L92 head gasket with 317s
  238. Reputable machine shops-Ohio
  239. Looking for cam advice
  240. Knock sensor & ls6 valley question
  241. Stock m6 tranny/engine rpm limit? -(9k rpms lol) - heads -cams -bore/stroke
  242. cam shaft sensor
  243. c6 oil pan or ls6
  244. Feedback on Warhawk heads.
  245. Motor Knocking. Budget replacement options?
  246. Coolant Crossover
  247. Want to rent a time sert kit for head bolts!
  248. Vacuum line going into throttle body?
  249. help me guess my cam!
  250. tr5 vs tr6
