View Full Version : Generation III Internal Engine
  1. i dont think this is good...TONS of smoke out my VC breather!!!
  2. Here is my new Build comments??
  3. ATTN: cam gurus, CA smog legal cam L@@K!
  4. 853's on a 6.0l
  5. valve spring suggestions
  6. custom work
  7. Timing cover gasket or RTV?
  8. Accusump questions
  9. 98 Camaro 408.. Fuel Perssure ..drops
  10. 408 teardown, need expert opinions
  11. combo
  12. New setup, need advice regarding milled AFR 205's
  13. stroked lq9
  14. What causes the sticky orange gunk build-up in the intake runners?
  15. Doing H/C swap at 75k. Should I replace lifters too?
  16. motor drop for cam swap?
  17. Another Ticking with high oil pressure, bit different then others
  18. accessory parts needed
  19. 5.3 Cam Question
  20. low oil pressure when screw the pulley
  21. Cam choice?
  22. Building a 383 LS1 need H/C/I selection advice.
  23. flycutting?
  24. alexsparts pushrods?
  25. 4.250 Stroke Crank in LQ4 Iron block
  26. Review this idea for me, Please.
  27. REV Valves....any good?
  28. LS1 Shortblock?
  29. cam swap and now car starts and dies?
  30. shelf cam to custom cam?
  31. 243 + streetsweeper cam question
  32. 228R cam most HP cylinder head
  33. Question about valve spring install
  34. Ported/milled 241's or ported /big valve 706's
  35. Way was it slow????????????
  36. ported milled 241 55cc
  37. Callies VS Eagle Forged Cranks
  38. TSP 402 Stroker Kit
  39. Which way to install bearings?
  40. oil pressure question / Post CAM Checkup
  41. Went from mid cam to donkey cam, Looking for experiences
  42. How to replace your pinched oil pump pickup tube o-ring with PICS!
  43. Second best SINGLE roller chain
  44. Opening chamber size, unshrouding valves and cleaning up CNC work gain
  45. help with pushrod lenght and help to calculate compression
  46. Need opinions on a cam
  47. Castrol Edge
  48. 806 heads
  49. Need some help with lifters
  50. So any body upgrade Fast 90 to ported 102 yet?!!
  51. ARP Rod Bolt Torque
  52. What "Cam" for AFR 205 heads int Fbody A4
  53. Don't know which cam to look for.
  54. Cam and crank gear alignment question
  55. Head milling question
  56. Wanna upgrade my heads for more power which set to use?
  57. Hand ported 241 heads (pictures)
  58. How many cubes bigger can you go with a 346CI ?
  59. goin 9s with my new motor
  60. Ws6 engine tick/noise? Need help.
  61. how much have these heads been milled? (Pictures)
  62. Whole Left Bank Misfiring....
  63. LS1 to LS6 Crate Engine Questions
  64. coolant in oil?
  65. Square Port heads vs. Cathedral Port heads
  66. How much 70cc should be milled to get 64cc ?
  67. thinking of a cam swap
  68. Sykokilla's engine build - MS4/PRC LS6 stg1.0
  69. engine valley cover
  70. Lifter question
  71. ENGINE BUILDERS,, How is this possible, and what would you recommend
  72. How much power before it blows
  73. Please Help ,Back firing through Exaust !?!?
  74. help with setup and compression
  75. Best setup/next step
  76. Compression Test
  77. basecircle/pushrod length
  78. Have a LS2 timing chain dampener, must I pull the engine to install??
  79. gonna try running cracked block
  80. LS6 cam and ported LS1 853 Heads?
  81. LS6 Questions
  82. What O2 sensor do I want? Running issues after Torquer v.2
  83. Guys some opinons or first hand exp on H/C street car
  84. help with comp 918 blue stripe springs?
  85. 2000 z28 camaro insurance
  86. map sensor boot for a weiand intake
  87. Need engine advice
  88. Lq4 build some ? And advice needed
  89. Which of these 3 cams
  90. Re-use head gasket?
  91. Need LM7 help? Running very strange in Jeep
  92. What lift can I go on an LQ9
  93. Oil pump pickup tube o-ring...
  94. Weird coolant/overheating issue...
  95. Opinions/Experience on these cams for DD
  96. EPS 230/234 Acting HUGE
  97. timing chain set from tsp help
  98. hmm anyone esle have this oild pressure issue (vids inside)
  99. First startup after cam install!!!
  100. Need a reality check here
  101. what is the best way to clean engine and heads
  102. Need help please alternative to jpr lifter holder
  103. which should i use? melling 10295 or 10296??
  104. Cam install - few pics, Video added.
  105. help, im freaking out
  106. LS1 crank in LQ9?
  107. Help me calculating my CR plzzzz
  108. Melling 10296 for turbo?
  109. headers/cam replacement
  110. Will TF235 work with L92 relief pistons ?
  111. Misfires, Backfires and Bucks after Cam install
  112. Head Choice ???
  113. Code help?
  114. Pushrod lenght w/non adjustables
  115. WTF is up with my dipstick?!
  116. Catty and F-Booty (not girls, but oil pans!)
  117. Do ARP Side bolts for main caps use washers underneath?
  118. ls1 cam gear/lq4 cam gear ?
  119. LS2 Aluminum or LQ9 IRON?
  120. 228/234 114+4 cam
  121. Opinions/info wanted about this setup.
  122. valve spring life?
  123. will these cams fit?
  124. MS4 pushrods
  125. balancer issue, please help.
  126. Can y ou accidentally double seat a spring?
  127. 414 iron block EPS cam idle clip
  128. Baseline dyno run, is this right?
  129. PRC 650 spring kit - No locks?
  130. Gen III LS2 short block - Which heads to use?
  131. Help me figure out what my compression will be
  132. Rear main seal help
  133. Need recommendation on a set of heads
  134. Need some Cam help
  135. Plz help with cam choice???
  136. ordering cams, need opinions.
  137. accurate measured bore size for 4.010" pistons
  138. help! the 5.3 in my truck has high oil pressure!
  139. 2008 chevy 1500 with 4.8... question aabout cam and heads
  140. mls head gasket question
  141. Over heating
  142. callies compstar rods
  143. Lifter Install
  144. Which Head and cam package to buy??
  145. Stock piston and rod weight
  146. LXR 245 or TF235 ?!!
  147. Just some help to anyone having too much fuel
  148. Thoughts on a h/c/i setup
  149. MTI Stage III LS6 Head question
  150. Looking for a good shop to install heads and cam
  151. Heads/Cam (243's/TR230) Dyno day 10/19/10! ~ Track results here!
  152. Crankshaft question
  153. rough idle question
  154. low oil pressure after stroker start up solved!
  155. 5.3 drivers side bank dead. Sometimes
  156. Car stalls when clutch is engaged or sometimes when car stops
  157. Saleens arch enemy... BOLT ONS =P
  158. problem with valve springs
  159. EPS Cam now Idles great--No more surging
  160. oil pressure gage jumpy
  161. 224/230 vs 230/224 grrrr... is DD cam so complicated??
  162. Manual crank in an Auto car
  163. First start no oil pressure HELP
  164. New to LS1, engine noise, clicking...need help bad
  165. need a good machine shop
  166. Yank Adjustable Timing Set
  167. If you were going to build a 427...
  168. Pushrods help ASAP
  169. need info on cam please help asap
  170. Similarities between gen 1 sbc cam swap and ls1 cam swap?
  171. Lifter "hold up" tool/dowels?
  172. TFS 215cc matched to bigger headers
  173. 99 Z28 Rebuild
  174. How much are your heads milled by?
  175. Rod knock question (W/PICS)
  176. Water seeping on new head gasket -not fired yet
  177. Katech "Stage 2' 806 head info.
  178. lq4 imitating an ls6?
  179. 600hp sleeves?
  180. NEED HELP!! 2 different lifters in motor. Pushrod advice ASAP!!!
  181. Need help looking up a cam P/N....
  182. Parts comparison
  183. Cam help ????
  184. help me choose a good cam for my heads
  185. more turbulence???
  186. Nasty oil pan leak, possible pan removal
  187. Valve Spring Question
  188. cam identification help??
  189. timing chain and covers question & rough idle question.
  190. Rocker arm?
  191. 6.0 block with l92 heads
  192. Misfiring issue, no codes, need a guru's help
  193. How to identify Castech 706 truck heads??
  194. best street 400 rwhp cam?
  195. Th 350?
  196. How to clean hears (brakkleen ok for springs)
  197. Head gaskets
  198. 99 6.0 crank identification.
  199. Pontiac 2002 5.7 engine problem
  200. SLP Dual Dual Exhaust..What is it worth??
  201. Oil Pressure Sensor Adaptor
  202. question on ud pulley??
  203. Revving the car makes oil pressure gauge go to 0
  204. Valve Guide Replacement
  205. 6.0 questions
  206. whats the difference between L33&LH6 Motor
  207. Let's play "Name those chunks stuck to the drain plug"
  208. Heads ported, is it ok that they went into the rocker arm bolt area???
  209. lq4 Build help
  210. Head/Cam Combo
  211. Heads for 2001?
  212. stock ls1 piston ?
  213. 243 heads are they the same all years?
  214. Valves stuck open from carbon
  215. Ive Got a Problem!!!!
  216. LS1 swap is running hot (over 210*F) any ideas?
  217. What oil?
  218. engine noise
  219. Help a newbie understand cams....
  220. A few top end questions.
  221. 7.450" pushrods w/02-04 z06 cam?
  222. Cam help
  223. Those with TSP's 231/237, what valve springs you runnin?
  224. Want to Go to Synthetic Oil,Need Advice Especially From PatMan!
  225. what happened to my main bearings!!!???!!!
  226. Rc????
  227. Need help with internal noise (posted with video)
  228. 4.8l?
  229. The setup look good for a cam swap?
  230. Need help
  231. Best heads for my car
  232. How often should you change comp 918 valve springs
  233. Porting 241's???
  234. Anyone have a ls1 block they wanna sell
  235. Engine Swap or H/C?
  236. Heads/cam with 100k ?
  237. LS6 specific manuals?
  238. Ping maybe knock?
  239. Why are my Pistons so clean?
  240. Ls1 rebuild time
  241. Can I replace a 6.0 with a 5.3 with no modifications?
  242. 5.3 cam help dragcar
  243. How to get more HP and TQ with the least amount of money lol???
  244. Best heads for a tsp 228r camshaft?
  245. Torquer V3 with 62cc heads?
  246. What cam is this ??
  247. torquer v2 good for stock heads/gears daily driver?
  248. head porting/machining question?
  249. Could i use Nitrous built engine for FI
  250. LS6 cam in 6.0
