- Looking for new heads/cam - car details inside
- Well, cracked my block
- 59cc or 64cc chambers
- Compression Ratio Calculator ( Excel File )
- Please help. Question on Patriot heads
- 01' 5.3 w/ fuel cell help
- Installing a ton of parts, but what am I forgetting?
- need some help, almost done with build
- LSX guy who's s10 wont start..status post head gasket replacement
- LQ9 Block on the way
- Possible fuel issues please help
- 383 stroker question
- Carbed 5.3 cam question
- Are these heads for real? I didn't think it was possible!? Sorry if repost.
- new cam weds, help me pick one
- stock fuel filter fitting
- diff between 918 and stock springs need help before epic engine fail!
- oil pan baffle (f-body)
- Question on Trickflow and stock rockers, not what you think.
- help with cam swap
- what do u guys think about this set up help
- Angle mill?
- 5.3 Heads or other?
- Damage to nitride coating, possible effects on spring strength
- Valve help please
- oil presure and loud ticking???
- 6.0 lq4 swap
- 2002 LQ4 piston part number (cross on top)
- -.016 deck height?
- spun bearing on new motor
- oil burning????
- Need help with my norwegian 383 build
- Low-End Torque F-body 98-02
- Crank Compatability
- Need help with cam selection
- 6.0????
- heads
- Stock cam power band
- Max RPM for stock bottem end?
- is there a way to know compression after an engine is built
- 243's ported or unported?
- 317 heads that I just got have .030 longer exhaust valves
- rocker arm chaser size?
- New build
- Passenger side trouble
- Connecting rods??
- Valve locks?
- I am going to have to flycut!!! :(
- Something is fked with my oil psi
- built motor question
- Ticking noise on passenger side of motor....
- Bad Lifter
- Looking at TSP's cam kit...
- the tsunami will be here tomorrow!***updated w/ track times!***
- How much power and rpm on stock rods
- What are the effects of having too short of pushrods?
- fuel problem??
- i have Questions about the ASA Cam 226/236 .525/.525 110 lsa
- torquer v2 question
- looking for a good cam for a turbo 434 lsx
- .045 quench too much?
- The End is Near
- big torque cam..help!!!!
- looking for input
- Is this normal on a AFR head?
- quench and nitrous
- ls6 camshaft
- crank
- stock crank ?
- How much power are you making with your Hot Cam?
- 408 stroker dish pistons for L92 heads???
- heads/cam questions
- PI 215 heads vs tfs heads
- 918 valve springs, ms3 cam??
- would you pay $1500
- What Patriot Cylinder Heads Do I Have? LS6 Engraved In Head
- Cause of cold engine ticks (Vid inside)
- Burned Valve question
- 317 heads
- Crap in my heads
- How much to mill?
- new cam, small problem
- Front oxygen sensors going bad.
- No oil pressure at first start.. HELP!!
- How to tell the difference between 4.8 & 5.3?
- Little help on a stroker heads and cam
- Did I damage something? (idiot inside)
- Corvette/Camaro LS1 differences
- Comp R lifters + non adj rockers?
- head and cam combo question
- Installing AFR heads, Do I need this part?? Pics Inside, HELP QUICK!
- LS1/ LS2 question.
- cam only?
- SLP 1.85 roller rocker kit
- Lq4 Rotating Assembly
- 5.3L swap/no oil psi
- Valve Stem seal question, done my research
- Trick Flow 215 Cylinder Heads
- Power
- Will this cam work with LS6 heads?
- Optimal Cam ???
- 5.3 cam selection?? tricky!
- Wierd idle.. HELP!!!
- Stock pushrod length on 5.3
- Tell me I didn't screw something up (compression Q)
- Very Low Preload #'s - sound right?
- Anyone have a Cam for Sale??
- would it be worth swaping my as cast tfs heads for PI 215
- LQ4/6.0 budget build advice needed please..
- temp gauge and speedo issues
- For those that have pulled/installed the motor from the top.
- Has anyone saw this?
- best cam for my heads?
- 5.3 for a miata. What cam?
- Cam
- Missing something?
- Will the fuel pump work when ecu go bad?
- Untuned Ms4
- Radiator water going up
- Will this work?
- Newbie on how to degree a cam, a question or two
- Need help computer acting funny.
- El Torro Specs @ .2 & .006
- Cam Install Question For 99 Auto
- Have an 01 Vette. Getting AFR 215 Heads. Do I need a FAST Intake?
- We copied an aftermarket cam and had nissan install it and fked up our car
- What do you check/used Ls1 engine
- what length push rod?
- 5.3l & turbo reliability issues
- new rebuild will not start
- Adding to the slew of Cam threads :)
- Where is the Stamped Serial Number on Patriot LS6 Style Heads
- Anyone ran 218/226 .595”/.598” 114LSA +4
- Can you swap stock 241 valves into 243 heads?
- Anyone have AFR 215's in stock? Looking to buy.
- Looking to get the New AFR 215 HEADS to replace Patriots in my C5.
- Engine rebuild questions ?'s
- Eps 226/234 113
- What shift points for my hotcam?
- Biggest Cam with stock convereter???
- Comp Cams trunion upgrade Q's???
- Balancer install depth?
- Attn Patriot Head Owners! Where is Head Stamp At?
- Attn patriot Head Owners! Where is Head Stamp At?
- LS2 chain: 12586482 anything else needed ?
- help, lifter stuck up or turned in retainer?
- TR6 spark plug gap
- Got my first Ls1 build started
- to dry sleeve or bore a 6.0
- Possible Heat-relayed Intermittent Start Issue
- Porting/Shimming stock pump vs Buying new pump?
- whats up with HKE???
- Best cam for my setup? - HELP!!
- better benefits from which one?
- timing chain comparison
- Can you re-torque heads with headers inplace?
- Did not chase head bolt threads...problem?
- Over-rev?
- Lifter preload?
- File Fitting rings?
- Are all LS heads like this? bolts in intake ports?
- 317 head milling?
- Oil pressure problem: 50% drop when hot.
- Question: A 4.25" Stroke on LS Block (Standard Deck Hight)... It is possible
- best way to remove Crank Freeze Plug? UPDATED>>
- TRex and PP Stage 2 5.3L Heads PTVC?
- need help where can i get coolant bypass o-rings
- Help with stroker build
- What's the difference in porting and milling heads?
- Rapid Motorsports "Dominator" Series II Cam Kit
- camshaft change
- Build 14.1 CR in LS1 for E85 daily drive?
- external pickup
- for those of you who need to shim your stock rockers come inside
- JP performance timing set...do I need spacers?
- Anyone running 5.3 heads with a Torquer 2?
- 5.3 / ls6 compatiailty in parts? Doing a motor swap
- injector harness question
- Future mods for 2000 Trans am
- I found the problem the misfire!
- Increased operating temp with new setup
- Do i have everything i need for the cam swap?
- I have a misfire, COME INSIDE!
- El Torro Idle
- I want cheap performance
- A troubled 404 Stroker...***UPDATEDD** PLEASE READ LAST POST!
- timing set??
- Help me here-what all will I need
- c5 z installing comp 236 238 .601 .605 112
- afr heads need longer pushrods?
- Which blower cam would be better for me?
- difference in rocker pedestools ls1 / ls6
- trick flow as cast 220's vs. tsp stage 2.5 ls6's
- ls1 lq9 question
- Catch can installation on ls1
- flex plate
- Air Pipe Gasket
- Anybody run .040 or less preload w/ "LS7" lifters?
- New rockers or upgrade?
- Lets build an LS1 shortblock. On the cheap.
- Help! Car bogging down...
- Head Question
- what do you think of this build?
- new oil pump with low preasure
- Which Cam to Buy
- AFR 62cc head with .040 head gasket = 11:1 CR Right? LS1
- Help me pick out a cam for my LS1 powered IS300
- Looking for moderate/aggressive cam
- ALOT of blue smoke??
- What LS6 heads to buy!?!?!
- PLEASE tell me where this part goes in the motor! pics.
- Yella Terra Rocker Q's
- El Torro and MAYBE heads...what fuel pump and injectors?
- Cam motion custom grind
- asa cam.
- ms4 vs megadeath
- Bad Sensor?
- *****just read it*****
- Help, Fuel in Oil!
- Melling Re-sleeve LS1?
- pre-oiling after sitting
- Crank Sensor getting tore up by Reluctor Wheel
- Help me pick a cam.
- car wont start after rebuild
- vavle seals on 243 heads
- coolant leak on trick flow heads!! help!
- Help me ID this cam please!
- Need some help/advice...my car is having issues
- Will the cam from my M6 Camaro work in my A4 Camaro?
- New lifters with new cam? YAY OR NAY
- LS1/LS6 PCV Question
- How much bigger is the 98 99 cam then the 00 01 02?
- any way to CC a head at home?
- Are the AFR 245s shipping
- Looking for Piston Rings for boosted motor.. :(
- 7.425 on Stock LQ4?
- Selling Comp Cams XR269HR CAM
- The Ride!
- another LM7 swap and noob with ??????S
- Patriot ls6 2.5 or PRC 5.3 stage II
- What are these connectors for?
- Bored at work today, so I offset ground my crank and took pics of the process
- What do you guys think about this setup?!?
- quiet fuel pump for ls1?
- Have cam need advice on heads?
- melling and double roller chain
- Stupid question about idle with MS3
- oil pan clearance!!!
- timing chain Question
