View Full Version : Generation III Internal Engine
  1. 383 stroker cam choice
  2. questions on my cam swap
  3. New bullet for AFR 215 R&D
  4. Low-End Torque
  5. Com Cam, straught up or degree it
  6. i think the preformance shop screwed up
  7. Lots of valvetrain questions...
  8. LS1 issues
  9. specs on used cam
  10. 59cc heads, 11:1 CR & 92 octane?
  11. I need LS1 engine
  12. Powdered metal rods
  13. TR227/224 and 241 heads install 56K NO WAY
  14. cost of cam install on 02 Z28.
  15. who else?
  16. LQ4 engine and about to do cam install and need advice
  17. Misfire & A Sh!tload of Codes
  18. ported stock oil pump?
  19. GM MLS headgasket bore size question
  20. Machining deck surface of 317's...
  21. cleaning heads...
  22. Put My Motor Back Together....Initial Start-Up
  23. LS6 Cam specs?
  24. boggs down @ high RPM
  25. will LS7 springs work on LS1 heads?
  26. Iron Block limits
  27. idle problem
  28. Mother Thumper
  29. LS7 Lifters and new heads/cam
  30. The beat to death connecting rod debate...
  31. 5.3L heads? Help
  32. Let's get me 450-480hp
  33. Decked 5.3 heads and valve size
  34. roller rockers worth the money??
  35. Good cam or not
  36. Engine removal help!
  37. From what are this ARP head studs?
  38. engine covers and cam plate
  39. Just wanna make sure of the lq4 and lq9 differences
  40. Heads...Edelbrock/Lingenfelter vs AFR 1510
  41. which piston is better
  42. What in the hell noise is this?
  43. header selection on ms3 ls1
  44. 5.3 vortec internaly ballanced or externaly?
  45. Did your machine shop use a torque plate when machining your motor?
  46. Anyone got a certain cam they prefer?
  47. MOTOR IS TICKING Ls6 HEAD STOCK BOTTOM
  48. ms4's favorite head?
  49. need help with plugs and gap please...
  50. TR CheaTR package vs GT2-3 and Patriot LS6 heads
  51. do i have everything for my cam install?
  52. can i put a ls3 cam in a ls1
  53. A fast, easy way to measure preload.
  54. Let's hear it
  55. 3 angle or 5 angle, plus porting questions.
  56. ls6 yellow valve spring question
  57. HELP Break Booster Hose Routing
  58. Will I have to remeasure pTV clearance
  59. Question about a built LS6
  60. Installing forged pistons in 90k ls1
  61. Serious Idle Surge Problem
  62. ?s about 03 6.0 lq4 with L92 heads
  63. Predator-Z need your assistance
  64. Valve Spring Shims Question? HELP
  65. Im stranded help
  66. whats the BEST FRESH CANVAS that needs paint.
  67. using l92 heads on a 408
  68. 99 LS daily driver, heads any good?
  69. gas mileage with 228 cam?
  70. What should I expect?
  71. 285cc PRC LS7 CNC Ported 415+cfm Cylinder Heads Now Available
  72. Head Swap surface prep?
  73. Lq9 Cam recommend in a crawler???
  74. Patriot cam?
  75. lq9 info needed
  76. '98 Head question
  77. LS1/ LS2 Swap in 98 ws6
  78. best cam for motor only with longtubes
  79. How to properly install and torque ARP Fasteners
  80. 383 vs turbo!?!?!
  81. noob set up question
  82. N2O cam for 370...
  83. build question...
  84. check out my head gaskets
  85. Any Pro Head Porters in Here?
  86. Help with upcoming head swap
  87. 10:5 compression from my LQ4
  88. sleeper
  89. Need some help with AC pump wiring
  90. ls6 cam value
  91. ARP head bolts need TQ specs
  92. best budget heads for 6.0 besides the l92's???
  93. Possible way to keep DOD
  94. another what cam,carb LQ9
  95. Is this a hotcam?? Cam guru's
  96. Piston to Valve Clearances Q's
  97. ls1 to a 408 or just heads and cam?
  98. PushRod Lenght
  99. '98LS1 block max honing?
  100. Having trouble picking a cam
  101. 500+HP 383 setup
  102. Morel Lifter RELABELS
  103. COMP CAM Rocker Arm Trunion Upgrade, rocker bolt question?
  104. Simultaneous Builds (with pictures this time)
  105. School me on Heads
  106. Big Inch LSX
  107. Comp Cams LS1 Rocker Arm Trunion Upgrade
  108. cam only
  109. Rocker Torque Sequence
  110. RPM Increase ?
  111. Well gotta switch up the build again!!!
  112. Modding my 98 ls1 camaro
  113. HELP: '97/'98 LS1 3.905 Bore Power Limit?
  114. i need some help
  115. Thunder Racings Cheater cam LS1
  116. Oil pressure dropping
  117. Cam Newbie...
  118. what do i have to change on a 5.3 or 6.0
  119. ls1 reading low temps after changing ect!!
  120. Connecting rod bolts
  121. Motor problems... lifters, Cometics and unknown
  122. LS7 cam in LS1?
  123. Can cam bearing fall down when a cam swap!
  124. New Parts Installed NeeD Help!
  125. Drilled lifter tray?
  126. Broken lifter
  127. Those of you with TSP shortblocks... Opinions?
  128. Help me verify my cam spec's.
  129. Miss under load only, idles fine, but no codes??
  130. Slight lifter tap
  131. LS1 Heads Pros & Cons VS Ls6 (BUILDERS,Porters & Tuners Chime IN)
  132. Bought a 2001 6.0l but.....
  133. TSP LS6 head questions. Castech?
  134. etp head question
  135. what will my cam swap make???
  136. which lifters ls7, morel?
  137. question
  138. 383 build..
  139. Flashing SES light... No code?
  140. cam advice please
  141. flycutting cc size has anyone actually measured???
  142. Brake Pad question
  143. ls1 bearing clearence
  144. piston ring gap
  145. Anybody running Advanced Induction H/C ls6??
  146. Anyone run the EPP blower cam NA? Results?
  147. GM Grand Am Cup cam in 408 iron block.
  148. What can cause this?
  149. 241 p&p heads flow data
  150. Help fast 3.73 question ls1
  151. ls6 heads milled???
  152. ls2 swap need help!!! cmp sensor
  153. i need the front drive accesories
  154. Any ideas on PTV on this cam?
  155. Ls1 Camaro Vs. Ls1 Corvette
  156. Trickflow heads and cam
  157. Questions about new setup
  158. This is going to sound dumb...
  159. cam for gas milage?
  160. LS3 cam swap info what cam = ? hp
  161. What cam with a blower???
  162. Help with heads?
  163. New here please help me out
  164. LS7 Lifters???
  165. 6.0l- 4.125 stroke
  166. 1 Wire LS Alternator
  167. Stock Replacement Pistons
  168. push rod length
  169. 408 stroker or lq9?
  170. 2003 LS6 (Z06) engine - are forged pistons available ?
  171. Head Help?
  172. Thinkin about a head swap
  173. i want the BesT cam ??
  174. PTV Help!
  175. 5.3 cam ideas
  176. Did LQ4/9 head bolt questions...
  177. 6.0 headgasket on LS1
  178. Need help ASAP... Cam sprocket or the tune?
  179. Trick Flow 220cc "as cast"? comments?
  180. Lifter going symptoms
  181. Cam help v2 v3 ms3
  182. TFS assembly questions
  183. Need help picking the right cam and not just some huge cam
  184. good setup
  185. Motor Break In Question?
  186. 5.3 Thumpr
  187. SLP 402 Issues
  188. What size injectors
  189. Lunati 408 from a LQ4?
  190. What cam?
  191. Do I have everything for a head swap?
  192. ls2 to ls1 conversion
  193. PRC stg 2.5 5.3l heads to PRC l92 head quesitons..
  194. Baby cam question, So whats the LSA??? Cam guys come in
  195. Crank Bolts for 6.0 Spacer
  196. ARP rod and main bolts
  197. Pac 28-1518 valve springs
  198. How Fast Can You Spin A LS1
  199. Best 15 degree head on the market??
  200. opinions wanted. time to order parts. spring life? and cam selection.
  201. Need some advice on what LSA
  202. LS1 Parts on 5.3s Good or Bad??
  203. Head and cam swap-Best place to buy lifters and pushrods?
  204. do i need lifters??????
  205. lq4 fc rx7 need some advice (newb)
  206. whats the problem?
  207. stock LQ4 with a cam what should i expect?
  208. Max stroke/rod lth on resleeved block
  209. What cam???
  210. LS6 Windage Tray Different Than LS1?
  211. Head bolt help
  212. Anyone put stock 5.3 heads on LS1?
  213. Would it be Possible to Retrofit my 383 with VVT?
  214. Anyone Tried the MAST Black Label LS3 350+cfm heads for 3.900 bore engines?
  215. Oil Pressure Help
  216. Ls1 block crank with Ls2 rods and pistons
  217. Poor Man's LS2 - For five grand...
  218. mystery engine?
  219. Cam ID??
  220. LS6 Bat Wing Oil Pan for sale
  221. Head swap now no gauges? Please help
  222. Help! No Oil Pressure
  223. are the comp. lifters good for 6500RPM levels
  224. Anyone using the Manley H-Lite Series Forged Rods?
  225. How many cfm can 5.3 heads flow?
  226. starter issues
  227. is there a HP to compression real of thumb
  228. How will these heads work with my setup?
  229. Help finding static and dynamic CR
  230. 241's heads anygood
  231. ls1 IS THIS NORMAL????
  232. Sanity check my engine build... anything I'm missing?
  233. 383ci question
  234. Car is not starting, I need some help......
  235. LS1 Advice
  236. Whats the Best Hyd Roller Lifter on the Market?
  237. 5.3 head question
  238. Bearing cost?
  239. what cam is this
  240. 2000 WS6 almost cought fire! help:mad:
  241. what was the best years for the ls1
  242. Trick flow 235 r heads v/s PRC 227/237????
  243. 5.3/LS6 Question
  244. What all to look for in a head?
  245. gm fails again.......lifter
  246. Powerbond Underdrive Pully and LS2 timing chain
  247. Wanting to add a cam but need some info
  248. what you think
  249. loosing coolant
  250. HELP fuel coming out exhaust.
