View Full Version : Generation III Internal Engine
  1. Comp Ratio question
  2. cam install questions
  3. LQ4 swap?
  4. po174
  5. 6.0 ls cylinder numbers ?
  6. Think with your dipstick.
  7. 806 heads need help
  8. fuel injectors rates
  9. Bmr
  10. what piston
  11. ls1 rebuild
  12. Who has Shelf Pistons with pin offset for strokers
  13. 408 heads
  14. Cleaning block?
  15. ms3 flycut?
  16. Cam selection for 5.3
  17. New Cam Specs
  18. Need help asap please!
  19. Help with build
  20. Cam difference?
  21. Forged Motor
  22. ms4 cam ?
  23. stall speed? ms3/ms4
  24. Possible bent valve?
  25. fuel pressure way to high!!
  26. good set up???
  27. Opinion on cam for 427
  28. should I reuse my PRC duals on my new heads?
  29. found G6X3 new very cheap got Some ?s **PLEASE HELP**
  30. Cam sound clip .wav files
  31. Head bolts?
  32. Milling Trick Flow Heads
  33. LQ9 Stroker options?
  34. What head gaskets? 317s on ls1
  35. Solid Valley Cover Modifications - PCV
  36. High Mileage Motor!!! Should I head and cam it??
  37. output and drivability
  38. Cam Selection For 383
  39. H/C selection help.
  40. A4 to M6 Wire Harness
  41. ok the truck guys arent really helping
  42. 6.0 liter build... Can someone point me in the right direction???
  43. Rotating Assembly: A DIY?
  44. piston rings Federal Mogul Sealed Power ????
  45. Comp 918 failure costs an LS1 it's life...
  46. Cam comparo
  47. Is this Cam trash?
  48. Compression for towing
  49. help diagnosing
  50. Buying a used Motor
  51. forged crank question
  52. Anyone have an uninstalled GMPP LS1 Hot Cam?
  53. wanna do a budget 6.0 for my S10.
  54. What is the size of coolant drain plug on side of block ?
  55. About to Order Parts! Need Opinions!!!!
  56. timing chain question
  57. sTRoker cam switch
  58. Ptv
  59. advice please
  60. Engine bolts, reuse or new?
  61. LQ4 timing chain?
  62. Painting or polishing lifter valley
  63. will this work?
  64. why arp . . .
  65. Custom Cam or Shelf Cam?
  66. Looking For Piston Fly Cutting Tools
  67. Va Speed. We'd like to apologize.......
  68. Anyone ever done a valve drop on a stock ls1 longblock ?
  69. heads
  70. With a 231/235 113+2 Dcr= 8.74:1 112lsa= ?
  71. Noisey valvetrain (sewing machine)
  72. Flooded Car doesn't run the best what could it be?
  73. Low Oil Pressure
  74. oil consumption
  75. hows this combo look
  76. lsx running on nitro fuel
  77. 75mm MAF connect to FAST 92/92
  78. Head & cam - HP VS. TQ
  79. Camshaft LS1 VS Lm7
  80. strocke 3.622 ls1
  81. Dipstick broken off in block
  82. Need imput please! Bad missfire and power loss
  83. First Camshaft/Valvespring Install on LQ4
  84. Head gasket question
  85. anyone have a 2.055 and 2.08 intake valve laying around?
  86. Compression vs Pump Gas
  87. asa 60% underdrive
  88. Cam for lighter vehicle?
  89. Galled cam gear on LQ9.....WTF???
  90. lq9 knock sensors same as LS1?
  91. does LS6 valley cover fit on 06 LQ9 with out block clearancing?
  92. fk it im going bigger, need some advice.
  93. cam 106 +4?
  94. 799 heads
  95. How long will my valve springs last me?
  96. Flycutting piston help
  97. Is this a good combo for 400rwhp?
  98. Hve a few questions about cams
  99. Rod bolt failure limit
  100. Help me decide on a H/C/I combo!
  101. No oil pressure!!!!
  102. head gasket swap on a 5.3
  103. head gasket help
  104. Oil pick-up tube?
  105. Cam swap done!
  106. mystery noise
  107. head opinions
  108. Milling 243 heads w/ nitrous???
  109. Question on cam size for 5.3L
  110. ls1/ls2 timing chain damper?
  111. Help me with my new build!
  112. 1999 5.3 vortec to 2007 5.3...Help
  113. Aluminum 5.3l block and sleeving
  114. Oil Pressure Sending Unit
  115. Whats the weight diffrence between Iron and Aluminum blocks?
  116. Scat I-beam rods
  117. Cam help for Winter project... need help with PTV and suggestions
  118. Questions about ARE sleeved block
  119. 393 stoker questions
  120. cosmetic gasket
  121. Arp rod bolt replacement ?
  122. bolting down LS1 heads torque/bolt pattern? Q
  123. Mystery LS1 issues
  124. rod bolt questions
  125. Worked 243's worth the $$$$????
  126. Some PTV and Milling Questions
  127. Any track results from POLLUTER cam?
  128. 4.8 and5.3 heads
  129. Quick quest about LS6 Intakes
  130. LS2 cam better than LS1 cam?
  131. Changing cams... Stumped
  132. pushrod lenght ?s
  133. Durability of a stroked 346 to 383
  134. Break in procedure/oil for new LS6 crate engine
  135. LS1 sluggish at low RPMs
  136. cam guru's
  137. Ms4 with stock heads
  138. Harland Sharp Roller rockers backed off?
  139. Did my thermostat stick?
  140. Pro gram engineering sucks my d---
  141. head swap
  142. 5.3 block bore
  143. Burning Oil Fast
  144. Are heads worth the money
  145. PRC 215, AFR 205, ETP 215, or TFS 215
  146. Need help with engine build
  147. LS3 small bore heads or TFS 215s
  148. Head Bolts
  149. Need particulars on a cam
  150. 1.7 rockers or 1.8 rocker arms
  151. ls1 combo set up
  152. 1.7 roller rockers or 1.8 rollers rocker
  153. 317 heads VS TFS 225cnc
  154. lq9 317 heads: MS3, TREX, or Raptor???
  155. anyone ever heard of this brand of rods and crank
  156. Looking for a mild street cam for 97 vette
  157. timing chain and gears?
  158. Aftermarket valve covers
  159. cold idle
  160. some valve spring help
  161. Indulge me
  162. Looking for a cam!
  163. Ls1 heads
  164. Valvetrain Question
  165. Oil pan gasket question
  166. *Pics added* Cylinder wall rust?
  167. LS-3 cylinder walls...
  168. Can you guys recommend a cam for me?
  169. ?s about my 98 trans am
  170. L33?
  171. 6.0l stroker
  172. ?s about my combo
  173. 227 231 111 +2 cam lsl lobes
  174. spun rod bearing?
  175. Any problems with 99 ss?
  176. have a question about lifters
  177. L92 head question
  178. cam help
  179. budget questions
  180. Yellow sludge under oil cap?
  181. 14:1 static compression ratio on pump gas and the "Its all about the tune" excuse...
  182. What is the best combination for me...
  183. LS1: Stroked from 346ci to 412ci... IS IT POSSIBLE
  184. PRC 2.5 LS6 Heads/Cam Combo's Flycut Question?
  185. Need a Part # Please
  186. Cutoff at WOT
  187. Opinions
  188. pulling vacume???
  189. patriot ls6 heads & ms3 cam, clearance?
  190. 853 heads and 233/239 cam?
  191. Real quick self check
  192. Need some help
  193. California friendly, shorty header street cam?
  194. Engine Rpm
  195. Please Help!
  196. Cam Install Question
  197. Corrosion pitting in valley cover at knock sensor
  198. help needed
  199. Valve springs for my cam swap
  200. Who makes this cam? How much of a change..
  201. in car cam swap
  202. LS1 oil pump
  203. help me pick a cam!!!!!!!
  204. Help with cam choice
  205. Cams that eat Valve Springs
  206. bad news everyone!
  207. What to do...!?!
  208. have a question about throttle body ls6 intake
  209. cams...
  210. Yella Terra Bolts??
  211. TEA Stage 1 243s
  212. TREX V.2 questions
  213. 6.0L rods fit in LS1?
  214. how much horsepower
  215. Piston rings?
  216. 6.0L L92 L76 Idle sound of new cam
  217. 6.0 iron block
  218. Rebuild or Replace
  219. 862 heads
  220. Too much compression with my heads and LQ9???
  221. Whats a good mild cam for 402
  222. Lq9,60cc ported LS1 Heads, what cam w/o flycutting? what thickness head gasket????
  223. LS1 Oil Pump
  224. Questions about going to 6.0
  225. Dry Sleeving an Iron Block?
  226. Best junkyard heads? I need a shopping list!!
  227. Where is best place to buy a LS1 383 stroker kit ?
  228. 383 build..
  229. Need advice on clearance issues
  230. Build possibilities with an LS1 block? Big cubes?
  231. What lifters do you use???
  232. Lq4 cam question
  233. Is my cam wrong?
  234. Cam Helpp!
  235. will I hit 400hp?
  236. help me diagnose this problem.......
  237. high idle and auto rev when movimg
  238. MS4 110+3 Ground advance
  239. Rod bolts
  240. LQ4. High Compression?? ==383
  241. Oil leak after cam install.Please LOOK
  242. Best "cam only" cam for a LS2?
  243. Should i go bigger w my cam?
  244. Best bearings to use
  245. 01-02 f body ls1 flywheel weight
  246. Best bang for the buck LS1
  247. Lq4 Head Question
  248. Compression Test Results
  249. drive by wire
  250. Important cam ?
