View Full Version : Generation III Internal Engine
  1. prc .660" springs with stock cam ok?
  2. Edlebrock Cam w/No Tuning? 430HP?
  3. Cam identification help please.
  4. Does anyone have a ported stock TB
  5. help with ticking noise
  6. 243 heads
  7. Strange engine behavior at WOT - Help!
  8. Any info on the Edelbrock 430 HP cam, no tuning required
  9. Forged 347 to run 6.50's 1/8th?
  10. Noob questions about Lifters/pushrods
  11. help diagnosing an engine knock
  12. Machining question
  13. Anybody Re-use Cometic head gaskets?
  14. People w/ TR230, what heads are you using?
  15. compression ratio guesstimate
  16. damaged block
  17. the truth about oil pumps....
  18. Intermittent Power Loss - 01 WS6
  19. Head/Cam question
  20. plugs / wires - tuneup
  21. No Start Condition driving me Crazy
  22. need help identifiying piston
  23. 20 more horses!
  24. 2001 ss engine bay fender well clean up
  25. what kinda numbers can I expect?
  26. Can you have too much oil pressure? Any long-term negatives?
  27. 408 setups with L92/L76 combos?
  28. Dynograph of 491hp 5.3L with TF 205 heads...
  29. PRC 5.3 stage 2.5 heads with stock cam
  30. What is the biggest Texas Speed Cam I can run on my stock 2000 heads?
  31. cam swap
  32. 228r cam with 59cc heads
  33. My build...
  34. hrpt in 2 days now oil pressure TOO high???
  35. X1 Vs. MS3
  36. stock bottom end specs question
  37. Wierd Oil Pressure at WOT...
  38. Will I hit 450rwhp??
  39. Spark plugs and gap question
  40. Best cheap combo for 250hp and max mpg?
  41. Melling pump & stock o-ring?
  42. Cam upgrade questions
  43. Milling 317's down to 58cc
  44. do i have to degree my cam?
  45. Play in yella terra rockers?
  46. 408 needs
  47. Friends getting heads and cam
  48. Stalls and Cams...
  49. LS2 404 not very strong...need some advice!
  50. Ready to buy a cam need help
  51. If your daily driver is cammed, please come in!
  52. burning oil...why??
  53. 5.3 cam
  54. ported ls6 pump only 48 psi wot!
  55. Should I replace my oil pump?
  56. wtb: ls1 STOCK throttle body in south jersey
  57. Engine Building help
  58. prc stage 2.5 ls6 heads w/ stock cam
  59. cam to pass smog?
  60. Head and cam question
  61. Heads without a tune
  62. Thinking of switching prc5.3's for afr...
  63. Head swap opinions
  64. pulled my g5x3 cam out to finf its not what was installed by shop
  65. ordering my cam today
  66. 1.7 rockers with stock cam/heads
  67. So who's installed a smaller cam the 2nd time around?
  68. difference between adjustable and non-adjustable roller rockers?
  69. advice on nitrious setup!!
  70. need honest answer now before i go to lmr!
  71. Problems with windage tray
  72. need help!!!!! baddddddd
  73. Heads ???
  74. Any way to measure lift and duration while it is in the engine????
  75. Zero Oil Pressure
  76. Weird oil pressure
  77. AFR 205 Install Check List
  78. 241 Heads on a 98 block
  79. Hot cam dyno results...
  80. 5.3 to 383
  81. cam..stock cr.. low lsa
  82. let's hear horror stories from people who bought assembled engines
  83. my combo on a 408
  84. What does this mean??? HELP
  85. which is the better combination for a lq4?
  86. Valve seal recommendations
  87. Cam Install
  88. Compression Question
  89. Rocker Pedestal Rail Play
  90. AFR heads milled .020 w/Vengeance cam suggestion ??
  91. What can I do to make 500rwhp?
  92. What cam is this?
  93. 5.3 forge pistons
  94. Pumped up Lifters - Questions ?
  95. Cam questions
  96. Can i use my old heads now and change to new one later ?
  97. pushrod length check, where do i buy on
  98. ls1 in sand car, need some advice
  99. need more help after cam install
  100. ?'s about new cam
  101. AFR 205's Milled to 62cc
  102. LS Series Head Gasket Listing
  103. where is the best place to buy a new long block?
  104. what cam do you guys think?
  105. Hp gain with stock ls6 heads
  106. Cam Help
  107. cam question
  108. Help please engine acting weird
  109. LQ9 L92 street combo
  110. Can someone help indentify this ls1 cam?
  111. Value of a LS1 block and crank
  112. Prc stage 2.5 5.3 heads or prc stage 1 ls6 heads
  113. Knock Sensor touble
  114. The right bottom to match the top.
  115. lifter question
  116. Broke header bolt in head!!!!!!
  117. how good are bo white ported heads?
  118. A Flooded Street vs. LS1
  119. best heads for trex cam
  120. Just want to verify this:
  121. custom cam
  122. TFS215 and 4.060" Bore LQ9
  123. Intermittent engine tick (with video)
  124. Odd Oil Pressure Change...
  125. Oil pressure spikes on decel - thoughts?
  126. fuel injectors
  127. misfire and no tac signal confusion...
  128. 5.3 liter.. is it worth anything?
  129. Ooooohhhh f..k!!!!!!!!!!!!!!
  130. Valvespring shims
  131. Help me put a god engine combo
  132. NEWBIE, Big Cam, Help/Advice Please
  133. Freakin' Coolant Leak!
  134. the correct way to install head studs
  135. Harmonic balancer bolt for procharger
  136. cam and vacuum question
  137. LS7 lifters
  138. Cam help
  139. 408 questionair
  140. I'm planning on a build. Need suggestions
  141. Need forged piston knowledge?
  142. Engine Whine from 1300-1800 RPM HELP CTS-V
  143. Race fuel??
  144. e.p.s. cams
  145. MS3 and PRC 5.3 heads... Intake question?
  146. Anyone remove there motor in there garage?
  147. Is there a position I can turn the crank to shut all the intake valves?
  148. ls1 pilot bushing swap question
  149. looking for heads
  150. stroker downside?
  151. Engine misfire,Crankcase smoke, now water in oil !
  152. I need lightweight valves, what are my options?
  153. Another push rod question!
  154. Are 227 cc intake runners too big?
  155. What Guages Are Necessary?
  156. a good one for you
  157. Pro Comp Scat I-beams - How Strong ?
  158. Popping, missfire, etc
  159. Rear main seal blown out?
  160. Oil coming from breather?
  161. Will stock L92's outperform stock 243's?
  162. L92 heads and cam
  163. H/C Swap DONE Lots of Pics
  164. Question on 241, vs 706 heads
  165. helpp! problems after cam install
  166. "All Aluminum"
  167. Rod bearings identification numbers
  168. anyone else that has ordered trickflow 215 heads
  169. Camshaft help
  170. Getting worried as hell!!! help
  171. Lifter opinion fast!
  172. How to tell if lifters are bad??
  173. GTO CAM....yes I search a lot
  174. Stroker setup?
  175. What should i do first?
  176. max bore on LS1 block
  177. heads
  178. 02 z06 and ecs n/a cam
  179. engine build?
  180. Oh damn, a knock.. What the hell???
  181. Dirt late model
  182. Heads question, help
  183. setup questions
  184. Rear main seal
  185. 6.0 going away
  186. Stumble/No Power - o2 sensor??
  187. Need stuff for H/C swap...What stuff can I get from Summit?
  188. 241 heads on a 5.3/UD pulley question
  189. Motor swap & H/C/I, now no start???
  190. 2001 ls1 from trans am ws6 pulley/idler
  191. belt tensioner location
  192. trickflow 235 help
  193. Anyone had this problem?
  194. better times with new cam but not what I expected
  195. lost oil pump, now having low power/stumbling issues
  196. Cam lope question.... reverse split!
  197. Opinions on this setup
  198. Heads/cam 11:1 LQ4 vs RB26DETT
  199. Whered this come from?
  200. Low Dyno #'s, need advice
  201. Blown head gasket
  202. Pullin the engine again!! ugh...answer this plz!
  203. Dropped Bolt in Oil Pan
  204. cam question
  205. Im looking to get a cam specd.
  206. How much Overlap with Cats?
  207. Ls1 crank and Lq4 crank the same?
  208. I NEED Help ... LS1 to LQ9
  209. ls1 squeaking
  210. head studs
  211. Stripped Head Bolt Hole!!! HELP!!!
  212. piston slap
  213. PLEASE HELP!! Hella engine ticking noise
  214. can you use ls2 6.0 rods/pistons in lq4?
  215. Started my heads/cam swap today
  216. Try a can of Fluid Film for free!
  217. Vacuum @ pass valve cover and low oil pressure
  218. Opinions or experience with Warhawk 15* heads?
  219. Stupid Questions...
  220. Hydrolocked LS1
  221. bull's eye on block what does that mean?
  222. Need to know when first C5R engines were..
  223. top speed
  224. Cam suggestions?
  225. Went to the Stealership, which Rod bolt do I need??
  226. Any Vendors Sell Oil Pump O-Rings???
  227. LS7 in an F-body pics
  228. What heads to use with lq4?
  229. Broken Bolt Head on Head!!!! HELP
  230. afr 59cc ms4 guys come in!!!!!
  231. New TEA Stage 2 Heads Video
  232. pushrod length
  233. spring max lift question
  234. AFR 205cc heads Lg G5X3 cam
  235. are these right?
  236. Any 396 LS1 guys out there
  237. Valvespring Advice?
  238. Precision Race Components CNC-Ported LS3 & L92 Heads
  239. Harland Sharp Called - Rebuilt rockers require Zinc in oil? WTF???
  240. Question about lifter preload and pushrod length???
  241. Upgrades needed for engine with ms4 cam?
  242. Crank Pully Install
  243. Accessory Bolt Help
  244. 500rwh h/c 346 guys please come in
  245. back firing after head gasket change?
  246. Almost 200K motor, is it to late for high HP
  247. BAD vibration revving in park??????
  248. What spark plugs to user with 408ci 500rwhp 11.6 CR ?
  249. i cant get my crank pulley off!!
  250. Video of my car after Torquer2 install
