View Full Version : Generation III Internal Engine
  1. Anybody Re-use Cometic head gaskets?
  2. People w/ TR230, what heads are you using?
  3. compression ratio guesstimate
  4. damaged block
  5. the truth about oil pumps....
  6. Intermittent Power Loss - 01 WS6
  7. Head/Cam question
  8. plugs / wires - tuneup
  9. No Start Condition driving me Crazy
  10. need help identifiying piston
  11. 20 more horses!
  12. 2001 ss engine bay fender well clean up
  13. what kinda numbers can I expect?
  14. Can you have too much oil pressure? Any long-term negatives?
  15. 408 setups with L92/L76 combos?
  16. Dynograph of 491hp 5.3L with TF 205 heads...
  17. PRC 5.3 stage 2.5 heads with stock cam
  18. What is the biggest Texas Speed Cam I can run on my stock 2000 heads?
  19. cam swap
  20. 228r cam with 59cc heads
  21. My build...
  22. hrpt in 2 days now oil pressure TOO high???
  23. X1 Vs. MS3
  24. stock bottom end specs question
  25. Wierd Oil Pressure at WOT...
  26. Will I hit 450rwhp??
  27. Spark plugs and gap question
  28. Best cheap combo for 250hp and max mpg?
  29. Melling pump & stock o-ring?
  30. Cam upgrade questions
  31. Milling 317's down to 58cc
  32. do i have to degree my cam?
  33. Play in yella terra rockers?
  34. 408 needs
  35. Friends getting heads and cam
  36. Stalls and Cams...
  37. LS2 404 not very strong...need some advice!
  38. Ready to buy a cam need help
  39. If your daily driver is cammed, please come in!
  40. burning oil...why??
  41. 5.3 cam
  42. ported ls6 pump only 48 psi wot!
  43. Should I replace my oil pump?
  44. wtb: ls1 STOCK throttle body in south jersey
  45. Engine Building help
  46. prc stage 2.5 ls6 heads w/ stock cam
  47. cam to pass smog?
  48. Head and cam question
  49. Heads without a tune
  50. Thinking of switching prc5.3's for afr...
  51. Head swap opinions
  52. pulled my g5x3 cam out to finf its not what was installed by shop
  53. ordering my cam today
  54. 1.7 rockers with stock cam/heads
  55. So who's installed a smaller cam the 2nd time around?
  56. difference between adjustable and non-adjustable roller rockers?
  57. advice on nitrious setup!!
  58. need honest answer now before i go to lmr!
  59. Problems with windage tray
  60. need help!!!!! baddddddd
  61. Heads ???
  62. Any way to measure lift and duration while it is in the engine????
  63. Zero Oil Pressure
  64. Weird oil pressure
  65. AFR 205 Install Check List
  66. 241 Heads on a 98 block
  67. Hot cam dyno results...
  68. 5.3 to 383
  69. cam..stock cr.. low lsa
  70. let's hear horror stories from people who bought assembled engines
  71. my combo on a 408
  72. What does this mean??? HELP
  73. which is the better combination for a lq4?
  74. Valve seal recommendations
  75. Cam Install
  76. Compression Question
  77. Rocker Pedestal Rail Play
  78. AFR heads milled .020 w/Vengeance cam suggestion ??
  79. What can I do to make 500rwhp?
  80. What cam is this?
  81. 5.3 forge pistons
  82. Pumped up Lifters - Questions ?
  83. Cam questions
  84. Can i use my old heads now and change to new one later ?
  85. pushrod length check, where do i buy on
  86. ls1 in sand car, need some advice
  87. need more help after cam install
  88. ?'s about new cam
  89. AFR 205's Milled to 62cc
  90. LS Series Head Gasket Listing
  91. where is the best place to buy a new long block?
  92. what cam do you guys think?
  93. Hp gain with stock ls6 heads
  94. Cam Help
  95. cam question
  96. Help please engine acting weird
  97. LQ9 L92 street combo
  98. Can someone help indentify this ls1 cam?
  99. Value of a LS1 block and crank
  100. Prc stage 2.5 5.3 heads or prc stage 1 ls6 heads
  101. Knock Sensor touble
  102. The right bottom to match the top.
  103. lifter question
  104. Broke header bolt in head!!!!!!
  105. how good are bo white ported heads?
  106. A Flooded Street vs. LS1
  107. best heads for trex cam
  108. Just want to verify this:
  109. custom cam
  110. TFS215 and 4.060" Bore LQ9
  111. Intermittent engine tick (with video)
  112. Odd Oil Pressure Change...
  113. Oil pressure spikes on decel - thoughts?
  114. fuel injectors
  115. misfire and no tac signal confusion...
  116. 5.3 liter.. is it worth anything?
  117. Ooooohhhh f..k!!!!!!!!!!!!!!
  118. Valvespring shims
  119. Help me put a god engine combo
  120. NEWBIE, Big Cam, Help/Advice Please
  121. Freakin' Coolant Leak!
  122. the correct way to install head studs
  123. Harmonic balancer bolt for procharger
  124. cam and vacuum question
  125. LS7 lifters
  126. Cam help
  127. 408 questionair
  128. I'm planning on a build. Need suggestions
  129. Need forged piston knowledge?
  130. Engine Whine from 1300-1800 RPM HELP CTS-V
  131. Race fuel??
  132. e.p.s. cams
  133. MS3 and PRC 5.3 heads... Intake question?
  134. Anyone remove there motor in there garage?
  135. Is there a position I can turn the crank to shut all the intake valves?
  136. ls1 pilot bushing swap question
  137. looking for heads
  138. stroker downside?
  139. Engine misfire,Crankcase smoke, now water in oil !
  140. I need lightweight valves, what are my options?
  141. Another push rod question!
  142. Are 227 cc intake runners too big?
  143. What Guages Are Necessary?
  144. a good one for you
  145. Pro Comp Scat I-beams - How Strong ?
  146. Popping, missfire, etc
  147. Rear main seal blown out?
  148. Oil coming from breather?
  149. Will stock L92's outperform stock 243's?
  150. L92 heads and cam
  151. H/C Swap DONE Lots of Pics
  152. Question on 241, vs 706 heads
  153. helpp! problems after cam install
  154. "All Aluminum"
  155. Rod bearings identification numbers
  156. anyone else that has ordered trickflow 215 heads
  157. Camshaft help
  158. Getting worried as hell!!! help
  159. Lifter opinion fast!
  160. How to tell if lifters are bad??
  161. GTO CAM....yes I search a lot
  162. Stroker setup?
  163. What should i do first?
  164. max bore on LS1 block
  165. heads
  166. 02 z06 and ecs n/a cam
  167. engine build?
  168. Oh damn, a knock.. What the hell???
  169. Dirt late model
  170. Heads question, help
  171. setup questions
  172. Rear main seal
  173. 6.0 going away
  174. Stumble/No Power - o2 sensor??
  175. Need stuff for H/C swap...What stuff can I get from Summit?
  176. 241 heads on a 5.3/UD pulley question
  177. Motor swap & H/C/I, now no start???
  178. 2001 ls1 from trans am ws6 pulley/idler
  179. belt tensioner location
  180. trickflow 235 help
  181. Anyone had this problem?
  182. better times with new cam but not what I expected
  183. lost oil pump, now having low power/stumbling issues
  184. Cam lope question.... reverse split!
  185. Opinions on this setup
  186. Heads/cam 11:1 LQ4 vs RB26DETT
  187. Whered this come from?
  188. Low Dyno #'s, need advice
  189. Blown head gasket
  190. Pullin the engine again!! ugh...answer this plz!
  191. Dropped Bolt in Oil Pan
  192. cam question
  193. Im looking to get a cam specd.
  194. How much Overlap with Cats?
  195. Ls1 crank and Lq4 crank the same?
  196. I NEED Help ... LS1 to LQ9
  197. ls1 squeaking
  198. head studs
  199. Stripped Head Bolt Hole!!! HELP!!!
  200. piston slap
  201. PLEASE HELP!! Hella engine ticking noise
  202. can you use ls2 6.0 rods/pistons in lq4?
  203. Started my heads/cam swap today
  204. Try a can of Fluid Film for free!
  205. Vacuum @ pass valve cover and low oil pressure
  206. Opinions or experience with Warhawk 15* heads?
  207. Stupid Questions...
  208. Hydrolocked LS1
  209. bull's eye on block what does that mean?
  210. Need to know when first C5R engines were..
  211. top speed
  212. Cam suggestions?
  213. Went to the Stealership, which Rod bolt do I need??
  214. Any Vendors Sell Oil Pump O-Rings???
  215. LS7 in an F-body pics
  216. What heads to use with lq4?
  217. Broken Bolt Head on Head!!!! HELP
  218. afr 59cc ms4 guys come in!!!!!
  219. New TEA Stage 2 Heads Video
  220. pushrod length
  221. spring max lift question
  222. AFR 205cc heads Lg G5X3 cam
  223. are these right?
  224. Any 396 LS1 guys out there
  225. Valvespring Advice?
  226. Precision Race Components CNC-Ported LS3 & L92 Heads
  227. Harland Sharp Called - Rebuilt rockers require Zinc in oil? WTF???
  228. Question about lifter preload and pushrod length???
  229. Upgrades needed for engine with ms4 cam?
  230. Crank Pully Install
  231. Accessory Bolt Help
  232. 500rwh h/c 346 guys please come in
  233. back firing after head gasket change?
  234. Almost 200K motor, is it to late for high HP
  235. BAD vibration revving in park??????
  236. What spark plugs to user with 408ci 500rwhp 11.6 CR ?
  237. i cant get my crank pulley off!!
  238. Video of my car after Torquer2 install
  239. What cylinder is #7
  240. Revised Comp918 Failure!
  241. "Max lift" on stock heads?
  242. where can i buy sensors for engine ?
  243. Two problems after my H/C/I Swap
  244. Changing lsa on a cam from 116 to 118.
  245. Running Lean
  246. Valve Train noise???
  247. Need budget rockers - best GM option?
  248. msd wire life
  249. Plugs/wires
  250. is this custom cam good ?
