View Full Version : Generation III Internal Engine
  1. An interesting argument (Reverse Split cams)
  2. pushrod length
  3. head cam install
  4. Jeep Cherokee Engine Swap
  5. Main bearing oil clearance tang position ls1 builders Come IN!
  6. Diff oils diff pressures?
  7. Need to pick sum compression, how much can I shave my AFR heads?
  8. Need to pick sum compression, how much can I shave my AFR heads?
  9. stock length pushrods or not?
  10. Trick flow valve springs
  11. Fuel Milage ???
  12. Where to tap/connect mechanical oil pressure gauge?
  13. about 6.0 block
  14. 240+ cam guys
  15. Telling 241 from 243 Castings
  16. Sponsors timing chain and pushrods
  17. Pricing GTP Heads
  18. PCM reprogramming
  19. cam/heads/intake and hp question
  20. what size shims when porting/shiming a oil pump ?
  21. to rocker or not to rocker.... that is the question
  22. 99-01 6.0L build
  23. Went to the Dyno with MS4
  24. gain from milling 243's
  25. Does 2002 ZO6 exhaust manifolds flow any better then stock C5?
  26. 5.7 carnage!
  27. GM camshaft anyone know what its out of?
  28. 6.0L Buildup questions
  29. Can't get cam out of GenI 305 GM small block
  30. Rebuild Vs New
  31. Oil Pressure Gauge Pegged
  32. good or not
  33. oil and timing chain
  34. ls1 cam
  35. engine mount bolt pattern?
  36. I need camshaft selection help..
  37. Engine Build
  38. Valve seal question..
  39. convert 853 heads to MLS gaskets?
  40. oh boy.....help lol
  41. Stock Pushrod Diameter?
  42. 98 LS1 block-Advice
  43. Introducing The All New PRC Spring Kit
  44. Looking for a bigger cam
  45. aluminum or iron?
  46. 99 Trans am
  47. Milling unported heads
  48. ? about 1.8 rockers
  49. what heads for high torque and undercurve power?
  50. Pushrod Length...
  51. comp 918s
  52. Granatelli MAF Sensor
  53. 799 heads
  54. Anyone install a '02-'04 LS6 cam? Any valvetrain issues w/ the shorter valves?
  55. Guys with MS4s Inside
  56. Do I NEED to change my injectors
  57. need help with my heads
  58. CAM / SETUP for AFR heads???
  59. bearings?
  60. Same ol' question but this time its for real, cam help!
  61. Engine Gurus: How to make a 383 stroker
  62. Patriot Performance GM LS6 CNC Ported 64cc Heads, 225/229 .580/.590 114 lsa Cam?
  63. gas in oil again!
  64. Are std. size rod & main bearings Selective Fit?
  65. High rpm LS1 questions
  66. New Motor, no oil pressure.
  67. How bad should my h/c 92/92 car run w/o tune?
  68. Oil Pump Install Question
  69. Anyone has a cam for sale
  70. head dilemma..port 853's or buy 243's
  71. Idea's for more power
  72. which head gasket?
  73. 660 valve springs
  74. SLP Oil Pump Springs
  75. rocker arms
  76. i want 440 rwhp
  77. Afr heads
  78. Royal Purple $500 Giveaway
  79. if you wanna build then check these out first!
  80. Trickflow 235's and 4.005" bore?
  81. are shortblock bearings re-useable?
  82. Advanced Induction Cylinder Head Development
  83. what to expect from a setup like this???
  84. 6.0?
  85. Need some lifter help quick!
  86. engine removal
  87. T P S sensor is bad need help.
  88. Proform Rockers ?
  89. Big Cam or STS Turbo for a Weekend 02 SS
  90. insane cam......... or not?
  91. Final answer on LS7 preload please
  92. Am I missing anything? What should I expect powerwise?
  93. LS1 Stock Lifter not enough for Jesel Shaft Mount 1.85s?
  94. Car started smoking on start-up...
  95. Max Lift on my cam?
  96. PAC 1518 Setup Questions
  97. How Much Is It Worth?
  98. Dart 225s Fully ported value
  99. PRC ls6 2.5 VS. TFS 205's
  100. Oil Pressure Issue
  101. TSP LS6 Stage 1 limits
  102. MS3 in for sale section
  103. 2 cam questions
  104. do i need to flycut for XXXX cam?
  105. Which cams are considered the donkey dick cams?
  106. Lifter problems
  107. Ls1-5.3 power loss?
  108. LQ4 for 73 Impala... opinions on build
  109. Seafoam WTF?????
  110. New LS1 or rebuild time?
  111. street fun Tsunami vs. ms3
  112. Got a Cam with .550+ Lift and stock rockers, You've got problems
  113. 2002 GMC Yukon motor
  114. heads on a budget
  115. NEed urgent help with comp cams pushrod checker!!
  116. LOUD Knocking Sound!!!/Rod Bearing?? (sound clip inside)
  117. difference between prc heads???
  118. Prc 5.3
  119. Another F13 horror story
  120. Header Question!!
  121. H/C for my C5 - Please offer suggestions...
  122. Just Finished my Forged 347, What is the break in period on a Forged Motor?
  123. Rods&Pistons for boosted LS1
  124. Is this a better cam for boost than a ls6 cam
  125. No Oil Pressure on Start Up
  126. Matching TC stall to MS4 and 3.73s
  127. LS6 street/strip build, what cam + clutch?
  128. Knocking in LS1
  129. Whats the deal with ET heads now ?
  130. H/C+Stock Intake Guys What HP You Makin?
  131. New LS2 404 not firing on some cylinders...
  132. Lowering LSA does what....?
  133. Fuel rail fitting question
  134. Compression Ratio Driving Me Crazy!!
  135. 04 GTO LS1 difference with Fbody LS1
  136. about to break in my engine- help please
  137. push rod size?
  138. Um What did i do???
  139. installed new cam.. have question
  140. pissed
  141. CAM and STALL???
  142. Head Bolt Hole
  143. Gurus help please (yes Cam question)
  144. Would this make a nice DD
  145. what set of heads and cam for a street car please help
  146. Did I create myself a problem?
  147. Picked up a Nitrous kit
  148. Is this the oil pump i want?
  149. has anybody tried the afr 225 small bore on a 346?
  150. How much power from a 6.0?
  151. Whats causing the ticking sound
  152. help me decide on a cam
  153. what heads came on a 2002 z28
  154. engine vin #
  155. 2000 ws6 cam swap
  156. Wierd problem noticed in log, oil pressure drops in 1st and some of 2nd/3rd not 4th.
  157. heads/cam/springs/etc question
  158. swapping in another LS1
  159. ms3 Is it a good cam!!! what do i need
  160. Can it be done?
  161. Need some opinions
  162. t&d shaft roller rocker arms
  163. Rod Bearings LS1= SBC
  164. LSL vs. XFI vs LSK
  165. hans fuestal=NO GOOD!!!!!
  166. For those who wondered what EL-Torro would do with heads..
  167. what valvesprings to go with tsp toquer v3 cam.
  168. Cam for my 6.0 swap...
  169. rev xtreme catch can question
  170. Flywheel Holding tool
  171. How long will an LS! last?
  172. What cam would require a 7.250 push rod?
  173. the mysterious ticking sound
  174. ls7 lifter problem
  175. Valve seals,retainers,locks. Where to get?
  176. Cam Curious...
  177. Help w/ NA setup in my 2000 SS
  178. piston?????
  179. OK, ordered some parts.......
  180. Ms3
  181. cam question
  182. Will this supercharger work???
  183. cam suggestions ls1 98 camaro
  184. who here runs Yella Terra rockers?
  185. 5.3 truck Heads or Aftermarket
  186. much apologies TSP
  187. What all needs to be changed when doin Heads?
  188. Quick vavle spring question
  189. V2 cam from Vengeance
  190. What Determines Oil Pressure?
  191. which rocker arms?
  192. parts for changing lifters, etc
  193. heads??
  194. Can you use stock valvle seats, and retainers?
  195. Trick Flow 215's and Polluter Cam
  196. New to LS1 Tech and the LS1 club...
  197. anyone sell block plates for inline water pump?
  198. Cometick Gasket Thickness?
  199. ls6 cam
  200. LQ4 and Seafoam
  201. Noisy valvetrain, time to upgrade.
  202. Ls6
  203. looking for cam with with rpm band from 2k to lower 6k
  204. Valve seal Question Engine Guys
  205. change reluctor wheels
  206. MS3 and driveablitly
  207. I'm fixing to do a tsp torker 3 cam should i change oil pump?
  208. cam suggestion for a stealth setup
  209. Anyone used/using Livernois valve springs?
  210. head gasket question
  211. Any "Issues" with the '97-'98 'Vettes?
  212. Getting a cam got some ?'s
  213. rough idle and suddenly rich
  214. Rod/Piston combo!
  215. tsp 228 cam
  216. New vs old technology
  217. Roller rockers or no?
  218. Flycutting Question
  219. Pacesetter w TSP y pipe
  220. UMI TB vs Nicki William TB (90mm)
  221. is the ls6 pcv setup/valley cover worth cuttin a piece of the block on my 2002 ls1
  222. Advice or Opinions on my iron ls2 build
  223. putting in forged 347 in, ok to run for short period on stock injectors?
  224. LS6 PCV conversion
  225. If your heads are...
  226. Morel Lifters
  227. Mechanical Oil Pressure gage - Where to hook in?
  228. Tapping, ticking sound.
  229. new TFS 205 heads
  230. 5.3 5.7 6.0 cranks?
  231. what was your initial and total timing ?
  232. Rear main cover????
  233. Pushrod Length Q again... (yes, I used the checker!)
  234. Heads/cam package from Texas Speed???
  235. suspect head gasket???
  236. LS6 Heads - What are they worth?
  237. Milling my 243
  238. Knock Sensor Question
  239. Is an ms4 cam good for the street
  240. %#&! (not happy)
  241. Opinion...stay bolt on or go cam only?
  242. what can the stock bottom end handle? i need a quick answer
  243. Can someone "custom grind" a cam for me?
  244. cylinder head question
  245. thanks to KATECH
  246. crank bolt problem
  247. Complete LQ9 S91 Turbo Build - From the Ground up
  248. Anybody know were to find flow #'s for as cast Allpro heads
  249. Crank Differences
  250. Roller rocker question?
