View Full Version : Generation III Internal Engine
  1. What size pushrods for GMPP ASA Cam
  2. Newbie with another cam question
  3. custom vs off shelf pistons
  4. why ls2 timing cover?
  5. those that did cam, then heads later
  6. Low oil pressure when hot***
  7. to much cam info, totally confused now!!!!
  8. Why the smoke?
  9. Rod bolts
  10. Thinner head gasktet on LS6 rebuild?
  11. My 2009 Combo Chime in With Opinions/Suggestions
  12. How much will leaving your throttle closed affect cranking compression?
  13. Need opinions...too many choices for cams!
  14. Thinking bout upgrading my cam.. suggestions please
  15. Alright guys a few more ?'s
  16. TFS 215's vs LS6 "243" Stock
  17. how much for stock heads?
  18. KNOCK.. not good.. need major advice PLEASE!!
  19. cam only change ?
  20. TSP oil pump doesn't come with an o-ring
  21. Nitrous rods pistons??
  22. Gauge Cluster Question
  23. Ever heard of this???
  24. h/c swap guys in here please???
  25. flow numbers off my old 853 heads
  26. Ms4 cam right for what I'm doing?
  27. cam specs
  28. safe dynamic comp ratio?
  29. Split second oil pressure drop WOT
  30. what timing chain to get? lq4 swapped
  31. Harland Sharp rocker ?
  32. correct rod bolts for 5.3?
  33. Comp "R" lifter preload setup?
  34. Can you figure this out?
  35. Ls1 and Ls6 crank position pulse wheel- differences?
  36. Oil pressure problem... Need advice
  37. What to do with LS6 block?
  38. Help Please ! Need MAHLE piston ring end gap setting for my 383
  39. before a bearing failure are there any signs
  40. 5.3 Head questions
  41. effects of over milled heads
  42. Cam Help... I know beaten to death.
  43. Stock heads
  44. anyone running a Z06 cam in their LS1?
  45. stock rocker+double valvesprings=???
  46. Going Bigger Cubes - What options??
  47. Lq9 ARP head bolts
  48. Custom cam gear
  49. Chokin it with this cam?
  50. Lifter install?
  51. Best heads for lq4
  52. shimming comp 921 valve springs
  53. Lifter ?
  54. Lost job and blew engine on same day need help?
  55. Is LS1 crank weaker than LQ9 crank?
  56. 4.8 liter ??????
  57. need help on where connector goes quick
  58. Ring Gaps
  59. Trick Flow upgrade question.
  60. Installing Crane roller rockers w/ls7 lifters
  61. Broken Valve Springs
  62. What are my options for 6 bolt cathedral port heads?
  63. LS6 vs LS1
  64. What is a good price?
  65. ls6 to a 427
  66. pac springs ?
  67. oil pressure issue
  68. Where to look...
  69. Texas Speed H/C Setup
  70. L92 on cathedral ports?
  71. mystery???
  72. Rev Issue
  73. Solid roller lash setting
  74. Cam install help in a hurry please!!!!
  75. Solution needed?
  76. Change Rod Bolts while in car??????
  77. what heads do you guys recomend
  78. MS4 Cam Card / Spring Pressures
  79. Valve Cover Gasket.. Not Fitting Properly
  80. MS4 and patriot 59cc
  81. Compression/Leak Down Test
  82. Trick flow 225 springs
  83. What NGK Plugs To Run?
  84. Ud pulley
  85. torque sequence for valley pan??
  86. 5.3 cam questions
  87. Compression numbers reason for concern?
  88. Cam only MS4 getting heads. Suggestions
  89. Oil starvation prevention mods?
  90. Blow Back Sound through intake?
  91. Oil Pressure Acting Strange!
  92. Need help with 6.0L combo
  93. How fast????
  94. 1.75 rocker arms?
  95. stock cam specs for a lq4?
  96. forged pistons
  97. Need Help finding the right Rotating Assembly Kit
  98. are comp PRC springs a good spring to go with?
  99. What cam works the best with LS6 heads?
  100. Do 2007 5.3L 862 heads fit '99 Escalade 5.7?
  101. Who's running an MS3 or similar in a 1998 A4?
  102. Crank sensor problem/question
  103. free heads that need repaired, or another route?
  104. Motor vibration???
  105. How much rwhp after cam/tune?
  106. ls1 block
  107. ignition problem?
  108. stock 5.3 head gaskets
  109. PRC 215 heads are shipped
  110. who has best deal on......
  111. BBK throttle body and intake?
  112. 04 Chevrolet Silverado 1500 5.3l
  113. Motor finally finished; Suggestions/opinions?
  114. Is this a lifter tick?
  115. Engine alarm?
  116. arp rod bolt rounded off when torquing
  117. ARP 234-4316 work on lq9?
  118. about engine combo
  119. airconditioning messing up my car...
  120. Vinci Performance / Crane Cams
  121. How many of you have "bulletproofed" a LS1?
  122. Wow. Houston we definitely have a problem
  123. How Universal are the LS series Engine dampers?
  124. upgrading stock rod bolts, what to use?
  125. Oil pump pickup tube mount support
  126. Warm ticking
  127. suggestions for cam/heads for street car
  128. Trying to check my PTV on my LQ4. Help would be great.
  129. Right side running hot?
  130. Chromoly or what?
  131. Head Porting
  132. need help for ticking noise.
  133. More power after rebuild?
  134. Comp cams rockers & stock v/c's
  135. LS1 Crank -worth it to have Rod Journals Turned?
  136. Lifter noise come and go?
  137. vacuum
  138. LS2 Block WHATS IT WORTH?
  139. Anybody running a Schwanke engine?
  140. LS3 head for a LS1/LS6 short block
  141. Main cap bolts and engine hardware for rebuilding LS1
  142. Coolant crossover question
  143. El torro + heads
  144. head gasket pics (?)
  145. What should a car with mods like my generally run?
  146. Can you re-use ARP Head bolts???
  147. Head gasket selection getting bigger
  148. What oil to use to quiet down a noisey 5.3?
  149. Just a thought for the gearheads (engine change up)
  150. Strange misfire.
  151. 00 SS 500RWHP 20k miles, should I change the rod bolts??????
  152. What site sponsor is renting out cam installation tools?
  153. heads
  154. heads
  155. My Fans are killing my alternator heeeeelp :(
  156. Re-use header bolts?
  157. Jesel Dogbone Lifters
  158. lsa question
  159. roller rockers noisy? yella terra nosier after install?
  160. Knock sensor oil seal part number, been searching for 2 days
  161. is this to much rpm for stock bottom
  162. connecting rod out of round tollerence
  163. Now I'm ready for a cam
  164. Head/Cam Swap List, What am I missing?
  165. Tell me its not that bad.
  166. Retorquing with Cometics
  167. Need help with options for a LQ9 based build on a budget.
  168. Cam & Heads for Torque?
  169. engine tools
  170. mechanical oil gauge
  171. fast gaskets
  172. MTI R1 cam
  173. Which headgasket-Have TFS 235-6bolt-on iron 408 4bolt?
  174. Is This Normal (pics)
  175. 706 Heads on LS1
  176. 317 Head questions
  177. Is it normal for ls1 engine to burn oil?
  178. Id'ing a LQ4 vs an LQ9
  179. Valve Train Exposed
  180. Valves wont seal?
  181. will this make 400fwhp
  182. How The Hell Do I Line Up Dot-To-Dot?!?!?
  183. Heads and cam swap?
  184. want a recipe for 10 sec cam only nitrous car.
  185. ls6 heads or heads ?
  186. Timing chain after cam swap
  187. GM MLS gaskets on 408 w/ 4.030 bore?
  188. Question About Intake and Valve Cover Gaskets
  189. $115 cam on ebay
  190. COnsidering these cams, input?
  191. oil pressure dropping above 2.5k...
  192. 2000 ws6 cam
  193. sps rod bolts?
  194. how much pwoer you guys making with a 6.0
  195. LQ4 block
  196. It started as a header install...
  197. Lq4 top end question
  198. Well, this sucks.
  199. ls1 crankshaft limits
  200. How much to mill on LS2 243s?
  201. cam size vs gas milage
  202. Street sweeper HT VS XER281HR
  203. Tips for cleaning out head bolt holes...?
  204. Parts shopping list (suggestions and input needed)
  205. 2000 LS1 Questions
  206. Engine rebuild tips
  207. Tweaked 5.3 Power Level?
  208. 24tooth to c6
  209. simple question
  210. Doing some mods very soon.. what kind of dyno #'s should I expect?
  211. Lifters from Blown Motor, Useable
  212. Question. Aftermarket cam stock motor.
  213. need help... ASAP
  214. Rear Main Seal
  215. Opinions on GC 0w30.
  216. Best Cam Only but H/C later
  217. Ls6 heads ported vs. unported
  218. Difference between these two cams?
  219. camshaft journal
  220. New throttle body...throttle cable to short
  221. regrind cam
  222. oil pump question
  223. Melling Oil Pump 10296 - A Few Questions
  224. anybody dd a t rex cam mpg?
  225. Do I really need a new oil pan gasket?
  226. Engine? Vibration - Help!
  227. Engine wish list stuff
  228. Ms3?
  229. Any 6.0/MS4 with 2.5 PRC making good numbers?
  230. rocker arm install
  231. Any benefits from turning ls6 cam at 112lsa???
  232. 240/244 608/613 114 408 who's using one
  233. oops
  234. Etp cylinder heads pushrod hitting side of wall please help
  235. Car Started Once, Wont Start Again
  236. cam question for those in the know
  237. DTC0106 after cam install
  238. F13
  239. To all ms3 six speeds????
  240. timing chain question?
  241. Peak RPM?
  242. Help! Found a small spring after oil change(pics)
  243. Getting the rear cover to seal
  244. Finally some dyno numbers!!!
  245. horse power on tiny budget
  246. What do you think happened ??
  247. 317's and cam stock ls1
  248. ms3 vs mti x1
  249. Pushrod length for LS1 to LS6 cam swap???
  250. Morel lifters/pushrod length?
