View Full Version : Generation III Internal Engine
  1. GM Performance oil pan & lifters
  2. valve cover oil filler breather
  3. stock rockers
  4. L33 Rehab
  5. Oil Pressure Problem.. please
  6. 110lsa and 200 shot
  7. ls1 cu inch punch out question
  8. New to lq motors help!!!
  9. Hesitation between 2500-3500RPM
  10. Backfiring, Smoking, Ready to Sell Car (just looking for ideas)
  11. Lunati Cam or LTs?
  12. 02 z06 cam?
  13. Replace sensor
  14. 04 GTO 5.7 Piston and rod Needed
  15. Buy or run?
  16. Need help choosing a custom cam
  17. Driving after cam
  18. Who's cut the deepest flycut in their piston and used it with success?
  19. Titanium retainers and valve locks
  20. stock duration, higher lift any idle change?
  21. TREXv2 or custom 240/244 .608/.612 112lsa for a 403inch motor??
  22. Piston Confusion
  23. z06 cam id numbers?
  24. Biggest cam with Patriot LS6 heads?
  25. Gonna do a cam only install
  26. Fuck my life.
  27. 160 stat vs 195
  28. Low oil pressure/top end noise?!
  29. Polluter with rocker arms come in!
  30. L33
  31. Ok Cam Boys Chime in
  32. CR vs HP??
  33. Smoke from exhaust?!!
  34. how come no love for tsp ls6 heads?
  35. 240z with ls1 need some help.
  36. valve spring/cam color code?...
  37. why is there water from when i just pulled my ls6 intake?
  38. newbie needs help ls1 build
  39. tsp heads/cam
  40. Heads question????
  41. Need set up advice/suggestions
  42. cam plate and gear wear?
  43. windage tray
  44. engine gasket set
  45. my car run lean today ?? need help please
  46. heads/cam
  47. how do i tell if i have a ls-6 intake or a ls-1 intake?
  48. Wanting to build a sleeper combo
  49. Metal Shavings.....
  50. Pulling cam ??
  51. LS1 intake on a 5.3 engine
  52. lifters??
  53. 317 Heads on 5.7L
  54. What size pushrods for GMPP ASA Cam
  55. Newbie with another cam question
  56. custom vs off shelf pistons
  57. why ls2 timing cover?
  58. those that did cam, then heads later
  59. Low oil pressure when hot***
  60. to much cam info, totally confused now!!!!
  61. Why the smoke?
  62. Rod bolts
  63. Thinner head gasktet on LS6 rebuild?
  64. My 2009 Combo Chime in With Opinions/Suggestions
  65. How much will leaving your throttle closed affect cranking compression?
  66. Need opinions...too many choices for cams!
  67. Thinking bout upgrading my cam.. suggestions please
  68. Alright guys a few more ?'s
  69. TFS 215's vs LS6 "243" Stock
  70. how much for stock heads?
  71. KNOCK.. not good.. need major advice PLEASE!!
  72. cam only change ?
  73. TSP oil pump doesn't come with an o-ring
  74. Nitrous rods pistons??
  75. Gauge Cluster Question
  76. Ever heard of this???
  77. h/c swap guys in here please???
  78. flow numbers off my old 853 heads
  79. Ms4 cam right for what I'm doing?
  80. cam specs
  81. safe dynamic comp ratio?
  82. Split second oil pressure drop WOT
  83. what timing chain to get? lq4 swapped
  84. Harland Sharp rocker ?
  85. correct rod bolts for 5.3?
  86. Comp "R" lifter preload setup?
  87. Can you figure this out?
  88. Ls1 and Ls6 crank position pulse wheel- differences?
  89. Oil pressure problem... Need advice
  90. What to do with LS6 block?
  91. Help Please ! Need MAHLE piston ring end gap setting for my 383
  92. before a bearing failure are there any signs
  93. 5.3 Head questions
  94. effects of over milled heads
  95. Cam Help... I know beaten to death.
  96. Stock heads
  97. anyone running a Z06 cam in their LS1?
  98. stock rocker+double valvesprings=???
  99. Going Bigger Cubes - What options??
  100. Lq9 ARP head bolts
  101. Custom cam gear
  102. Chokin it with this cam?
  103. Lifter install?
  104. Best heads for lq4
  105. shimming comp 921 valve springs
  106. Lifter ?
  107. Lost job and blew engine on same day need help?
  108. Is LS1 crank weaker than LQ9 crank?
  109. 4.8 liter ??????
  110. need help on where connector goes quick
  111. Ring Gaps
  112. Trick Flow upgrade question.
  113. Installing Crane roller rockers w/ls7 lifters
  114. Broken Valve Springs
  115. What are my options for 6 bolt cathedral port heads?
  116. LS6 vs LS1
  117. What is a good price?
  118. ls6 to a 427
  119. pac springs ?
  120. oil pressure issue
  121. Where to look...
  122. Texas Speed H/C Setup
  123. L92 on cathedral ports?
  124. mystery???
  125. Rev Issue
  126. Solid roller lash setting
  127. Cam install help in a hurry please!!!!
  128. Solution needed?
  129. Change Rod Bolts while in car??????
  130. what heads do you guys recomend
  131. MS4 Cam Card / Spring Pressures
  132. Valve Cover Gasket.. Not Fitting Properly
  133. MS4 and patriot 59cc
  134. Compression/Leak Down Test
  135. Trick flow 225 springs
  136. What NGK Plugs To Run?
  137. Ud pulley
  138. torque sequence for valley pan??
  139. 5.3 cam questions
  140. Compression numbers reason for concern?
  141. Cam only MS4 getting heads. Suggestions
  142. Oil starvation prevention mods?
  143. Blow Back Sound through intake?
  144. Oil Pressure Acting Strange!
  145. Need help with 6.0L combo
  146. How fast????
  147. 1.75 rocker arms?
  148. stock cam specs for a lq4?
  149. forged pistons
  150. Need Help finding the right Rotating Assembly Kit
  151. are comp PRC springs a good spring to go with?
  152. What cam works the best with LS6 heads?
  153. Do 2007 5.3L 862 heads fit '99 Escalade 5.7?
  154. Who's running an MS3 or similar in a 1998 A4?
  155. Crank sensor problem/question
  156. free heads that need repaired, or another route?
  157. Motor vibration???
  158. How much rwhp after cam/tune?
  159. ls1 block
  160. ignition problem?
  161. stock 5.3 head gaskets
  162. PRC 215 heads are shipped
  163. who has best deal on......
  164. BBK throttle body and intake?
  165. 04 Chevrolet Silverado 1500 5.3l
  166. Motor finally finished; Suggestions/opinions?
  167. Is this a lifter tick?
  168. Engine alarm?
  169. arp rod bolt rounded off when torquing
  170. ARP 234-4316 work on lq9?
  171. about engine combo
  172. airconditioning messing up my car...
  173. Vinci Performance / Crane Cams
  174. How many of you have "bulletproofed" a LS1?
  175. Wow. Houston we definitely have a problem
  176. How Universal are the LS series Engine dampers?
  177. upgrading stock rod bolts, what to use?
  178. Oil pump pickup tube mount support
  179. Warm ticking
  180. suggestions for cam/heads for street car
  181. Trying to check my PTV on my LQ4. Help would be great.
  182. Right side running hot?
  183. Chromoly or what?
  184. Head Porting
  185. need help for ticking noise.
  186. More power after rebuild?
  187. Comp cams rockers & stock v/c's
  188. LS1 Crank -worth it to have Rod Journals Turned?
  189. Lifter noise come and go?
  190. vacuum
  191. LS2 Block WHATS IT WORTH?
  192. Anybody running a Schwanke engine?
  193. LS3 head for a LS1/LS6 short block
  194. Main cap bolts and engine hardware for rebuilding LS1
  195. Coolant crossover question
  196. El torro + heads
  197. head gasket pics (?)
  198. What should a car with mods like my generally run?
  199. Can you re-use ARP Head bolts???
  200. Head gasket selection getting bigger
  201. What oil to use to quiet down a noisey 5.3?
  202. Just a thought for the gearheads (engine change up)
  203. Strange misfire.
  204. 00 SS 500RWHP 20k miles, should I change the rod bolts??????
  205. What site sponsor is renting out cam installation tools?
  206. heads
  207. heads
  208. My Fans are killing my alternator heeeeelp :(
  209. Re-use header bolts?
  210. Jesel Dogbone Lifters
  211. lsa question
  212. roller rockers noisy? yella terra nosier after install?
  213. Knock sensor oil seal part number, been searching for 2 days
  214. is this to much rpm for stock bottom
  215. connecting rod out of round tollerence
  216. Now I'm ready for a cam
  217. Head/Cam Swap List, What am I missing?
  218. Tell me its not that bad.
  219. Retorquing with Cometics
  220. Need help with options for a LQ9 based build on a budget.
  221. Cam & Heads for Torque?
  222. engine tools
  223. mechanical oil gauge
  224. fast gaskets
  225. MTI R1 cam
  226. Which headgasket-Have TFS 235-6bolt-on iron 408 4bolt?
  227. Is This Normal (pics)
  228. 706 Heads on LS1
  229. 317 Head questions
  230. Is it normal for ls1 engine to burn oil?
  231. Id'ing a LQ4 vs an LQ9
  232. Valve Train Exposed
  233. Valves wont seal?
  234. will this make 400fwhp
  235. How The Hell Do I Line Up Dot-To-Dot?!?!?
  236. Heads and cam swap?
  237. want a recipe for 10 sec cam only nitrous car.
  238. ls6 heads or heads ?
  239. Timing chain after cam swap
  240. GM MLS gaskets on 408 w/ 4.030 bore?
  241. Question About Intake and Valve Cover Gaskets
  242. $115 cam on ebay
  243. COnsidering these cams, input?
  244. oil pressure dropping above 2.5k...
  245. 2000 ws6 cam
  246. sps rod bolts?
  247. how much pwoer you guys making with a 6.0
  248. LQ4 block
  249. It started as a header install...
  250. Lq4 top end question
