View Full Version : Generation III External Engine
  1. Difference between fast 90mm and 92mm
  2. High idle till i come to a stop?
  3. MTI Lid won't fit over MAF. Pics inside.. Help!
  4. Need a quick measurement, any help would be appreicated
  5. Difficulty Installing Shorties vs Longtubes??
  6. Is this a reverse flow water pump? How else could this work?
  7. battery dieing overnight
  8. Belt routing for water pump as the only accessory?
  9. How big is the TB opening on a LS6 intake itself?
  10. LS6 intake repair near MAP w/pics
  11. Drag racing event
  12. Loud backfiring.
  13. fast 92mm ... need help
  14. Quick opinion please...
  15. A/C compressor removal and reinstall ???
  16. Header wrap questions..
  17. Exhaust resonating
  18. Need a shift light and is my tach really laggin this bad?
  19. Stiff throttle after FAST 90 install?
  20. Serious header heat issue
  21. O2 Sensor Help!
  22. faster throttle response
  23. 16mm hole on driver's side of block for temp readings?
  24. Are all throttle bodies created equal? Help me choose a 92mm tb.
  25. Need some quick help
  26. Need help choosing a replacement exhaust
  27. Good or bad idea?
  28. Anyone go with TSP true duals and NOT like them?
  29. What's your 90-92mm TB depth mounted?
  30. If you have a Voltage Drop at WOT, Here is the Solution
  31. Best muffler for my '00 z28?
  32. How bad is Flowmaster?
  33. speedo or mileage gauge are working
  34. need help
  35. pcv valve guestion
  36. Cracked bolt hole on LS6 intake
  37. TSP True Duals do they have Rasp or no? Owners chime in!
  38. Changed Spark Plugs and now MPG socks !!!
  39. throttle body question
  40. Fast 92 or 102
  41. Ls2 throttle body on Ls6 mani
  42. Exhaust installed!!!!
  43. Help! My throttle is stuck open when i first start it up.
  44. NW 102 TB, anyone used it?
  45. borla with headers question
  46. Crappy pics of my duals over the axle build
  47. Slight Rear End Build Advice
  48. Just installed a CAI on 2004 denali...
  49. Cruise on an Accufab
  50. Problem with nick williams 102??
  51. CBM LS7 Porsche 911 Swap + LSX TV
  52. coil packs wiring harness ???
  53. Poly Motor Mounts
  54. 98 TA Engine Swap
  55. The Oil Leak.... Continued... Leaking oil above starter area
  56. Will I get an SES light if I remove AIR system?
  57. I think I might be sick...
  58. Taller valve covers ?
  59. Fast 102 Install Questions??
  60. Any gains from k&n fipk?
  61. Loudmouth
  62. Just installed Powerbond UDP, now alternator is not working?
  63. C5R heads what intake?
  64. ls6 intake 90mm
  65. cam swamp questions
  66. How loud is an open header LT ls1?
  67. Looking for LS1 Corvette idler pulley bolt
  68. T-Brake/2 Step Wiring for Horn Button
  69. information on kooks true duals install
  70. Magnaflow cat back
  71. need a strange part...
  72. Pic request: Magnaflow 5x8 or (4x9) mufflers AFTER axle true duals setup.
  73. Don't buy dynomax ory
  74. Myth or Fact
  75. Ory to stock heads?
  76. 98 Z28 Verty Engine Transplant Build
  77. Catalytic Problems
  78. 102mm Fast LSX. Yes or no?
  79. Engine stumble and RPM indication spike
  80. What gains should I see?
  81. ok to drive after headers
  82. H/C/I and headers install question
  83. New black fast 92 installed looks good!
  84. Fast 92 install
  85. Cold Feet... True Duals
  86. Where to get 4" flanges
  87. Texas Speed Long Tubes! Easy Install, Thumbs Up!
  88. Throttle cable for a four barrel throttle body?
  89. Head Casting question
  90. Cam help first time here
  91. How much gain from ls6 intake on cam only trans am?
  92. where to find long sanding rolls and everything i need to port a fast
  93. doings a battery relocation... kill switch loaction?
  94. car starts some times need help
  95. IAT Sensor Placment In A CAI
  96. MSD 6AL Digital Ignition Module w/Rev Control
  97. Best Prices On Parts
  98. Hooker catback fits like crap and chambers are damaged new
  99. 02 sensor question
  100. Chrs1313, SES
  101. anyone have a CAI on a dd?
  102. Catback-without muffler
  103. MSD Wires?
  104. Which muffler for true duals? (opinion and Idea thread)
  105. TSP X pipe back
  106. Vacuum Lines
  107. Proform LS valve covers
  108. Odd question fellas, help if you can
  109. You guys are crazy if...
  110. GTO throttle body question
  111. Dumped duals
  112. LS1 Compression Test now Ive got a miss fire???
  113. has any one had the front seal wear a grove in a underdrive pulley?
  114. GUIDE:Sakou Michi LS1 Dual Cans/truck PCV Install (w/ pics)
  115. s2 throttle body.
  116. KU Coolant Vent system, anyone runnin it?
  117. truck intake
  118. off the wall intake question LS6 specific
  119. Amsoil Drop-In Air Filter EAA-83 Review
  120. Intake swap questions
  121. TSP catted y to non-TSP headers?
  122. what do you guys use to port your fasts/ composite intakes
  123. Torque on the manifold Bolts
  124. Dual inlet truck fuel rails
  125. Another code 1153 thread lol
  126. oil pressure mechanical gauge
  127. Intake question
  128. Header Install...DONE!!!
  129. getting a custom tune couple of questions.
  130. MAP sensor wiring?
  131. how are bbk throttle bodys?
  132. 99 m6 wiring harness/pcm vs 2002 a4 harness/pcm
  133. need info on high mount a/c braket
  134. Need your guys' help on this one. Exhaust.
  135. Passenger Head Tensioner Pulley Deal...
  136. push button starter wiring
  137. TSP Catted Y-Pipe with Ebay header?
  138. 1998 Camaro dead spot 3000rpm in second gear
  139. Vertical Mount Throttle body?
  140. Raptor Performance Digital Mini Shift Light with Launch Feature
  141. Tsp headers PITA!!
  142. Don't like your LM1 or LM2? Consider this...
  143. The vacuum T fitting at the back of the manifold, size of A/C barb?
  144. New CAI Results..Got rid of my lid and airbox
  145. Does Texas do visual emissions inspection?
  146. Can Anyone Tell Me What This Is?
  147. Cut off my tips
  148. high volumen master clutch cylinder
  149. Noise after bbk intake install
  150. ls1 intake manifold
  151. Installed my Headers/Y Pipe/Etc..
  152. Camaro Shorty Headers for LS1 - Cali legal
  153. WOT: Noise from engine bay area - whine?
  154. catted Y pipe to fit QTP LTs
  155. Slim alternator
  156. Magnaflow exhaust tip broke off
  157. PCV Catch can question
  158. how good are 317 heads for LS1
  159. Trying to find intake/vacuum leak help
  160. SLPloudmouth 1 or 2 exhaust system
  161. DSL with TDs?!?
  162. new ls1 for 3k?
  163. car wont crank need help asap plz, need car moved asap
  164. Help first time starting the new motor
  165. Misfire on cylinder 4....out of ideas
  166. Knock-Off FAST Throttle Bodies
  167. Valve cover bolts?
  168. Quick question
  169. What sponsor ports tb?
  170. P&P TB after tune?
  171. What size belt for SLP/march underdrive pully belts?
  172. Stall size for Ms3 cam for DD
  173. Are manifold gaskets the same?
  174. Corvette Cold Air Intake on Camaro?
  175. Cons of welding ypipe?
  176. Got wrong headers in mail, 1 7/8 instead of 1 3/4
  177. Unique Exhaust need QUIETER!
  178. New cbm whipple side mount throttle body adapter lsx
  179. fly by wire tbody?
  180. whats the best mods for a stock ls1??
  181. 2OTL Owners, come in!
  182. Wiring
  183. Wiring
  184. building my own ram air..where do they sell sheets of clear or black plastic?
  185. FAST 92mm Lower Shell
  186. Header issues
  187. Where to get hump hose coupler
  188. How much do cut outs help
  189. identifying water pump
  190. Blackwing OE Decal
  191. Any Suggestions?
  192. water pump wiring
  193. Headers on car 8 months.. Oil smell???
  194. How restrictive are non-mandrel bends?
  195. Pics of my used Vengace 'ported' FAST 92 I just bought...
  196. which x pipe???
  197. help with intake setup
  198. AC relay
  199. how much are stock manifolds worth?
  200. DO NOT BUY professional products 101mm TB
  201. belt squeal
  202. AIR and EGR removal with cats
  203. Cutting of tips
  204. Turndowns pointed down or angled out?
  205. Quieter Exhaust Needed..Cammed, LT's, ORY, etc
  206. LM2 Install Help!!!
  207. pulled t56 for rebuild.. now bad o2's?
  208. Headers, intake and disappointed
  209. Best Bolt on?
  210. Auburn Gear Differential Installation
  211. Why does my 02 WS6 not take the correct oil filter???
  212. EGR removed
  213. Alt/exiter connection?
  214. Question About Meth Kit?
  215. Gasket for AIR tube to manifold??
  216. oil pressure sensor Teflon tape ?
  217. Raptr Cam n 243 heads "build"
  218. head question
  219. Center Bolt Valve cover PCV routing
  220. 6.0 LQ9 Swap OR Supercharger on my 4.8?
  221. wtf new waterpump and now belt wont fit
  222. starter try to crank motor when battery connected help asap plz
  223. Corsa Power Pulse vs B&B Exhaust for 98-02 F-Body
  224. Ground wire for PCV valve
  225. Installing TSP 1 7/8" Headers next week
  226. Straight thermostat housing?
  227. Exhaust Adjustment Help Needed....
  228. Vacuum pump questions
  229. Changing exhaust
  230. Can a magnaflow muffler cause a poping/misfire sound?
  231. idle issue in gear
  232. hottest factory coils????
  233. Please help me with P0107
  234. Will this be holding me back?
  235. General exhaust diameter question
  236. turbo s10 overheating
  237. Must Make Car Faster Than Douchebag Friend's
  238. Kwick Performance Accessories HELP!
  239. Getting shocked while working on car
  240. What kind of tool to port a FAST intake?
  241. Connecting 90mm throttle body to maf??
  242. FAST92 and FAST 92MM ThrottleBody
  243. Any dyno testing on this intake manifold?
  244. Flowmaster H Pipe U-Fit?!?
  245. 4150: help me remember please
  246. GMMG Exhaust rattling noise??
  247. Ls1 Top passenger side o2 sensor?
  248. best way to install underdrive balance w/o TOOL
  249. LS6 Manifold Differences
  250. NTK 21537 instead of Bosch 13111
