- Where do/did you buy LS2 plug wires?
- is there any advantage to raceheader
- best ypipe for stock manifolds
- going from stock to bullets, need help
- Powersticks or Cherry Bomb Extreme
- Need help with an electrical short issue
- Time for a new Waterpump Already!
- restrictor plates/block off plates????
- header and ory question
- Bolt on DYNO #'s
- So confused....PCV issues
- exhaust problem
- Exhaust clips of magnaflow with lt headers w/cats?
- Stock 3 pin Maf Pigtail part number needed
- got a SLP LM2
- Cut out wingnuts?where to get them
- qtp cut outs
- ARP bolts with Fast 90??
- Vacuum leak question?
- Valve cover air breather?
- need to quiet down my true duals alot
- coolant leak, 2k2 suburban
- TSP Rumbler with stock Z28 tips?
- wondering where to get morel lifters
- two step rev limit???
- ordering pacesetter longtubes...what y-pipe to use??
- kinda of confused..ls1??
- Exhaust size q...
- Fuel Rail Covers
- spark plug wires
- pacesetters and ORY+ fowmaster= Rasp????
- Ported tb help
- is there Lower temp fan switch for 99 ls1?
- Spark plug wires
- Holes in valve covers HELP!
- What do you guys think about the granatelli mass air meters?
- What kind of mufflers are on my TSP TD's?
- New exhaust
- Texas Speed 100mm MAF: Pre-Order Now!!!
- spohn solid mounts - cracked block?
- XS Headers
- Which Header Gasket?
- anyone ever used one of these??? they look freakin sweet
- Air Pump Check Valve Help
- ARP Intake Bolt Kit
- Poly motor mount install question.
- Rear Battery re-location (wiring)
- N/w
- verdict? Tune for Ported TB?
- ls1 programmer.
- 402 pipe size for duals and single
- Reworking a LS1 instaed of buying LS6 intake
- TSP 100mm MAF???????????
- going to install pacesetter headers and ory
- Any successfull Corsa/LT rasp killers W/O ***s...
- 6.0 intake options
- On a 402 how good would Pacesetters be?
- Flowmaster American Thunder
- oil and coolant in tail pipes
- To long tube or not to long tube that is the question?
- You think the stock y-pipe is flat?
- Long Tube Header Question
- Dynatech Supermaxx stainless header system
- O2 extenders & Kooks headers?
- Slp Exhaust
- Cat-back vs. catted y
- exhuast set up?
- Center bolt valve covers, how much?
- Stainless Headers..Are they all the same?
- 2004 GTO intake manifold part number?
- Which One? ****Stainless Hooker or Jet-hot coated pacesetter's*****
- MAFcleaning question..???
- Help with my shopping list - Pacesetter install
- How shall i build my Crank Case ventilation?
- looking for a cat back. which one to get
- fast 90 problems?
- porting throttle body
- need exhaust help
- Need Help!! FAST 90 guys come inside!!
- LS6 balancer broken. Is my engine FU#@*%???
- muffler recommendations
- Magnaflow Dual/Dual just arrived....Pics
- Direct Hits Ignition....
- Comparision between 10% UD and 25% UD
- question about my soon to be exhaust setup
- car is running like crap after installing lt's
- what size cutout I have one but not sure on the size of it
- installing headers question?
- best throttle body?
- LS6 ported head question
- possible ignition problem, hestitation and popping
- Hey guys where do our cars suck air from?
- ATI Super Damper
- cleaning volant cai
- GM LS6 intake on my LS1. What else is needed??
- Harmonic Balancer.....different type of ?.....
- Loudest exhaust possible...
- Headers to cause SES light?? And other questions.
- Slp Loudmouth 2
- 243 head questions
- spark plug question
- cheapest place to have my tb ported
- PCV fix?
- ported, polished tb
- my new TD's video clips
- New track times, from SLP induction
- Question about under intake coolant lines
- TSP TD problems...
- y-pipe to cat bolts part #
- SLP later or Pacesetter now?
- Exhaust set up, SPL loudmouth II??
- Will Ses Light Turn Off With Catalytics Converters???
- picture of back of intake manifold
- doing a head swap ..... damn driver header!!!
- Question about starter
- Open Exhaust Question
- which borla xr-1
- Need help. Installed headers and ory but...
- Y-Pipe
- Intake manifolds
- LS6 Swap: Can I keep stock drive train?
- what exhaust to get
- Need new PS pump pulley
- Is anyone running edelbrock SDT mufflers on their duals?
- Header bolts
- !!!!stock metal fuel rails wtf?????!!!!!!!
- 400whp Corvette vs Mazda Miata. Who will win... G i wonder....
- 3.5 inch Mufflex with spintech muffler *video*
- heads!
- ported tb, 4500 idle
- Removing A/C belt
- hp gains w/ FAST intake???
- 02 ? plz help!!!
- Edelbrock Super Victor LS1 EFI out yet??
- NEW JAAM, Rain will afect the car????
- Rattling noise from exhaust...
- need (CO) emission help fellas!
- Hooker exhaust
- Confused with my current exhaust setup.
- My magnamouth sound clips
- 02 sensors
- Wiring diagram for Oxygen sensors? Or pics!?
- Who makes the BEST electric exhaust cutout?
- Jet hot headers
- Stock computer limitations
- Exhaust connections
- true duals ?
- Just bought headers! Finally!!
- o2 extensions
- Air Pump Fuse?
- Has anybody done this?
- Header advice please
- FAST 90mm swap, A/F richer or leaner?
- Gmmg?
- O2... matter which side?
- SLP Blackwing Question?
- Poll: WS6 owners... JAAM or FTRA
- ???input On A X-pipe With Flowmaster Mufflers
- Weich Water Pump for ls1, use ls2?
- Figured I would ask...
- XS LT's, ORYP and Flo Pac Muff, rasp?
- the spark advance free mod???
- Autozone German Castrol
- Hooker/Magnaflow on stock?
- 400hp???
- underdrive pully
- Ls6 intake install
- Bad thing happened when swapping O2 sensors...
- P0171 and P0174 after Ported TB, lid
- biggest valve that can put in 5.3 and 4.8 block
- 90mm Weiand/Holley aluminum intake manifold?
- QTP Y PIPE SUCKS!!! Want to start over!
- What MAF with a FAST 90/90 setup?
- Any help in with the noise under my hood???
- SFC's get in way of tranny?
- My Car Just Backfired Really Bad
- How to tell what injectors I have?
- Headers Question.....
- Bad Map Sensor?
- dumps at cats stock manifolds
- Please help me discover A random noise please?
- Exhaust Wrap on Ceramic?
- B&B or GMMG????
- LM2 clip
- Autometer Oil Pressure gauge ?
- 160 T-Stat.....Questions
- Is It Worth It?
- Z06 Exhaust
- Differences in engine & underhood harnesses
- a tad lean or a tad rich
- Alternator issues
- Headers for a 4.8
- exhaust question?
- non-slip fit headers
- What should i do?
- Bad O2 sensors causing idle problems?
- 416" L92...GMPP Carb intake or FAST L92??
- VERY small cats? bullet's? powerpack? Trying to kill rasp & drone on duals
- Bassani true duals and torque arm issues....
- PCV setup
- CME Question
- tru duals with umi tunnel mount torque arm
- any1 have non-coated pacesetters
- 98' knock sensors
- X-pipe Question?
- p&p throttle body?
- Datalogged my new FTRA.
- Classic Chamber Vids
- Ram Air?
- Exhaust gurus!! lol.. Please come in.
- Need a y pipe to bolt up to stock manifolds who makes em?
- Help Surgeing
- fuel rail bolts for fast ?
- car is back firing at high rpms
- Breaking the oil pressure sending unit...
- What 85mm MAF to use besides the SLP MAF?
- Engine Swap Question
- Throttle return spring
- Exciter wire
- baddset head
- 3.5" or 4" coupler, cant decide
- Wait for Weiand intake or get ported LS6 for this?
- coolant light...
- who makes this?
- Electric Cuttoff Problem
- Typhoon Intake issues
- stock harmonic balancer or underdrive
- where to buy a ORY pipe for stock manifolds?
- Help me pick my exhaust!
- lid and the k&n fipk
- CME Exhaust options
- Need to rewire O2 sensor to the other side
- Stock cat-back w/ cut-out will flow just as well any aftermarket cat-back, correct??
- problems with y-pipe..
- Bouncing RPM's
- 6.0 Flex plate touching the block
- Hi Temperature Silver paint..
- Change Exhaust?
- Poly motor mounts
- single cutout on I pipe??
- What Vortec engines are all aluminum?
- What is the correct term for the area that the lid attaches to? pics inside
- Do you know what Hooker and Edelbrock headers look like?
- How much with 17" flo-pro twisters quiet down my car over 12" moroso spiral flows?
- Throttle body porting question. Need experieced Help!
- Wiring????
- hey wanting info on a cam upgrade?
- Overdrive crank pulley?
- Has anyone else had this problem?
- Identify this box in front of the drivers side fender
