View Full Version : Generation III External Engine
  1. '02 TB cable on a '99
  2. Misfire HELP
  3. Coolant Pipes & Plugs For LS6
  4. If i install ls6 intake. Do i need to retune?
  5. How can I quite down my GMMG exhaust?
  6. cant figure it out!
  7. Any reason not to run a vented catch can?
  8. Pics of my JPR EWP and short belt :)
  9. Where to start on a 2002 Firehawk
  10. Insertable cats
  11. Who sells the Flat EXH clamps??
  12. what type of headers are these
  13. Full bolt ons for 2001 f-body
  14. Plates for Borla Exhaust
  15. OMG!! PIMP NEW CutOUT!! MuST SEE!!!!!!!!!!!
  16. Cold Air vs. Wisper
  17. 98 camaro under hood wiring harness not engine harness
  18. should I rebuild a 98' ls1?WHAT SHOULD I DO ?
  19. What will an electric water pump really free up power wise?
  20. If you don't shop here...your slow
  21. Ls6 Intake swap coolant lines?
  22. Qestion for those with cut outs close to the header.
  23. need a pic of pacesetter LT's and pacesetter ORY installed!
  24. Water Pump Ports Questions
  25. Should I get a Lid and MAF
  26. Clip of my new TD's with single chambers on H/C car
  27. New SLP Lid...
  28. 96mm Typhoon
  29. maf sensor?
  30. SLP lid fitment
  31. Electrical Gremlin ,Ls1 CamShaft Postion sensor
  32. headers and A.I.R. system removal question
  33. Got some new bolt-ons!!!!!
  34. Pacesetter and tsp ory Install HELP!!
  35. edelbrock or GMPP carb intake
  36. shaft mounted 1.75
  37. Cat spark plug non fouler size.
  38. Which is better 90/90 setup or carb style?
  39. Thinking about lt headers and cat back
  40. LS1 Fbody Air Filter
  41. would it be worth it?
  42. fast 78mm throttle body
  43. ***help!!!!*** Slp Package ????????
  44. Slp 1.85
  45. New Member - New Project
  46. Hooker (Super Comps)
  47. cost for LT?what will i need
  48. Pushrod ends worn off?? has this happened.
  49. XS headers
  50. Purchased my KOOKS today...
  51. What to use and how do you set the idle set screw?
  52. Generic Alternator Questions
  53. 2002 Fbody harness on an '04 GTO pull out?
  54. cut out?
  55. Throttle cable adjustment(no tcs)
  56. Wanted ---> Reviewer For WS6 Ram Air Kit
  57. Car stumbles at light throttle
  58. GC 0w30
  59. PCV valve and oil catch can giving me problems.
  60. Opinion on headers?
  61. Futral 228/230 .576 .595" Cam's
  62. headers
  63. Will running my TSP Duals out the back change the sound?
  64. Most quiet true dual mufflers?
  65. Too Loud?
  66. cutout v. catback
  67. Header Install. Help me out.
  68. does closer= louder?
  69. my headers and td's
  70. how will i know if blew a head gasket ???
  71. Flowmaster question
  72. How loud is GMMG with ORY/LTs
  73. no more true duals for me........
  74. Rear 02 sensor question (pertaining to ORY)
  75. TB Interchangibility?????
  76. GTO cat deletes fit on my car?
  77. Catted Y on lowered car
  78. long tube header problems
  79. Replacing positive battery cable?
  80. Intake Swap
  81. 02 AIR Detail Question
  82. Is It Holdin Power Back?
  83. Mac Off Road Y-Pipe
  84. slp loudmouth 2
  85. lower radiator hose size???
  86. exhaust cutout wiring question
  87. Porting out a 85mm bbk intake to 90mm?
  88. What kind of exhaust is on this thing?????
  89. 2.5 or 3" I-Pipe & Cut-Out?
  90. ls6 intake??
  91. Ported and Polished Throttle Body
  92. Fernco tubing?
  93. Stupid AC Delco
  94. O2 simulators purpose?
  95. Is this manifold too much for a stock cam?
  96. custom dual/dual
  97. muffler delete stock ws6
  98. strait pipes?
  99. Map Sensor Help
  100. does this fernco fit right?
  101. Looking for opinions on coated pacesetters and TSP off road Y
  102. how much difference in a .125" test bore?
  103. Is Mobil 1 5w30 really crap?
  104. MAC mids vs AR Long tubes
  105. Does anyone have any comments on this leak-down tester?
  106. XS Header Install
  107. geting pacesetters go with cats or no cats?
  108. Exhaust question
  109. Legit Header Question
  110. yank or vigilante stall ?
  111. What the hell kind of exhaust is this? (vid)
  112. Stock LS1 specs
  113. Pacesetter headers just come in
  114. Spark Plugs and Wires
  115. bolt size ?
  116. 3D Breakouts of manifolds
  117. Quick Question
  118. Tps
  119. Y pipe and headers
  120. valve job, timing chain, oil pump questions
  121. Best intake porter?
  122. help
  123. ORY pipe question
  124. LS2 in place of an LS1?
  125. true duals question??
  126. o2 sensor question...
  127. muffler size
  128. FLP header? 3.5 main pipe ?
  129. Another header bolt rounded
  130. Exhaust elbow bypass mod ?
  131. Fast 90, LS2 90 TB, C5, Oil catch can giving me a problem. Help.
  132. Ever modify rear seat pans for TDs w/ Magnaflow 4x9's?
  133. Air fitting for stainless headers
  134. victor jr intake
  135. what do you think?
  136. Weiand Streetfighter Intake
  137. victor jr intake
  138. GMMG..LT's, ORY...with TR224/112 cam..??
  139. Maf
  140. spark plugs....
  141. What grinder for TB porting..
  142. Anyone have the Volant CAI
  143. Questions on leak down testing
  144. Anyone modify thier own coolant tube instead of getting the later one and plugs?
  145. Exhaust for a 347 procharged camaro?
  146. underdrive pulleys
  147. Issues with new O2 sensors
  148. what should a stock auto 01 trans am run ????
  149. easiest way for a catch can?
  150. put my new lid on
  151. Air Vents not working right after Head swap??
  152. What SHould be my next mod?? need info have money
  153. Air Vents not working right after Head swap??
  154. A.I.R. Location on headers
  155. LS1sounds.com not working?????
  156. Is This A Good Aftermarket Throttle Body ??? Opinions Please
  157. New 85mm Fast Toys Lid, if you have a z28 come inside
  158. Stainless Edelbrock Victors
  159. header clearence
  160. Check out this new intake for LS7, L92, C5R
  161. Most free flowing muffler
  162. Help 02 problems
  163. Tune for the Z28
  164. Need to know which engine-bellhousing bolts to get
  165. Profesional Products 85MM Polished Intake Install
  166. just got my kooks 1 7/8 LT header need help on tune and other questions
  167. Intake question..
  168. LS1 grenade
  169. Air pump delete Question????
  170. Kooks banging
  171. Weiand intake, Yes or No.
  172. running hotter plugs?
  173. Will LT1 True duels fit my LS1?
  174. Pacesetter and tsp ory?
  175. Help! Mass Airflow (MAF) Sensor problem
  176. Just bought a 85mm, 5pin maf, who sells an F-body adapter?
  177. what size pipe for true duals?
  178. starter bolts
  179. Gutted Random Technology Cats.....
  180. Pacesetter Install ??
  181. FAST 92mm Intake?
  182. ''fast 90 to much''
  183. Has your MTI Clear Lid cracked?
  184. Which pulleys when bad make a loud mettalic whinning noise?
  185. my makeshift k&n ram air
  186. Dyno Tune Worth it?
  187. Cutout..Manual created to electric?
  188. Will Running Open Lt Headers Hurt My Car???
  189. Stock Head/Cam 346 LS6 w/ bolton's pre-post Fast 90/90 Results
  190. Exhaust question (CME)
  191. ported tb results
  192. Rare 98 WS6 with SLP LM1...wanting more sound
  193. Can I run a belt around the alt,water pump, and crank only?
  194. Debating over LS6 Manifold...
  195. Where to put DMH cutout on TSP Y Pipe.
  196. True Duals or GMMG??
  197. dyno tune shop in Missouri?
  198. Simple Wideband ???? but can't find my answer??
  199. SLP lid or 85mm Fast Toys Lid ???
  200. new exhaust help for h/c car
  201. egr block off plate for ls1 intake
  202. Double Roller + Underdrive Pulley = Help
  203. Got a ticket for open headers..
  204. HELP! new fast toys lid wont let hood close!
  205. Throttle cable swap TCS to non TCS swap?????
  206. Tick after LS6 install
  207. 99 Camaro throttle cables!!!!!
  208. quiet exhaust
  209. Passenger Side Valve Cover..
  210. Volant Install Question
  211. Cutouts Location in a Dual Exhaust setup, Behind or in Front of X pipe ?
  212. Anyone with AR Header have this problem?
  213. need help with headers!
  214. Aluminum vs plastic intake
  215. Clearance pics w/ 40 series race mufflers.
  216. LQ4 throttle body vs LS1 throttle body.
  217. ok need a little help with 02 sensors
  218. Anyway to lower idle w/o a tuner?
  219. high idle, searching idle
  220. Oil dipstick tube question!
  221. Borla !muffler
  222. What do you guys think about this setup?
  223. Bullet Muffler Placement?
  224. Close bend hose ideas?
  225. Accessing header bolts...
  226. Polished LS1 TB and MAF ends???
  227. World's oldest liveing set of Grotyohann headers?
  228. Help Alternator removal
  229. Heads specs ??
  230. Add bullets to Hooker cat-back?
  231. Header Flange
  232. Open Pacesetters = FUN!
  233. What to expect?
  234. Anyone use these Magnaflow mufflers for duals?
  235. 59cc Ls6 heads
  236. ?on MTIs and ACCUFABs TBS
  237. TB question
  238. Tb????
  239. Which plugs to use???
  240. Found cause of misfires
  241. Where to buy DMH Cutout?
  242. HELP! Passenger side header
  243. whats the cheapest stainless headers?
  244. Kooks / Pace Setter / QTP / Flowtech ?
  245. Muffler question???
  246. major misfiresm no other faults :( help ASAP!! PLEASE
  247. Slp dual/dual muffler
  248. Modding party!!!!!!!!!
  249. may be getting some parts CHEAP
  250. Heard There Is An Oil Pan Alignment Tool?
