- FAST intake on a 00 SS?
- Muffler Change???
- LS2 Coils on Ls1
- Whats My Car A A4 Or A M6????
- Got my hands on an LS6 intake from a Daytona Prototype engine program. Any good?
- What's the best muffler to add to a I pipe?
- Headers
- Header Gasket ?
- Quick LS6 intake/!air/!egr question
- borla owners!
- Lets see some engine oil cooler pics!!!
- Need help picking air intake system on C5
- changing plugs from underneath
- epoxied TB question
- looking for some cool valve covers
- 98 Racetronix Plug N Play Kit
- 160 degree thermostat install questions
- what exhaust??
- Who has/had stock engine with no cats?
- 98 and 99 coolant hoses
- Strange Exhaust Rattling...
- anyone running jet hot headers
- QTP Headers not rubbing anymore!!
- Swapping Muffler form Hooker CB,, what muffler?!
- c5 intake specs? What mm size?
- Quietest mufflers, yet high flowing...
- Oil Problem
- Header debate in Iraq
- Factory exhaust
- relocating battery v cutoff switch location
- 5.3L truck oil pan on 98 LS1
- Flowmaster 1 Chamber + Loudmouth?
- Patriod heads, oil problem
- Valvecover breather: Thunder Racing, Speed Inc., Summit, etc., what's the difference?
- Custom or Bolt-On Exhaust?
- Curious Question... WB02
- Headers and other Mods! Kooks/QTP/ARH??
- If youre knock sensors are out REPLACE them!!! (pic)
- Crank Pulley bolt on A4
- Ported Fast Intake
- True Dual mufflers??
- Kooks, Hooker, ARH, QTP, Gibson or Corsa?
- knock sensors questions...
- Header advice
- upgrading engine pulleys??
- doesn't like to idle
- Just got my lts and ory and have some ?? on the install
- My car sound likes crap!! Help!!
- a different pcv ?
- WHICH xr1 for borlamouth???
- Anyone try these Ebay headers?
- True Dual Magnaflow bullet setup?? Opinions please
- Largest single exhaust?
- does this car sound loud for a slp dual/dual?
- Everyone Who Has/had Xperience W/ Gmmg
- exhaust questions
- I'm thinking SLP!!!
- Anyone have a B&B exhaust on their LS1?
- Would removing the muffler hurt my performance?
- Extending Dumps. . Better Sound?
- P0121 and p0300 code?
- is coating worth it??
- Super Victor vs. Victor jr.
- what headers for a 427??
- Rough Idle???
- borlamouth hookermouth?
- Swapping a 6.0 into my TA
- More Mods?
- LS6 Swap
- My belt about flew off the other day
- dies after awhile
- Anyone's exhaust "hum"?
- Egr/air Removal
- Is there a difference between Corvette & Fbody Power Steering Reservoir?
- alternate y pipe
- stock size exhaust
- Anyone have a pic of their belt routing without powersteering?
- Over 2 years in development ---> New Fast Toys 85mm Air Lid!!!!
- Where to buy o2 sims for cheap????
- Ported TB now Smoke from Manifold
- Throttle body myth or not???
- need help with true dual exhaust
- any tried the p.t.m 90mm tb?
- installing asp underdrive pulley , how hard to do
- LS6 Intake
- So many now, but Good heads to match to TSP TqrII?
- TSP Catted Y Pipe - Fit Issues / Installation Tips?
- am i losing power? 85mm maf
- intake gaskets
- Thunderbolt Mufflers ?
- What are your guys Average engine Temps??
- How I fixed my banging y-pipe for free. BIG PICS
- quick question y-pipe
- starting problem
- mid pipes install q (flanges)
- Computer Code Diagnostic Question...
- I searched and need help...What size cut out?
- how much power am i losing?
- header/kmember contact-heater hose ok for temp fix?
- single dynamax bullet dumped
- Kooks HP gain over SLP's
- Ignition problem... Need ideas what to check?
- 3 1/2" exhaust??
- stepped headers
- Qtp
- MAF need help!!!
- How to ship a block?
- which shift light?
- Ssra
- LS6 intake gasket question - pics
- Show me your oil cooler setups please!
- Need a flycut tool for exhaust valve
- Which Headers?
- steering help!
- hooker header install
- Exhaust question
- Borla, Headers, ORYP, what plate?
- XS Header problem!! I need help
- Custom catback questions
- Where can I get these 3" band exaust clamps?
- Quick Help On Spark Plugs
- XS header solution to touching floorboard with pictures
- HELP best way to locate exhaust leak
- Best Y pipe for Edelbrock Shorties?
- Need Help Fast/ Broken Bolt
- Help please... Steering shaft is driving me up the wall
- Custom Mufflex Exhaust. *PICS*
- install trans temp guage need help fast!!
- quick question about exhaust
- Emissions headers question
- Cold Air Intake for 2000 Z71
- $350 Corsa catback. LS1
- So why isn't Spintech more popular?
- Engine Running Hot!! Please help...
- whare to buy a slp powerflo muffler????
- will slp underdrive pulley cause less voltage&cooling?
- Any high performance fan motors availible?
- Valley cover question
- X-pipe and H-pipe vs No-pipe
- truck coils
- new exhaust, and 200 miles on a stock gas tank???
- Question for Hooker catback owners.....
- No cats, no sims, no ses light....???
- mechanical o2 sims?
- What next for bolt ons
- roller rockers
- TSP catted Y pipe question
- FTRA's back in stock!
- PP typhoon 85m intake t/b options?
- Wondering about a catch can....
- Pulled spark plugs...weird reading
- Heat Soak..
- What Should I Do!?!?!
- Oil pan sensor, whats it for?
- BBK w/80mm vs.LS6 w/p&p stock tb.
- bbk intake and throttle body
- Shift Lite
- AFR 205s Vs. PRC 6.0 2.5s
- cold air intake
- Need Help Finding Writeup
- What size o-rings for injectors to fit in LS2 injector??
- Driver Side Cat Overheating
- Stock Exhaust, what size cutout?
- $$$ What would you buy?
- Overlap v. Exhaust
- Took off my muffler what now?
- 243 castings
- Alternator wiring question
- P+p Tb
- I need quick response PLEASE!
- Will LS2 intake manifold fit directly on LS1?
- pacesetter long tube help
- O2 sensors
- ATI balancer installation question.
- is there a way?
- Just bought my FAST 90 intake,now is there...
- header to x pipe help
- Fluidampr 10% underdrive pulley...belts?
- First Mod
- Cat Question...
- VOLANT CAI and RAM AIR HOOD ???
- Are Dynatech Split flow the same as Borla XR-1?
- Do I need rear o2 simulators/tuning?
- ok.. who has loudmouth and loves it? I do!
- pusher vs puller cooling fan?
- Borla Catback install
- Muffler?
- oil pump question
- Need some Loudmouth advice.....Please
- electric water pump
- Powerbond UD Pulley Install:
- just installed LS6 Intake
- Will I need tuning with Pacesetter LTs, ORY, and sims
- Need a 90 mm tb
- Need help finding cats!!
- borlamouth vs. borla vs. magnaflow
- 90mm bellow? Guys using FAST 90mm intake please help!
- Does your MTI lid........
- Cutout Tripping SES Light and Sensors???
- Need Flexplate Help!!!!!
- Under Drive Pulley?
- center bolt valve cover bolts PN?
- Scarry Oil Pressure
- Poly engine mount install feedback??
- what else to bolt on?
- 85mm MAF on 2000 LS1?
- LS6 intake swap problems
- Bosch 2 plugs?
- Does MAP Sensor have to be laying flat to function?
- Puzzling problem - please read!
- Oil pressure gauge is screwed up!?!?
- Wheres a good place to find a 99-02 wiring harness?
- 3 bolt flange problem
- Ftra?
- spark plugs....
- valley cover screws for FAST90
- ls1 headers.Gains? installation?
- Going to track...ned 2turn off asr..for real!
- Quick Hooker Header Question?
- mufflex bump stop
- exhaust suggestions
- Power Steering taking a dump..... :(
- DIY C5 FAST 90/90 install instructions ??
- Intake manifold leak
- Headers - Re-Coating?
- Spintech Sportsman.... good or bad???
- plugs for rear o2 sesnors
- exhaust problem quick question
- 90mm intake port matchted to afr205s, will intake work on stock heads?
- XS Stainless Steel Headers
- help me pick spark plugs
- i want to make 400whp and spin to 7k- help
- Slp 1cme finally done!
- FAST 78 and stock TB issue
- exhaust loss without mandrel bends
- oil pressure guage problem
- Torn between True Duals or ORY
- magnaflow catback
- FAST Intake over LS6..
- 98 LS1 vs 99-02 LS1
- Gmmg/stock/cutout
- whats the average hp
- Dust collectors on transmission
- what valve covers?? alum ones perfered
- air, egr, o2 sensors, is that it?
- roller rockers
- band clamp help
- Direct Hits Ignition any body use this?
- Showin off them Powersticks
