View Full Version : Generation III External Engine
  1. Polished Stainless Headers and Y pipe
  2. True dual ?
  3. I also installed XS Headers today!!!
  4. TPS Washer. Need Help!!
  5. Misfire issue
  6. Parts for TB bypass
  7. SLP Lid & K&N Filter Right?
  8. Guys with true duals, HELP ME with fuel lines
  9. MTI clear lid
  10. High flow cats help quiet my exhaust ? (Video Inside)
  11. what underdrive pulley???????????
  12. Fouled plugs
  13. Just installed my Pacesetters Yesterday!!!
  14. Installing new motor mounts......how do I get everything to line back up?
  15. Does magnaflow make a 4" in and two 3" out?
  16. Exhaust Gaskets-Nothing in Search
  17. Being cost effective?
  18. Best bang for buck mod??
  19. Cutout Install is blowing fuses!!!
  20. Belts!
  21. can i stuff a 90MM throttle body on to a stock ls1 manifold?
  22. header bolt torque
  23. Edelbrock headers and y-pipe
  24. Magnaflow and OEM underbody piece
  25. can anybody giv me a start on wiring a manual fan switch!!!!
  26. Overheating problem need some help!?!?
  27. Pacesetter headers and TSP catted Y questions
  28. Car wont start after headers and mounts =[
  29. K&N Cold air intakeVs SLP intake kit
  30. Dumb Question....
  31. Fast 90mm for stock car?
  32. Just ordered a powerstick for "Chambermouth". :)
  33. Good Throttle Body to run with Typhoon intake
  34. Starter To Flex Plate Clearnace (pic)
  35. Cleaning the inside of the radiator..
  36. New gauge pod and gauges
  37. Is it likely that Kooks had a bad batch of headers/y-pipes?
  38. stock exhaust ?
  39. Long Tube like flow without the hassle... My new setup!
  40. Which Lid
  41. Mufflex??? Corsa????
  42. Cut Out Question ,,,
  43. Anyway to mount a 85 or 90mm TB on top of a Vic Jr?
  44. Installed XS longtubes today..........
  45. Need help putting on SLP UD PULLEY.....
  46. Rebuilding Engine..
  47. Holley Air Filter
  48. Intake...
  49. mti t.b.?
  50. Need an exhaust mount
  51. ATI balancer install
  52. FAST 78mm vs LS6
  53. longer oil filter
  54. Help, powerbond pulley will NOT go on straight!
  55. do your headers get beat up under the car?
  56. Will this cause any problems...
  57. Air removal quick Q?
  58. FAST intake, which TB?
  59. Cme
  60. pacesetter LT & Borla
  61. cats/header question
  62. Pacesetter header install how to's?
  63. Engine mount bolts
  64. The 1$ LS6 intake install...
  65. What Intake to Use
  66. Where does this go? Something about getting air out of the coolant.
  67. Exhaust gaskets?
  68. *****Why QTP headers compared to others?*****
  69. Flowmaster Delta 40's Anyone Run Them????
  70. airbox fit
  71. Ordered headers and X
  72. Wiring Harness ID Needed
  73. HELP!! Stock throttle body????
  74. ls6 intake or cams
  75. PP 98 throttle body, which shaft?
  76. Maf
  77. header pricing
  78. LS6 intake ?s
  79. About to purchase Combo from texas-speed.. quick ?
  80. thinking about a hooker muffler???
  81. Clear air lid
  82. what tools needed for TB sensors?
  83. Middle of header install, need some help...
  84. which exaust is louder TSP true duals or SLP loudmouth?
  85. AC Relocation... is it possible? has it been done?
  86. Need help removing emissions crap
  87. '99 Z28 - Spark Plug Replacements
  88. New car has Mac header ?
  89. PCV routing question
  90. Slp Longtubes w TSP Duals
  91. ok so im going to install my headers, some quick questions
  92. Can someone check my catch can arrangement?
  93. is it worth it too
  94. Throttle Cable Help
  95. LC1 Wideband Grounding
  96. Fuel pressure / Tuning
  97. MAF/IAT Adapter
  98. TB not opening completely. WTF!?
  99. Alternator probs after heads/cam swap
  100. MAF Position
  101. how much louder
  102. Finally Installed My Edelbrock Headers!!
  103. Too much movement removing crank bolt. Advice?
  104. SLP FloPac ??
  105. SLP vs. volant
  106. keeps throwing code 2101
  107. Prof. Products intake users, inside
  108. Flowtech Headers??
  109. who here has 3 point SFC abd is running a TD setup
  110. afr guage
  111. is the ls6 intake worth it???
  112. look what i just ordered!!
  113. 3" H-Pipe/Cut-Outs Questions
  114. AEM's new "DRYFLOW" filters...
  115. surface discharge plugs
  116. Check out this BS.
  117. Needs Pics of 4bbl Throttle Body + Victor Jr.
  118. Underdrive pully
  119. should i get a t-stat?i can program the fans
  120. Exhaust Leak From Band Clamps
  121. grottyohann y-pipe???
  122. ypipe question
  123. Anyone with magnaflow exhaust with new quad tips (Corsa like)?
  124. Identify my setup
  125. Fast 90 & LS2 TB Upside down?
  126. >>problems after my coolent change
  127. LS1 Alternator Question?
  128. Install University- EGR free Mod!
  129. Gain from longtubes
  130. Options besides bosch 13111's?
  131. TexasSpeed 3'' Y??
  132. my LT headers & y pipe are flanged!!
  133. are all LS6 intakes created equal?
  134. SLP fan switch turns off TCS ???
  135. Best o2 sensors for slp long tubes.
  136. Cheapest LT setup possible?
  137. Loudmouth/Loudmouth II
  138. trying to make more clearance. (pic)
  139. do i need o2 sims?
  140. Flowmaster 80 series catback exhaust
  141. American Racing Headers / y-pipe installed today !!!
  142. hooker shorty headers
  143. Spohn DS Loop Fitment.
  144. Options besides bullets for Loud Mouth??
  145. SSRA...gggone!
  146. PLEASE HELP! Broke a bolt off in the end of my crank!
  147. Dipstick tube plug
  148. Intermittent idle, O2's or IAC?
  149. question about header studs
  150. Oil Pump going bad?
  151. flowtech headers
  152. how many cutouts in your exhaust?
  153. Pacesetters LT's work for all ls1 fbodys?
  154. Primaries: 1 3/4 or 1 7/8 for a 408ci
  155. Need some info on Inspections
  156. Are these the band clamps I need for headers?
  157. kooks headers and tsp y pipe ?
  158. HP gains question.
  159. Who's doing P&P TB?
  160. need some quick info???
  161. Cherry bomb mufflers?
  162. Just a littly FYI.
  163. Flowmaster "1 chamber"
  164. Should I install my pacesetters?
  165. exhaust question please read
  166. Write up for PWS rack removal
  167. Electric Sweep gauges w/ sending units
  168. ok so another problem.....
  169. ASR problem
  170. what kind of headers should i get?
  171. best radiator??
  172. Weak factory engine pieces
  173. what diameter cutouts to use with pacesetters?
  174. Dynatech question??
  175. MAF frequency specs
  176. where to buy remote cutouts?
  177. Bolt sizes...
  178. help...cant figure out misfire in upper RPM!
  179. exhaust manifolds
  180. Ground clearance with TDs
  181. which intake fast 90/90 or carb style
  182. gaskets?
  183. Magnaflow catback with cut tips
  184. Car runs like ass after header install
  185. CAI on a SS
  186. Can i run the engine alternator disconnect ?
  187. Possible option opinions needed.
  188. G5x3 and Powersticks or Sweet Thunder???
  189. LS2 intake on LS1?
  190. Dyno Results From Gutted Cats
  191. Will a carb LS1 run without ignition/distributor
  192. slp fan switch
  193. Off Road headers....
  194. What exhaust do I have
  195. Its this a good header/exhaust Combo?
  196. True dual question
  197. Throttle Body ?
  198. Silver bracket on transmission tailshaft?
  199. help!!! intake boot ??????????
  200. single chamber flowmasters or bullets?
  201. Deleting TC
  202. What is this?
  203. dynomax bullets?
  204. To bullet or not to bullet..
  205. Which is a better intake??
  206. Red Paper Filter?
  207. leaking coolant!
  208. Exhaust Installation Question: Need Help
  209. flowtech headers?
  210. Questions about Headers? from Iraq
  211. Questions about Pacesetters
  212. h/c
  213. WTF? Water Temp Senspr Broke!!!!
  214. blackwing filter Install
  215. QTP Cutout install question
  216. ditching my true duals, question about "y" pipe and catback
  217. Katech spark plug wires/relo brackets ??
  218. Part numbers for an LS6 intake?
  219. Pace setters vs edelbrock headers
  220. LS1 intake/Ls6 intake swap questions ???
  221. Header question
  222. What stock MAF can I use on a 98 LS1?
  223. Pacesetter LT's and TSP Catted Y-Pipe
  224. 32 valves for your LS2/LS7...
  225. fast intake install question
  226. should i get headers for my SS?
  227. coolant cross over lines
  228. LT installation question
  229. TB bump stop, too far??
  230. Anyone using OBX headers?
  231. Crossed 02 wires ?
  232. Headers for 92 firebird?????
  233. help with underdrive pulley
  234. exhaust system troubleshooting
  235. PCV Delete
  236. Exhaust Leak...
  237. Jacksonville, FL - anyone that installs LT headers?
  238. What do I need besides a basic cam kit?
  239. Suggestions on my exhaust setup
  240. what gains will I see form an underdrive pulley?
  241. People with dynatech/FLP headers HELP!!!
  242. punching out cats
  243. What benefits/HP increase from 78mm to 100mm MAF?
  244. Differences in power curves between LS1 Intake and LS6 Intake...
  245. tps sensor
  246. what y pipe works with hooker headers?
  247. need LID
  248. World LSX1 15 degree Heads
  249. Will a H-pipe quite my car
  250. best mod for highway racing
