View Full Version : Generation III External Engine
  1. punching out cats
  2. What benefits/HP increase from 78mm to 100mm MAF?
  3. Differences in power curves between LS1 Intake and LS6 Intake...
  4. tps sensor
  5. what y pipe works with hooker headers?
  6. need LID
  7. World LSX1 15 degree Heads
  8. Will a H-pipe quite my car
  9. best mod for highway racing
  10. Does this sounds like a good setup?
  11. Cutout Illegal?
  12. 2 "Y" exhaust
  13. Is anyone using magnaflow race cats???
  14. Your opinion please....
  15. SES on both passenger side O2 sensors
  16. P0200 Whats that mean?
  17. Quick Question about upcoming H/C install
  18. nick williams
  19. Need Help with O2 Sensor Sims
  20. Airlids w/ air tube...
  21. Pacesetter ORY question?
  22. need the best stroker kit in market - -
  23. Friendly reminder... check that belt!
  24. Egr block off plate for LS1 intake
  25. cherry bomb exhaust
  26. LS1 Serpentine Belt replacement
  27. best x-pipe for true duals
  28. true duals with Powersticks or Powerpacks
  29. My duals
  30. NASTIEST/MeaNEST eXhausT?! help!-
  31. Factory Power Steering Cooler
  32. slp headers
  33. Anyone have the Fast Toys SLP CAI upgrade? Comments?
  34. OBX Headers??
  35. OBX Headers???
  36. Port matched LS6 Intake???
  37. wideband o2 placement?
  38. Radical Radiator Relocation?
  39. need exhaust hanger part numbers
  40. MAF Question
  41. need a less raspy exhaust
  42. Anyone know how super 44 flowmaster sounds?
  43. cme question
  44. How to get better ground clearence?
  45. PCV question...Long
  46. Making My Own Mufflers, D%#& It!
  47. Got a new exhuast setup, dumped under seat, too loud inside.
  48. Magnaflow Quad Tip ?'s and pic request on T/A
  49. Help! Need Replacement Part
  50. no low end after QTPs and true duals
  51. finishing my new motor, need some advices, pics! help
  52. TCS w/o ABS???
  53. HELP asap. oil spot on plugs, wot missfire
  54. American Racing Headers & True-dual's video!
  55. Pics of ARH headers and y pipe
  56. More XS headers installed and questions
  57. Please Help Diagnose Minor Misfires On LS6 Swap
  58. To X or not to X, for true duals.
  59. tb install question
  60. Cutout Issues
  61. removing injectors electrical connection from rail
  62. question about piping after headers
  63. Porting your own TB
  64. True duals no X or H pipe....
  65. what kind of gains...
  66. Catback. Corsa or GMMG?
  67. Will turning the MAF sideways affect anything?
  68. Cut out
  69. Header leak or normal.
  70. coolant block off
  71. slp ls6 vs fast 78
  72. stainless twister...
  73. Headers & Exhaust: lift tools needed?
  74. Headers for 98 TA Conv.?
  75. Use the pacesetter header gaskets?
  76. question on sensor, new MTI airlid installed!!
  77. Best way to check for intake and exhaust leaks?
  78. Quick Cutout Question?!
  79. ls6 intake
  80. A/C Vacuum question....
  81. Stage 8 Bolts
  82. tb bypass
  83. C6 exhaust question
  84. pyrometer temp??
  85. Help me troubleshoot. -shiftlight
  86. What is this connector for? (pic)
  87. Maf needed with aftermarket lid?
  88. what exhaust systems w/ headers?
  89. Cheapest 160 degree thermostat
  90. My car sounds like poo
  91. Y-pipe question
  92. Help identifiying intake TB????
  93. what size is the passenger head bolt for the water temp sender?
  94. What exactly is RASP and DRONE?
  95. Aerochamber muffler...what others fit in its place?
  96. Finally ordering headers
  97. question about pacesetters
  98. How many horse powers should I be making
  99. ory for flp headers?
  100. LS6 intake = burning oil wtf??
  101. Fast 90mm intake and NW 90TB 90 MM What kind of a gain?
  102. How long will these last.....
  103. Value over power?
  104. Open Headers?
  105. How will the spintech muffler work with Loud Mouth?
  106. Removing Air Conditioning.
  107. Best catback for low interior noise?
  108. metallic cats?
  109. Dynomouth questions?? for straight pipe setup
  110. Question for the exhaust experts
  111. chime location
  112. Tsp Catted Y-pipe??
  113. Surge after lid install?
  114. My ws6 and fast 90/NW 90 and bellows.
  115. To those with true duals and cats.....
  116. next mod
  117. Which is the best Longtube for the money?
  118. How loud is SLP d/d on lopey cam,lts,ory?
  119. Oil pump prob
  120. PORTED TB SALE from $40 SHIPPED!!!
  121. Pacesetters Long Tube’s work with kook’s Y?
  122. Where does air from vents enter the cabin?
  123. What kind of exhaust?
  124. Borlamouth
  125. True dual question.
  126. Ported Tb Size?
  127. Calling GM techs and Parts guys. Where did the rear main seal go?
  128. Good price for SLP headers???
  129. Shift light hook up help
  130. Cause of this?
  131. Pacesetter Y to stock I
  132. tried a search but didn't find info...
  133. Dana S60 + Loudmouth1+ lowering springs will it fit?
  134. Any pics of new magnaflow tips?
  135. ?? about air pump...
  136. Testing O2 sensors
  137. wiring diagram for coilpacks....
  138. Will ARH's fit with TSP TD's?
  139. MAC/ORY to LT?
  140. Need help!
  141. Those with QTP's lookin for y-pipe inside...
  142. installing a flame thrower kit and wondering if this will do harm....
  143. true duals who sell them!
  144. Noone said there were TWO bolts!?!
  145. Another pacesetter thread but...
  146. diff between 2005 cts-v motor
  147. Greddy catch can
  148. car wont start on first start-up
  149. FLOWMASTER SOUND on 2 totally different vehicles
  150. Is this a fair price for O2 installation?
  151. This is how you remove a fuel line....[video]
  152. 105 MM Throttle Body w/sheet metal intake
  153. Who's tried a "HookerMouth"?
  154. HELP! Anyone found out if TSP true duals work on XS headers???
  155. Jet-Hot Y-pipe Replacement?
  156. Do we have oil coolers on our cars?
  157. noobie ?? on headers and muffle shops in fl
  158. Catback exhaust
  159. Changing Motor Mounts
  160. WTF!! Header primary blocking oil plug
  161. summit racing tb
  162. transporting my y-pipe/catback??
  163. cooling fan wiring
  164. thermostat bolts
  165. simple Y-pipe question
  166. engine miss MSD wires
  167. Magnaflow cat-back is on...
  168. Catch Can
  169. SLP Y pipe?
  170. is there a writeup on how to remove the fuel line from the manifold?
  171. Tired of listening to exhaust clips HELP!
  172. Could this be a Prolem on my intake??
  173. LTs/ORY with TSP rumbler catback?
  174. true duals sound clips inside..need opinions!
  175. need help with throttle body...
  176. PaceSetter Longtubes, I have some vibration in first,why?
  177. Will drilling a hole in the Throttle body affect performance on a stock cam?
  178. Oil pressure sending unit
  179. LS6 intake manifold?
  180. 99 TB On a 00 ?
  181. WS6 vs SS Air lid base, have you noticed?....
  182. LS1 to LS6 PCV conversion
  183. EDELBROCK 80mm THROTTLE BODY?
  184. Pacesetter Headers.....
  185. true dual sounds clips needed
  186. y pipe to fit between slp longtubes and hooker catback
  187. pcv breather question
  188. Ahhhh RASP!
  189. Cat Back Instalation Queston
  190. Which dipstick when putting in new LS6?
  191. Collant Cross-over Line
  192. SLP air lid for '02 trans am
  193. Media of my ARH headers/intake install
  194. Dyno numbers: longtubes + true duals
  195. TB Coolant Bypass vacuum/idling problem..
  196. how long before your cutout motor crap out?
  197. Where to buy block off place for MAP Sensor?
  198. Long tube install writeup?
  199. Playing w/ my exhaust setup.
  200. cut out were to weld in
  201. collector inserts?
  202. How much more does a stock pulley weigh than a powerbond pulley?
  203. Intake Poll
  204. I am not liking my Kooks LTs + GMMG catback
  205. Clogged cats? How to diagnose? lean>?
  206. LS6 question
  207. Anyone know what this is....Off of manifold
  208. K&N filter question.
  209. Pacsetter Y-pipe removal
  210. Mustang sound?
  211. sorry guys need some help
  212. fast 78 but what tb?????
  213. help with victor jr
  214. Question about Catylic Converters
  215. what muffler produces a muscle car sound?
  216. Show me your Custom air intakes!
  217. Porting stock manifolds? need guidance
  218. Fvcking slip fit exhaust
  219. Holley Intake better than others???
  220. Air System/ Header Install/ SES light Question
  221. dual or single
  222. Dam rusty AIR bolt broke off in the manifold.
  223. EGR tube cracked off.
  224. I'd buy that for a dollar!
  225. jet hot cats
  226. 90mm throttle body on a 78mm fast intake?
  227. need header help ASAP
  228. SLP Loudmouth Catback
  229. Help with ignition system!!!!
  230. Switched to longtubes...power loss???
  231. coil packs (trucks vs cars)
  232. SLP High Flow Cats
  233. slp lt headers
  234. Question about electric cutout
  235. is an X-pipe the cure?!
  236. Any JBA header users out there?
  237. jet hot
  238. TSP Rumbler to SLP dual/dual w/ ecutout
  239. American Racing Headers Just Ordered
  240. Track Results BBK SSI vs. Mamo Ported FAST
  241. Y-Pipe to fit between QTP's and Magnaflow?
  242. Vic Jr o-rings
  243. EGR and LS6 intake
  244. Maf?
  245. new header install
  246. Emissions passing performance
  247. Will Borla work on a Z with factory ground effects?
  248. stock exhaust and cutouts??
  249. exhaust question
  250. Which headers?
