View Full Version : Generation III External Engine
  1. What Plugs To Get???
  2. injectors
  3. well...the cutout is welded in!
  4. bosch plugs
  5. quick question
  6. Which wires do you guys prefer?
  7. Custom...
  8. Fake
  9. BBRC Sheetmetal Vs. Vic Jr Efi Vs ??
  10. Anybody ever use the Professional Products Mani and TB??
  11. SLP Long tube install ???
  12. custom plug wires?
  13. Porting LS1/6 "based" cast aluminum intakes...
  14. qtp electric cutout issues need help asap
  15. Easiest underdrive pulley to take off?
  16. Header Dilemma...help!!!
  17. How much louder with cam
  18. What is this part on a camaro ???
  19. Pacesetter Question
  20. Jet Hot Cats?
  21. victor jr, elbow pics please
  22. Lingenfelter Intake Gasket Question!!!!
  23. Powerbond under drive pulley question?
  24. What else is needed to support 90/90?
  25. Anyone know what this is???
  26. how to get open headers?
  27. How do you wire up A/F gauge with corvette 02's?
  28. ran into a rather odd PCV issue.. take a look
  29. Size of Magnaflow Quad tips
  30. Sound/Flow of Magnaflow Catback
  31. Your thoughts on my Mod list
  32. what work needed to be done for l92 heads?
  33. no-gap spark plugs
  34. aftermarket air lid fit?
  35. oil-less filter
  36. TB and IDLE
  37. Corsa with LT's and ory
  38. Removing the Cats
  39. Y-Pipe questions?
  40. Exhaust quote....
  41. PLEASE help me get this SOUND!
  42. Im back...proof of ported TB gains.
  43. Im back.....proof of ported TB gains.
  44. idle
  45. Who makes 2.5'' inlet corsa clones??
  46. Which pulleys for my setup?
  47. Can I reinstall a screen on my MAF? Or new/used one?
  48. Quieting the Loudmouth (SF VS Powerstick)
  49. Rust on my SS headers????
  50. LS6 valley cover?
  51. K&N Generation II FIPK
  52. exhaust/ground clearance issues,, what options with flowteck headers?
  53. Questions as to tube size on exhaust?
  54. Texas Speed Rumbler Catback(owners come inside)
  55. shopping for headers.
  56. where can I get borla adj plates
  57. 2 1/2" diameter mufflers, whats size piping?
  58. TB Coolant Clamps (Bypass)
  59. Best underdrive pulley that will allow double roller timing set
  60. DIY true duals (i've read the TD sticky)
  61. First Mod - Exhaust
  62. LS1 intake gaskets
  63. Extending O2s
  64. 00 ls1 throttle fit a 99 ls1 ?
  65. meth injection
  66. over axle duals
  67. Where to find AIR/Lid plug?
  68. Exhaust Pipe Joining Clamps?
  69. spark plugs on my dad's 02 silverado
  70. need help, I dont know much about headers!
  71. Borla Adjustable plates
  72. FAST or LS6 Question
  73. air pump holes on exhaust header
  74. fuel rail psi gauge?
  75. Will This Exhaust Set-up Work In My Corvette?
  76. Oily Substance in LS6 intake manifold
  77. Lingenfelter Intake Gaskets!!!!!
  78. slp header ground clearence
  79. header install finished questions left
  80. PS Pulley install..how far onto shaft
  81. Where's the oil pressure sending unit?
  82. Loss Of Power?????
  83. Nick Williams or Holley TB?
  84. Limits of stock coils.
  85. Quieting down true duals
  86. Changing knock sensors without completely remomving intake?
  87. Borla 3" adjustable for '02 trans am
  88. Help..TB questions
  89. Ls6 intake swap
  90. @#$#$% Spark Plugs!
  91. Blocking off heater hoses at Water Pump
  92. H-Pipe Duals Fitment Questions..
  93. Shooping for Cat-Back
  94. Anybody know the part number(s) of this??
  95. Do Moroso Spiral Flows Flow Ok or....
  96. Do I Need The Complete Cat Back/
  97. Check gauges light at drag strip??
  98. What diameter cut-out?
  99. Lanes True Duals?!?!
  100. pacesetters w/no cats?
  101. ls1 intake manifold gaskets? ----help
  102. MAF Sensor & K&N Filter
  103. Victor Jr setup with Air cleaner
  104. Pacesetter ORY.. so easy to install.. why do people bitch about it
  105. it's been beaten to death..Corsa or B&B?
  106. Throttle cable question
  107. Got an awesome deal on an LS6 intake!!!
  108. Pics of the new duals and a Question
  109. LM 2 Muffler restrictive?
  110. 85mm Summitt Throttle body
  111. Cut Off My Muffler?
  112. what kind of power
  113. Bbk Lt
  114. Price Increase
  115. Coolant crossover conversion questions.
  116. Pacesetter headers w/ cat y-pipe
  117. Engine Vibration HELP!
  118. Anyone ever see these flex pipes??
  119. LS6 intake results
  120. Selling car with modded exhaust?
  121. BBK SSI intake on a Cam only LS6 car, worth it?
  122. How much do headers affect the air/fuel ratio?
  123. taking off the stock exhaust.
  124. Exhaust ?
  125. true duals with no balancing pipe
  126. installing TSP duals
  127. Kooks On Speed Channel Tonight
  128. shift light
  129. car is sputtering, HELP please
  130. Whoah!~. . chokemaster gone ....
  131. Need Intake Help
  132. what underdrive pulley ASP or SLP
  133. Fast 90mm over LS6 intake
  134. After install its just not loud enough!!
  135. Off Road Y-Pipe
  136. Damn Header Bolts...
  137. Alternative alternators?
  138. Need Help!!
  139. Ls6 intake part numbers
  140. Intake gasket on high-ish mile engines
  141. true duals at last
  142. 2k idol/ running hotter / TB blade sticking
  143. which plugs
  144. Best X-Pipe
  145. what heads do i have?!?!?!
  146. header install on my ss
  147. What size O2 EXT?
  148. Changing radiator cap pressure
  149. L/Ts
  150. JBA cat4rward headers?
  151. Shelp life of spark plugs
  152. Flywheel....crank bolts....torque specs
  153. some one help!!!!!!!!!!
  154. Truck coils question
  155. Third Gen exhaust help...
  156. What exactly entails a "built motor"
  157. Harness Relocation
  158. Intake Manifold Install
  159. Removing AC Compressor and lines?
  160. true duals soon which mufflers.
  161. Super Victor LS1 vs. GMPP Carb style EFI
  162. slp lid
  163. Quiet muff needed
  164. Spark Plug wire question
  165. FAST Intake Install.
  166. Heat shield removal
  167. Electric water pump questions
  168. cooler thermostat?
  169. What Catted-Y for Jet Hot Headers?
  170. What LS2 waterpump for LS1 F-bodies?
  171. Can stock fuel rails be switched around?
  172. Wow, I think I need a tune
  173. spark plug selection...?
  174. Reusing stock manifold gaskets.
  175. Book?
  176. Searched...what size Magnaflow?
  177. Question for others who have Flowmaster single chambers...
  178. Header gasket
  179. Can you clean fuel injectors and O2 sensors?
  180. Porting Corvette TB
  181. Engine Covers
  182. DMH Electric Cutouts
  183. how to tell new vs. old pacesetters?
  184. Moroso resonator
  185. horse power
  186. FAST90 on stock fuel lines
  187. NKG TR-55's
  188. What do I need to install Pacesetters??
  189. Motor/ Tranny Mounts
  190. 02 Sensor Thread Size and Pitch
  191. running hot at idle water pump or balancer?
  192. Another " I just installed my headers" thread
  193. FRC's and Aftermarket Fuel rails
  194. pacesetters or hooker?
  195. o2 Sims
  196. 97 t/a or 99 t/a
  197. Pacesetter LTs
  198. Which y-pipe with QTPs?
  199. stock SS muffler
  200. Rattling Noise
  201. What Mods next?
  202. got my DUALS done
  203. ASP Pulley
  204. low end torque
  205. Exhaust shops?
  206. truck coil packs on LS1...
  207. Headers?
  208. Help Headers?
  209. Exhaust question
  210. Free mods
  211. Cat Question
  212. warped belt sound coming from LS6 intake?
  213. need to shed some weight
  214. Ls6 Intake Hp Guess with my Setup?
  215. Is gmmg too loud....
  216. Painted my new FAST
  217. 02 trANS am cam Qs
  218. Typhoon Manifold
  219. pwoder coating headers?
  220. Wheres the best place to get........
  221. honing noise
  222. FRPP dual-mode mufflers?
  223. Stock exhaust removal?!
  224. Cut out pipe size question / help
  225. Damn SLP headers...
  226. Trans-brake?????
  227. what type of muffler shop needed
  228. Before i debaffle my hood...
  229. wires for coil relocation?
  230. New setup...
  231. which header?
  232. crank pulley bolt
  233. stupid question
  234. DMH Cable Cutout Question
  235. F.A.S.T intake or Spectialy products intake manafold
  236. slp headers
  237. FAST 90 w/ stock internals?
  238. OBX R headers- any good?
  239. running on 7?
  240. true dual under axle questions
  241. Ac blows through the bottom after ls6 intake install.
  242. CME tips Broke!
  243. header, ory and cutouts installed ??
  244. Used heads, been massaged, have questions
  245. What paper filter do you like best?
  246. Which paper air filter do you think is the best?
  247. Favorite or best paper air filter?
  248. Stupid Question time.....
  249. Cali people with Headers come on in!~
  250. LT header decision
