- ok, i dont know how to do this.
- Lid problem!
- Will I need O2 Simulators
- tired of exhaust setup
- Exhaust system with nasty tank
- Under the Axel True Duals ?
- Electric waterpump flow?!?!
- Attempting to quiet down TSP true dual (suggestions on mufflers?)
- What do you use to clean inside of intake manifold?
- Would like to make my Cme louder!
- Stupid mistakes that make your car run like crap thread.
- Im dumb, How do I unplug the knock sensor?
- Best $1,000 ??????
- Cai
- Stock manifolds
- tb question
- Air Dam
- Quick exhaust question
- xs longtubes+ory+spiral flow=wow
- ARP harmonic bolt.
- True Duals with a Tunnel mount Torque Arm??
- I need a new mass air flow sensor what to do??? search won't work
- Energy Suspension Trans-mount experience
- Exhaust Question or Opinions?
- ss camaro ftra help? pics?
- Cutout worth it?
- Corsa cat back installation
- Cleaned / Oiled Filter....Idle Problems???
- polyurethane motor mounts
- taking your air filter out
- Which is better for PCV: Catchcan or Breather??
- Bought a professional products TB. Don'ty know about it
- Vacuum Leak, off of Manifold. Help needed.
- Exhaust Help PLZ!
- Ls1 Typhoon Intake,bling Or Sting.?
- SLP Dual-Dual Hardware
- FAST 90/90 intake & T/B, Billet F/R install.
- Overdrive Pulley for Alternator?
- LoudMouth II Dumped?
- Throttle Body Question
- What is that computer box?
- Rear O2 sensors on longtubes...
- Kook's 1 3/4", stepped, or 1 7/8" Header Help!
- re: qualitiy throttle bodys.?
- Fast 90/90 bellows
- Spark plugs that WILL NOT FOUL
- E3 spark plugs
- What temp should 160* t-stat run at?
- LS6/ported TB to Fast 90, getting Yella Terra rockers 1.7..worth it?
- Race header EGR?
- Disassembling LS1 throttle body?
- Pacesetter dyno #'s low
- miss after LT ORY!!! help please
- new headers
- 2 questions ?
- Is it necesssary to replace knock sensor, when swapping to ls6 intake???
- Airbox Question
- Vengeance Racing Ported and Painted my Intake!
- Whats Next???
- SSRA,Gears,PTB (NEW TIMES)
- test 02 extensions?
- How Can I Tell If I Have An SLP Muffler?
- harmonic balancer
- Would a catback help me much?
- best price on set of msd coil's
- Broke my header bolt when installing longtubes a few questions
- After installing headers, do I now need a tune?
- lid question
- need a few more tenth's
- Bonehead question: Where are the O2 sensor plugs?
- rear o2s
- Confused on all the exhaust brands
- ORY vs. Catted Y
- GMPP Valve Covers fit stock filler neck
- race muffler or cut-out
- Powers steering pump
- exhaust
- Fast intake swap question
- who has pics of their painted fast manifold(black)
- One Cut Two Cut
- True duals are finally on :)
- guys with tsp tru duals
- How will a TD setup affect my sound
- hose on side of air lid
- airlid rubbing
- corsa catback question
- Just had an idea for a sleeper exhaust...
- which ls6 heads
- Serpintine belt question
- What could I stand to gain from a tune?
- anyone running tsp duals on qtp headers
- Polished Kooks almost finished!
- Crank pinning instructions
- Ws6 exhaust and SS exhaust...
- LS2 on stock displacement = bad. LS2 + 383???
- Does anyone have belt slippage problems with their underdriver pulleys?
- header install tomorrow!!
- Belt length
- Big problem after header install.
- Need Help ASAP TA wont start starter/clutch switch?
- Thermostat Ques.
- Valve covers Missing Hookups?
- another OMG I GOT MY HEADERS IN thread
- Verdict
- Headers
- Couldn't get a response in the electronics section.
- Headers in Chicago
- 1 7/8 Headers Too Big ?
- RUMBLER...the good, the bad, and....well the good
- 2004 GTO intake?
- Typhoon Gaskets
- Would not capping off the coolant line through the TB cause a vacuum leak?
- lsi to ls6 intake no egr
- Gmmg
- Whats better? Tuned or Untuned headers
- ls6 coolant pipe o-rings
- I just bought an EWP!
- *Video clip* My T/A w/ Kooks LT Headers & GMMG catback
- F***ing Lid
- What else I need.
- Is it common after ls6 intake install............
- Borla
- PP intake and TB
- what size belt do i need
- LTs Question
- Catch Cans
- Catch can Question
- need info...
- Ceramic Coated Pacesetter
- whats the loudest muffler for TSP TD's?
- shave TB screws or leave them?
- Header Gaskets which way do they go on?
- LS2 intake swap
- where to put cutout
- TR55's pregapped?
- Question on Painting Exhaust
- Free EGR mod
- intake elbows
- LS6 Intake installed
- amw pcv routing?
- any way to keep tips with duals?
- Who broke their oil pressure sending unit?
- Please Help Asap!!!! Central Illinois
- will 98 Headers fit my 2002?
- anyone ever get dtc after ls6 intake swap?
- She bangs! She bangs!
- Buying some Pacesetter Headers, here’s my checklist so far, anything else?
- WB02 where to connect wires???
- Not a newbie, but I do have an exhaust question
- What determines the powerband of an engine via intake manifold design
- problems after intake swap
- i need all aftermarket guages, how do i do this?
- Time for a new exhaust. What to buy?
- Header question
- ORY to stock manifolds
- moutning wideband
- Found the best sounding exhaust
- 98 knock sensor question
- ASP or March U/D Pulley?
- Best Clearance Y pipe...PaceSetter?
- Erratic idle (mostly with A/C off) after TB install?!?!?!
- catback exhaust leak
- Estimated HP with these mods
- FAST gasket install ?
- Bump stop mod help
- PCM cover removal (2nd topic post)
- Muffler Ideas
- LT header newb question.
- noobie here...will I hate my LM2?
- best intake for 427
- Just got it iN!
- Should NGK plugs work ok with Autolite plug wires??
- QTP header installation
- Who's successfully quieted down exhaust volume INSIDE the cabin?
- Ignition Problem – Intermittent Ignition/Start
- Low idle after LT/ORY install.
- idling high, not sure if right forum
- will LS6 exhaust manifolds fiit a F body
- mounting coil packs
- I Wanna Be A Little Louder......
- Kooks Y-Pipe Hitting The Car
- L92/L76 or PRC 5.3/FAST 90 on 408?
- coil pack mounting
- Anyone running Kooks LT's with TSP TD's
- LS1 to FAST 90 and coolant lines!! help
- Moroso Spiral flows look like they flow like crap?
- LS6/Ported TB VS. FAST 78MM LSX
- rattle from exhaust?
- Self-Tune after Header install
- 2.02 or 2.05 valves?
- Production #
- New Magnaflow Quad tips on a Camaro....thoughts?
- Need Help!! Power Trouble
- Will an LS6 intake work off a.....?????
- Still a little jumpy.
- my magnaflow catback or tsp sweet thunders
- oval muffler
- power wire
- Opinions on Magnaflow mufflers on duals?
- Need muffler help real quick
- Reuse stock cats?
- water pump
- header question
- Mac Headers?
- Let's Hear Your Opinions on These 3 Cat-Backs.
- Fast/nw 90/90
- edlebrock LTs and ory w/ dual cutouts
- Throtle Body Questions
- ls2 intake
- Piston Slap?
- LS1 clamshell mount applicability
- LS6 Heads
- Quick cutout ? HELP
- Buying Headers.
- coil spark
- Camaro People Who Has A ........
- Race headers?
- First dyno run
- help on intake install!!! ASAP
- 100k ?
- MAF sensor
- For those who think Magnaflow isn't loud...
- Quench formula?
- Will the Pacesetter Y-Pipe fit Jet Hot LT's?
- what thermastat is everyone running
- magnaflow or true duals
- Throttle body isssue
- Intake
- What Do U need for Header install (Pacesetter)
- Open headers car runs like crap
- cool heads..
- New exhaust, shaking?
- Power Steering
- Which plugs/wires
- Flowmasters
- Tucking up GMMG tips
- new Ls1 ignition coil wire harness
- F.A.S.T 90mm intake porting?
- Going the LS6. what do i need to know?
- semi-unique exhaust thread
- Relocation ignition coil kit
- Corsa clones how long are they?
- *Pic's of my new used exhaust*
- Cut Outs
- Valve Train Replacement
- Clearance
- Here's the COOLANT article from Master Technician magazine
- muffler hanger missing catback installation
- Bought A Ws6 Hood
- Jet Hot LT's
