- EPS 226/230 Cam and ARH 1 7/8 Install Questions
- looking for some good mufflers for my car
- Need exhaust help/opinions.
- BBK LT Ceramic coated Headers and Y pipe
- Starter Question
- Best way to run exhaust with LT's and Spohn Torque Arm
- broken pcv crossover hose
- custom pcv routing victor jr/ proflo
- borlamouth ftw!!!!!
- Corvette owners with fast 92 Help!
- Adding a Powerstick
- Need help
- Change the Exhaust or stay same?
- Porting throttle body
- Exhaust
- anyone installed a LS6 with a modified 90mm LS2 mouth?
- Going 85 mm MAF
- SLP Flowpac CAI/Ported TB
- Rear heat shield exhaust rattle
- plug wires
- GZ vacum pump install
- Can I plug the vacuum port leading to the Air Diverter Valve?
- LS2 or LS6 intake manifold?
- holley ram air intake?
- Farm truck Sound
- check out these 270$ pacesetters off ebay?
- accidently broke header bolt, nowhave leak and car backfires
- Car Won't Start
- Thinking of doing TSP TD<'s....questions
- Fast toys Airlid to fast 102 intake
- I think my AC compressor is dying, video inside
- ASP underdriven balancer,
- ory or catted with my settup
- Edelbrock Fuel Rails, FAST intake
- Slammed 01 Formula: Need Headers That Won't Scrape!
- What if you had a cheap iron headed 6.0
- Anyone using MSD 6010 on EFI car?
- Looking for a wide flat air filter for end of MAF...
- coolant temp sensor relocation?
- Tall valve cover question and pcv
- Recommend me a new muffler!
- magnaflow catback used value
- best torque arm to use with tsp true duals
- Exhaust help!
- New Intake Manifold
- New at CBM
- what MAF and lid for my new ls6 intake?
- ignition coil question
- My FAST 78 *after* install woes
- I thought I had a miss!!!!!!
- TSP ORY not matching up to cat back
- Exhaust question - I searched
- High pitched whine, like a bearing noise
- Looking for exhaust help
- bolt on hp
- engine came with batwing oil pan
- I love my J&S Vampire!!!
- P0306 Cylinder 6 Misfire!
- 02 COOL LEVEL sensor
- Silicon coupler for FAST 102mm to SLP 85mm MAF?
- Ported truck intake vs Edelbrock Pro Flo vs FAST LSX RT
- LS1 Firebird Custom Exhaust?
- Best Exhaust/LT Setup for Ground Clearance
- Ball valve cutout??
- how to install an slp cold air induction?
- What y pipe works with ebay headers?
- Differences between a 08 6.0l and a 04 6.0l??? Need help ASAP
- Looking for parts for my t/a
- Help with FAST 92 Intake Install
- TB, Headers, Intake Manifold?
- What Intake to use?
- Reccomend an exhaust for deep sound
- ls6 intake, hooker longtubes, tsp ory, magnaflow
- Few questions about motor build
- 96mm intake manifold on stock ls1?
- 98-99 exhaust manifolds vs - 02'ish manifolds - size difference?
- Braided Hose
- Knock after clutch/header install
- Magnaflow fitment issues
- Next Bolt-On?
- LS6 Intake question
- Prothane motor AND trans mount
- Belt Tensioner pulley....
- Just put my LT's on, question about exhaust
- Rear main leaking.
- Quick Lid fitment issue question.
- I need help! newbie with a sick car!
- CTS V water pump?
- 1st Ls1 build. Advice?
- FAST 102 INTAKE is FULL of OIL ?
- Exhaust Rattle?
- Header install gone wrong!
- Picked up a FAST 92/92, Injector questions
- possibly a major problem please help!
- oil consumption/pcv hose
- Truck intake plugs.
- SLP Loudmouth
- put headers on car wont run
- Dead alternator fixed - vibrations
- Cat opinions
- Grand National Mod for 98 Z28?
- FAST 92 intake
- 92mm tb on fast 90?
- More Money More Power?
- stock gasket or bbk header gasket
- LS3 intake/heads on LQ4 Block
- Whistling sound from rear of car (HELP!!!)
- intake hose
- Coil relocation
- A.I.R. system removal
- Slp cold air and jaam ram air??
- Sudden drop in voltage from 14 to 11
- Who does the best port job on a fast intake?
- electrical gremlins
- Long tube selection for 04 GTO...
- Poly mounts question
- Mac mid length question.
- TPS reading 15%....high idle
- Wow....these tsp headers....
- are 706s killing my cammed LQ4's potential?
- 2002 LQ4 Camshaft?
- knocking sound after ls6 intake
- 5.3 brackets
- power steering problem
- sign of a clogged fuel filter???
- ls6 on my engine
- Percys Header Bolts
- 317 coolant sensor options
- Need quick help with head gaskets
- exhaust leak at header
- 98 z28 with truck harness
- solid motor mounts
- Stand alone harness
- Pacesetter 1 3/4" vs TSP 1 7/8" headers
- motor mount question....
- bolt on gains
- best tb for fast 90
- Radiator Upgrade
- Need some valve cover help! Perimeter to centerbolt
- Norris catch can...
- Cbm 454 lx tt warhawk dyno video 1100+ rwhp
- another loudmouth question
- '01 SS starts heating up while idling
- CTS-V T56, LS1 with an early 6.0 crank .400" extra flange, starter not work. Help.
- LS6 Manifolds
- o2 extenders
- Fuel Lines
- Anyone ever made a good flowing Y to replace muffler?
- Cam only lq4 down on power.Need advice.
- LS Coil Harness Ends?
- Ls6 Intake or LT headers?
- Power Steering Pump Whine
- Edelbrock #4254 2 Piece Timing Cover
- question about a stock ls1 throttle body
- exhaust question
- intake manifold choice
- BBK Headers
- Edelbrock throttle body?
- Crank bolt?
- Balancer install - does this sound right?
- Need length of Silicon Sleeve with Fast 102
- time for change
- INSTALLING CHRS1313 ram air... shroud trimming?
- Misfire on drivers side?
- intake manifold
- getting the most out of bolt-ons
- Potz speed throttle body
- wtb!
- Stock Y pipe dump
- Added some cats to my ORY yesterday
- plug gap... dammit
- fast 90 vs 92
- Please Help, Want my WS6 to sound more mild, What muffler??? My neighbors hate me!!!
- bbk headers, need to know
- o/f longtubes
- MSD coil packs?
- advice on inake manifold???
- lingenfelter and MSD 2-steps....
- typhoon intake
- tsp true duals
- Has anyone ever run texas speed LTs with kooks true dual exhaust
- Alot of mods getting put on. Estimated 1/4??
- Vibration issues, any help appreciated
- Vacuum Leak?
- $1200 Mods?
- 2000 camaro SS. stock inlet and outlet diameter?
- TSP Y Pipe/Mufflex Question
- need advice for headers
- Header ? What would u do.
- Borla xr-1 vs Flowmaster 10 series
- Muffler replacement gains?
- Next mod : Finish suspension or stall??
- LS1 header gasket questions...
- Added turndowns to dual exhaust, now runs lean
- Cutout/turndown issue.
- fast 102 problem
- Quick question please
- kooks header question
- Where to get headers ceramic coated in or near nj
- Injector and exhaust size.
- Startup issue after LS6 intake install
- Suggestions on this setup Im trying out
- Question to new jersey drivers.
- fuel pump not getting any power
- Which ory should i get
- So im pulling my trans for a rebuild and a new clutch..how to change the pan gasket
- 102mm throttle body fit a pro flo?
- Truck/towing header question
- New member a bunch of issues
- ATI Super Damper hub...
- Alternator Died On Me
- i need a 98-02 wiring harness!!!
- Bassani True-Dual Exhaust Systems WITH headers
- plug change done
- Will a C5 harness work on a F body?
- Excited! Ordering my tsp headers tomorrow.
- LS6 - belt/pulley (drive & a/c) part numbers?
- EGR/Air Block off plates
- installing headers on ls1 Fbody...haha ls1...
- will this fit help pleassee
- Will TSP Y-Pipe work with SLP LM2?
- Bad cat, what to do...
- Which adapter harness to run an LS7 maf?
- Accufab 4150: What all is needed to make work
- removal of PS and AC - wot pulley set up ?
- SUPER victor intake V JNR V Fast for FI
- F.a.s.t Intake ?
- My engine runs "cool"
- SUMMIT RACING LS1 valve covers
- Passenger side header problems
- o2 sensor issue
- first start up -no oil pressure,with remote oil filter
- Headers Installed..Few questions on the rest
- Is $1400 a good price for ported fast 90 with nick williams tb included?
- which lid to replace my MTI?
- Wix air filter doesnt fit slp lid?
- Rear o2 sensors information please!
- how low can I go!
- Can I unhook Steam line to re route?
- Motor mount bolt size
- Intake build worth it with shorty headers?
- 1998 alternator - I need to rewire, HELP!!!
- PCV valve
- Possible TPS and MAF problems...Help!
- Hooker LT's install issue
- corsa clones where to buy?
- fuel pump removal help
- SLP Loudmouth on Stock Exhaust
