- Brake Fluids. NEED HELP!
- Intake Emergency
- what gives here!
- Header Install ??
- Any sponsers with slp lid in stock
- how high is your stck cam producing power
- PICS!!! of victory jr intake w/ air lid set up...
- slp out of stock
- SLP or Z06 Mass Air Flow
- Best alternator
- Need to know if its worth it. (ASAP)
- Yanking out the EGR & AIR, what to do with wire?
- mac mids, ory and ls6 intake
- How do you know?
- Will Hypertech LS1 Thermostat work with a Meziere Water Pump?
- Dual cutouts-HP GAINS DYNO PROVEN
- Quietest exhaust with lt's and ory
- What are the dimensions of Flowmaster 1 Chambers?
- Installed LS6 Intake Yesterday
- cutout question...
- Twin Cone's Vs. Lid
- Wiring harness question?
- 02 question
- diff. between SLP lid and Black wing Lid
- What airlid for 90mm TB
- What pulleys for LS2 402
- Qwik foolish header question...
- Granatelli spark plug wires
- Hope i dont mess this up.....
- Nick Williams Throttle Body?
- Good bolt-on combo to get my C5 A4 into 11's?
- LSx IAC Location
- tying in ORY into stock exhaust mid pipe
- No muffler
- CATS or no??
- problems after header install
- header question
- longetube header install question
- Air removal Help needed asap
- Header tube rubbing steering column??? Need help ASAP
- Mac headers??
- Dyno numbers
- Guys with the high polish QTP headers
- another ls6 intake thread
- Open Headers = Slow
- Rear brake light kill switch
- Plug wire/keep burning em up
- QTP e-cutout
- size of stock tb??
- Need Valley Cover Bolt Size
- Cam Vid
- Loud Mouth Question?
- Damn header gaskets!
- td vs catback
- 402-worth switching from 1 3/4 to 1 7/8?
- Hooker LT's, Comps vs. Supercomps, difference??
- LS1 Exhaust header design question to the pros! (Lou, I'm looking at you!)
- Idle Problem ? H E L P !
- another shorty thread
- ls2 won't work on an ls1 will they?
- I started my Professional Products Typhoon swap today
- putting fast 90mm on need help
- help manifolds help help help
- is 02 sensor needed?
- Question about installing my own exhaust
- throttle body question?
- fuel injector clips
- Dynomax bullet intermediate pipe and over axle???
- Spark Plug gap with H/C/I & 42LB injectors
- New Magnaflow system?
- Freaking dealerships
- Lid problems...
- AIR/EGR question
- New JET HOT Header Coating!
- Looking for a specific sound (I check ls1sounds)
- Exhaust volume Cam vs. stock internals?
- After My Header Install.....
- Installed SSRA a few days ago...
- 853 vs. 241 vs. 243 castings?
- B&B Retrofit?
- won't start with battery moved
- BBK Intake Problem
- wtf is up with my ls1
- slp header install?
- Question about 93 octane in relation to car performance...
- Possible Idle Problem Related to Screenless MAF
- Will 5.3 Starters and MAFs Interchange with 5.7 or 6.0's and different years?
- AIR Removal with PICS!
- Best place to get LS6 intake
- LM1 muffler LM2 muffler differences?
- Backfiring?
- Is it possible to get 12 secs out of bolt ons only
- Cruise Control Cable
- Tb Coolant Bypass Mod
- 2002 ss fact i learned today...
- Exhaust Tips or Info.
- F.A.S.T. intake, LS2 90mm T.B., and Haltech worth it???
- were can i find this damn band clamp part
- Weird noise?
- Exhaust??
- SLP headers guys I need help!
- any decent flowing quiet mufflers out there?
- Check for intake leak?
- Has anyone seen/tried this kit?
- Proper Gap for NGK TR55's?
- Coolant system help!!!!
- 1998 WS6/SS Single outlet exhaust (picures)
- Very high idle problem after motor swap. Please Help!!!
- EVERYONE needs to get one of these!!!
- How long did you wait
- Anyone seen this lid?
- installed ls6 intake
- Help with next mod. LS6 intake?
- How many guys running QTPs and Flowmaster ORY
- Katech valve covers and coil brackets
- I am tanked and out of control1111!!!
- UMI Vs Nick Williams
- Spring mods inside opinions welcome
- Question About Heads & Intakes
- have a dumb question to ask
- BBK 85mm Throttle Body
- Center Monut Exhaust???? Not looking for slp!!!!!!
- VERY stiff radiator hoses
- switching front and rear o2's?
- headers
- few questions for my install next week
- Header install?
- What size is the tube for the tb bypass?
- Professional Products
- Best intake
- new generation coils and ls1 coils....
- Coolant Crossover Bolt Broken
- Pwr Steering Pump Whines like Sprchrgr
- Did I do wrong by getting a ORY?
- egr and o2 questions
- 1 3/4 FLP LT headers enough for 408?
- those with stall/gears inside!!!
- Upcoming Header Swap...
- 02 sensor question
- SES light
- FRc
- Need pics of power steering pulley removal
- bolt on and rpm?
- bbk throttle body on weiland intake,
- Fast 90mm Map Sensor Fix
- blew a hole in my primary
- Who's got a B&B Triflow...
- o2 simms?
- what next?
- tone it down?
- Mild Cam People, inside!
- Muffler with SLP Quad exhaust
- Header collector leak
- Y-pipe vibration?
- Custom exhaust for 402
- Photo of LS6 "Vette Dip Stick
- Cutouts? Some questions
- Bad Lid?
- Texas Speed Rumbler X True Duals
- I-pipe
- help on manifold for ls1 346ci
- I have an exhaust and cam problem Anyone help?!?
- Going from ls6 manifold to ls1
- When would the LS6 be a restriction??
- catted with cutout?
- removing tb accessories
- Flowmaster one chambers
- Exhaust
- True dual guys
- Where can I get Stainless Headers?
- Check Engine light on and blinking
- Looking for a specific lid
- Best place to buy o2 sensors
- exhaust help
- those who made their own exhaust. . .
- Ok Try This Intake Vs. Td?????
- "Fulll bolt ons"
- Porting a FAST
- Part number for Flowmaster Merge?
- Exhaust Diagram
- Pacesetter ory is it worth it?
- What do i need???????????
- Higher idle rpm after TB P&P?
- BBK Intake and throttle body
- egr or no egr?
- Will the LS1 MAF work on a LT1?
- engine accesory mounting
- Pacesetter LTs and Stock Y Pipe
- Long tube header guys, best FIT and FINISH?
- Intakes
- LS1 Water pump fittings
- passenger pacesetter?
- New exhaust 3" H w/Borla XR-1's Video too!
- Best replacement muffler ?
- Kook's Header Issue. Search Did Not Help
- Bellows for a 90MM
- damn exhaust
- Ory???
- Fouled a plug?
- MTI clear lid?
- opti vs. distributor
- Motor Mount Question...
- Y-pipe installation questions (Jet hot)
- Pacesetter Coating
- Intake Manifold Heatsoak - Aluminum (Weiand) Vs. Composite (LS6)
- Is this a legit P0135 code?
- QTP or Kooks???
- Would you be interested in replacing your Magnaflow tips only?
- X pipe vs Y pipe at WOT
- Exhaust that exits through the body.....
- Magnaflow Exhaust Sale and Free Shipping at EAD Performance
- stock Y pipe?
- Magnaflow Impressions.
- 90mm air bellow??
- Electric Cutout Guys inside!!!
- FLP exhaust question
- pacesetter headers and msd 8.5 plug wires fitment issue
- Replacing Motor/Trans Mounts - Which Combo?
- need some help!!!
- Make a TD setup quieter?
- Hooker or Pacesetter LT's?
- Using Delphi (85mm) MAF with 4" intake piping?
- Need opinions from you exhaust guys
- what hardware does the TSP catted y and Pacesetter LTs come with?
- Weiand Vs Ls6
- fast 90/90= 500
- AC Delco Front O2 Sensor Part Number Please
- what headers?
- Flowmaster
- pcv delete
- Kooks
- how hard is it to...
- Headers And Ory Installed.. Major Problems!!!
- Headers Install,first Start Up=smoke???
- spark plug gap
- Kooks headers help!!!
- Just installed ASP pulley>>
- Porting my throttle body, question....
- Weird Exhaust Noisee!
- exhaust
- Exhaust? Long Tubes, No cats
- o2's disconected
- Thinking about ordering A BBK LS1 Intake...
- Should i move the IAT?
- F.A.S.T. 90mm Gains on my setup?
- ls1>ls2 oil pressure unit!!!
- pulley?...Difficult install???
- Will an LS6 intake make a differance with my setup?
- cast intake for LS1 based motors
- just did the autozone pcv delete
