- Y Pipe ?'s
- whats the point of........
- how will this setup be slp to corsa?
- Hooker Catback - Cool ass set-up
- Opinions On Headers!!!!!
- Reducing drone with TSP TD setup
- Stock Exhaust, Pacesetters, Custom Y...??
- question about mufflers for true dual setup
- Intake and Headers for ls1 Z28??
- Service Engine Light
- loudmouth trouble
- ?'s about loudmouth
- Kooks Headers
- which mod to do next....?
- Ses Light..will This Be An Ongoing Problem??
- side exhaust poll yes or no rice or nice
- fast questions
- Pros / cons to deleting EGR/AIR???
- Ignition question
- Sensor question
- Holy exhaust batman!
- Quick Header question
- QTP headers install question
- Exhaust Bolts / Gaskets?
- CME with borla adjustable exhaust
- Running car without thermostat?
- *Your opinions on Headers*
- Front Driver Side 02 Sensor…
- How well does factory SLP Dual/Dual flow over other Catbacks?
- Help for winter decisions!!
- Aftermarket Valve Covers & PCV setup question
- SLP LM question
- Stock HP
- Need some help trying to get some parts.
- Backfiring -cold only
- Performance Curve (ebay) mufflers?
- dynomax bullets
- header combo question
- Car is finally gettin Tru duals
- cant get my hOOkers to fit
- POLL: spirals/powersticks/single chambers
- Headers over intake???
- Slp Tb???
- New 4" Mufflex pics.
- D-port headers for L92 heads
- Belt tensioner for the AC belt? Also, how tough to turn the alternator by hand?
- Jegs/Summit premade x pipe kit
- Obx Stainless Headers For Ls1
- How does this look?
- Borla Question.
- need some heat protection for fuel lines...
- PVC catch can
- MTI Clear Lid fitment
- Oil collector ?
- porting???
- Y-pipe?
- AC Delco Iridium Plug Gap?!?!?!
- What Intake
- Edelbrock Exhaust/Slp Performance Pac
- Tsp True Duals!!!!!???
- Stock tips on 3" duals...
- TSP Rumbler vs. Chambered cat-back
- LSX Intake and TB
- water temp sensor
- Gapped my NGK TR55's to .045" Is this gonna be a problem?
- Muffler options for TD setup?
- I Need Pics Of True Dual Setups!!!
- are these legit powersticks????
- Symmetrical Exhaust
- My PCV Line was disconnected the whole time.
- What do i need???
- slp flow pac
- what 90mm tb do u prefer?
- 02 Sensor Sim? Need 4 ORY?
- 3" TD 1 chamber flowmasters under axle with 238/242 cam Video-->
- nick wiliams
- Enough!!! with the HVMC!!!
- Pacesetter install problems...any advice?
- Magnaflow catback - lower prices?
- TB difference ETC vs cable
- How much HP left in my setup?
- Two front intake bolts???
- header question
- victor jr. intake questions
- Borla XR-1 Sound Clip
- any good places to buy the better truck coil packs?
- just installed my newly ported tb!
- what do I need for LT's
- Low idle at startup
- Build my exhaust w/ part of my tax return, ~$1200
- ideal problem
- True duals by LG
- cut out on stocker
- Pacesetter LT Install PICS
- spiral flow vs 1 chambers which is louder?
- Hooker Aero Chamber V.S. Magnaflow
- Installed Obx Header Info!!
- triple gasketing?
- battery question
- Well...?
- Is it worth it for me to switch to TD setup?
- is 1 7/8 stepped and 3.5 ORY worth the money
- Whistling and high idle after TB install
- Meziere EWP leaking...
- bbk 80mm vs p@p ls1 tb /wieand
- Time for a new MAF... just go with stocker?
- I have a question regarding spark plug gap...
- BMR driveshaft loop clear FLP headers/Y?
- Magnaflow for td's?????
- Opinions on True Duals w/High Flow Cats & which TD's under or over
- Help picking out a Throttle body
- Under Axle TD Problem???
- battery just died, what new one should I buy?
- stepped header gains over non stepped
- Who sells Ture dual systems?
- Oil Catch Can **PICS**
- Single best bang for buck???
- GTO Engine covers on a 6L?
- HVMC headers worth it?
- QTP Stainless Y-Pipe??????
- True Dual H/X pipe, and LT Headers
- pacesetter y pipe
- Cutout placement?
- Tell me if i did ok
- How much HP will this net me?
- What years will my headers fit?
- SSRAs are being made out of a much better plastic
- SLP y pipe worth 75$?
- pulley vibration
- True Duals + Single Chambers + Lowered Car?
- Can we swap out ls1 motors in our f-bodies?
- Smog with LT's and duals?
- To those doing 1 hour intake swaps...
- thinking about !powersteering cooler.... not a DD. thoughts?
- Intake compatible?
- E.T. Gains with headers
- PCV--how exactly does it work?
- what type of spark plugs . help
- 4 mufflers in a TD system
- If no VIN, how to tell what it is?
- Borla Catback - How to check plates?
- Bottomed out in the Mother of all Potholes..
- Which TR55 spark plugs should I buy?
- Trouble Code Help
- Pics of my duals extended out the rear
- Threaded holes for accessories in LS heads??
- Ported and Polished TB?
- True duals
- Header install...
- Catch Can
- dumps
- 90mm F.A.S.T. Intake on bolt-on car?
- Pacesetters/ORY/LM1
- Need some suggestions for PS pump
- Anyone make a cat delete that just bolts in
- maf idea need your imput needed
- Loudmouth 2 Sound Clip
- F-body Oil Cooler ?
- A.i.r System Want It Off!!!
- LS2 Intake manifold
- Mccord Cutout On Borla ???
- fast toys air lid?
- LM vs Hooker
- Finally my kooks are installed
- what do u think???
- Fouled plugs after head/cam install??? HELP!!
- What kind of exhaust tip is this?
- Gettin Off Manifolds!!!!!!!!
- !EGR! & !AIR!
- Tickets for loud exhaust
- Kooks Lt/ California
- question on underdrive damper for ls1
- Weld in bungs on Valve covers.
- FAST 78mm VS LS6
- Questions about my planned exhaust setup.
- bubbling noise
- Alternator
- 85mm Lid???
- LS6 Exhaust Manifold Possibilities
- True Duals
- Which Headers For My Situation?!?!
- bbk intake owners 98 thru 00 cars
- Professional Products Intake!
- Easy ?
- LS6 intake
- Header Question
- Cam or Gears?
- Catch can fix oil consumption?
- best intake and throttle setup
- Do It Myself Or Shop????? Help!!
- LS1 Numbers ?
- Sound Clip:LT's, Duals w/ bullets
- Headers
- Stupid question about tips.
- best place to get good deal on gaskets
- Header Install Question!!
- Electric cutout install
- CME SWEET THUNDER Video/Sound Clips shows how car runs also
- Throttle body problems
- LT's
- Why did GM use coolant plugs with the LS6 intake manifold?
- Alternator mod
- Texas Speed Rumbler X True Duals
- Starting problem...come on in!
- Where to buy pieces to make custom CAI?
- MSD 6010 Box users come in
- QTP electric cutout
- What are the best long tubes?
- Low coolant, what's the problem?
- Ebay Y-pipe installed
- headers / tuning question
- slp cai
- ASP Pulley ?
- Fast 90/90 question.
- who makes the best hedder gasket
- What do you think?
- Pulleye.. Yes or No
- Nology hot wires FAIL!
- Mustang Guys
- Crane Wires: Who's used them?
- Quick question about cats…
- qtp ory issues
- H/C 90/90 car #'s
- cut outs
- I need your help one more time!
- slp exhaust
- Best Throttle Body in the market ?
- Used motor mounts? Yes or no.
- quick header question
- Putting my Fast 90 back together- Need a little help
- Add 2nd bullet muffler or dynomat?
- Who has Powersticks?
- TSP rumbler X pipe clearance
- hooker aerochamber fit V6?
- O2 and AIR Wires
- QTP header vibration (searched!!)
- sweetness from jethot!
- Possible True Dual setup questions
- Is anyone running OBX headers?
- Cable ?'s
- XS lt's with TSP TD's**pics**
- Nick Williams or FAST
- poly motor mounts
- Stainless Headers, Cats, and Y-pipe for $500?
- What's the best electric cut-outs for a daily driver?
- installing 4" mufflex with spintec wow!!!
- does 4 inch exhaust hurt a bolt-on car
- HELP Catted Y Hitting Floor Board After Header Install
- SLP lid Question
- ls6 intake tubes?
