View Full Version : Generation III External Engine
  1. header question
  2. vroom vroom!
  3. qtp headers...which y pipe besides qtp works???
  4. Help! Need torque specs for Header bolts
  5. The Metal Intake Thread...
  6. Smooth Bellow Really Worth It??????
  7. removing egr
  8. Longtube??
  9. Any write up's on Installation Of underdrive pulleys?
  10. bought an EWP, having second thoughts though...
  11. Headers?
  12. porting out throttle body???
  13. T-Stat Question
  14. need help...trouble code P0135
  15. any info on these
  16. Difference in 78mm and 90mm?
  17. Long tube headers in CA
  18. Cold Air Intake Opinions
  19. Long Tubes on their way!!!!
  20. muffler choices for behind the tips on a TSP rumbler?
  21. Truck intakes
  22. Who makes the best Ls1 air Lid??
  23. Which cat-back is better?
  24. Is SLP Flowpack worth the money???
  25. 4inch Exhaust
  26. Exhaust experts needed!
  27. LS1 intake manifold fit on silverado 4.8 engine?!?! HELP!!
  28. How important are headers?
  29. Anyone have these exhaust tips?
  30. can i get 12 secs with bolt-ons???
  31. F%#@...manifold swap problems
  32. H/C/I swap
  33. question about h pipe
  34. Difference between LS2 timing set and timing chain??
  35. Center Mount Exhaut (please help!!!!)
  36. throws a rear O2 code during WOT? rich?
  37. Suncoast Creations ramair
  38. installing oil pan on fbody
  39. Shorty headers?
  40. Fast intake or TB for MS3
  41. induction idea..TRUE cowl or SS hood?
  42. SLP lid & what filter?
  43. Pacesetter LTs
  44. any deals on loudmouth catbacks now?
  45. Professional Products Intake Manifold...
  46. ls1 starter
  47. Tooo much oil inside intake; any suggestions???
  48. F-body SLP-ZO6 Mass air sensor, resister?
  49. Modifiying my Borla
  50. anybody make a tool to hold the damper on a C5?
  51. here is another quick clip of my TRUE DUALS!
  52. cold air induction..worth it??
  53. Just bought a Borla exhaust for my 3rd gen IROC-Z
  54. EGR Delete Issues?
  55. Looking for some feedack..Heads or Intake
  56. Ordered FAST 90, do I need to keep anything off my LS6 intake?
  57. Broke something installing headers =(
  58. O2 sensor problem
  59. Loudmouth back to stock exhaust = hp loss ???
  60. my intake is filled with oil ,how to fix?
  61. QTP stainless cutout?
  62. People with hypertech 160*stat
  63. question rewarding headers
  64. Smooth Bellows
  65. anyone make a 10" bullet or smaller?
  66. Just got my Beck Sheetmetal Intake (pics)
  67. Crank Pulley
  68. Too loud!
  69. True duals under axle
  70. HELP!! professional products intake
  71. Best Ceramic Coating
  72. slp lid
  73. Under drive pulleys
  74. Anyone Know how to clean the MAF sensors???
  75. Only god can help me now!! Or can you?
  76. Motor Mounts
  77. Header Help
  78. PCV Valve Purpose?
  79. real LS6?
  80. is it hard to swap an intake??
  81. Where To Find A X Pipe Set Up?
  82. BBK SSI Aluminum intake manifold for LS1
  83. Where to put a bullet
  84. Whine After Changing Serpentine Belt
  85. what is a catch can??
  86. Hose from intake
  87. Custom intake canister
  88. Would Maganaflow tips fit on my Borla??
  89. !AIR question and idea
  90. Ram air help!
  91. Muffelx Y-pipe bump stop??
  92. Anyone using a TQ strap , to hold the LS! motor from twisting?
  93. lid cracked...
  94. Anyone ever tried 3 cats??
  95. 78mm Fast or LS6?
  96. quietest bullet type muffler
  97. How many people are....
  98. Should i add another muffler?
  99. SLP dual/dual hurting my performance?
  100. buying/installing ls6 intake questions
  101. Spark plug Question
  102. Simple question
  103. Cheapest Place for O2 Sensors?
  104. Vote on exhaust tips
  105. Flowmaster that bad??
  106. Big A$$ Crack
  107. Intake/Full Exhaust - This Everything?
  108. Which is louder?
  109. Cutout or catback
  110. exhaust ?
  111. please post pics of true duals on Fbody
  112. 3.73's and spray with an M6??
  113. Tune After LT's
  114. where is the write up for LT install, cant find it
  115. performance gain w/cat off???
  116. fast 90mm intake bolts?
  117. Is it worth it too.....
  118. EGR Question
  119. Pulley Question
  120. Car running really rich after headers
  121. Who makes boltin or custom radiators for the LS F cars?
  122. Lid?
  123. What Is On Your 2007 Wish List For New Products??
  124. cc503 vid: Cold start
  125. stock c/b with hooker muffler/ cut out restriction?
  126. How's this look? (Catch can)
  127. ppl with FAST 90 THROTTLE BODY please come in
  128. Need Advice!!
  129. True Dual set up... idk what mufflers to choose?
  130. Turbo LS1 in a small airplane
  131. GMMG with Longtubes and ORY
  132. Coil pack wiring extension???
  133. finally got my TRUE DUALS!!! clip inside!
  134. Fast 90 porting???
  135. Question on year of cats ?
  136. Louder? Magnaflow or Hooker muffler
  137. are expensive wires worth it?
  138. Do I Need O2 Sensors???
  139. best exhaust tips??
  140. PCV hose collapsed
  141. High Mileage Engine (Heads & Cam Swap)?
  142. Ls6 Intake
  143. open headers?
  144. PP Typhoon Intake - For Sale Yet? How much?
  145. Exhaust Hanger Replacement
  146. F.A.S.T. Intake or carb setup !!!
  147. Gutting cats
  148. cats
  149. Gotta replace water pump
  150. Engine prep ?'s
  151. Difference between FAST 90mm and NW 90mm?
  152. Lt's, ORY, stock catback question..
  153. hp gain with true duals
  154. ls6 heads
  155. Aluminium exhaust, can it be done? and negtive things?
  156. How much this worth?
  157. Burns racing mufflers experience anyone
  158. anyone have luck getting SLP headers to seal
  159. Passenger Side Front O2 Sensors????>?
  160. O2 Simulators!
  161. slp headers on vette
  162. California exaust set up?
  163. Help !! Bbk Tb Feels Like Its Sticking
  164. Getting My TB P&P
  165. Throttle body bumpstop mod, Question
  166. Weiand Intake?
  167. ls6 intake or not?
  168. DynaTech Test Pipes
  169. Switching to TD's, have some questions..
  170. Problem !
  171. true duals vs y pipe/catback
  172. Gut cats with just catbacks?
  173. Spark plugs
  174. What catback?
  175. window switch and e-cutout is it possible?
  176. muffler with turndown or tailpipes
  177. vacuum pump.............
  178. Stainless or Coated Headers?
  179. y pipe for jet hots!!
  180. Cam Install Question AC Recharge
  181. LS6 Pro fogger intake; what size pill for 100 shot.
  182. length of bullet?
  183. QTP or Hooker headers.
  184. bad cats?
  185. ported fast 78 vs ls6 intake RESULTS
  186. QTP dual cut out y-pipe or true dual??
  187. Exhaust manifold numbers for ZL1???
  188. Removing stock exhaust??
  189. True Duals and ground clearance
  190. poly motor mounts....need help
  191. Headers, Y, Cat delete Help!
  192. Headers
  193. Tool for changing spark plugs?????
  194. LS6 Intake Questions
  195. Help withe header choise look in side.
  196. Check engine light....
  197. Finally Installing my first mod.
  198. HELP! He Spliced my 02 sensor wires!
  199. port my TB?
  200. Header Question
  201. Longtubes & Y-pipe 3rd Gen...
  202. Cutout question with borla
  203. True Duals or not?
  204. cat problem
  205. Will a FAST 90/90 Help me that much?
  206. Lsx Tv Is On
  207. Deleting pcv...
  208. Need Help, driver side header install
  209. Will TDs Hurt My Performance?
  210. Ported MAF. Does it help or hurt?
  211. Cost for a straight ls1 swap?
  212. Where can I get these valve covers (GMPP Cast Bowtie)
  213. Sheet Metal Intakes
  214. magnaflow bullets
  215. Would it be hard to run a torque arm with...
  216. LS6 question
  217. qtp cut outs
  218. are smooth bellows crap?
  219. y pipe question
  220. QTP cutout question
  221. G Tech Pro
  222. pacesetter shorty headers
  223. pacesetters clearance???
  224. Suspension
  225. eliminating the EGR
  226. !AIR question....
  227. B&B v. Flowmaster
  228. quick exhaust clip: LTs/ORY/Magnaflow Catback/Partially Open Cutout
  229. Need Header help, want to alter headers
  230. a/c system
  231. Quick TB question...????
  232. an easy, cheap breather solution
  233. New catch can from JEGS
  234. Exhaust Videos!
  235. Anyone running QTP LT's w/ ORY and tunnel mounted Torque arm?
  236. what size TD's for 450-460 hp?
  237. Fast 90mm TB any good?
  238. High flow cats on stock exhaust?
  239. Y-pipe w/cats sound ?
  240. kooks header with A.I.R. connection wrong
  241. 180 degree headers
  242. Headers ???
  243. O2 sensor problem
  244. slp resinator question?
  245. Kooks Headers owners inside please!
  246. where can i buy this
  247. LS7 Stock Manifolds
  248. Exhaust question
  249. bad cats????
  250. tips for installing y pipes?
