View Full Version : Generation III External Engine
  1. Parts/Adapters needed...
  2. g-tech bolt on results (intake comparison)
  3. ATI crank pin kit help!
  4. At about 500rwhp, how much hp will magnaflow cats rob?
  5. Need a part number for plastic shield
  6. air pump hole in exhaust manifold
  7. Who sells 02 Sensors now?
  8. Pacesetter specific LT question.
  9. changed LT's & y, now terrible vibration
  10. ls2 intake on a ls1
  11. How much power/sound will i lose with hi-flo cats?
  12. anyone know anything about rhs heads?
  13. Alternator problems
  14. TPS mod? Just had a thought
  15. 3-Bolt Flange?
  16. what rwhp difference between dual exhaust setup & dual cut outs on the y pipe?
  17. Complete Bolt On list and rwhp expected from them?
  18. K&N fpik filter on stock bellows
  19. Grotyohann headers?
  20. Which plugs and wires?
  21. insanely loud? new exhaust setup
  22. do ls1 mac mids need 02 extensions?
  23. LS6 valve covers-do they have PCV outlets on them?
  24. any gain going to 1 7/8 headers
  25. getting ready to install Pacesetter LT's. any advice?
  26. lid question...
  27. 2.5" vs. 3" Y-Pipe
  28. exhaust
  29. which intake do i need
  30. replace intake on 04TAHOE 5.3L
  31. TSP True Duals with Ebay headers
  32. anyone know about these cats?
  33. Help me!!!!
  34. pcv question...search isnt working
  35. A different approach to PCV delete.
  36. stock exhaust???
  37. what does EGR do !
  38. Whistling Noise
  39. 99 LS1 knock sensor problems
  40. TB hole size
  41. Headers off a 98 fit an 02??
  42. pcv vacuum leAK
  43. Anybody have video clip of magnaflow on F body?
  44. i am looking for a 3.5in cable operated cutout
  45. noise increase question
  46. Meziere water pump=better E.T.?
  47. NX intake and throttle body?
  48. Let's see your tanks!
  49. Need help please!
  50. i broke something is it important
  51. modifications....
  52. Help!!
  53. best headers
  54. TSP true duals
  55. OBX R Racing Headers??
  56. Questions about a starter
  57. Sheet Metal Intake?
  58. GMMG and CME elbows help
  59. Header Help
  60. EGR removal
  61. LTs+ TSP y-pipe = no safty loop ?
  62. Who had to modify their TSP ORY?
  63. The best y-pipe
  64. Is Ls6 possibly better than Fast 90/90
  65. How long did your stock water pump last?
  66. Most HP/TQ from LS1 intake
  67. Quieter Exhaust + FLOW:
  68. Update with links to pics
  69. Granatelli MAF from an 02, for an 01?
  70. TB question
  71. Will TSP catted-y work w/UMI body mounted TA?
  72. New Problem
  73. Speed Bumps
  74. No start after ported throttle body
  75. Those Running TSP
  76. Need a new belt
  77. how much horsepower with cutout
  78. Magnaflow True Duals?
  79. Autometer Oil Temp Gauge Install
  80. Where can I find o2 simulators? $$?
  81. How do I tell if I have the LS6 intake?
  82. Pics of LM I or LM II Installation
  83. Sweet Thunder Help
  84. Kooks header install in progress...
  85. Wazee Pulleys
  86. Exhuast options
  87. K & N filter....who wants it?
  88. Meziere EWP
  89. 90/90 on a SI motor??
  90. Best muffler with no cats and LT's
  91. gmmg oval tips
  92. radiator
  93. Quick question On holding the crank to torque the balancer bolt
  94. Breather cap
  95. Daily Driven TD's dumped
  96. is the slp underdrive pulley worth the money
  97. All with slammed rides and long tubes chime in!!!
  98. Throttle Body Question, Mti Racing 80mm
  99. All corsa owners...what header/ypipe do you run with your system??!
  100. Does Kooks make a stepped header?
  101. stock 75mm MAF chokes 90/90??? COME IN
  102. gmmg exhaust wow!
  103. Short power steering Belt Part#!!!!
  104. What will Mizere water Pump,Ported TB and Rocker arms get me?
  105. Adjustable throttle cable
  106. TPS with Nick Williams TB question
  107. Electric Cutout
  108. tsp rumbler cat back
  109. Which header bolts???
  110. poly mounts
  111. leaking coolant
  112. True Dual Question????
  113. Help with CME questions
  114. Muffler Suggestions and Location.
  115. ls6 intake gains question
  116. texas speed catted y fitment issues + how to do cutouts?
  117. What's the average length of primaries on longtubes?
  118. What headers?
  119. Meziere Water Pump
  120. what do you think?
  121. Can I Swap A Catted Y For An Ory?
  122. Catch can question...
  123. Exhaust help
  124. Help me....misfire at idle
  125. ORY and inspection stickers????
  126. Is $170 a deal for macs?
  127. where to get catted y for pacesetters?
  128. Problem chewing up belts.. plz help
  129. TD question
  130. Which Catback?
  131. Open Headers??
  132. is there a write up on debaffling for the intake
  133. Co2
  134. best fitting lid out there?
  135. Lid/MAF coupler & MAF/Throttle Body coupler
  136. Ram air or aftermarket intake
  137. FAST Manifold question
  138. Which exhaust setup?
  139. pipe size
  140. Starter wires????
  141. Intake advise
  142. Has anyone had their Mezieere STRRET water pump rebuilt
  143. Sweet Thunders at end of System??
  144. Rocker arm ratio
  145. 2 mod ? pulley / sensor
  146. Ls6 Intake, What's The Advantage?
  147. Header Gaskets
  148. stock y pipe pics
  149. ls1 accesorie interchange
  150. Difference between dual/dual and slasher tips on Loudmouth?
  151. please help
  152. Car Wont Start
  153. Flowtech Headers
  154. Problems after header & exhaust install
  155. NEW PRODUCT: Offroad Pipes For Dynatech's SuperMaxx Headers!
  156. Can Any 1 Tell Me What The Best Muffler Is For A 95 Z28?!
  157. Difference in Valve Covers???
  158. Which exhaust on a WS6???
  159. after header install, throwing a few codes...need help
  160. Adding Fast 90/90
  161. what exhaust should i run?
  162. Front/Rear o2 swap
  163. Cant decide on headers.
  164. Squires turbo??
  165. Header question???
  166. ATS carbon-fiber valve covers
  167. Truck coil wires
  168. Front and Rear O2s Interchangeable?
  169. removing intake
  170. what should I gap my plugs to
  171. Was anyone else dissapointed by their "perforance" exhaust?!
  172. LT Header Help...
  173. what would a set of brand new Z28 flat black tips be worth???
  174. Damaged water pump during cam install?
  175. Whas this right????
  176. weld exhaust components together?
  177. O2 Sensor Interchange
  178. Dynatech Supermaxx Clearance Pictures?
  179. Ported Throttle Body
  180. Modding Advice???
  181. Will this work??????
  182. I need an exhaust recommendation for my 6.0L
  183. best fit and sound
  184. Exhaust for a full size chevy?
  185. ORY vs Legal Y
  186. Pacesetter y-pipe vs TSP y-pipe
  187. tsp rumbler with flowmaster 1 chamber
  188. Stock Headers off, Stock gasket question
  189. Water pump
  190. Throttle body
  191. spark plug
  192. Need help please
  193. exaust size difference Q
  194. Cheap 1 chamber's like flowmasters?
  195. SLP LT and the car wash
  196. Can exhaust systems be pressure tested?
  197. Installing a NW/FAST 90/90
  198. Is it possible to get 12 secs from bolt-ons only
  199. doug's headers - anybody used them?
  200. Just got my Borla on
  201. 408 LQ9 P1SC vette
  202. SEMA >> Professional Products Intake Manifold
  203. Advantage from Texas Speed true duals over Borla?
  204. What fuel filter should I get?
  205. How far did you grind down your K-member for headers?
  206. Header dyno#'s and clearance?'s
  207. i have a slp loudmouth and want new tips
  208. Anybody put bullets in place of cats on a C5 vette?
  209. Silverado 02 Sensors
  210. no start please help asap
  211. Headers ?????
  212. Which Y-pipe?
  213. how to fix
  214. How well will this exhaust set-up work?
  215. How much for cut-out install?
  216. Pro Flow F4 series Twister Mufflers?
  217. Pacesetters...
  218. Hooker LT's
  219. truck intake manifold
  220. This damn cutout - advice please
  221. th400 guys, what exhaust are you running?
  222. confused about ram air and intake.
  223. egr/air questions
  224. quick spark plug wire question!
  225. Added performance from Canton racing oil pan
  226. When is my RWHP restricted with this exhaust setup?
  227. ls1 alternator/ a/c hook up question!!! need help!!
  228. What are my 1 7/8" header choices?
  229. Finally got my EWP installed!!!!
  230. katech tensioner question
  231. ported ls2 v.s box stock fast 90
  232. ls6 vs fast 90
  233. o2 Sim price hike?
  234. P&P TB
  235. A few LS6 question...
  236. So Damn close!!!!!!!!!!!!!
  237. 1998 Z28 exhaust interchangability
  238. Header Install time
  239. carb'd style intake questions
  240. FAST 90mm intake
  241. ssra dimensions
  242. LS6 intake install, Slade's take on it...
  243. Loud Mouth questions?
  244. opti spark (red top)
  245. Attention LG Motorsports!!
  246. Rear end question
  247. GM 85mm MAF
  248. Is this ok to clean a throttle body with?
  249. Silicone Bellow length for 90/90 set up.
  250. Where/who to get FAST 90mm intake ported by?
