View Full Version : Generation III External Engine
  1. LS6 Manifold vs Professional Products Typhoon
  2. Anyone running a ypipe>muffler>Dump setup?
  3. need help with catch can install please
  4. Any additional tuning required when installing a ported throttle body?
  5. Anyone Have a MAC cat-back
  6. Help with intake/TB for 408
  7. Got my pace setters and catback!
  8. Z06 Header Ball and Socket Flange
  9. Question on installing 98 longblock in 2000 fbody
  10. QTP off road y?
  11. Quick Power Steering Line question...
  12. pics of TSP Y?
  13. tickets with rumbler?
  14. Catback with Stock Manifolds
  15. Harmonic Ballancer
  16. diff. in ls1 exh. manifolds? 98-02
  17. TSP True Duals Compared To.. Come Inside
  18. H-pipe w/Cats...advice needed
  19. thoughts on the F.A.S.T. intake
  20. Weird Problem On Page
  21. X vs H.. SOUND Questions.. i know another thread
  22. What is the I pipe size for SLP LM II modular exhaust??
  23. Do you think 450hp 400tq is reachable??
  24. How often should I change my TR6's?
  25. 02 ws6 m6 what kinda gear go I have?
  26. Pacesetter/TSP Catted Y Problems
  27. Duals on Stock
  28. 4' exhaust
  29. torque specs??
  30. Where to buy header to cat 3 bolt flanges?
  31. car running hotter than normal?
  32. Twist on dual electric cutouts
  33. Anyone heard of these small 3" cats?
  34. Cam w/ stock manifolds?
  35. Need Help!!! What makes the fans work?
  36. What am i missing in my engine bay?
  37. 02 sensors new but acting up
  38. help me pick plugs for my H/C combo
  39. Anyone have dyno #'s for MIdS vs. LT's?
  40. revision on my ported tb. no epoxy.
  41. Anyone have any good over the axle pics....
  42. dual cutouts or true duals?
  43. Should I stay w/ y-pipe?
  44. what intake??
  45. Looking for part number for IAC bolts
  46. kooks headers question
  47. Dexcool
  48. Short or Long Bullets?
  49. Anyone know where to order custom TD's???
  50. 02 camero engine numbers stamped on block
  51. Whats the difference between these??
  52. O2 Sensors
  53. Gutting Cats??
  54. header bolts not going in right?
  55. Lt Headers???????????
  56. new mufflers
  57. Got my new Pacesetters!
  58. Differences in the LS2 and LS6 intakes
  59. Can I weld on my engine bay??? Please help asap
  60. Texas Speed True Dual Question?? Woh Has 1?
  61. anyone running carbed 6.0?
  62. True dual help
  63. up to date pn's for coolant pipe and plugs
  64. BBK LS1 intake...
  65. Ditching a magnaflow for a flowmaster
  66. Bling Bling :) Vengeance Ported/Painted FAST 90mm Inside
  67. Gmmg
  68. Duals?
  69. How loud are dumped true duals?
  70. opinion on these stuff
  71. LS6 Intake gains?
  72. What is the best exhaust?
  73. header gaskets?"
  74. Help with Goodyear belts
  75. Home made GMMG?????
  76. best exhaust for my setup?
  77. Need so help guys, Exhaust
  78. exhaust smoke after lts ory and catback install
  79. Looking for Z06 Higher Flow Exhaust Manifolds
  80. Got a turbo sound but no turbo
  81. Ported LS6 Intake vs. Ported FAST 78mm Intake
  82. throttle body question for 2000 ss
  83. How to make an LS! quiet and not loose HP!!
  84. Loud mouth, 1 7/8s and ory noise
  85. real k&n intake, or ebay k&n intake
  86. Flame kit for exhaust?!?
  87. Corvette Exhaust.
  88. What other headers bolt to Flowtech Y?
  89. qtp or dmh Ecutout
  90. QUICK QUESTION, I need to know if this will work
  91. Is This A Header Leak?? Pics And A Vid Inside
  92. 408 w/ GMPP Intake/Accel TB & Aerospace Vac Pump Setup PICS INSIDE!!!
  93. catted y vs. bullet in I pipe
  94. Anyone sell the I pipe?
  95. Broken manifold bolt...Driver's side
  96. LS6 Head and Cam packege.
  97. water-methane injection...
  98. question regarding bump stop and swapping shaft
  99. Gaskets w/ LS6 Coolant Tubes?
  100. charging system
  101. Does pcm get tach signal from cam or crank pos. sensor
  102. Help me quiet down my car... (stroker with TD's)
  103. how 2 clean up coolant bypass by tapping into water pump
  104. quick e-cutout wiring question
  105. Fuel purge solenoid disconnect
  106. LTs and ORY installed! Video included
  107. Whistling Sound
  108. Header Install Question
  109. Need to get cats on my car for inspection- need suggestions on good flowing cats
  110. ls6 heads and cam??
  111. bullet muffler in I-pipe for LT/ORY pipe combo....which one?
  112. mystery exhaust noise / rattle
  113. Hp Gains For Corsa Cat Back??
  114. Open Headers?
  115. Coil pack wiring Q
  116. electric supercharger
  117. oil catch can location?
  118. e-cut out questions
  119. whats the differnce in desing between 98-99 manifolds and 00-02 manifoldss
  120. slp center exit exhaust cleaning
  121. Where can i get an H pipe
  122. Starter clicking
  123. k and n intake
  124. what kind of power increase will a dynotune give me
  125. where to buy an ls6 intake manifold?
  126. need help identifying part
  127. Inside of a busted FAST
  128. which headers for a huge cam
  129. Someone PLEASE explain this to me
  130. Elec cutout in Borla cat-back?
  131. Next Big Mods
  132. Adding EGR to aftermarket or LS6 intakes?
  133. My LTs might be banging a bit.. HELP
  134. I love the sound of this exhaust!!!
  135. With gutted Cats, are O2 sims neccesary?
  136. Exhaust clamps... easy take off...
  137. want to remove cats but stay quiet???
  138. maf ???
  139. Need Help!!! Car Overheats!
  140. 2000 Camaro: ground for coil packs
  141. Dyno'd 4" catback w/cutout
  142. LT Install HELP Hookers wont clear!!! Tips?
  143. TSP duals and SLP SFC
  144. Optimal coolant temp at the Track?
  145. Is it bad to run open headers?
  146. Stainless header question
  147. just ported my tb
  148. qtp y w/ qtec
  149. Just how much?
  150. SLP Lid and Blackwing fiter?
  151. How hard to install TB?
  152. which one sound better
  153. Muffler Help
  154. Help, steering knuckle rubbing headers!
  155. GMMG vs 1 Chambers
  156. How do I adjust throttle cable for FAST TB?
  157. X,h,or Open Headers?????
  158. Anyone in CA with LT's???
  159. corsa on the way...lookin for headers&ORY to go along w
  160. What would be my best bet for Duals?
  161. !QTPs are in!!!!!!!!!!!!!
  162. K&N performance kit
  163. magnaflow true duals
  164. whats the electric plug on..
  165. Installing FTRA - Best Tool to Cut Airbox?
  166. electric cutout
  167. write up on header install
  168. What kind of Catback is this?
  169. 1 3/4" vs. 17/8" primaries???
  170. Mass produced full length dual exhaust
  171. LS6 PCV Conversion Idea
  172. Which headers?
  173. TB idle inlet orifice for TPS question
  174. will a loudmouth thats for lt1 fit my ls1?
  175. TB idle inlet orifice for TPS question
  176. TR-55 or TR55IX on Stock Motor?
  177. Exhaust on the quiet side for LT's/ORY...
  178. How to insulate wires next to headers
  179. Mufflex LS1-HR Anti Y-Pipe Banging Part Install?
  180. Should be prowling the streets again on Monday Night
  181. Under or Over Axle True Duals
  182. Any 383/402/408 Owners with LS6 Intake?
  183. A4 guys running FTRA or other CAI
  184. best sounding flowmaster on ls1
  185. Debating LTs setup or just catted Y in Mass.....
  186. Best Fuel Rails
  187. Don't wait to get rid of your EGR/AIR! Check your PCV system too!
  188. installing headers
  189. Headers
  190. waterpump?
  191. cutout ???
  192. EGR mounting instruction for SLP LS6 intake
  193. Cutting out plastic piece below filter?
  194. Water temp gauge is in...
  195. Back To Stock??spark Plug Help!!!
  196. What you think it will do?
  197. LG lid DOES NOT fit 85mm maf...
  198. few qtp header questions
  199. Another Tune or no tune...?
  200. Composite gaskets, any tips on preventing them from sticking...
  201. Anyone running a Wilson Ported FAST?
  202. filter removal tips? Need TQ!
  203. 2000 T/A Exhaust
  204. How much will i gain?
  205. stock head question
  206. SLP header Q mainly about welds.
  207. Borla Catback fitment question
  208. stock throttle body size
  209. About to order headers...
  210. FAST intake warning
  211. Does this work or is it a rip off ???
  212. Headers?
  213. Pic request: 99' LS1 intake w/ EGR intakes
  214. band clamps
  215. Loudmouth ?
  216. BG Ram Air any good for WS6 guys?
  217. 98 WS6 almost overheating
  218. Great! My LM came off
  219. How much HP gain will this get me...
  220. little tweaks
  221. Car is back firing after header install
  222. Help me figure this out...
  223. coolant problem
  224. gmmg or stainless works?
  225. Looking for car need help
  226. Kooks Y Pipe
  227. Need help with vaccuum hose (line)
  228. 2002 Ls1 Freeze plug??????
  229. Emmissions block off plates.....How thick?
  230. Exhaust sounds and video clip
  231. Show me pics of your ORY ground clearance
  232. oil catch can question
  233. Can't Decide: Corsa or B&B?
  234. manual cut out...
  235. Will i see any gains?
  236. Headers!!!!!!!!!!!!!!!!
  237. What Is A Good Replacement O2 Sensor
  238. Pacesetter connection
  239. Flawless!!! Installed my longtubes today.
  240. Manual Fan Switch
  241. What ARP headers studs for an LS1?
  242. Mufflers right off the headers.
  243. 3.5in Collector to 3in Xpipe system?
  244. crank pulley help!
  245. torque spec
  246. where 2 get parts i need to convert ls1 to ls6 on 2000 ss
  247. I found out why the ebay headers were so cheap.
  248. How to identify an LS6 intake?
  249. Am I losing this much horsepower with GMMG?!
  250. egr question
