- filter removal tips? Need TQ!
- 2000 T/A Exhaust
- How much will i gain?
- stock head question
- SLP header Q mainly about welds.
- Borla Catback fitment question
- stock throttle body size
- About to order headers...
- FAST intake warning
- Does this work or is it a rip off ???
- Headers?
- Pic request: 99' LS1 intake w/ EGR intakes
- band clamps
- Loudmouth ?
- BG Ram Air any good for WS6 guys?
- 98 WS6 almost overheating
- Great! My LM came off
- How much HP gain will this get me...
- little tweaks
- Car is back firing after header install
- Help me figure this out...
- coolant problem
- gmmg or stainless works?
- Looking for car need help
- Kooks Y Pipe
- Need help with vaccuum hose (line)
- 2002 Ls1 Freeze plug??????
- Emmissions block off plates.....How thick?
- Exhaust sounds and video clip
- Show me pics of your ORY ground clearance
- oil catch can question
- Can't Decide: Corsa or B&B?
- manual cut out...
- Will i see any gains?
- Headers!!!!!!!!!!!!!!!!
- What Is A Good Replacement O2 Sensor
- Pacesetter connection
- Flawless!!! Installed my longtubes today.
- Manual Fan Switch
- What ARP headers studs for an LS1?
- Mufflers right off the headers.
- 3.5in Collector to 3in Xpipe system?
- crank pulley help!
- torque spec
- where 2 get parts i need to convert ls1 to ls6 on 2000 ss
- I found out why the ebay headers were so cheap.
- How to identify an LS6 intake?
- Am I losing this much horsepower with GMMG?!
- egr question
- Just did the coolant bypass mod.
- new oil pump?
- high idol with TB swap
- Lane?
- 160º t-stat...can't find one for the 'turd!
- is the throttlebody bypass worth getting
- Weird spark problem!!
- Mixing exhaust parts.
- Header Install Nightmare
- sensor on back of intake
- Quick Question
- Corsa?,borla?,or Magnaflow?
- SLP LM1 resonator
- opinions needed on mods install
- noob true duals question..
- JEGS xpipe... anyone?
- LS1 to LS6 PCV conversion w/ LS1 steam tube.....GURU's please come inside!!
- difference n ls1&ls6 int
- Anyone make F-body TD's that aren't dumped?
- cats
- Ls6 Or Fast 78mm Intake What To Get???
- fixing EGR leak
- Summit X Pipe Kits
- Asp underdrive pulleys
- This weekend = Cutout & !EGR/!AIR
- Ported My TB...
- Killing cats?
- which air intake is better
- Will UMI's 3point SFC's work with TSP True Duals?
- whats best y pipe to buy
- air breather for a lid?
- Bassani TD
- Should I bother w/a cut out?
- H/c Swap. Pace Setters Dont Fit!!!!
- cut camaro grille for better cooling?
- what's the consensus on running an ORY and an open cutout for daily driving?
- header install time
- 1-chamber in I-Pipe?
- new ls6 intakes
- My ported throttle body...
- whats the true answer (cutout question)
- Help!! Just Did LS6 Heads/Intake, Car backfires and has very slow throttle response..
- ~Hooker or Magnaflow~
- TSP Catted-Y question
- mid length headers that will pass emissions in cali?
- Header gasket blew!
- my torque wrench slipped and smashed.........
- 5.3 TB vs 5.7 TB
- Hooker Comp Vs. Super comp, where the difference?
- Headers for LS6 in an T/A
- Is LS2 MAF sensor applicable for LS1 swap?
- Quick exhaust question
- Longer Power Steering hoses
- What is this hose for?
- looking for exhaust tips like these
- What size aluminum radiator?
- Kook's Lts install issue
- FAST90/LS2 TB problems Help?
- WS6 intake?
- NEED HELP! TB Oring Q!
- eBay intake?
- Lt's or mids?
- Air lids?
- headers?? so many which one is the best for the money??
- V clamp for FLP longtube headers????
- Header install, please help
- Where to find a cap for the AIR hose in my lid
- aftermarket starter
- NX 85mm Throttle Body ?
- Can I weld my headers in the engine bay?
- SLP D/D on LT1 Car?
- pulley stuff
- c5 sheet metal intake pics please!!
- SLP LID AND K&N FILTER OMG
- Loudmouth II for Hooker??
- SLP Lid Question Please Help
- cut out question
- Those w/borla & qtp cutout
- !Bump Stop Mod
- O2 sensors ?
- headers on Ebay
- New LS6 intake?
- weiand intake questions/problems
- Limited Slip for F-Body 4 Sale!!
- Gutted Cat
- How to P&P TB?
- march underdrive pulleys
- porting a tb...
- loudmouth installed! holy shi...
- Shorty's or Long tubes?
- HELP!!!! Did I just break the oil pressure sensor (LS6 intake swap)
- Broken Exhaust Manifold Bolts
- colant
- looking to get hooked up
- What kind of clamp are you using on cat to header?
- ls7 intake??
- tech question?
- change exhaust
- What would the best exhaust option for me be?
- WHAT GAINS FROM LS6 OR FAST 78MM INTAKE & SHANER PORTED TB??
- Hooker Headers
- Stuck cutout??
- corsa owners inside
- Upgrading plug wires: Worth it or Not?
- This ok to seal my EGR hole?
- FEL PRO Gaskets ok?
- What is the hose in the lid for?
- 1995 Firebird Exhaust
- glasspack???
- ExhaustVid (Borla,bullet,trueduals)
- Security Problem, Car won't Start. NEED HELP FAST!
- CME with a bullit muffler
- Dynatech supermaxx ?
- GM LS6 VS Holley Aluminum LS1
- how good is the moble oil filter
- Flowmaster cat back
- SEAFOAM ='s Hole in Header. I THINK!!! OR????
- Pacesetter's (painted vs. ceramic)
- Loundest bullet???
- ~TSP True Duals ?~
- anybody made a homemade loudmouth
- Ported Tb Or 90mm Unit?
- LS1 catback on on 98 v6 fbody FIT?
- Leaking Fast 90?
- Please help, 1996 Tahoe 5.7L
- spintech mufflers
- need help installing e/cutout
- B&B Exhaust Tips??
- Installing LS1 Headers
- check valves?
- i-pipe size
- Got Work Done Now Fan Stays On After I Stop?
- what is this??!!
- Got LTs, Now I Stink?? LOL
- Headers
- How to cut down drone on highway - loudmouth
- I see oil...help!
- SLP Dual Dual exhaust
- Installed Exhaust
- just installed lid and k&n....WOW
- FAST90 TB TPS question
- Bfh
- ls1 to ls6 intake
- Most Quiet Bullet Muffler? Help please.
- Manual Fan Switch?
- A problem in slp`s C.A.P
- FAST/NW 90 good for 800 rwhp?
- Do I?????
- crankcase pressure
- Hookers are in, one problem
- anyone using the tourque tech x pipe?
- bad engine ping after installing mods
- epoxy or jb weld when porting tb
- Throttle body Bypass kit ? 6- 8hp?
- Low idle at start up
- Egr Help
- Which One.....
- exhaust question?
- qtec....foot switch?
- Tb
- Can't get the alternator pulley off???
- Oil in the intake...
- catch can
- Ported Tb Or Underdrive Pulley
- Dual cutout question
- TSP or Pacesetter Y?
- Spiral Flows
- removed AIR now backfiring! help!!!
- what should i do next
- Good headers?
- L92 or LS6?
- Corsa vs GMMG for Drone, Loudness
- Will a QTP ory fit on Pacesetter headers?
- Are radiator hoses going to be the same as stock on a 408ci LQ9
- pacesetters LTs unequal length primaries?
- going with TD's...what do i do with elec. cutout?
- Can I swap my Corsa muffler for a SLP 2OTL
- 2 chamber flows on true duals??
- Header Install Question
- Ls6 Manifuld
- so, is it possible that....
- Intake and TB Compatibility??
- how much would i gain?
- Has anyone done a ram air through the foglight openings?
- Best place to buy MSD spark plug wires?
- Car number
- SES Light - P0420 and P0430..NEED HELP!!
- mobil 5w40 truck and suv oil!
- pacesetters rusting
- Balancer pulley bolt size??
- Are 1 7/8 too big for this setup?
- Flowmaster Cat-Back LS1 to 3.8
- under drive pulley.'s
- Exhaust tone change?
- How well do Spintech mufflers flow?
- Aftermarket Airbox Lids?
- Headers....
- reccommend a intake
- Please help!! Terrible sqeak coming from front of motor.
- cats and a big cam?
- Lid Chipped, HELP.
